SF31G THRU SF38G
3.0A Axial Leaded Super
Fast Rectifiers-50-600V
Package outline
Features
• Axial lead type devices for through hole design
• High current capability.
• Superfast recovery time for switching mode application,
• High surge capability.
• Glass passivated chip junction structure.
• Lead-free parts meet RoHS requirments.
• Suffix "-H" indicates Halogen free parts, ex. SF31G-H.
DO-201AD
0.94(24.0)
MIN.
.220(5.6)
.197(5.0)
DIA.
Mechanical data
.375(9.5)
Epoxy : UL94-V0 rated flame retardant
.285(7.2)
Case : Molded plastic, DO-201AD
Lead : Axial leads, solderable per MIL-STD-202,
Method 208 guranteed
0.94(24.0)
MIN.
.051(1.30)
Polarity: Color band denotes cathode end
.043(1.10)
DIA.
Mounting Position : Any
Dimensions in inches and (millimeters)
Maximum ratings and Electrical Characteristics (AT
PARAMETER
T A=25 oC unless otherwise noted)
CONDITIONS
O
Forward rectified current
Ambient temperature = 55 C
Forward surge current
8.3ms single half sine-wave (JEDEC methode)
MAX.
UNIT
IO
3.0
A
I FSM
125
A
Symbol
MIN.
TYP.
O
V R = V RRM T J = 25 C
Reverse current
Thermal resistance
Junction to ambient
Junction to case
Junction to lead
Diode junction capacitance
f=1MHz and applied 4V DC reverse voltage
Storage temperature
V RMS*2
(V)
*3
VR
(V)
SF31G
50
35
50
SF32G
100
70
100
SF33G
150
105
150
SF34G
200
140
200
SF35G
300
210
300
SF36G
400
280
400
SF37G
500
350
500
SF38G
600
420
600
*4
VF
(V)
*5
t rr
(ns)
Operating
temperature
T J, ( OC)
μA
100
R θJA
R θJC
R θJL
8
CJ
50
T STG
*1
V RRM
(V)
SYMBOLS
5.0
IR
O
V R = V RRM T J = 125 C
-65
°C/W
° C/W
° C/W
pF
O
+175
C
*1 Repetitive peak reverse voltage
*2 RMS voltage
0.95
*3 Continuous reverse voltage
35
-55 to +150
1.25
*4 Maximum forward voltage@I F=3.0A
*5 Maximum Reverse recovery time , note 1
1.70
Note 1. Reverse recovery time test condition, I F =0.5A, I R =1.0A, I RR =0.25A
www.fuxinsemi.com
Page 1
Ver2.1
SF31G THRU SF38G
Rating and characteristic curves
FIG.2-TYPICAL FORWARD CURRENT
DERATING CURVE
FIG.1- TEST CIRCUIT DIAGRAM AND REVERSE RECOVERY TIME CHARACTERISTIC
trr
10W
NONINDUCTIVE
25Vdc
(approx.)
D.U.T.
PULSE
GENERATOR
(NOTE 2)
1W
NONINDUCTIVE
+0.5A
AVERAGE FORWARD CURRENT,(A)
50W
NONINDUCTIVE
-0.25A
OSCILLISCOPE
(NOTE 1)
NOTES: 1. Rise Time= 7ns max., Input Impedance= 1 megohm.22pF.
-1.0A
1cm
2. Rise Time= 10ns max., Source Impedance= 50 ohms.
3.0
2.5
2.0
1.5
Half Wave 60Hz
1.0
Resistive Or Inductive Load
0.375"(9.5mm) Lead Length
0.5
SET TIME BASE FOR
50
75
100
125
150
175
AMBIENT TEMPERATURE,(°C)
50 / 10ns / cm
FIG.4-TYPICAL REVERSE
CHARACTERISTICS
CHARACTERISTICS
REVERSE LEAKAGE CURRENT, (uA)
INSTANTANEOUS FORWARD CURRENT,(A)
FIG.3-TYPICAL FORWARD
PERCENT OF RATED PEAK REVERSE VOLTAGE,(%)
FORWARD VOLTAGE,(V)
FIG.6-TYPICAL JUNCTION CAPACITANCE
FIG.5-MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
175
125
JUNCTION CAPACITANCE,(pF)
PEAK FORWARD SURGE CURRENT,(A)
Single Phase
100
TJ=25 C
8.3ms Single Half
Sine Wave
75
JEDEC method
50
25
150
125
100
75
50
25
5
10
50
100
.01
NUMBER OF CYCLES AT 60Hz
www.fuxinsemi.com
.05
.1
.5
1
5
10
50
100
REVERSE VOLTAGE,(V)
Page 2
Ver2.1
SF31G THRU SF38G
Pinning information
Pin
Pin1
Pin2
Simplified outline
cathode
anode
Symbol
1
2
1
2
Marking
Type number
Example
Marking code
SF31G
SF32G
SF33G
SF34G
SF35G
SF36G
SF37G
SF38G
SF31G
SF32G
SF33G
SF34G
SF35G
SF36G
SF37G
SF38G
For Halogen D evice
For Halogen-free Device
LOGO
LOGO
SF38GH
SF38G
Marking code
Marking code
Taping specifications for AXIAL devices
52.4mm
A
OFF Center
both sids
1.0mm
6.3mm
Max OF
Alignment
1.2mm
AMMO PACKING
DEVICE
Q'TY 1
INNER
CARTON
Q'TY 2
APPROX.
CASE
(PCS / BOX)
BOX SIZE
SIZE
(PCS / CARTON)
CROSS
(m/m)
(m/m)
TYPE
DO-201AD
www.fuxinsemi.com
1,250
258 * 75 * 143
405 * 270 * 320
Page 3
WEIGHT(kg)
12,500
14.0
Ver2.1
SF31G THRU SF38G
Suggested thermal profiles for soldering processes
1.Lead free temperature profile wave-soldering
280
Peak soldering temperature not
to exceed 260ºC
260
240
220
Temperature(°C)
200
180
160
140
120
Peak
Max well
time 5 Max
100
80
Cool Down
Max gradient-4ºC/s
Suggested gradient - 2ºC/s or
less
60
40
Preheat
Max gradient 2ºC/s
60
80
100 120 140 160 180 200 220 240
Time(Sec)
www.fuxinsemi.com
Page 4
Ver2.1
很抱歉,暂时无法提供与“SF38G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.43702
- 100+0.35303
- 300+0.31104
- 1250+0.24339
- 5000+0.21822
- 10000+0.20558
