TPG113S6
TPG113S6
    TECHPUBLIC(台舟)
    SOT23-6
    TPG113S6
TPG113S6 数据手册
TPG113S6 WWW.SOT23.COM.TW MICRF113YM6 Pin to Pin fully compatible      电 舟 TYPICAL APPLICATION 子 Complete UHF transmitter Frequency range 300MHz to 450MHz Data rates up to 10kbps ASK Output Power to 10dBm Low external part count Low voltage operation (down to 1.8V) Operate with crystals or ceramic resonators 台        1 Fan Controllers Remote Power Switches Multi-Media Remote Control Remote Sensor Data Links Infrared Transmitter Replacement TPG113S6 WWW.SOT23.COM.TW 子 PIN CONFIGURATION 6 ASK PAOUT 1 VSS 2 电 5 XTLIN VDD 3 4 XTLOUT Pin Number SOT23-6 Pin Name Pin Function 1 台 舟 SOT-23-6 PA_OUT Bandwidth Selection Bit 0 (Digital Input): Used in conjunction with SEL1 to set the desired demodulator filter bandwidth. See Table 1. Internally pulled-up to VDDRF 2 VSS Ground 3 VDD Voltage Drain Drain (Input): Positive Power Supply 4 XTLOUT 5 XTLIN 6 ASK Crystal Out (Output): Reference oscillator output connection. Crystal In (Input): Reference oscillator input connection. ASK DATA Input Absolute Maximum Ratings +5V Supply Voltage (VDD) VSS–0.3 to VDD+0.3 Input/Output Voltage (VI/O) +7.2V Voltage on PA_OUT(VPA_OUT) –65°C to +150°C Storage Temperature Range (TS) Lead Temperature (soldering, 10 sec.) +300°C ESD Rating 2KV (3) Operating Ratings RF Frequency Range 300MHz to 450MHz Supply Voltage (VDD) +1.8V to +3.6V Ambient Temperature (TA) –40°C to +85°C 2 TPG113S6 Electrical Characteristics WWW.SOT23.COM.TW ( TA=25 C unless otherwise noted) (VIN=5V, TA = 25℃T unless otherwise specified) Specifications apply for VDD = 3.0V, TA = 25°C, FreqREFOSC = 13.560MHz, EN = VDD. Bold values indicate –40°C to 85°C unless otherwise noted. 1kbps data rate 50% duty cycle. RL 50ohm load (matched) Parameter Condition Min Typ Max Units Power Supply 12.3 mA @ 433.92MHz, POUT = +10dBm 12.5 mA 3 mA 3 mA 子 Mark Supply Current ION @ 315MHz, POUT = +10dBm @ 315MHz SPACE supply current, IOFF 电 @ 433.92 MHz Standby Mode (For F115 and F117) @ 315MHz 舟 Standby supply current, ISTB @ 433.92 MHz uA 1 uA ASK transition from HIGH to LOW 30 75 120 ms ASK transition from LOW to HIGH 500 700 900 us 台 Standby delay time 1 RF Output Section and Modulation Limits: @315MHz (4) 10 dBm (4) 10 dBm 2nd harm. -39 dBc -53 dBc 2nd harm. -55 dBc 3rd harm. -55 dBc 70 dBc Output power level, POUT ASK "mark" @433.92MHz TPG113S6 @ 630MHz Harmonics output for 315MHz @945MHz (4) (4) 3rd harm. @ 867.84MHz (4) Harmonics output for 433.92 MHz @1301.76MHz (4) Extinction ratio for ASK ASK Modulation 3 TPG113S6 Data Rate 10 @315MHz (6) kbps
TPG113S6 价格&库存
很抱歉,暂时无法提供与“TPG113S6”相匹配的价格&库存,您可以联系我们找货
