ROHS Compliant
承 認 書
SPECIFICATION FOR APPROVA
CUSTOMER:
CUSTOMER P/N:
CUSTOMER PA RT NO:
DESCRIPTION:
PRODUCTS NO:
FIRST DA TE:
DA TE:
A PPROV A L BY
SMD INDUCTOR
BCIHP0412-R68M
2019-10-22
2019-10-22
PURCHA SER CONFIRMED
CHECK BY
BC REV : X 1
DRA W N BY
REMA RK
A PPROV A L BY
Ouyang weijun
PROV IDER ENGINEER DEPT.
CHECK BY
DRA W N BY
Xuqiuyue
chenlinli
誠陽實業有限公司
TAIPEI OFF ICE TAIWAN CHENG YANG COMPONENT CORP
2F-1, NO. 176, Chine-Yi Road., Zhonghe District, New Taipei City, TAIWAN(R.O.C)
新北市中和區建一路176號2樓之一
POSTAL CODE: 23500
TEL NO.:+886-2- 8228-0930 FAX NO.:+886-2-8228-0929 E-mail:h21803@ms29.hinet.net
寶誠電子有限公司
CHINA FACTORYZHUHAI BAO CHENG ELECTRONICSCO.,LTD
Guan Tang Industrial Park, Tang Jia Wan Town, Zhuhai City, Guangdong Province, CHINA
中國廣東省珠海市塘家灣鎮官塘工業區
POSTAL CODE: 519085
TEL NO:86-756-3383187 FAX NO:86-756-3380704 E-mail: baocheng@baocheng.biz
昆山誠陽電子有限公司
CHINA FACTORYKUNSHAN CHENG YANG ELECTRONICSCO.,LTDP
江蘇省昆山市高科技工業園區強安路35號
POSTAL CODE: 215300
TEL NO:86-512-57823500 FAX NO:86-512-57823503 E-mail: kscy@taiwan-chengyang.com.tw
1/8
ROHS Compliant
SPECIFICATION FOR APPROVAL
DATE: 2019-10-22
CUSTOMER:
CUSTOMER PART NO:
FIRST DATE:
DESCRIPTION:
SMD INDUCTOR
PRODUCTS NO:
BCIHP0412-R68M
BC REV:
2019-10-22
X1
1.CONFIGURATION DIMENSIONS
DIMENSIONS(UNIT:mm)
A:
4.35 Max
B:
4.80 Max
C:
1.20 Max
D:
1.60 ±0.2
E
0.76 ±0.3
R68
Marking:激光刻字
2.RECOMMEND LAND PATTERN DIMENSIONS
F:
G:
H
4.95
1.95
1.60
3.ELECTRICAL CHARACTER
Inductance (uH)
Part Number
BCIHP0412-R68M
0A
0.765
0.00
1A
0.762
0.70
2A
0.749
2.90
3A
0.730
6.70
Typical
33.5
Max
39.0
4A
0.713
12.80
5A
0.686
20.70
(5)
(6)
(Irms)(A)
Heat Rating Current
DC
Amps
Typical
5.0
6A
0.669
29.50
(Isat)(A)
Saturation Current
DC
Amps
Typical
9.0
△T≦40℃
7A
0.636
46.20
8A
0.609
73.0
△L≦30%
9A
0.582
94.0
(1) Tolerance of Inductance: M=±20%.
(2) All test data is referenced to 25℃ ambient.
(3) Inductance is measured at200kHz/0.25v/0A..25℃ ambient.
TEMPERATURE (℃)
INDUCTANCE(uH)
Adc
L(0.68uH)
△T(℃)
200kHz/0.25v/0A.
0.68
20%
Rdc (mΩ)
DC CURRENT ( AMPS )
(4) Operating Temperature Range -40℃ to +125℃.
(5) DC current (Irms) (A) that will cause an Approximate △T≦40℃
(6) DC current (Isat) (A) that will cause L0 to drop approximately
△L≦30%
(7) The part Temperature (ambient + temp rise) should not exceed 125℃ under worst case operating conditions.
Circuit design, component placement, PWB trace size and thickness, airflow and other cooling
provisions all affect the part temperature Part temperature should be verified in the end application.
※Irms : Heat Rating Current DC Amps.
※Isat : Saturation Current DC Amps.
