SYN510R
SYN510R
    SYNOXO
    SOP-16
    300 - 450MHZ ASK接收器
SYN510R 数据手册
SYN500R Datasheet (300-450MHz ASK Receiver) Version 1.0 Contents 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. General Description ................................................................................................................ 1 Features .................................................................................................................................... 1 Applications ............................................................................................................................. 1 Typical Application ................................................................................................................. 2 Pin Configuration .................................................................................................................... 2 Pin Description ........................................................................................................................ 3 Absolute Maximum Ratings (Note 1) .................................................................................... 4 Operating Ratings (Note 2) .................................................................................................... 4 Electrical Characteristics (Note 4) ......................................................................................... 4 Typical Characteristics ........................................................................................................... 7 10.1. Sensitivity Graphs ..................................................................................................... 7 Functional Diagram ................................................................................................................ 8 Functional Description............................................................................................................ 8 Receiver Operation ................................................................................................................. 8 13.1. LNA .......................................................................................................................... 8 13.2. Mixers and Synthesizer ............................................................................................. 8 13.3. Image Reject Filter and Band-Pass Filter .................................................................. 9 13.4. OOK Demodulator .................................................................................................... 9 13.5. Detector and Programmable Low-Pass Filter ........................................................... 9 13.6. Slicer, Slicing Level ................................................................................................ 10 13.7. AGC Comparator .................................................................................................... 10 13.8. Reference Control ................................................................................................... 10 13.9. Reference Oscillator ................................................................................................ 10 Applications Information ..................................................................................................... 11 Package Information............................................................................................................. 18 SYN500R/SYN510R/SYN520R 1. General Description The SYN500R is a general purpose, 3V-5.5V ASK Receiver that operates at 300-450MHz with typical sensitivity of -109dBm. The SYN500R functions as a super-heterodyne receiver for OOK and ASK modulation up to 10kbps. The down-conversion mixer also provides image rejection. All post-detection data filtering is provided on the SYN500R. Any one-of-four filter bandwidths may be selected externally by the user in binary steps, from 1.25KHz to 10KHz. The user need only configure the device with a set of easily determined values, based upon data rate, code modulation format, and desired duty-cycle operation. SYN510R is the SOP16 package version. SYN520R is the SOP8 package version. 