VL102-Q4
VL102-Q4
    VIA(威盛)
    QFN-48-EP(6x6)
    类型:-;协议类别:-;驱动器/接收器数:-;数据速率:-;
VL102-Q4 数据手册
Datasheet VL102 DP Alt-mode & PD 3.0 Controller for USB-C Devices Oct 18th, 2016 Revision 0.8 -1- VL102 DP Alt-mode & PD 3.0 Controller for USB-C Devices Revision History Rev Date Note 0.70 06/29/2016 Preliminary release HC 0.80 10/18/2016 Convert to VLI latest datasheet format HC -2- Initial VL102 DP Alt-mode & PD 3.0 Controller for USB-C Devices Contents Revision History ....................................................................................................................... 2 Table of Contents ..................................................................................................................... 3 List of Figures .......................................................................................................................... 3 List of Tables ........................................................................................................................... 3 Product Features ...................................................................................................................... 4 VL102 System Overview ........................................................................................................... 5 Typical Applications .................................................................................................................. 6 Pinout .................................................................................................................................... 7 Pin List ................................................................................................................................... 8 Pin Descriptions ....................................................................................................................... 9 Signal Type Definition................................................................................................... 9 USB-C Interface ............................................................................................................ 9 USB Billboard Interface ................................................................................................ 9 USB2.0 Interface .......................................................................................................... 9 DP Alt-mode Interface ................................................................................................ 10 SPI Interface .............................................................................................................. 10 Analog Command Block .............................................................................................. 10 General Purpose I/O and Miscellaneous ..................................................................... 11 Test Pin ...................................................................................................................... 11 Power and Ground ...................................................................................................... 11 Electrical Specification ............................................................................................................ 12 Package Mechanical Specifications ........................................................................................... 14 Package Top Side Marking ....................................................................................................... 15 Ordering Information.............................................................................................................. 15 List of Figures Figure Figure Figure Figure Figure Figure 1 2 3 4 5 6 – – – – – – VL102 Block Diagram ........................................................................................... 5 VL102 USB-C Video Adapters with Hub and PD Charging-Thru ............................. 6 VL102R USB-C Multi-function Dock ...................................................................... 6 VL102 QFN-48 Pin Diagram .................................................................................. 7 QFN 48L 6x6x0.85 mm Mechanical Specification ................................................ 14 VL102 Package Top Side Marking ....................................................................... 