MXD8651
MXD8651
    MAXSCEND(卓胜微电子)
    QFN-14-EP(2x2)
    用于接收分集的SP5T射频开关
MXD8651 数据手册
MXD8651 SP5T Switch for Receive Diversity VED APPRO This document contains information that is confidential and proprietary to Maxscend Technologies Inc. (Maxscend) and may not be reproduced in any form without express written consent of Maxscend. No transfer or licensing of technology is implied by this document. Page 1 of 7 Maxscend Technologies Inc. All rights reserved. Maxscend Confidential MXD8651 – SP5T Switch for Receive Diversity General Description Features The MXD8651 is a low loss, high isolation SP5T  Excellent insertion loss and isolation performance switch with performance optimized for receive - 0.5 dB Typical Insertion Loss, Band 7 diversity routing applications. - 25 dB typical Isolation, Band 7 The MXD8651 is compatible with +1.0V control logic, which is a key requirement for most cellular transceivers. This part is packaged in a compact 2mm x 2mm x 0.55 mm, 14-pin, QFN package which allows for a small solution size with no need for external DC blocking capacitors (when no  Multi-Band operation 700MHz to 2700MHz  GPIO compatible to 1.8V Typ (1.0V min)  Power handling +30dBm  Compact 2mm x 2mm x 0.55 mm, in QFN package,MSL1  external DC is applied to the device ports). No DC blocking capacitors required (unless external DC is applied to the RF ports) Applications  Cellular Handset Applications  Cellular modems and USB Devices  Multi-mode GSM/Edge/WCDMA applications  LTE applications GND RF3 RF2 RF1 Functional Block Diagram and Pin Function 14 13 12 11 RF1 RF2 V3 1 V2 2 V1 3 ANT RF3 Ground Paddle 6 7 RF5 RF4 V3 5 V2 GND VDD V1 4 RF5 VDD RF4 10 GND 9 ANT 8 GND Figure 1. Functional Block Diagram and Pinout (Top View) Page 2 of 7 Maxscend Technologies Inc. All rights reserved. Maxscend Confidential MXD8651 – SP5T Switch for Receive Diversity Application Circuit RF2 RF1 RF1 RF2 RF3 GND RF3 V2 ANT V1 GND C1 100pF C3 C2 100pF 100pF VDD C4 100pF GND ANT RF4 V1 RF5 V2 GND V3 VDD V3 RF4 RF5 Figure 2. MXD8651 Evaluation Board Schematic Table 1. Pin Description Pin No. Nam Description e 1 V3 Control Logic #3 2 V2 Control Logic #2 3 V1 Control Logic #1 4 VDD Power supply 5 GND Ground 6 RF5 RF port5 7 RF4 RF port4 Ground GND Ground Paddle Pin No. Name Description 8 9 10 11 12 13 14 GND ANT GND RF1 RF2 RF3 GND Ground Antenna Ground RF port1 RF port2 RF port3 Ground Note: Bottom ground paddles must be connected to ground. Truth Table Table 2. Control pins V1 1 0 1 0 1 V2 0 1 1 0 0 V3 0 0 0 1 1 Switched RF Outputs RF1 Insertion Loss Isolation Isolation Isolation Isolation RF2 Isolation Insertion Loss Isolation Isolation Isolation RF3 Isolation Isolation Insertion Loss Isolation Isolation RF4 Isolation Isolation Isolation Insertion Loss Isolation RF5 Isolation Isolation Isolation Isolation Insertion Loss Note: “1” = 1.0 V to 3.0 V. “0” = 0 V to 0.3 V. Insertion loss in the V1/2/3 = 110 state is 3dB lower than typical insertion loss with only one arm “on”. Page 3 of 7 Maxscend Technologies Inc. All rights reserved. Maxscend Confidential MXD8651 – SP5T Switch for Receive Diversity Recommended Operation Range Table 3. Recommended Operation Condition Parameters Operation Frequency Power supply Switch Control Voltage High Switch Control Voltage Low Symbol Min Typ Max f1 VDD VH VL 0.1 2.5 1.0 0 2.8 1.8 0 3.0 3.3 3.0 0.3 Units Units Test Condition (Note 2) GHz V V V Specifications Table 4. Electrical Specifications Parameter Symbol Min. Specification Typical Max. DC