AW13418QNR
AW13418QNR
    AWINIC(艾为)
    QFN-14-EP(2x2)
    停产 0.1-3GHZSP8T多路射频开关
AW13418QNR 数据手册
AW13418 Nov 2017 V1.1 0.1-3GHz SP8T Diversity Switch FEATURES GENERAL DESCRIPTION  Broadband frequency range: 0.1 to 3.0 GHz  Low insertion loss: 0.75dB typical @ 2.7 GHz  High isolation: >20dB @ 2.7 GHz  Integrated logic The AW13418 is a SP8T switch with low insertion loss and high Isolation. It can be used to support band switching and mode switching in antenna diversity systems for 2G/3G/4G, data cards and tablets.  Small QFN (14-pin, 2.0mm x 2.0 mm) package (MSL1, 260 °C per JEDEC J-STD-020) The symmetrical design of internal ports makes it convenient for PCB routing and adjustment of receiving and transmitting signals. The band/mode switching is realized by the GPIO pins as referenced in the chip block diagram and the control logic. APPLICATIONS  2G/3G/4G antenna diversity  Cellular modems , tablets and USB Devices  Other RF front-end modules The AW13418 is provided in a compact 2.0mm x 2.0mm, 14-pin QFN package. TYPICAL APPLICATION CIRCUIT ANT 13 RF7 14 RF5 1 AW13418 12 RF8 11 RF6 RF3 2 10 RF4 RF1 3 9 RF2 4 1nF VDD Figure 1 5 6 7 100pF V3 100pF V2 100pF V1 Typical Application Circuit of AW13418 All trademarks are the property of their respective owners. www.awinic.com.cn 1 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW13418 Nov 2017 V1.1 PIN CONFIGURATION AND TOP MARK 3418 – AW13418QNR XXXX – Production Tracking Code Figure 2 Pin Configuration and Top Mark PIN DEFINITION No. NAME DESCRIPTION 1 RF5 RF I/O path 5 2 RF3 RF I/O path 3 3 RF1 RF I/O path 1 4 VDD DC power supply 5 V3 DC control voltage 3 6 V2 DC control voltage 2 7 V1 DC control voltage 1 8 NC Not connected 9 RF2 RF I/O path 2 10 RF4 RF I/O path 4 11 RF6 RF I/O path 6 12 RF8 RF I/O path 8 13 ANT Antenna port 14 RF7 RF I/O path 7 Note: Bottom ground paddles must be connected to ground. www.awinic.com.cn 2 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW13418 Nov 2017 V1.1 FUNCTIONAL BLOCK DIAGRAM RF1 RF2 RF3 RF4 ANT RF5 RF6 RF7 RF8 Controller and Decoder VDD V3 Figure 3 V2 V1 GND FUNCTIONAL BLOCK DIAGRAM ORDERING INFORMATION Part Number AW13418QN R Temperature Package -40°C~85°C QFN2mm* 2mm-14L Marking 3418 Moisture Sensitivity Level MSL1 Environmental Information Delivery Form ROHS+HF 3000 units/ Tape and Reel AW13418 Shipping R:Tape & Reel Package Type QN:QFN www.awinic.com.cn 3 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW13418 Nov 2017 V1.1 ABSOLUTE MAXIMUM RATINGS(NOTE1) PARAMETERS RANGE Supply Voltage Range VDD 2.4V to 3.3V Control Voltage Range V1,V2,V3 0V to 3V RF input power(RF1 to RF8) 31dBm Operating Free-air Temperature Range -40°C to 85°C Storage Temperature TSTG -55°C to 150°C Lead Temperature (Soldering 10 Seconds) 260°C ESD (NOTE 2) HBM ±2kV CDM ±1kV NOTE1: Conditions out of those ranges listed in "absolute maximum ratings" may cause permanent damages to the device. In spite of the limits above, functional operation conditions of the device should within the ranges listed in "recommended operating conditions". Exposure to absolute-maximum-rated conditions for prolonged periods may affect device reliability. NOTE2: The human body model is a 100pF capacitor discharged through a 1.5kΩ resistor into each pin. Test method: MIL-STD-883J Method 3015.9 ELECTRICAL CHARACTERISTICS VDD=2.8V, V1=V2=V3=0/1.8V, PIN=0dBm, TOP=+25℃, Z0=50Ω. (unless otherwise noted) PARAMETER TEST CONDITION MIN TYP MAX UNIT 2.4 2.8 3 V DC Specifications VDD Supply Voltage IDD Supply Current A 45 Control Voltage VCTL_H VCTL_L ICTL tON High 1.35 Low 0 Control Current Turn-on Switching Time 1.8 3 V 0.45 VCTL = 1.8V 0.1 1 A 50% of final control voltage to 90% of final RF power, switching between RF1/2/3/4/5/6/7/8 0.5 1 S 0.1-1.0G 1.0-2.0G 2.0-2.7G 0.1-1.0G 1.0-2.0G 2.0-2.7G 0.50 0.70 0.75 35 27 22 0.60 0.80 0.90 dB dB dB dB dB dB RF Specifications IL ISO Insertion loss(ANT pin to RF1-RF8) Isolation (ANT pin to RF1-RF8) www.awinic.com.cn 4 28 22 18 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW13418 Nov 2017 V1.1 PARAMETER TEST CONDITION Second harmonics (ANT pin to RF1-RF8) 2fo P0.1dB IIP3 23 20 18 27 22 20 dB dB dB 90 dBc 80 dBc 0.1GHz–3GHz 31 dBm @ 2.0GHz, PIN=+26dBm, 57 dBm 0.1-3GHz MAX UNIT PIN=+26dBm, Third harmonics (ANT pin to RF1-RF8) 3fo TYP 0.1-1.0G 1.0-2.0G 2.0-2.7G PIN=+26dBm, Input return loss (ANT pin to RF1-RF8) RL MIN 0.1-3GHz 0.1dB Compression Point (ANT pin to RF1-RF8) 3rd Order Input Intercept Point Δf=1MHz TIMING DIAGRAM (POWER ON AND OFF SEQUENCE) It is very important that the user adheres to the correct power-on/off sequence in order to avoid damaging the device. The control signal V1, V2, V3 should be set to 0V unless VDD is set in the operating voltage range. Power ON: 1) Apply voltage supply --- VDD 2) Set Controls---V1, V2, V3 3) Apply RF input Change switch position from one RF port to another: 1) Remove RF input 2) Change