15 List of Tables Table 1 – VL102 QFN-48 Pin List .......................................................................................... .8 -3- VL102 DP Alt-mode & PD 3.0 Controller for USB-C Devices Product Features VL102 DisplayPort Alt-mode & PD 3.0 Controller for USB-C Devices  CC Logic & PD Engine supporting one charging UFP and one DRP – Compliant to USB Type-C Cable and Connector Specification Revision 1.2 – Compliant to USB Power Delivery Specification Revision 3.0 Version 1.0a – Integrated Type-C transceivers, supporting one charging UFP and one DRP – Built-in pull-up/pull down resistors, including Rp, Rd, and Ra – Built-in Vconn power switch  DP Alt-mode Configuration – Compliant to VESA DisplayPort Alt Mode on USB Type-C Standard Version 1.0a – DP mode Discovery/Enter/Exit – DP configure, status update, source/sink connection detection – Built-in Aux_CH switch  USB-C Charging UFP Capability – Charging connected PD hosts once external power is available – Support Provider and Consumer roles – Support PD Power Rule up to 100W – Support charging dead battery and Fast Role Swap  USB-C DRP Capability – Support Provider and Consumer roles – Support PD Power Rule up to 100W as Sink and 15W as Source – Built-in D+/D- Charging ePHY for chargers using D+/D- as protocol handshake – Built-in USB HS data switch  USB Billboard Device & USB C-Bridge – Compliant to USB Device Class Definition for Billboard Devices Revision 1.1 – Compliant to USB Type-C Bridge Spec Revision 1.0 RC – Integrated in-house USB2.0 PHY  Fast 8051 Macro cell 80C32-Compatible Microcontroller – Standard 1T 8051 instruction set – Embedded Mask ROM and SRAM – Support external SPI flash for firmware upgrade Built-in Voltage Regulators, Voltage Detector, and Current Detector  – 5.0V to 3.3V LDO & 3.3V to 1.8V LDO – Auto power source selection between Vbus and Vconn – Vbus Voltage Detector and Vbus Current Detector for power monitoring  GPIOs for Special Function and Control – 9 GPIOs for application customization and one I2C master interface  Physical – QFN 48 green package (6x6x0.85 mm)  Certification – TBD  – – Applications USB-C video adapters USB-C Multi-function docks -4- VL102 DP Alt-mode & PD 3.0 Controller for USB-C Devices VL102 System Overview VIA Lab’s VL102 is a highly integrated single chip DisplayPort Alternate mode and Power Delivery 3.0 controller for USB-C devices that designed for applications like USB-C video adapters and USB-C multi-function docking stations. Integrated USB-C charging UFP, VL102 can perform DP alt-mode video out functionality and simultaneously enable charging connected PD host once external power is detected. Integrated USB-C DRP can either connect to USB-C power adapter to charge PD host or connect to USB-C devices to do data transfer. A D+/D- charging ePHY is integrated to support chargers using D+/D- to do protocol handshake. VL102’s Device Policy Manager could negotiate power rules between its DRP and UFP then enable power charging-through. Charging a host under dead battery mode and fast role swap are supported. SBU1/SBU2 switch is built-in to support USB-C cable flipping feature. USB Billboard device and USB-C bridge function are implemented to meet “VESA DP Alt-Mode on USB Type-C” spec and let the USB host to communicate with PD products connected on downstream port. Built-in required linear voltage regulators, Vbus voltage detector, and Vbus current detector, VL102 can work perfectly with power input either from Vconn power or from Vbus power and can monitor abnormal power behavior. Up to 9 GPIO pins are available for power discharge control, power switch control, data switch control, or other special application usage. The SPI interface can support external flash for firmware upgrades through USB Billboard device. VL102 is available in QFN 48L (6x6x0.85 mm) green packages to fit small form-factor design. Figure 1 – VL102 Block Diagrm -5- VL102 DP Alt-mode & PD 3.0 Controller for USB-C Devices Typical Applications Figure 1 – VL102 USB-C Video Adapters with Hub and PD Charging-Thru Figure 2 – VL102R USB-C Multi-function Dock -6- VL102 DP Alt-mode & PD 3.0 Controller for USB-C Devices Pinout Figure 3 – VL102 QFN-48 Pin Diagram -7- VL102 DP Alt-mode & PD 3.0 Controller for USB-C Devices Pin List Pin Pin Name Pin Pin Name 1 VDD5IN 25 DM_IN 2 CC1_D 26 DM_OUT 3 CC2_D 27 DP_OUT 4 ODV5DP 28 DM_U 5 AUXP 29 DP_U 6 AUXN 30 VCC33 7 HPD 31 GPIO9 8 SBU1 32 GPIO8 9 SBU2 33 GPIO7 10 CC2_U 34 GPIO6 11 CC1_U 35 GPIO5 12 VBUS_DET2 36 GPIO3 13 VBUS_DET1 37 VDD5V 14 REXT 38 VCC33 15 VCONNIN33 39 GPIO4 