Specifications Supply voltage VDD Supply current Control voltage: High Low Control current Switching Speed, on RF to another IDD 2.8 3.3 V 50 90 μA 3.0 0.3 5 V V μA 2 5 μs 10% to 90% RF ton 5 10 μs Time from VDD=0V to part ON and RF at 90% IL 0.40 0.40 0.50 0.50 0.55 dB dB dB dB dB 704MHz to 787MHz 815MHz to 960MHz 1710MHz to 1980MHz 2110MHz to 2170MHz 2300MHz to 2690MHz dB dB dB dB dB 704MHz to 787MHz 815MHz to 960MHz 1710MHz to 1980MHz 2110MHz to 2170MHz 2300MHz to 2690MHz VCTL_H VCTL_L ICTL Turn-on time 2.5 1.0 0 Active mode VDD must be > VCTL at all times RF Specifications Insertion Loss Insertion Loss TRx ANT Isolation Isolated TRx ports ANT ISO Harmonics (Pin =+16 dBm) Low Band, 2fo Low Band, 3fo High Band, 2fo High Band, 3fo High Band, 2fo High Band, 3fo VSWR 2fo 3fo 45 45 35 30 25 -110 dBc -105 dBc -105 dBc -100 dBc -100 dBc -100 dBc 1.1 1.5 Pin = +16dBm, 50ohms, fo=824MHz Pin = +16dBm, 50ohms, fo=824MHz Pin = +16dBm, 50ohms, fo=1980MHz Pin = +16dBm, 50ohms, fo=1980MHz Pin = +16dBm, 50ohms, fo=2570MHz Pin = +16dBm, 50ohms, fo=2570MHz 704-2690MHz Page 4 of 7 Maxscend Technologies Inc. All rights reserved. Maxscend Confidential MXD8651 – SP5T Switch for Receive Diversity Absolute Maximum Ratings Table 5. Maximum ratings Parameters Supply voltage Control voltage (V1, V2, and V3) RF input power (RF1 to RF5) Operating temperature Storage temperature Electrostatic Discharge, Human Body Model (HBM), Class 1C Symbol Minimum Maximum Units VDD 2.5 +3.3 V VCTL 0 +3.0 V +30 dBm +85 +125 ℃ ℃ 1000 V PIN TOP TSTG –20 –40 ESD Note: Exposure to maximum rating conditions for extended periods may reduce device reliability. There is no damage to device with only one parameter set at the limit and all other parameters set at or below their nominal value. Exceeding any of the limits listed here may result in permanent damage to the device Package Outline Dimension Figure 3. package outline dimension Page 5 of 7 Maxscend Technologies Inc. All rights reserved. Maxscend Confidential MXD8651 – SP5T Switch for Receive Diversity Marking Specification Product Code(Fixed): 8651 ABCD 8651 Manufacture Code(Variable): From 1~9 and A ~Z excluding letter "I" and "O" for lot tracking Pin 1 Figure 4. Marking specification (Top View) Tape and Reel Dimensions Figure 5. Tape and reel dimensions Page 6 of 7 Maxscend Technologies Inc. All rights reserved. Maxscend Confidential MXD8651 – SP5T Switch for Receive Diversity Reflow Chart tP TP Critical Zone TL to TP Ramp-up Temperature TL TSmax tL TSmin Ramp-down tS Preheat t 25 ℃ to Peak Time Figure 6. Recommended Lead-Free Reflow Profile Table 6. Reflow condition Profile Parameter Ramp-up rate(TSmax to Tp) Preheat temperature(TSmin to TSmax) Preheat time(ts) Time above TL , 217℃(tL) Peak temperature(Tp) Time within 5℃ of peak temperature(tp) Ramp-down rate Time 25℃ to peak temperature Lead-Free Assembly, Convection, IR/Convection 3℃/second max. 150℃ to 200℃ 60 - 180 seconds 60 - 150 seconds 260℃ 20 - 40 seconds 6℃/second max. 8 minutes max. ESD Sensitivity Integrated circuits are ESD sensitive and can be damaged by static electric charge. Proper ESD protection techniques should be used when handling these devices. RoHS Compliant This product does not contain lead, mercury, cadmium, hexavalent chromium, polybrominated biphenyls (PBB) and polybrominated diphenyl ethers (PBDE), and are considered RoHS compliant. Page 7 of 7 Maxscend Technologies Inc. All rights reserved. Maxscend Confidential
MXD8651 价格&库存
很抱歉,暂时无法提供与“MXD8651”相匹配的价格&库存,您可以联系我们找货
