SF58G
SF58G
    JF(晶发)
    DO-27(DO-201AD)
    耐压:600V 电流:5A 反向恢复时间:35NS
SF58G 数据手册
SF51G THRU SF58G R SUPER FAST RECTIFIER Reverse Voltage: 50 to 600 Volts Forward Current:5.0Amperes S E M I C O N D U C T O R DO-201AD FEATURES Low forward voltage drop High current capability 1.0(25.4) MIN. High reliability High surge current capability 0.220(5.6) 0.190(4.8) DIA. Good for switching mode application Lead (Pb)-free component Component in accordance to RoHS 2011/65/EU 0.375(9.50) 0.285(7.20) High temperature soldering guaranteed:260°C/10 seconds at terminals MECHANICAL DATA Case: JEDEC DO-201AD molded plastic body TerMINals: Plated axial leads, solderable per MIL-STD-750,method 2026 1.0(25.4) MIN. Polarity: Color band denotes cathode end 0.052(1.32) 0.045(1.14) DIA. Mounting Position: Any Weight: 0.041ounce, 1.15 grams Dimensions in inches and (millimetrers) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (Rating at 25°C ambient temperature unless otherwise specified ,Single phase ,half wave ,60HZ,resistive or inductive load. For capacitive load,derate current by 20%.) Symbols SF 51G SF 52G SF 53G SF 54G SF 55G SF 56G SF 58G Maximum Repetitive Peak Reverse Voltage VRRM 50 100 150 200 300 400 600 Maximum RMS Voltage VRMS 35 70 105 140 2 10 280 420 Maximum DC Blocking Voltage VDC 50 100 150 200 300 400 600 Maximum Average Forward Rectified Current 0.375''(9.5mm)Lead Length I(AV) 5.0 Amps Peak Forward Surge Current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) IFSM 150 Amps Maximum Instantaneous Forward Voltage at 5.0 A VF Maximum DC Reverse Current At Rated DC Blocking Voltage TA=25°C 0.95 1.3 1.7 Volts Volts Volts Volts A 5.0 IR Units 50 TA=100°C Maximum Reverse Recovery Time(Note1) Trr 35 Typical Junction Capacitance(Note2) Cj 50 ns PF RθJA 20 ℃/ W TJ -55 to+150 ℃ TSTG -55 to+150 ℃ Typical Thermal Resistance(Note3) Operating Temperature Range Storage Temperature Range Note: 1.Reverse Recovery Test conditions: IF=0.5A,IR=1.0A,IRR=0.25A. 2.Measured at 1MHZ and applied reverse voltage of 4.0 Volts. JINAN JINGHENG ELECTRONICS CO., LTD. 2-1 HTTP://WWW.JINGHENG.CN RATINGS AND CHARACTERISTIC CURVES SF51G THRU SF5 8 G FIG.2-MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT FIG.1-MAXIMUM AVERAGE FORWARD CURRENT DERATING PEAK FORWARD SURGE CURRENT(AMPERES) AVERAGE FORWARD CURRENT (A) 6 5 4 3 2 Single Phase Half Wave 60Hz Resistive or Inductive Load 0.375''(9.5mm)Lead Length 1 0 0 75 50 25 125 100 150 175 AMBIENT TEMPERATURE (°C) 150 120 90 TJ=25°C 60 30 0 20 10 5 2 1 50 100 NUMBER OF CYCLES AT 60Hz FIG.4-TYPICAL REVERSE CHARACTERISTICS FIG.3-TYPICAL FORWARD CHARACTERISTICS 100 100 -S F5 4G InsTANTANEOUS REVERSE CURRENT.(μA) 50 F5 8G SF 51 G 10 SF 55 G -S 3.0 1 0.1 0.01 Tj=25°C Pulse Width=300μs 1% Duty Cycle 0 0.2 0.4 0.6 1.2 1.0 0.8 TJ=100°C 10 1 TJ=25°C 0.1 0.01 1.4 FORWARD VOLTAGE (VOLTS) 0 20 40 60 80 100 120 140 PERCENT OF RATED PEAK REVERSE VOLTAGE(%) FIG.5-TYPICAL JUNCTION CAPACITANCE JUNCTION CAPACITANCE(pF) InsTANTANEOUS FORWARD CURRENT( AMPERES) 8.3ms Single Half Sine-Wave (JEDEC Method) 180 175 150 125 100 75 50 25 0 .01 .05 .1 .2 .5 1 2 5 10 20 50 100 REVERSE VOLTAGE. (V) JINAN JINGHENG ELECTRONICS CO., LTD. 2-2 HTTP://WWW.JINGHENG.CN
SF58G 价格&库存
很抱歉,暂时无法提供与“SF58G”相匹配的价格&库存,您可以联系我们找货