2. Features         –109 dBm sensitivity, 1kbps and BER 10E-02 Frequency from 300MHz to 450MHz Supply Voltage from 3V to 5.5V Image Rejection Mixer Data-rate up to 10kbps (fixed-mode) Low power, 6.0mA, 3.3V @ 433.92MHz, 3.9mA, 3.3V @315MHz, continuous on data rates to 10kbps (Manchester Encoded) Analog RSSI Output No IF filter required Excellent selectivity and noise rejection 3. Applications     Automotive Remote Keyless Entry (RKE) Remote controls Remote fan and light control Garage door and gate openers *This specification is subject to change without notification. -1- SYN500R/SYN510R/SYN520R 4. Typical Application 433.92MHz 1K Baud Rate Example 5. Pin Configuration SYN500R SSOP16 and SYN510R SOP16 SYN520R SOP8 *This specification is subject to change without notification. -2- SYN500R/SYN510R/SYN520R 6. Pin Description SSOP16 Pin Name Pin Function 1 RO1 Reference resonator input connection to Colpitts oscillator stage. May also be driven by external reference signal of 1.5V p-p amplitude maximum. 2 GNDRF 3 ANT 4 GNDRF 5 VDD 6 NC Negative supply connection associated with ANT RF input. RF signal input from antenna. Internally AC coupled. It is recommended that a matching network with an inductor -to-RF ground is used to improve ESD protection. Negative supply connection associated with ANT RF input. Positive supply connection for all chip functions. Not Connected (Floating) 7 SEL0 Logic control input with active internal pull-up. Used in conjunction with SEL1 to control the demodulator low pass filter bandwidth. (See filter table for SEL0 and SEL1 in application section) 8 SHDN Shutdown logic control input. Active internal pull-up. 9 GND Negative supply connection for all chip functions except RF input. 10 DO Demodulated data output. SEL1 Logic control input with active internal pull-up. Used in conjunction with SEL0 to control the demodulator low pass filter bandwidth. (See filter table for SEL0 and SEL1 in application section) 12 CTH Demodulation threshold voltage integration capacitor connection. Tie an external capacitor across CTH pin and GND to set the settling time for the demodulation data slicing level. Values above 1nF are recommended and should be optimized for data rate and data profile. 13 CAGC 14 RSSI 15 NC Not Connected (Connect to Ground) 16 RO2 Reference resonator input connection to Colpitts oscillator stage, a 18pF capacitor is connected from this pin to GND during normal operation. 11 AGC filter capacitor connection. CAGC capacitor, normally greater than 0.47µF, is connected from this pin to GND Received signal strength indication output. with 200Ω typical output impedance. *This specification is subject to change without notification. Output is from a buffer -3- SYN500R/SYN510R/SYN520R 7. Absolute Maximum Ratings (Note 1) Supply Voltage (VDD) +7V Input Voltage +7V +150°C Junction Temperature (TJ) Storage Temperature Range (TS) –65°C to +150°C Lead Temperature (soldering, 10 sec.) +260°C Maximum Receiver Input Power +10dBm Note 3 ESD Rating 8. Operating Ratings (Note 2) RF Frequency Range 300MHz to 450MHz Supply Voltage (VDD) +3.0V to +5.5V Input Voltage (VIN). 5.5V (Max) Maximum Input RF Power –20dBm Ambient Temperature (TA) –30°C to +85°C 9. Electrical Characteristics (Note 4) Specifications apply for 3.0V < VDD < 5.5V, VSS = 0V, CAGC = 4.7µF, CTH = 0.1µF, fRX = 433.92 MHz, unless otherwise noted. Bold values indicate –40°C – TA – 105°C. 1kbps data rate (Manchester encoded), reference oscillator frequency = 13.52127MHz. Symbol ISS ISHUT Parameter Condition Min Typ Max Units VDD=3.3V, fRX = 433.92MHz 6.0 mA VDD=5V, fRX = 433.92MHz 7.0 mA VDD=3.3V, fRX =315MHz 3.9 mA VDD=5V, fRX = 315MHz 4.7 mA 0.5 µA Operating Supply Current Shut down Current RF Section, IF Section Image Rejection 20 dB fRX = 433.92MHz 1.2 MHz fRX = 315MHz 0.86 MHz 1st IF Center Frequency *This specification is subject to change without notification. -4- SYN500R/SYN510R/SYN520R fRX = 433.92MHz , VDD=5V -109 dBm -109 dBm fRX = 433.92MHz 330 kHz fRX = 315MHz 235 kHz (matched to 50 Ω) BER=10-2 Receiver Sensitivity @ 1kbps fRX = 315MHz , VDD=5V (matched to 50 Ω) BER=10-2 IF Bandwidth 19 – fRX = 433.92MHz Ω j174 Antenna Input Impedance 32.5 – fRX = 315MHz Ω j235 Receive Modulation Duty Cycle Note 5 20 80 % AGC Attack / Decay Ratio tATTACK / tDECAY 0.1 TA = 25ºC ±2 nA TA = +105ºC ± 800 nA RFIN @ -40dBm 1.15 V RFIN @ -100dBm 1.70 V 13.52127 MHz 9.81563 MHz 300 kΩ AGC pin leakage current AGC Dynamic Range Reference Oscillator fRX = 433.92 MHz Crystal Load Cap = 10pF Reference Oscillator Frequency fRX = 315 MHz Crystal Load Cap = 10pF Reference Oscillator Input Impedance Reference Oscillator Input Range Reference Oscillator Source Current 0.2 V(REFOSC) = 0V 1.5 Vp-p 3.5 µA FREFOSC = 13.52127MHz 120 kΩ FREFOSC = 9.81563MHz 165 kΩ TA = 25ºC ±2 nA ± 800 nA Demodulator CTH Source Impedance CTH Leakage Current TA = +105ºC Demodulator Filter Bandwidth @ 434MHz *This specification is subject to change without notification. Programmable, see 1625 13000 Hz application