2/8
ROHS Compliant
DATE: 2019-10-22
CUSTOMER:
CUSTOMER PART NO:
FIRST DATE:
DESCRIPTION:
SMD INDUCTOR
PRODUCTS NO:
BCIHP0412-R68M
BC REV:
2019-10-22
X1
4.PACKAGING INFORMATION
(1) Tape Dimension / Packaging Quantity
DIMENSIONS(UNIT:mm)
A: 330.0 ±2.00
B: 100.0 ±0.50
C: 13.5 ±0.50
W1: 12.80 ±0.30
W2: 17.00 ±0.50
Q`TY: 4,000 PCS
DIMENSIONS(UNIT:mm)
W:
12.00 ±0.30
A0:
4.30 ±0.10
B0:
4.60 ±0.10
K0:
1.50 ±0.10
P:
8.00 ±0.10
F:
5.50 ±0.10
T:
0.30 ±0.05
(2) Tearing Off Force
The force tearing off cover 10 to 130 grams
(0.1N to 1.3N) in the arrow direction
under the following conditions.
●Storage conditions/Note things
(1) Storage temperature and humidity conditions :
1. Product packing with Carrier tape: +5℃~+40℃ and less than 60% RH.
2. Product alone: -20℃~+60℃ and less than 60% RH.
(2) Products should be used within 6 months.
(3) The packaging material should be kept where no chlorine or sulfur exists in the air.
(4) Do not touch the electrodes (soldering terminals) with fingers as this may lead to deterioration of solder ability
(5) The use of tweezers or vacuum pick-ups is strongly recommended for individual components.
(6) Bulk handling should ensure that abrasion and mechanical shock are minimized.
3/8
ROHS Compliant
SAMPLE ACKNOWLEDGE CHANGE RESUME
DATE: 2019-10-22
CUSTOMER:
CUSTOMER PART NO:
FIRST DATE:
2019-10-22
DESCRIPTION:
SMD INDUCTOR
REV
X1
PRODUCTS NO:
BCIHP0412-R68M
Change content
00
首次
BC REV:
X1
Change reason
Modify
Date
首次送样
chenlinli
2019-10-22
4/8
ROHS Compliant
TEST DATA
CUSTOMER:
CUSTOMER PART NO:
FIRST DATE:
DESCRIPTION:
SMD INDUCTOR
PRODUCTS NO:
BCIHP0412-R68M
BC REV:
(1) TEST DATA FOR SAMPLE
TEST ITEM
Inductance (uH)
Rdc (mΩ)
(6) (Isat)(A)Saturation Current DC Amps
(5) (Irms)(A)Heat Rating Current DC Amps
MEAS ITEM
SUGGEST
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
max
min
σ
X
Cpk
A
4.350
Max
4.04
4.05
4.04
4.05
4.06
4.06
4.05
4.04
4.05
4.06
4.06
4.04
0.008
4.05
12.91
B
4.800
Max
4.39
4.36
4.37
4.38
4.37
4.39
4.37
4.38
4.37
4.39
4.39
4.36
0.010
4.38
14.03
2019-10-22
X1
LOT NO.
DIMENSIONS(UNIT:mm)
A
4.35 Max
B
4.80 Max
C
1.20 Max
D
1.60 ±0.2
E
0.76 ±0.3
R68
1
2
3
4
DATE: 2019-10-22
C
1.200
Max
1.11
1.13
1.13
1.11
1.13
1.14
1.14
1.12
1.12
1.13
D
1.600
±0.2
SPEC
0.68
20%
39.0
Max
9.0
△L≦30%
5.0 △T≦40℃
E
0.760
±0.3
1.14
1.11
0.010
1.13
2.42
2.TEST CONDITION
TEMP.
R.H.
65%
25℃
3.TEST INSTRUMENTS
□HP-4284A METER
□CH-3305 METER
■HP-4285A METER
□CD1068+CD1320 METER
METER
□HP-4191A
□VR113+VR712 METER
□ CH101 LCR,METER
□WK3260B+WK3265B METER
■ VR116+VR7220 METER□VR562 METER
□CH-3200 METER
■CH-502B DCR METER
□CH-310 METER
TEST CONDITION
200kHz/0.25v/0A.
