A75X33BQF/Q
A75X33BQF/Q
    AMICCOM(笙科)
    QFN20_4X4MM_EP
    A75X33BQF/Q
A75X33BQF/Q 数据手册
A7533A/B 4X2 Switch Matrix with Tone/Polarity Controller Document Title Data sheet of A7533. History Issue Date Remark TI A Rev. No. L Revision History th 0.1 Initial issue. 0.2 0.3 0.4 0.5 Logo changed. Change DC spec, truth table Add B type Modify ordering information, add top marking info., reflow profile Jun. 25 , 2007 0.6 0.7 Change pin definition Modify typo of Pin 14 and Pin 16, add remark of application ckt. 0.8 Modify pin configuration 4,5,8 typo 1.0 Add ESD sensitive caution and MSL III information July, 2010 1.1 Change English Company Name Nov. 30, 2010 1.2 Modify the tape reel information and the add Shenzhen office address. Jul. 2011 1.3 Remark to use either 500pF or 470pF on pin 5 and pin 11. June, 2012 Preliminary Jul, 15, 2008 Jul, 08, 2009 Feb, 22, 2010 Full Production A M IC C O M C O N FI D EN Oct. 18th, 2007 Dec. 7th , 2007 Jan. 16th, 2008 Apr. 17th, 2008 Important Notice: AMICCOM reserves the right to make changes to its products or to discontinue any integrated circuit product or service without notice. AMICCOM integrated circuit products are not designed, intended, authorized, or warranted to be suitable for use in life-support applications, devices or systems or other critical applications. Use of AMICCOM products in such applications is understood to be fully at the risk of the customer. June, 2012, Version 1.3 AMICCOM Electronics Corporation A7533A/B 4X2 Switch Matrix with Tone/Polarity Controller Table of Contents A M IC C O M C O N FI D EN TI A L 1 Typical Applications ........................................................................................................................................................ 1 2 General Description........................................................................................................................................................ 1 3 Pin Assignments............................................................................................................................................................. 1 4 Block Diagram................................................................................................................................................................ 2 5 Pin Configurations .......................................................................................................................................................... 3 6 Electrical Specifications .................................................................................................................................................. 4 7 Absolute Maximum Ratings............................................................................................................................................. 5 8 Applications Circuit ......................................................................................................................................................... 6 9 Truth Table ..................................................................................................................................................................... 7 10 Ordering Information..................................................................................................................................................... 