section -5- SYN500R/SYN510R/SYN520R Digital/Control Section DO pin output current Output rise and fall times As output source @ 0.8 Vdd 260 sink @ 0.2 Vdd 600 CI = 15pF, pin DO, 10-90% 2 µA µsec RSSI RSSI DC Output Voltage Range 0.4 to 2 V 25 mV/dB RSSI Output Current 400 µA RSSI Output Impedance 200 Ω 0.3 sec RSSI response slope RSSI Response Time -109dBm to -40dBm 50% data duty cycle, input power to Antenna = -20dBm Note 1: Exceeding the absolute maximum rating may damage the device. Note 2: The device is not guaranteed to function outside of its operating rating. Note 3: Device is ESD sensitive. Use appropriate ESD precautions. maximum rating may damage the device. Note 4: Sensitivity is defined as the average signal level measured at the input necessary to achieve 10-2 BER (bit error rate). The input signal is defined as a return-to-zero (RZ) waveform with 50% average duty cycle (Manchester encoded) at a data rate of 1kbps. Exceeding the absolute Note 5: When data burst does not contain preamble, duty cycle is defined as total duty cycle, including any “quiet” time between data bursts. When data bursts contain preamble sufficient to charge the slice level on capacitor CTH, then duty cycle is the effective duty cycle of the burst alone. [For example, 100msec burst with 50% duty cycle, and 100msec “quiet” time between bursts. If burst includes preamble, duty cycle is TON/(TON+tOFF)= 50%; without preamble, duty cycle is TON/(TON+TOFF+TQUIET) = 50msec/(200msec)=25%. TON is the (Average number of 1’s/burst) × bit time, and TOFF=TBURST–TON.) *This specification is subject to change without notification. -6- SYN500R/SYN510R/SYN520R 10. Typical Characteristics 10.1. Sensitivity Graphs *This specification is subject to change without notification. -7- SYN500R/SYN510R/SYN520R 11. Functional Diagram Figure 1. Simplified Block Diagram 12. Functional Description Figure 1. Simplified Block Diagram that illustrates the basic structure of the SYN500R. It is made of three sub-blocks; Image Rejection UHF Down-converter, the OOK Demodulator, and Reference and Control Logics. Outside the device, the SYN500R requires only three components to operate: two capacitors (CTH, and CAGC) and the reference frequency device, usually a quartz crystal. An additional five components may be used to improve performance. These are: power supply decoupling capacitor, two components for the matching network, and two components for the pre-selector band pass filter. 13. Receiver Operation 13.1. LNA The RF input signal is AC-coupled into the gate circuit of the grounded source LNA input stage. The LNA is a Cascoded NMOS. 13.2. Mixers and Synthesizer The LO ports of the Mixers are driven by quadrature local oscillator outputs from the synthesizer block. The local oscillator signal from the synthesizer is placed on the low side of the desired RF signal to allow suppression of the image frequency at twice the IF frequency below the wanted signal. The local oscillator is set to 32 times the crystal reference frequency via a phase-locked *This specification is subject to change without notification. -8- SYN500R/SYN510R/SYN520R loop synthesizer with a fully integrated loop filter. 13.3. Image Reject Filter and Band-Pass Filter The IF ports of the mixer produce quadrature down converted IF signals. These IF signals are low-pass filtered to remove higher frequency products prior to the image reject filter where they are combined to reject the image frequencies. The IF signal then passes through a third order band pass filter. The IF center frequency is 1.2MHz. The IF BW is 330kHz @ 433.92MHz, and this varies with RF operating frequency. The IF BW can be calculated via direct scaling: BWIF = BWIF@433.92 MHz × Operating Freq(MHz) 433.92 These filters are fully integrated inside the SYN500R. After filtering, four active gain controlled amplifier stages enhance the IF signal to proper level for demodulation. 13.4. OOK Demodulator The demodulator section is comprised of detector, programmable low pass filter, slicer, and AGC comparator. 