0.674
0.674
0.696
0.688
0.689
0.631
0.691
0.625
0.662
0.684
2
39.0
Max
32.4
32.56
32.01
33.71
31.92
34.73
32.61
33.82
32.37
32.78
3
9.0
△L≦30%
75%
76%
77%
75%
75%
76%
75%
75%
76%
78%
0.70
0.63
0.024
0.67
2.03
34.73
31.92
0.857
32.89
2.38
78.0%
75.0%
0.010
75.8%
280.40
1
0.68
20%
APPROVED BY
ouyangweijun
CHECKED BY
Xuqiuyue
DRAWN BY
chenlinli
5/8
■GENERAL CHARACTERISTICS
page.1
Operation Temperature
-40℃ to +125℃ (Includes temperature when the coil is heated)
External Appearance
On visual inspection, the coil has no external defects.
More than 90% of terminal electrode should be covered with solder.
l After fluxing, component shall be dipped in a melted.
Solder Ability Test
dipped in a melted.
Solder:bath at 235℃±5℃ for 5 ± 0.5senonds
1.Components should have not evidence of electrical and mechanical damage.
2.Inductance: within±10% of initial value.
3.Impedance: within±10% of initial value.
Heat endurance of Soldering●Preheat:150±5℃ 60seconds.
●Solder temperature: 250±5℃.
●Flux: rosin.
●Dip time:10±0.5seconds.
After soldering of X,Y withstanding at below conditions .The terminal should not Peel
off. (Refer to figure at below)
Terminal Strength
5N:60sec.
Insulating Resistance
Over 100MΩ at 100V D.C. between coil and core.
Dielectric Strength
No dielectric breakdown at 30V D.C. for 1 minute between coil and core.
VibrationTest
Inductance deviation within +10% after vibration for 1 hour. In each of three
orientations at sweep vibration(10-~55-~10HZ)with 1.5mmP-P amplitudes
Inductance deviation within +10% after being dropped once with 981m/s2 (100G)
Drop test
shock Attitude upon a rubber block method shock testing machine, in three different
orientations
Application Notice/Handling
1. Storage Conditions
To
maintain
the solder ability of terminal electrodes:
1. Storage
Conditions
To maintain the solder ability of terminal electrodes:
(1) Temperature and humidity conditions: less than 40℃ and 70% RH.
2. Handling
(1) Do not touch the electrodes(soldering terminals)with fingers as this may lead to deterioration of solderability.
(2) The use of tweezers or vacuum pick-ups is strongly recommended for individual components.
(3) Bulk handling should ensure that abrasion and mechanical shock are minimized.
TEST
Required Characteristics
page.2
Test Method/Condition
1. No case deformation or change
in appearance
2. △L/L≦10%
High Temperature StorageTest 3. △Q/Q≦30%
4. △DCR/DCR≦10%
Reference documents:
MIL-STD-202G Method108A
Temperature:125℃±2℃ Time:96±2 hours.
Tested not less than 1 hour, nor more than 2
hours at room.
in appearance
2. △L/L≦10%
Low Temperature Storage Test 3. △Q/Q≦30%
4. △DCR/DCR≦10%
IEC 68-2-1A 6.1 6.2
Temperature:-40℃±2℃ Time:96±2 hours.
hours at room.
in appearance
2. △L/L≦10%
3. △Q/Q≦30%
Humidity Test
4. △DCR/DCR≦10%
MIL-STD-202G Method103B
Thermal Shock Test
1. Dry oven at a temperature of 40℃±2℃ for
96hours
2. Measurements At the end of this period
3. Exposure: Temperature: 40℃±2℃.
Humidity:93±2hoyrs.
4. Tested while the chamber.
5. Tested not less than 1 hour. Nor more than 2
hours at room temperature.
in appearance
2. △L/L≦10%
3. △Q/Q≦30%
4. △DCR/DCR≦10%
MIL-STD-202G Method107G
First–40℃ for 30 Minutes, last 125℃ for 30
Minutes as 1 cycle. Go through 20 cycles.
■Application Notice/Handling
(1) Temperature and humidity conditions : less than 40℃ and 70% RH.
■THE CONDITION OF REFLOW(RECOMMENDATION)
TYPICAL WAVE SOLDER PROFILE FOR
LEADED AND
LEAD -FREE THROUGH-HOLE PACKAGES
IPC/JEDEC J-STD-020C, Figure 5-1
page.3
TYPICAL IR REFLOW PROFILE FOR LEADED AND
LEAD -FREE SURFACE MOUNT PACKAGES
很抱歉,暂时无法提供与“BCIHP0412-R68M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.65448
- 10+0.38448
- 30+0.18144
- 100+0.16740
- 500+0.13716
- 1000+0.13392
