ES3AF THRU ES3JF
Surface Mount Superfast Recovery Rectifier
Reverse Voltage – 50 to 600 V
PINNING
Forward Current – 3 A
PIN
FEATURES
• For surface mounted applications
• Low profile package
• Glass Passivated Chip Juntion
• Superfast reverse recovery time
• Lead free in comply with EU RoHS 2011/65/EU directives
DESCRIPTION
1
Cathode
2
Anode
1
2
Top View
Marking Code:
ES3AF~ES3JF: ES3A~ES3J
Simplified outline SMAF and symbol
MECHANICAL DATA
• Case: SMAF
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 27mg 0.00086oz
Absolute Maximum Ratings and Characteristics
Ratings at 25 °C ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
Symbols
ES3AF
ES3BF
ES3CF
ES3DF
ES3EF
ES3GF
ES3JF
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
50
100
150
200
300
400
600
V
Maximum RMS voltage
V RMS
35
70
105
140
210
280
420
V
Maximum DC Blocking Voltage
V DC
50
100
150
200
300
400
600
V
Maximum Average Forward Rectified Current
at T L = 100 °C
I F(AV)
3
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
(JEDEC Method)
I FSM
100
A
Maximum Forward Voltage at 3A
VF
Parameter
Maximum DC Reverse Current
at Rated DC Blocking Voltage
Ta = 25 °C
Ta =125 °C
1.25
1
1.7
V
IR
5
200
μA
Typical Junction Capacitance
at V R =4V, f=1MHz
Cj
45
pF
Maximum Reverse Recovery Time
at I F =0.5A, I R =1A, I rr =0.25A
t rr
35
ns
T j , T stg
-55 ~ +150
°C
Operating and Storage Temperature Range
REV.08
1 of 3
ES3AF THRU ES3JF
Fig.1 Reverse Recovery Time Characteristic And Test Circuit Diagram
50 ohm
Noninductive
10 ohm
Noninductive
t rr
+0.5
D.U.T
PULSE
GENERATOR
Note 2
25Vdc
approx
1 ohm
OSCILLOSCOPE
Note 1
NonInductive
-1.0
Note:1.Rise Time = 7ns, max.
Input Impedance = 1megohm,22pF.
2. Ries Time =10ns, max.
Source Impedance = 50 ohms.
10ns/div
Set time Base for 10ns/div
Fig.3 Typical Reverse Characteristics
3.5
300
3.0
100
I R - Reverse Current ( μ A)
Average Forward Current (A)
Fig.2 Maximum Average Forward Current Rating
2.4
1.8
1.2
Single phase half wave resistive
or inductive P.C.B mounted on
0.315×0. 315"(8.0×8. 0mm )
pad areas
0.6
T J =125°C
10
T J =75°C
1.0
T J =25°C
0.1
0.0
25
50
75
100
125
150
175
Lead Temperature (°C)
60
80
100
Fig.5 Typical Junction Capacitance
45
10
T J =25°C
Junction Capacitance ( pF)
Instaneous Forward Current (A)
40
% of PIV.VOLTS
Fig.4 Typical Forward Characteristics
ES3AF
1.0
ES3EF
ES3JF
0.1
0.01
0.001
0.4
0.6
0.8
1.0
1.2 1.4
40
35
30
25
T J =25°C
f = 1.0MHz
V sig = 50mV p-p
15
10
0.1
Instaneous Forward Voltage (V)
REV.08
10
Reverse Voltage (V)
2 of 3
100
ES3AF THRU ES3JF
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SMAF
∠ALL ROUND
C
A
∠ALL ROUND
D
E
A
V M
g
g
pad
e
E
A
pad
HE
Top View
A
C
D
E
e
g
HE
max
1.1
0.20
3.7
2.7
1.6
1.2
4.9
min
0.9
0.12
3.3
2.4
1.3
0.8
4.4
max
43
7.9
146
106
63
47
193
min
35
4.7
130
94
51
31
173
UNIT
mm
mil
Bottom View
7°
The recommended mounting pad size
2.2( 86)
1.6(63)
1.8(71)
1.6(63)
Unit:mm(mil)
REV.08
3 of 3
很抱歉,暂时无法提供与“ES3GF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.37121
- 100+0.30719
- 300+0.27518
- 3000+0.22572
- 6000+0.20653
- 9000+0.19689