13.5. Detector and Programmable Low-Pass Filter The demodulation starts with the detector removing the carrier from the IF signal. Post detection, the signal becomes base band information. The programmable low-pass filter further enhances the base band information. There are four programmable low-pass filter BW settings: 1625Hz, 3250Hz, 6500Hz, 13000Hz for 433.92MHz operation. Low pass filter BW will vary with RF Operating Frequency. Filter BW values can be easily calculated by direct scaling. See equation below for filter BW calculation: BWOperating Freq = BW@433.92MHz × Operating Freq(MHz) 433.92 It is very important to choose the filter setting that best fits the intended data rate to minimize data distortion. Demod BW is set at 13000Hz @ 433.92MHz as default (assuming both SEL0 and SEL1 pins are floating). The low pass filter can be hardware set by external pins SEL0 and SEL1. SEL0 SEL1 Demod BW (@ 434MHz) 0 0 1625Hz 1 0 3250Hz 0 1 6500Hz 1 1 13000Hz-default Table 1: Demodulation BW Selection *This specification is subject to change without notification. -9- SYN500R/SYN510R/SYN520R 13.6. Slicer, Slicing Level The signal prior to slicer is still linear demodulated AM. Data slicer converts this signal into digital “1”s and “0”s by comparing with the threshold voltage built up on the CTH capacitor. This threshold is determined by detecting the positive and negative peaks of the data signal and storing the mean value. Slicing threshold default is 50%. After the slicer the signal is now digital OOK data . During long periods of “0”s or no data period, threshold voltage on the CTH capacitor may be very low. Large random noise spikes during this time may cause erroneous “1”s at DO pin. 13.7. AGC Comparator The AGC comparator monitors the signal amplitude from the output of the programmable low-pass filter. When the output signal is less than 750mV thresh-hold, 1.5µA current is sourced into the external CAGC capacitor. When the output signal is greater than 750mV, a 15µA current sink discharges the CAGC capacitor. The voltage developed on the CAGC capacitor acts to adjust the gain of the mixer and the IF amplifier to compensate for RF input signal level variation. 13.8. Reference Control There are 2 components in Reference and Control sub-block: 1) Reference Oscillator 2) Control Logic through parallel Inputs: SEL0, SEL1, SHDN 13.9. Reference Oscillator Figure 2: Reference Oscillator Circuit The reference oscillator in the SYN500R (Figure 2) uses a basic Colpitts crystal oscillator configuration with MOS transconductor to provide negative resistance. All capacitors shown in Figure 2 are integrated inside SYN500R. R01 and R02 are external pins of SYN500R. User only needs to connect reference oscillation crystal. *This specification is subject to change without notification. - 10 - SYN500R/SYN510R/SYN520R Reference oscillator crystal frequency can be calculated: FREF OSC = FRF/(32 + 1.1/12) For 433.92 MHz, FREF OSC = 13.52127 MHz. To operate the SYN500R with minimum offset, crystal frequencies should be specified with 10pF loading capacitance. 14. Applications Information Figure 3. SYN500R Application Example, 433.92 MHz The SYN500R can be fully tested by using one of many evaluation boards designed at Synoxo for this device. As an entry level, the SYN500R evaluation board(Figure 3) offers a good start for most applications. It has a helical PCB antenna with its matching network, a band-pass-filter front-end as a pre-selector filter, matching network and the minimum components required to make the device work, which are a crystal, Cagc, and Cth capacitors. By removing the matching network of the helical PCB antenna (C9 and L3), a whip antenna (ANT2) or a RF connector (J2) can be used instead. Figure 3 shows the entire schematic of it for 433.92MHz. Other frequencies can be used and the values needed are in the tables below. Capacitor C9 and inductor L3 are the passive elements for the helical PCB matching network. A tight tolerance is recommended for these devices, like 2% for the inductor and 0.1pF for the capacitor. PCB variations may require different values and optimization. Table 2 shows the matching elements for the device frequency range. For additional information look for Small PCB Antennas for Synoxo RF Products application note. Freq(MHz) C9(pF) L3(nH) 390.0 1.2 43 418.0 1.2 36 433.92 1.5 30 Table 2. Matching Values for the Helical PCB Antenna To use another antenna, like the whip kind, remove C9 and place the whip antenna in the hole provided in the PCB. Also, a RF signal can be injected there. *This specification is subject to change without notification. - 11 - SYN500R/SYN510R/SYN520R L1 and C8 form the pass-band-filter front-end. Its purpose is to attenuate undesired outside band noise which reduces the receiver performance. It is calculated by the parallel resonance equation f = 1/(2×PI×(SQRT L1×C8)). Table 3 shows the most used frequency values. Freq(MHz) C8(pF) L1(nH) 390.0 6.8 24 418.0 6.0 24 433.92 5.6 24 Table 3. Band-Pass-Filter Front-End Values There is no need for the band-pass-filter front-end for applications where it is proven that the