control voltages V1, V2, V3 to set the switch to desired RF port 3) Apply RF input Power OFF: 1) Remove RF input 2) Remove control voltages-V1, V2, V3 3) Remove VDD input Power on Change switch Power Off VDD V1/V2/V3 RF_IN Figure 4 www.awinic.com.cn Power on/Change switch/Power off sequence 5 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW13418 Nov 2017 V1.1 AW13418 CONTROL LOGIC Control Switch RF I/O Pins V1 V2 V3 RF1 RF2 RF3 RF4 RF5 RF6 RF7 RF8 0 0 0 ON Isolation Isolation Isolation Isolation Isolation Isolation Isolation 0 0 1 Isolation ON Isolation Isolation Isolation Isolation Isolation Isolation 0 1 0 Isolation Isolation ON Isolation Isolation Isolation Isolation Isolation 0 1 1 Isolation Isolation Isolation ON Isolation Isolation Isolation Isolation 1 0 0 Isolation Isolation Isolation Isolation ON Isolation Isolation Isolation 1 0 1 Isolation Isolation Isolation Isolation Isolation ON Isolation Isolation 1 1 0 Isolation Isolation Isolation Isolation Isolation Isolation ON Isolation 1 1 1 Isolation Isolation Isolation Isolation Isolation Isolation Isolation ON www.awinic.com.cn 6 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW13418 Nov 2017 V1.1 APPLICATION CIRCUITS ANT 13 RF7 14 RF5 1 AW13418 12 RF8 11 RF6 RF3 2 10 RF4 RF1 3 9 RF2 4 1nF VDD 5 6 100pF 7 100pF 100pF VCTL3 VCTL2 VCTL1 Figure 5 AW13418 EVB Schematic Figure 6 AW13418 EVB www.awinic.com.cn 7 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW13418 Nov 2017 V1.1 PACKAGE OUTLINE DIMENSIONS Figure 7 Package Outline AW13418 OUTLINE DIMENSIONS www.awinic.com.cn 8 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW13418 Nov 2017 V1.1 LAND PATTERN DATA TAPE AND REEL INFORMATION Pin 1 User Direction of Feed Figure 8-1 www.awinic.com.cn 9 Tape and Reel Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW13418 Nov 2017 V1.1 Figure 8-2 www.awinic.com.cn 10 Tape and Reel Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW13418 Nov 2017 V1.1 REFLOW Reflow Note Spec Average ramp-up rate (217°C to peak) Max. 3°C /sec Time of Preheat temp. (from 150°C to 200°C) 60-120sec Time to be maintained above 217°C 60-150sec Peak Temperature >260°C Time within 5°C of actual peak temp 20-40sec Ramp-down rate Max. 6°C /sec Time from 25°C to peak temp Max. 8min Figure 9 Package Reflow Standard Profile NOTE 1: All data are compared with the package-top temperature, measured on the package surface; NOTE 2: AW13418 adopted the Pb-Free assembly. www.awinic.com.cn 11 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW13418 Nov 2017 V1.1 REVISION HISTORY Vision Date Change Record V1.0 Aug 2017 Officially Released V1.1 Nov 2017 Change datasheet template www.awinic.com.cn 12 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW13418 Nov 2017 V1.1 DISCLAIMER Information in this document is believed to be accurate and reliable. However, Shanghai AWINIC Technology Co., Ltd (AWINIC Technology) does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. AWINIC Technology reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. Customers shall obtain the latest relevant information before placing orders and shall verify that such information is current and complete. This document supersedes and replaces all information supplied prior to the publication hereof. AWINIC Technology products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an AWINIC Technology product can reasonably be expected to result in personal injury, death or severe property or environmental damage. AWINIC Technology accepts no liability for inclusion and/or use of AWINIC Technology products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications that are described herein for any of these products are for illustrative purposes only. AWINIC Technology makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. All products are sold subject to the general terms and conditions of commercial sale supplied at the time of order acknowledgement. Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Reproduction of AWINIC information in AWINIC data books or data sheets is permissible only if reproduction is without alteration and is accompanied by all associated warranties, conditions, limitations, and notices. AWINIC is not responsible or liable for such altered documentation. Information of third parties may be subject to additional restrictions. Resale of AWINIC components or services with statements different from or beyond the parameters stated by AWINIC for that component or service voids all express and any implied warranties for the associated AWINIC component or service and is an unfair and deceptive business practice. AWINIC is not responsible or liable for any such statements. www.awinic.com.cn 13 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD
AW13418QNR 价格&库存
很抱歉,暂时无法提供与“AW13418QNR”相匹配的价格&库存,您可以联系我们找货
AW13418QNR
  • 1+0.57530
  • 200+0.37180
  • 1500+0.32340
  • 3000+0.28600
库存:890