16 LDOVDD5 40 DVCC18 17 LDOVDD33O 41 GPIO1 18 OSCVDD18O 42 GPIO2 19 OSCXI 43 RESET_ 20 OSCXO 44 TESTEN 21 BOOST_VTRL 45 SPI_CS_ 22 CS_N 46 SPI_Q 23 CS_P 47 SPI_CLK 24 DP_IN 48 SPI_D Table 1 – VL102 QFN-48 Pin List -8- VL102 DP Alt-mode & PD 3.0 Controller for USB-C Devices Pin Descriptions Signal Type Definition Name Type Input I A standard input-only signal O A standard active driver Output Input/Output I/O Analog bias ABIAS Signal Description Power PWR A bi-directional signal Analog bias or reference signal. Must be tied to external resistor and/or capacitor bias network A power pin Ground GND A ground pin USB-C Interface Pin Name QFN48 I/O Signal Description CC1_U 11 I/O Charging UFP Configuration Channel 1 CC2_U 10 I/O Charging UFP Configuration Channel 2 CC1_D 2 I/O DRP Port Configuration Channel 1 CC2_D 3 I/O DRP Port Configuration Channel 2 SBU1 8 I/O Sideband Use 1 SBU2 9 I/O Sideband Use 2 QFN48 I/O Signal Description DP_U 29 I/O D+ Data Line to USB Billboard Device DM_U 28 I/O D– Data Line to USB Billboard Device QFN48 I/O Signal Description DP_IN 24 I/O D+ Data Line Connect to Downstream Facing Port DM_IN 25 I/O D– Data Line Connect to Downstream Facing Port DP_OUT 27 I/O D+ Data Line Connect to Upstream Facing Port DM_OUT 26 I/O D– Data Line Connect to Upstream Facing Port USB Billboard Interface Pin Name USB2.0 Interface Pin Name -9- VL102 DP Alt-mode & PD 3.0 Controller for USB-C Devices DP Alt-mode Interface Pin Name QFN48 I/O Signal Description AUXP 5 I/O DP AUX Channel Positive AUXN 6 I/O DP AUX Channel Negative HPD 7 I QFN48 I/O SPI_CS_ 45 O Serial Flash Chip Enable SPI_D 48 O Serial Flash Data Input SPI_Q 46 I Serial Flash Data Output SPI_CLK 47 O Serial Flash Clock DP Hot Plug Detect SPI Interface Pin Name Signal Description Analog Command Block Pin Name QFN48 I/O Signal Description OSCXI 19 I 24MHz Crystal Input OSCXO 20 O REXT 14 ABIAS 24MHz Crystal Output Connect to External Resistor (20.5K ohm, +/- 1% accuracy) LDOVDD5 16 PWR 5V Input for 5V-to-3.3V LDO LDOVDD33O 17 PWR 3.3V Output Pin for 5V-to-3.3V LDO OSCVDD18O 18 PWR Analog 1.8V Power Output VCONNIN33 15 PWR 3.3V Vconn Power Input VBUS_DET1 13 I USB-C Charging UFP VBus Voltage Detector VBUS_DET2 12 I USB-C DRP Vbus Voltage Detector CS_P 23 I Current Sensing Positive Input CS_N 22 I Current Sensing Negative Input BOOST_VTRL 21 I Boost Voltage Control Input VDD5IN 1 PWR ODV5DP 4 O 5V Power Input for Vconn Power Output Open-Drain IO for 5V Video Power Control - 10 - VL102 DP Alt-mode & PD 3.0 Controller for USB-C Devices General Purpose I/O and Miscellaneous Pin Name QFN48 I/O Signal Description RESET_ 43 I External Chip Reset GPIO1 41 I/O General Purpose I/O GPIO2 42 I/O General Purpose I/O GPIO3 36 I/O General Purpose I/O GPIO4 39 I/O General Purpose I/O GPIO5 35 I/O General Purpose I/O GPIO6 34 I/O General Purpose I/O GPIO7 33 I/O General Purpose I/O GPIO8 32 I/O General Purpose I/O GPIO9 31 I/O General Purpose I/O QFN48 I/O Signal Description 44 I QFN48 I/O Signal Description VDD5V 37 PWR E-fuse Power Input, Connecting to 3.3V in Normal Use VCC33 30, 38 PWR Digital 3.3V IO Power Input 40 PWR Digital 1.8V Core Power Input Test Pin Pin Name TESTEN Test Mode Enable; Internal pull down Do not connect for normal operation. Power and Ground Pin Name DVCC18 - 11 - VL102 DP Alt-mode & PD 3.0 Controller for USB-C Devices Electrical Specification Absolute Maximum Ratings Symbol Parameter Min Max Unit Note TSTG Storage Temperature -55 125 °C — VDD33 3.3V Power Input Voltage -0.5 3.69 V — VDD50 5V Power Input Voltage -0.5 5.5 V — VO Output Voltage at any output -0.5 VCC+ 0.5 V — kV Human Body Model VESD Electrostatic Discharge -2 2 Note: Stress above conditions may cause permanent damage to the device. Functional operation of this device should be restricted to the conditions described. Recommended Operating Conditions Symbol Parameter Min Typ Max Unit LDOVDD5 5V to 3.3V LDO 5V Power Input 4.5 5 5.5 V VCONNIN33 3.3V Vconn power input 3.0 3.3 3.6 V VCC33 Digital IO power 3.3V 3.0 3.3 3.6 V DVCC18 Digital Core power 1.8V 1.62 1.8 1.98 V DGND Ground — 0 — V TA Ambient Temperature 0 70 °C General IO DC Characteristics Symbol Parameter Min Max Unit Note VIL Input Low Voltage -0.30 0.8 V — VIH Input High Voltage 2.0 3.6 V — VOL Output Low Voltage — 0.4 V IOL=15.8mA VOH Output High Voltage 2.4 — V IOH=26.5mA IIL Input Leakage Current — +/-10 µA 0
VL102-Q4 价格&库存
很抱歉,暂时无法提供与“VL102-Q4”相匹配的价格&库存,您可以联系我们找货