outside band noise does not cause a problem. The SYN500R has image reject mixers which improve significantly the selectivity and rejection of outside band noise. Capacitor C3 and inductor L2 form the L-shape matching network. The capacitor provides additional attenuation for low frequency outside band noise and the inductor provides additional ESD protection for the antenna pin. Two methods can be used to find these values, which are matched close to 50Ω. One method is done by calculating the values using the equations below and another by using a Smith chart. The latter is made easier by using software that plots the values of the components C8 and L1, like WinSmith by Noble Publishing. To calculate the matching values, one needs to know the input impedance of the device. Table 4 shows the input impedance of the SYN500R and suggested matching values for the most used frequencies. These suggested values may be different if the layout is not exactly the same as the one made here. Freq (MHz) C3 (pF) L2(nH) Z device (Ω) 390.0 1.5 47 22.5 – j198.5 418.0 1.5 43 21.4 – j186.1 433.92 1.5 39 18.6 – j174.2 Table 4: matching values for the most used frequencies For the frequency of 433.92MHz, the input impedance is Z = 18.6 – j174.2Ω, then the matching components are calculated by, Equivalent parallel = B = 1/Z = 0.606 + j5.68 msiemens Rp = 1 / Re (B); Xp =1/ Im (B) Rp = 1.65kΩ; Xp = 176.2Ω Q = SQRT (Rp/50 + 1) Q = 5.831 Xm = Rp / Q Xm = 282.98Ω Resonance Method for L-shape Matching Network *This specification is subject to change without notification. - 12 - SYN500R/SYN510R/SYN520R Lc = Xp / (2×Pi×f); Lp = Xm / (2×Pi×f) L2 = (Lc×Lp) / (Lc + Lp); C3 = 1 / (2×Pi×f×Xm) L2 = 39.8nH C3 = 1.3pF Doing the same calculation example with the Smith Chart, it would appear as follows, First, we plot the input impedance of the device, (Z = 18.6 – j174.2)Ω @ 433.92MHz.(Figure 4). Figure 4: device’s input impedance, Z = 18.6 – j174.2Ω Second, we plot the shunt inductor (39nH) and the series capacitor (1.5pF) for the desired input impedance (Figure 5). We can see the matching leading to the center of the Smith Chart or close to 50Ω. *This specification is subject to change without notification. - 13 - SYN500R/SYN510R/SYN520R Figure 5. Plotting the Shunt Inductor and Series Capacitor. Crystal Y1 or Y1A (SMT or leaded respectively) is the reference clock for all the device internal circuits. Crystal characteristics of 10pF load capacitance, 30ppm, ESR < 50Ω, -40ºC to +105ºC temperature range are desired. Table 5 shows the crystal frequencies and one of Synoxo’s approved crystal manufacturers. The oscillator of the SYN500R is a Colpitts type. It is very sensitive to stray capacitance loads. Thus, very good care must be taken when laying out the printed circuit board. Avoid long traces and ground plane on the top layer close to the REFOSC pins RO1 and RO2. When care is not taken in the layout, and crystals from other vendors are used, the oscillator may take longer times to start as well as the time to good data in the DO pin to show up. In some cases, if the stray capacitance is too high (> 20pF), the oscillator may not start at all. *This specification is subject to change without notification. - 14 - SYN500R/SYN510R/SYN520R The crystal frequency is calculated by REFOSC = RF Carrier/(32+(1.1/12)). The local oscillator is low side injection (32 × 13.52127MHz = 432.68MHz), that is, its frequency is below the RF carrier frequency and the image frequency is below the LO frequency. See Figure 6. The product of the incoming RF signal and local oscillator signal will yield the IF frequency, which will be demodulated by the detector of the device. Figure 6. Low Side Injection Local Oscillator. REFOSC (MHz) Carrier (MHz) Part Number 12.15269 390.0 SA-12.152690-F-10-H-30-30-X 13.02519 418.0 SA-13.025190-F-10-H-30-30-X 13.52127 433.92 SA-13.521270-F-10-H-30-30-X Table 5. Crystal Frequency and Vendor Part Number. JP1 and JP2 are the bandwidth selection for the demodulator bandwidth. To set it correctly, it is necessary to know the shortest pulse width of the encoded data sent in the transmitter. Like in the example of the data profile in the figure 7 below, PW2 is shorter than PW1, so PW2 should be used for the demodulator bandwidth calculation which is found by 0.65/shortest pulse width. After this value is found, the setting should be done according to Table 6. For example, if the pulse period is 100µsec, 50% duty cycle, the pulse width will be 50µsec (PW = (100µsec × 50%) / 100). So, a bandwidth of 13kHz would be necessary (0.65 / 50µsec). However, if this