SF58G
SF58G
    DY(迪一电子)
    DO-27(DO-201AD)
    SF58G
SF58G 数据手册
SF51G THRU SF58G 5 .0 AMPS. Glass Passivated Super Fast Rectifiers Features · Low forward voltage drop DO-201AD · High current capability · High reliability · High surge current capability · Plastic material-UL flammability 94V-0 0.96(24.5) MIN. Mechanical Data DIA. · Case: Molded plastic DO-201AD · Terminals: Plated leads solderable per MIL-STD-202,Method 208 guaranteed · Polarity: Color band dentes cathode end 0.96(24.5) DIA. · Mounting Position: Any MIN. · Making: Type Number · Lead Free: For RoHS/Lead Free Version Dimensions in inches and (millimeters) Maximum Ratings and Electrical Characteristics Rating at 25℃ ambient temperature unless otherwise specified Single phase,half wave,60Hz,resistive or inductive load For capacitive load derate current by 20% Type Number SYMBOL SF51G SF52G SF53G SF54G SF55G SF56G SF58G Unit Maximum Recurrent Peak Reverse Voltage VRRM 50 100 150 200 300 400 600 V Maximum RMS Voltage VRMS 35 70 104 140 210 280 420 V Maximum DC Blocking Voltage VDC 50 100 150 200 300 400 600 V Maximum Average Forward Rectified Current.375"(9.5mm) lead length@TL =100℃ Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) I2t Rating for Fusing (t < 8.3ms) Forward Voltage @IF=5.0A Peak Reverse Current IF(AV) 5.0 A IFSM 150 A I 2t 93.375 A2s V VFM 1.30 0.95 5.0 @TA=25℃ 100 At Rated DC Blocking Voltage @TA=125℃ 1.7 uA Typical Junction Capacitance (Note 1) CJ 45 pF Typical Thermal Resistance Junction to Ambient(Note 2) RθJA 25 ℃ /W Maximum Reverse Recovery Time(Note 3) Trr 35 ns Operating Temperature Range TJ -55 to +150 ℃ TSTG -55 to +150 ℃ /Storage Temperature Range Note:1. Measured at 1.0 MHz and Applied reverse Voltage of 4.0V D.C 2. Leads maintained at ambient temperature at a distance of 9.5mm from the case 3.Reverse Recovery Test Conditions: IF=0.5A, IR=1A, Irr=0.25A version:02 1of3 www.dyelec.com SF51G THRU SF58G FIG.2-TYPICAL FORWARD CHARACTERISTICS 3.0 2.0 1.0 0 25 75 50 100 125 150 175 SF 54 G 10 3. 0 SF 58 G 4.0 -S F5 6G 5.0 50 SF 55 G 6.0 SF 51 G- INSTANTANEOUS FORWARD CURRENT,(A) AVERAGE FORWARD CURRENT ( A ) FIG. 1 – FORWARD CURRENT DERATING CURVE 1.0 TA =25 C 0.1 Pulse Width 300us 1% Duty Cycle O LEAD TEMPERATURE( C) 01 .4 .6 .8 1.0 1.2 1.4 1.6 1.8 INSTANTANEOUS FORWARD VOLTAGE (V) , FIG.4 – TYPICAL JUNCTION CAPACITANCE FIG. 3 – MAXIMUM NON-REPETITIVE SURGE CURRENT 200 150 CAPACITANCE, (pF) PEAK FORWARD SURGE CURRENT, ( A ) 200 100 50 PULSE WIDTH 8.3mS SINGLE HALF-SINE-WAVE (JEDEC METHOD) 100 T J = 25°C f = 1 MHz 0 1 2 5 10 20 50 100 NUMBER OF CYCLES AT 60Hz 10 1 4 10 REVERSE VOLTAGE ( V ) version:02 2of3 www.dyelec.com 100 SF51G THRU SF58G Important Notice and Disclaimer •Reproducing and modifying information of the document is prohibited without permission from DIYI. • DIYI reserves the right to make changes to this document and its products and specifications at any time without notice. Customers should obtain and confirm the latest product information and specifications before final design, purchase or use. •DIYI disclaims any and all liability arising out of the application or use of any product including damages incidentally and consequentially occurred. •DIYI does not assume any and all implied warranties, including warranties of fitness for particular purpose, non-infringement and merchantability. Applications shown on the here in document are examples of standard use and • operation. Customers are responsible in comprehending the suitable use in particular applications. DIYI makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. •The products shown here in are not designed and authorized for equipments requiring high level of reliability or relating to human life and for any applications concerning life-saving or life-sustaining, such as medical instruments, transportation equipment, aerospace machinery et cetera. Customers using or selling these products for use in such applications do so at their own ris k andagree to fully indemnify DIYI for any damages resulting from such improper use or sale. •Since DIYI uses lot number as the tracking base, please provide the lot number for tracking when complaining. version:02 3of3 www.dyelec.com
SF58G 价格&库存
很抱歉,暂时无法提供与“SF58G”相匹配的价格&库存,您可以联系我们找货