9 11 Package Information....................................................................................................................................................10 12 Top Marking Information ..............................................................................................................................................11 13 Reflow Profile..............................................................................................................................................................13 14 Tape Reel Information..................................................................................................................................................14 15 Product Status.............................................................................................................................................................15 June, 2012, Version 1.3 AMICCOM Electronics Corporation A7533A/B 4X2 Switch Matrix with Tone/Polarity Controller 1 Typical Applications 4*2 Switch Matrix for 0.2 -3.0 GHz Applications: n LNB n CATV L n Cellular Systems n DBS TI A 2 General Description A7533 is a low-cost 4 x 2 switch matrix with tone detector in a 20-lead QFN package for use in RF multiplexing applications from 200 to 3000 MHz. A positive voltage controlled 4 bit decoder and tone/polarity detector are both integrated on the switch with DiSEqC control signals rejection. A7533 is ok to be used in 50/75 ohm systems. EN 16 FI D N 18 19 C O 20 VH 15 N.C. 2 14 VL 13 N.C. M 1 O HL N.C. VHM N.C. HH N.C. 17 3 Pin Assignments Switch outputs (OP1 & OP2) can be independently selected from any of the four inputs (HH, HL, VH, VL) or simultaneously select the same inputs. Note that the switch is bi-directional and input/output functionality may be interchanged. 5 11 T1 DC1 OP1 A VDD DC2 OP2 10 T2 9 V1 8 12 7 4 6 C V2 M 3 IC A7533 N.C. A7533 QFN Package Top View June, 2012, Version 1.3 1 AMICCOM Electronics Corporation A7533A/B 4X2 Switch Matrix with Tone/Polarity Controller L 12 T1 11 N DC2 C O DC1 7 5 T2 A 4 V2 HL 6 OP2 2 M 20 HH IC C O M 9 Tone/Polarity Controll Circuit FI D EN 10 TI A 14 16 V1 OP1 VL VH 4 Block Diagram June, 2012, Version 1.3 2 AMICCOM Electronics Corporation A7533A/B 4X2 Switch Matrix with Tone/Polarity Controller 5 Pin Configurations Pin No. Pin Name 11 T1 12 V1 4 V2 5 T2 14 VL Function TI A L Tone and Polarity detector input. Tone and Polarity detector input. 16 VH 20 HH 2 HL 10 OP1 6 OP2 8 VDD Power pin, Connect to power. N.C. No connection, Connect to PCB ground. EN RF input pin FI D RF output pin 1 C O 15 N 3 13 17 19 Vertical-Horizontal Mirror. Connect to ground à Normal VHM M 18 DC2 9 DC1 Back side paddle GND By-pass , Connect to by-pass capacitor C 7 O Leave open à Mirror. A M IC Connect to ground. June, 2012, Version 1.3 3 AMICCOM Electronics Corporation A7533A/B 4X2 Switch Matrix with Tone/Polarity Controller 6 Electrical Specifications Typical condition: TA = +25°C, VDD= +3.3V, 50 ohm System. All RF port are terminated to 50 ohm . Condition Min. Typ. 200 - 950 MHz 950 - 1450 MHz 1450 - 2150 MHz 2150 - 3000 MHz 200 - 950 MHz 950 - 1450 MHz 1450 - 2150 MHz 2150 - 3000 MHz 200 - 3000 MHz 200 - 3000 MHz 200 - 3000 MHz 200 - 3000 MHz 6 6 6.5 7 35 31 29 23 12 10 20 15 6.5 6.5 7.5 9 37 33 31 25 15 15 EN Isolation N 200 - 3000 MHz C O Polarity and Tone Detector Polarity Threshold FI D Return Loss (Input; VL, HL, VH, HH) Return Loss (Output; OP1, OP2) Output IP3 Input Power for 1 dB Compression Switching On/Off Speed tRISE / tFALL (10/90% RF) Tone Signal Frequency Tone Signal Duty Cycle M Tone Signal Amplitude Threshold Supply Voltage dB dB dB dB dBm dBm 10 ms With external 62KΩ 14 14.75 15.5 V 7 22 78 KHz -40~85 ℃ 40 50 60 % With external 62KΩ and 500p / 470pF 0.1 0.17 C Current Consumption Units -40~85 ℃, 650mVpp O Power supply 8.5 7.5 8 11 TI A Switch Insertion Loss Max. L Parameter Vpp -40~85 ℃ 3 3.3 4.2 V -40~85 ℃ 1.5 2.2 3.2 mA A M IC Note: Tone/Polarization threshold could be tuned by change the value of external R,C. Please contact AMICCOM FAE for specified application. June, 2012, Version 1.3 4 AMICCOM Electronics Corporation A7533A/B 4X2 Switch Matrix with Tone/Polarity Controller Rating Bias Voltage Range (VDD) +5 VDC Storage Temperature -65 to +150°C Operating Temperature -40 to +85°C Maximum Input Power +17 dBm (200 - 3000 MHz) TI A Parameter L 7 Absolute Maximum Ratings EN *Stresses above those listed under “Absolute Maximum Rating” may cause permanent damage to the device. These are stress ratings only; functional operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. A M IC C O M C O N FI D *Device is ESD sensitive. Use appropriate ESD precautions. HBM (Human Body Mode) is tested under MIL-STD-883F Method 3015.7. MM (Machine Mode) is tested under JEDEC EIA/JESD22-A115-A. *Device is Moisture Sensitivity Level III (MSL 3). June, 2012, Version 1.3 5 AMICCOM Electronics Corporation A7533A/B 4X2 Switch Matrix with Tone/Polarity Controller A M IC C O M C O N FI D EN TI A L 8 Applications Circuit Note 1 Note 2 Note 3 62K ohm resistors shall be kept in 1% tolerance. The capacitors connected to pin 5 and pin 11 are ok to use either 500 pF or 470 pF. All capacitors shall be within 10 % tolerance. But, 5 % tolerance is preferred. June, 2012, Version 1.3 6 AMICCOM Electronics Corporation A7533A/B 4X2 Switch Matrix with Tone/Polarity Controller TI A L 9 Truth Table N FI D EN Above figure show the function of VHM. (Vertical/Horizontal mirror) C O Above figure show the different between 7533A and 7533B (High/Low band upside down) V1,V2 = 0 means DC voltage =9.5~14V, V1, V2=1 means DC voltage =15.5~19V T1, T2=0 means 22KHz tone disappeared. T1, T2=1 means 22KHz tone appeared. A7533A When pin 18 M O C IC V1 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 A M State 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 “VHM” connected to GND Control Input Output to Input State T1 V2 T2 OP1 OP2 0 0 0 HH HH 0 0 1 HH HL 0 1 0 HH VH 0 1 1 HH VL 1 0 0 HL HH 1 0 1 HL HL 1 1 0 HL VH 1 1 1 HL VL 0 0 0 VH HH 0 0 1 VH HL 0 1 0 VH VH 0 1 1 VH VL 1 0 0 VL HH 1 0 1 VL HL 1 1 0 VL VH 1 1 1 VL VL June, 2012, Version 1.3 7 AMICCOM Electronics Corporation A7533A/B 4X2 Switch Matrix with Tone/Polarity Controller A7533B When pin 18 M O C IC V1 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 “VHM” connected to GND Control Input Output to Input State T1 V2 T2 OP1 OP2 0 0 0 HL HL 0 0 1 HL HH 0 1 0 HL VL 0 1 1 HL VH 1 0 0 HH HL 1 0 1 HH HH 1 1 0 HH VL 1 1 1 HH VH 0 0 0 VL HL 0 0 1 VL HH 0 1 0 VL VL 0 1 1 VL VH 1 0 0 VH HL 1 0 1 VH HH 1 1 0 VH VL 1 1 1 VH VH A M State 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 TI A EN FI D N V1 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 C O State 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 “VHM” open. Vertical and Horizontal will be mirror. Control Input Output to Input State T1 V2 T2 OP1 OP2 0 0 0 VH VH 0 0 1 VH VL 0 1 0 VH HH 0 1 1 VH HL 1 0 0 VL VH 1 0 1 VL VL 1 1 0 VL HH 1 1 1 VL HL 0 0 0 HH VH 0 0 1 HH VL 0 1 0 HH HH 0 1 1 HH HL 1 0 0 HL VH 1 0 1 HL VL 1 1 0 HL HH 1 1 1 HL HL L A7533A When pin 18 June, 2012, Version 1.3 8 AMICCOM Electronics Corporation A7533A/B 4X2 Switch Matrix with Tone/Polarity Controller TI A EN FI D N V1 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 C O State 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 “VHM” open. Vertical and Horizontal will be mirror. Control Input Output to Input State T1 V2 T2 OP1 OP2 0 0 0 VL VL 0 0 1 VL VH 0 1 0 VL HL 0 1 1 VL HH 1 0 0 VH VL 1 0 1 VH VH 1 1 0 VH HL 1 1 1 VH HH 0 0 0 HL VL 0 0 1 HL VH 0 1 0 HL HL 0 1 1 HL HH 1 0 0 HH VL 1 0 1 HH VH 1 1 0 HH HL 1 1 1 HH HH L A7533B When pin 18 10 Ordering Information Package A75X33AQF/Q 490EA QFN20L, Pb Free, Tape & Reel, -40℃〜85℃ 3K QFN20L, Pb Free, Tray, -40℃〜85℃ 490EA A M IC A75X33BQF 3K QFN20L, Pb Free, Tray, -40℃〜85℃ C A75X33BQF/Q QFN20L, Pb Free, Tape & Reel, -40℃〜85℃ O A75X33AQF Units Per Reel / Tray M Part No. June, 2012, Version 1.3 9 AMICCOM Electronics Corporation A7533A/B 4X2 Switch Matrix with Tone/Polarity Controller 11 Package Information QFN 