NPCP215FA0YX
NPCP215FA0YX
    NUVOTON(新唐)
    QFN48_7X7MM_EP
    20W立体声D类音频功率放大器
NPCP215FA0YX 数据手册
January 2014 Revision 2.0 NPCP215x Audio Enhancing Engine and Power Amplifier Family General Description Outstanding Features The Nuvoton NPCP215x device is a member of Nuvoton’s Audio Enhancing family optimized for consumer electronics applications. The NPCP215x integrates MaxxAudio-3, an audio enhancement suite of algorithms designed by Waves The algorithm suite uses advanced methods, based on psycho-acoustics, to provide a full, rich, exciting and immersive sound, even from slim speakers, limited power amplifiers and other acoustic restrictions that are commonly found in modern consumer electronics devices. ■ Improves audio quality for low-performance speakers ■ System-level BOM savings ■ Stereo or Stereo + Sub-woofer operation ■ I2C controlled ■ 24-bit accuracy ■ Audio algorithms — MAXXBASS ® — — MAXXTREBLE — MAXXEQ — MAXXVOLUME — MAXXLEVELER — MAXXDIALOG ® ■ Audio input: up to four I2S or Synchronous Serial Interface (SSI) inputs ■ Audio output: — Up to three I2S or SSI outputs — Class-D Power output up to 2 x 20W — 2.1 way power output up to 2 x 10W + 20W (internal generation of sub-woofer) ■ 100 dB SNR ■ Typical power efficiency of 90% ■ Various protection sensors ■ Several General-Purpose digital signals available to the application (GPIOs) ■ Logic supply of 3.3V and Power supply up to 26.4V ■ 7 x 7 mm, 48-pin Quad Flat No-Lead (QFN) package System Block Diagram Speakers I2S LC Filters 4 Audio System Controller I2C (Control) Optional Sub-Woofer NPCP215x 3 I2S Outputs GPIOs MUTE © 2014 Nuvoton Technology Corporation www.nuvoton.com NPCP215x Audio Enhancing Engine and Power Amplifier Family Product Brief NPCP215x Features Bus Interfaces ■ ■ — MaxxLeveler regulates the perceived volume of the audio, keeping all audio content at the same level. ■ MaxxDialog Synchronous Serial Interface (SSI) — Compatible with I2S ■ I2C Interface — MaxxDialog is a revolutionary new technology that enables users to adjust center channel dialog levels without affecting the rest of the audio mix. Based on the Waves Center pro audio plug-in, MaxxDialog delivers clear, crisp dialog that does not disappear behind loud music and effects. ■ Sub-Woofer — Compliant with I2C-BUS Specification Revision 1.0, 1992 — Master or slave interface — Supports 7-bit address mode Audio Enhancing Engine ■ — Enables separating low-frequency content and directing it into a third audio channel, for driving a subwoofer. Processing Unit — 24-bit — 125 MIPs Power Amplifier Audio Algorithms ■ ■ MaxxBass ■ — Patented Waves MaxxBass psycho-acoustic bass extension delivers a more natural sound than traditional bass boost technologies, which use EQ and can overpower your system. MaxxBass analyzes low frequencies to create harmonics that are perceived as lower, deeper tones. ■ Maxx3D ■ ■ ■ ■ — Maxx3D extends the span of stereo-side content while maintaining the integrity of unprocessed center content. — Maxx3D improves the stereo separation of speakers, widening the stereo field for optimal imaging. ■ MaxxTreble Class-D Power up to 2 x 20W to 6 or 8 (0.5% THD) 2.1 way power output up to 2 x 10W + 20W (internal generation of sub-woofer) Typical power efficiency of 90% 100 dB SNR Less than 0.4% THD at 1W Protection: — Over-current — Under-voltage — Over-temperature Straps, Clocks, Supply and Package Information ■ — MaxxTreble delivers crystal clear high-frequency enhancement for increased RMS without exceeding the system ceiling. Its proprietary algorithm restores luster to over-compressed formats to provide the perfect listening experience. ■ MaxxEQ Strap Input Controlled Operating Modes — PLL reference clock select (REF strap) — Test mode select (nTEST strap) — I2C master or slave select (I2CMS strap) — Boot options ❏ ROM code operation ❏ — MaxxEQ provides the ability to design EQ curves and shape sound with surgical precision, using up to 20 programmable filters with bell, shelf, low pass, and high pass, plus adjustable frequency, gain, and Q parameters. MaxxEQ’s intuitive Graphic User Interface makes click-and-drag filter design fast and easy. ■ MaxxVolume Loadable algorithms for new functions or ROM code patching ■ Input Clocks — SSI / I2S clock: 1 MHz - 5 MHz input — Optional crystal oscillator or input clock ■ Power Supply — 3.3V Logic supply — 9V to 26.4V Power supply ■ Power-Save Modes — Power-down of less than100 mW — Power stage shut down ■ Package — 7 x 7 mm, 48-pin Quad Flat No-Lead (QFN) package — MaxxVolume is an all-in-one volume control, with High-Level Compression to increase RMS levels, Low-Level Compression to increase the clarity of soft sounds, Noise Gating to eliminate signal and system noise, and Leveling to smooth out volume levels. It includes: ❏ Leveler - (replaces traditional AGC) ❏ Low-level gain ❏ Dynamic range curve controller ❏ Noise gate www.nuvoton.com MaxxLeveler 2 Revision 2.0 NPCP215x Features (Continued) Derivative Table Algorithms I2S Package Stereo Inputs Output Power Maxx 3D SubMaxx Maxx Maxx Maxx Maxx & Maxx Woofer Bass EQ Treble Volume Leveler Dialog Support Product ID NPCP215F 0011 QFN48 4 2x20W or 2x10W + 20W   NPCP215B 0010 QFN48 4 2x20W or 2x10W + 20W         Algorithm Processing Chain Maxx Bass Revision 2.0 Maxx 3D Maxx Dialog Maxx Treble 3 Maxx EQ Leveler Maxx Volume www.nuvoton.com I2S 4x I2S inputs www.nuvoton.com SDI3 SDI2 SDI1 SDI0 4 + + Note: All paths in the diagram are stereo except otherwise stated. M8 M7 M6 M5 M4 M3 M2 M1 M[1..8] = -inf .. 18 dB Bypass Sub-Woofer Out + + + + In mode 2.0, M15 Is forced to 0. In Mode 2,.1 M16 and M17 are forced to 0. M15 M16 M17 M14 M11 M13 M10 M12 M9 Device Audio Path Block Diagram Note: Sub-Woofer Out appears on both left and right. Audio Engine Processing Path Stereo Out M[9..17] = -inf .. 0 dB SDO3 PWM 2x PWM Note: The sub-woofer PWM generation is mono. 1x Sample Rate Converter 2x Sample Rate Converter SDO2 SDO1 SDO0 I2S PWMSW PWML, PWMR 3x I2S outputs NPCP215x Features (Continued) Revision 2.0 NPCP215x QFN48 Physical Dimensions Control dimensions are in millimeters. 48-Pin Quad Flat No-Lead (QFN) Package Order Number: NPCP215BA0YX or NPCP215FA0YX Device topside mark specification: 1st Line: 2nd Line: 3rd Line: 4th Line: Nuvoton Company Logo. Part number - NPCP215xA0YX (x is B or F) (‘Y’: QFN package number; ‘X’: Green package finish indicator.) Assembly Lot Number - XXXXXXXXXXX. Tracking code - YWWXXXX, where YWW is the Date Code and XXXX is Nuvoton proprietary information. NPCP215xA0YX XXXXXXXXXXX YWWXXXX Date code: YWW, where Y is the year and WW is the week. For example, date code 235 indicates that device assembly was done on week 35, year 2012. Revision 2.0 5 www.nuvoton.com NPCP215x Audio Enhancing Engine and Power Amplifier Family Important Notice Nuvoton products are not designed, intended, authorized or warranted for use as components in systems or equipment intended for surgical implantation, atomic energy control instruments, airplane or spaceship instruments, transportation instruments, traffic signal instruments, combustion control instruments, or for other applications intended to support or sustain life. Furthermore, Nuvoton products are not intended for applications wherein failure of Nuvoton products could result or lead to a situation wherein personal injury, death or severe property or environmental damage could occur. Nuvoton customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify Nuvoton for any damages resulting from such improper use or sales. Headquarters No. 4, Creation Rd. 3, Science-Based Industrial Park, Hsinchu, Taiwan, R.O.C TEL: 886-3-5770066 FAX: 886-3-5665577 http://www.nuvoton.com.tw (Chinese) http://www.nuvoton.com (English) Nuvoton Technology Corporation America 2727 North First Street, San Jose, CA 95134, U.S.A. TEL: 1-408-544-1718 FAX: 1-408-544-1787 Nuvoton Technology (Shanghai) Ltd. 27F, 2299 Yan An W. Rd. Shanghai, 200336 China TEL: 86-21-62365999 FAX: 86-21-62365998 Taipei Office 9F, No.480, Rueiguang Rd., Neihu District, Taipei, 114, Taiwan, R.O.C. TEL: 886-2-2658-8066 FAX: 886-2-8751-3579 Winbond Electronics Corporation Japan NO. 2 Ueno-Bldg., 7-18, 3-chome Shinyokohama Kohoku-ku, Yokohama, 222-0033 TEL: 81-45-4781881 FAX: 81-45-4781800 Nuvoton Technology (H.K.) Ltd. Unit 9-15, 22F, Millennium City 2, 378 Kwun Tong Rd., Kowloon, Hong Kong TEL: 852-27513100 FAX: 852-27552064 For Advanced PC Product Line information contact: APC.Support@nuvoton.com Please note that all data and specifications are subject to change without notice. All trademarks of products and companies mentioned in this document belong to their respective owners. www.nuvoton.com
NPCP215FA0YX 价格&库存
很抱歉,暂时无法提供与“NPCP215FA0YX”相匹配的价格&库存,您可以联系我们找货
NPCP215FA0YX
  • 1+37.72930
  • 100+20.96070