data stream had a pulse period with 20% duty cycle, the bandwidth required would be 32.5kHz (0.65 / 20µsec), which exceeds the maximum bandwidth of the demodulator circuit. If one tries to exceed the maximum bandwidth, the pulse would appear stretched or wider. SEL0 JP1 SEL1 JP2 Demod. BW (hertz) Shortest Pulse (µsec) Maximum baud rate for 50% Duty Cycle (hertz) Short Short 1625 400 1250 Open Short 3250 200 2500 Short Open 6500 100 5000 Open Open 13000 50 10000 Table 6. JP1 and JP2 setting, 433.92 MHz. *This specification is subject to change without notification. - 15 - SYN500R/SYN510R/SYN520R Other frequencies will have different demodulator bandwidth limits, which are derived from the reference oscillator frequency. Table 7 and Table 8 below shows the limits for the other two most used frequencies. SEL0 JP1 SEL1 JP2 Short Demod. BW (hertz) Shortest Pulse (µsec) Maximum baud rate for 50% Duty Cycle (hertz) Short 1565 416 1204 Open Short 3130 208 2408 Short Open 6261 104 4816 Open Open 12523 52 9633 Table 7. SEL0 JP1 SEL1 JP2 Short JP1 and JP2 setting, 418.0 MHz. Demod. BW (hertz) Shortest Pulse (µsec) Maximum baud rate for 50% Duty Cycle (Hertz) Short 1460 445 1123 Open Short 2921 223 2246 Short Open 5842 111 4493 Open Open 11684 56 8987 Table 8. JP1 and JP2 setting, 390.0 MHz. Capacitors C6 and C4, CTH and CAGC respectively provide time base reference for the data pattern received. These capacitors are selected according to data profile, pulse duty cycle, dead time between two received data packets, and if the data pattern has or does not have a preamble. See Figure 7, example of a data profile. Figure 7. Example of a Data Profile. For best results the capacitors should always be optimized for the data pattern used. As the baud rate increases, the capacitor values decrease. Table 9 shows suggested values for Manchester Encoded data, 50% duty cycle. SEL0 JP1 SEL1 JP2 Demod. BW (hertz) *This specification is subject to change without notification. CTH CAGC - 16 - SYN500R/SYN510R/SYN520R Short Short 1625 100nF 4.7µF Open Short 3250 47nF 2.2µF Short Open 6500 22nF 1µF Open Open 13000 10nF 0.47µF Table 9. Suggested CTH and CAGC Values. Other components used are C5, which is a decoupling capacitor for the VDD line, R4 reserved for future use and not needed for the evaluation board, R3 for the shutdown pin (SHDN = 0, device is operation), which can be removed if that pin is connected to a microcontroller or an external switch, R1 and R2 which form a voltage divider for the AGC pin. One can force a voltage in this AGC pin to purposely decrease the device sensitivity. Special care is needed when doing this operation, as an external control of the AGC voltage may vary from lot to lot and may not work the same for several devices. Three other pins are worthy of comment. They are the DO, RSSI, and shut down pins. The DO pin has a driving capability of 0.4mA. This is good enough for most of the logic family ICs in the market today. The RSSI pin provides a transfer function of the RF signal intensity vs voltage. It is very useful to determine the signal to noise ratio of the RF link, crude range estimate from the transmitter source and AM demodulation, which requires a low CAGC capacitor value. The shut down pin (SHDN) is useful to save energy. When its level close to VDD (SHDN = 1), the device is not in operation. Its DC current consumption is less than 1µA (do not forget to remove R3). When toggling from high to low, there will be a time required for the device to come to steady state mode, and a time for data to show up in the DO pin. This time will be dependent upon many things such as temperature, crystal used, and if the there is an external oscillator with faster startup time. Normally, with the crystal vendors suggested, the data will show up in the DO pin around 1msec time, and 2msec over the temperature range of the device. When using an external oscillator or reference oscillator signal, the time is reduced considerably and can be around 140µsec. See Figures Figure 10 and 11. Figure 10: Time-to-Good Data After Shut Down Cycle, Room Temperature. *This specification is subject to change without notification. - 17 - SYN500R/SYN510R/SYN520R Figure 11. Time to Good Data, External Oscillator, Room Temperature. 15. Package Information SYN500R SSOP16 Package Type *This specification is subject to change without notification. - 18 - SYN500R/SYN510R/SYN520R SYN510R SOP16 Package Type SYN520R SOP8 Package Type *This specification is subject to change without notification. - 19 -
SYN510R 价格&库存
很抱歉,暂时无法提供与“SYN510R”相匹配的价格&库存,您可以联系我们找货