20L (4 X 4 X 0.8mm) Outline Dimensions unit: inches/mm BOTTOM VIEW 0.25 C 15 D2 11 TI A D L TOP VIEW 15 L 11 16 10 10 EN E2 FI D e E 16 20 6 6 0.25 C 20 5 5 1 e b 0.10 M C A B C O N 1 C y C M Seating Plane A3 A1 A // 0.10 C O Symbol Nom Max Min Nom Max A 0.028 0.030 0.032 0.70 0.75 0.80 A1 0.000 0.001 0.002 0.00 0.02 0.05 C IC M A Dimensions in mm Min A3 b 0.008 REF 0.007 0.010 0.203 REF 0.012 0.18 0.25 0.30 D 0.154 0.158 0.161 3.90 4.00 4.10 D2 0.075 0.079 0.083 1.90 2.00 2.10 E 0.154 0.158 0.161 3.90 4.00 4.10 E2 0.075 0.079 0.083 1.90 2.00 2.10 0.020 0.30 0.020 BSC e L y June, 2012, Version 1.3 Dimensions in inches 0.012 0.016 0.50 BSC 0.003 0.40 0.50 0.08 10 AMICCOM Electronics Corporation A7533A/B 4X2 Switch Matrix with Tone/Polarity Controller 12 Top Marking Information A75X33AQF A M IC C O M C O N FI D EN TI A L ¡Part No. : A75X33AQF ¡Pin Count : 20 ¡Package Type : QFN ¡Dimension : 4*4 mm ¡Mark Method : Laser Mark ¡Character Type : Arial June, 2012, Version 1.3 11 AMICCOM Electronics Corporation A7533A/B 4X2 Switch Matrix with Tone/Polarity Controller A75X33BQF A M IC C O M C O N FI D EN TI A L ¡Part No. : A75X33BQF ¡Pin Count : 20 ¡Package Type : QFN ¡Dimension : 4*4 mm ¡Mark Method : Laser Mark ¡Character Type : Arial June, 2012, Version 1.3 12 AMICCOM Electronics Corporation A7533A/B 4X2 Switch Matrix with Tone/Polarity Controller A M IC C O M Actual Measurement Graph C O N FI D EN TI A L 13 Reflow Profile June, 2012, Version 1.3 13 AMICCOM Electronics Corporation A7533A/B 4X2 Switch Matrix with Tone/Polarity Controller 14 Tape Reel Information QFN3*3 8±0.1 QFN 4*4 8±0.1 QFN 5*5 8±0.1 SSOP 12±0.1 A0 B0 P0 3.2 5±0.1 4.35 ±0.1 5.25 ±0.1 3.25 ±0.1 4.35 ±0.1 5.25 ±0.1 4±0.2 2±0.1 1.5±0.1 4±0.2 2±0.1 1.5±0.1 4±0.2 P1 D0 D1 1.5 1.5 2±0.1 1.5±0.1 1.5 8.2±1 8.8±1.5 4.0±0.1 2.0±0.1 1.5±0.1 1.5±0.1 F 1.75 ±0.1 1.75 ±0.1 1.75 ±0.1 1.75 ±0.1 5.5 ±0.05 5.5 ±0.05 5.5 ±0.05 W K0 Unit: mm Cover tape width t 0.3 9.3±0.1 ±0.05 0.3 12±0.3 9.3±0.1 ±0.05 0.3 12±0.3 9.3±0.1 ±0.05 0.3 13.3 7.5±0.1 16±0.1 2.1±0.4 ±0.05 ±0.1 12±0.3 M REEL DIMENSIONS E N P C O TYPE FI D EN TI A L Cover / Carrier Tape Dimension 1.25 ±0.1 1.2 5±0.1 1.25 ±0.1 R IC L C O T N A M D M K G Unit: mm TYPE G N M D K L R QFN 12.9±0.5 102 REF±2.0 2.3±0.2 13.15±0.35 2.0±0.5 330±3.0 19.6±2.9 SSOP 16.3±1 102 REF±2.0 2.3±0.2 13.15±0.35 2.0±0.5 330±3.0 19.6±2.9 June, 2012, Version 1.3 14 AMICCOM Electronics Corporation A7533A/B 4X2 Switch Matrix with Tone/Polarity Controller 15 Product Status Product Status Planned or Under Development Definition This data sheet contains the design specifications for product development. Specifications may change in any manner without notice. Preliminary Engineering Samples and First Production This data sheet contains preliminary data, and supplementary data will be published at a later date.AMICCOM reserves the right to make changes at any time without notice in order to improve design and supply the best possible product. No Identification Noted Full Production Obsolete Not In Production This data sheet contains the final specifications. AMICCOM reserves the right to make changes at any time without notice in order to improve design and supply the best possible product. This data sheet contains specifications on a product that has been discontinued by AMICCOM. The data sheet is printed for reference information only. O M C O N FI D EN TI A L Data Sheet Identification Objective C RF ICs AMICCOM IC Headquarter A M A3, 1F, No.1, Li-Hsin Rd. 1, Hsinchu Science Park, Taiwan 30078 Tel: 886-3-5785818 Shenzhen Office Rm., 2003, DongFeng Building, No. 2010, Shennan Zhonglu Rd., Futian Dist., Shenzhen, China Post code: 518031 Web Site http://www.amiccom.com.tw June, 2012, Version 1.3 15 AMICCOM Electronics Corporation
A75X33BQF/Q 价格&库存
很抱歉,暂时无法提供与“A75X33BQF/Q”相匹配的价格&库存,您可以联系我们找货
