PES1AF-PES1JF
Silicon Rectifiers
Feature
¾
For surface mounted applications
¾
Low profile package
¾
Glass Passivated Chip Juntion
¾
Superfast reverse recovery time
¾
Lead free in comply with EU RoHS 2011/65/EU directives
Mechanical Characteristics
¾
Case: SMAF
¾
Terminals: Solderable per MIL-STD-750, Method 2026
¾
Approx. Weight: 27mg 0.00086oz
Absolute maximum rating@25℃
PES1
PES1
PES1
PES1
PES1
PES1
PES1
AF
BF
CF
DF
EF
GF
JF
VRRM
50
100
150
200
300
400
600
V
Maximum RMS voltage
VRMS
35
70
105
140
210
280
420
V
Maximum DC Blocking Voltage
VDC
50
100
150
200
300
400
600
V
Parameter
Maximum Repetitive Peak Reverse
Voltage
Maximum Average Forward Rectified
Current at Ta =100 °C
Symbol
Units
IF(AV)
1
A
IFSM
30
A
Peak Forward Surge Current 8.3 ms
Single Half
Sine Wave Superimposed on Rated Load
(JEDEC Method)
Maximum Forward Voltage at 1 A
Maximum DC Reverse Current Ta=25 °C
at Rated DC Blocking Voltage Ta=125 °C
Typical Junction Capacitance
at VR=4V, f=1MHz
Maximum Reverse Recovery Time
at IF=0.5A, IR=1A, Irr=0.25A
Operating and Storage Temperature
Range
Rev.06.0
VF
1
1.25
5
IR
100
1.7
V
μA
Cj
10
pF
trr
35
nS
Tj, Tstg
-55 ~ +150
°C
1
www.prisemi.com
Silicon Rectifiers
PES1AF-PES1JF
Typical Characteristics
50 ohm
Noninductive
10 ohm
Noninductive
t rr
+0.5
D.U.T
PULSE
GENERATOR
Note 2
25Vdc
approx
1 ohm
OSCILLOSCOPE
Note 1
NonInductive
-1.0
Note:1.Rise Time = 7ns, max.
Input Impedance = 1megohm,22pF.
2. Ries Time =10ns, max.
Source Impedance = 50 ohms.
10ns/div
Set time Base for 10ns/div
1.2
300
1.0
100
I R - Reverse Current ( μ A)
Average Forward Current (A)
Fig.1 Reverse Recovery Time Characteristic And Test Circuit Diagram
0.8
0.6
0.4
0.2
Single phase half wave resistive
or inductive P.C.B mounted on
0.315×0. 315"(8.0×8. 0mm )
pad areas
T J =125°C
10
T J =75°C
1.0
T J =25°C
0.1
0.0
25
50
75
100
125
150
175
Lead Temperature (°C)
100
Fig.3 Typical Reverse Characteristics
14
10
T J =25°C
Junction Capacitance ( pF)
Instaneous Forward Current (A)
80
60
% of PIV.VOLTS
Fig.2 Maximum Average Forward Current Rating
PES1AF
1.0
PES1EF
PES1JF
0.1
0.01
0.001
0.4
0.6
0.8
1.0
1.2 1.4
12
10
8
6
T J =25°C
f = 1.0MHz
V sig = 50mV p-p
4
2
0.1
Instaneous Forward Voltage (V)
1
10
100
Reverse Voltage (V)
Fig.5 Typical Junction Capacitance
Fig.4 Typical Forward Characteristics
Rev.06.0
40
www.prisemi.com
Silicon Rectifiers
PES1AF-PES1JF
Solder Reflow Recommendation
Peak Temp=257℃, Ramp Rate=0.802deg. ℃/sec
280
240
200
160
120
80
40
60
90
120
150
180
210
240
270
300
330
360
390
420
450
480
Time (sec)
Product dimension (SMAF)
Rev.06.0
3
www.prisemi.com
Silicon Rectifiers
PES1AF-PES1JF
The recommended mounting pad size
1.6
(63)
2.8
(110)
1.6
(63)
1.8
____
(71)
Unit:
mm
___
(mil)
Ordering information
Device
Package
Shipping
PES1AF-PES1JF
SMAF (Pb-Free)
5000/ Tape & Reel
Rev.06.0
4
www.prisemi.com
Silicon Rectifiers
PES1AF-PES1JF
IMPORTANT NOTICE
and
are registered trademarks of Prisemi Electronics Co., Ltd (Prisemi) ,Prisemi
reserves the right to make changes without further notice to any products herein. Prisemi makes
no warranty, representation or guarantee regarding the suitability of its products for any particular
purpose, nor does Prisemi assume any liability arising out of the application or use of any
product or circuit, and specifically disclaims any and all liability, including without limitation
special, consequential or incidental damages. “Typical” parameters which may be provided in
Prisemi data sheets and/or specifications can and do vary in different applications and actual
performance may vary over time. All operating parameters, including “Typicals” must be
validated for each customer application by customer’s technical experts. Prisemi does not
convey any license under its patent rights nor the rights of others. The products listed in this
document are designed to be used with ordinary electronic equipment or devices, Should you
intend to use these products with equipment or devices which require an extremely high level of
reliability and the malfunction of with would directly endanger human life (such as medical
instruments, aerospace machinery, nuclear-reactor controllers, fuel controllers and other safety
devices), please be sure to consult with our sales representative in advance.
Website: http://www.prisemi.com
For additional information, please contact your local Sales Representative.
©Copyright 2009, Prisemi Electronics
is a registered trademark of Prisemi Electronics.
All rights are reserved.
Rev.06.0
5
www.prisemi.com
很抱歉,暂时无法提供与“PES1JF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.10582
- 200+0.07099
- 600+0.04991
- 3000+0.04451
- 9000+0.03986
- 21000+0.03731
