SYN531R
SYN531R
    SYNOXO
    SOP-8
    300MHZ至450MHZ ASK接收器
SYN531R 数据手册
FEARURES         300MHz to 450MHz Frequency Range -109dBm High Sensitivity, 1Kbps and BER 10E-2 @ 315MHz and 433.92MHz Image Rejection Function Low Power Consumption Excellent Selectivity and Noise Rejection No External IF Filter Required Low External part count SOP-8 Package Type Applications      Automotive Remote Keyless Entry (RKE) Remote Control System Access Control System Home Automation Toys DESCRIPTION The SYN531R is an UHF ASK receiver IC in a small SOP-8 package which operates at 300MHz to 450MHz with typical receiving sensitivity of -109dBm. The SYN531R is a Weaver architecture receiver for ASK and OOK modulation such as pulse width modulation, variable pulse modulation, Manchester modulation and so on. The Weaver receiver also provides image rejection function to remove the image band and selects the desired signal. The high integrated SYN531R uses the low cost 8-Lead Small Outline Package (SOP-8), no extra external component is required except two capacitors (CTH and CAGC), reference crystal and antenna matching network. The SYN531R provides the Shut Down function pin (SHDN). *This preliminary datasheet is subject to change without notification. -1- TYPICAL APPLICATION 433.92MHz, 1KHz Baud Rate Application Circuit SYN531R requires only three components to operate: two capacitors (CTH and CAGC) and the reference frequency device, usually a quartz crystal. Additional five components may be used to improve performance. These are: power supply decoupling capacitor, two components for the matching network, and two components for the pre-selector band pass filter. PIN CONFIGURATION ANT 1 8 RO GND 2 7 CAGC VDD 3 6 CTH 5 DO SHDN 4 SYN531R SOP-8 PIN DESCRIPTION Pin Name I/O Function 1 ANT I RF Input 2 GND GND Ground 3 VDD POWER 4 SHDN I Shut Down 5 DO O Data Output 6 CTH I Slicing Level Capacitor 7 CAGC I Filter capacitor Connected to AGC 8 RO I Reference Crystal Oscillator Power Supply *This preliminary datasheet is subject to change without notification. -2- ABSOLUTE MAXIMUM RATINGS Supply Voltage …………………..7V Input Voltage ……………….....…7V ESD Rating ……………….….Note 1 Storage Temperature Range ……-65° C to 150° C Junction Temperature ………………………150° C Lead Temperature (soldering, 10sec.) …...260° C OPERATING RATINGS Supply Voltage ……….…3.6V to 5.5V Input Voltage (Max.) ………..…5.5V Ambient Temperature (TA) ……….-40° C to 85° C ELECTRICAL CHARACTERISTICS Unless otherwise noted, VDD = 5V, CAGC = 1μF, CTH = 0.1μF, 1Kbps data rate (Manchester encoded, BER =10E-2), all test at TA = 25° C. Receiver Symbol Parameter fRX Frequency Input Range PIN,MAX Maximum Input Power PSENS Receiver Sensitivity (Note 2) Image Rejection fIF 1st IF Center Frequency IF Bandwidth Receive Modulation Duty Cycle VAGC AGC Dynamic Voltage Conditions Min. Typ. Max. 300 to 450 Units MHz 10 dBm fRX = 315MHz -109 dBm fRX = 433.92MHz -109 dBm fRX = 315MHz 20 dB fRX = 433.92MHz 20 dB fRX = 315MHz 0.86 MHz fRX = 433.92MHz 1.2 MHz fRX = 315MHz 235 KHz fRX = 433.92MHz 330 KHz Note 3 20 80 % PIN = -40dBm 1.15 V PIN = -100dBm 1.7 V Reference Oscillator Symbol Parameter fOSC Frequency Conditions Source Current Typ. Max. Units fRX = 315MHz 9.8131 MHz fRX = 433.92MHz 13.51783 MHz Input Range IOSCSC Min. 0.2 V(RO) = 0V *This preliminary datasheet is subject to change without notification. 1.5 3.5 VPP μA -3- DO Drive Symbol Parameter DO pin Output Current TRISE TFALL Output Rise and Fall Times Conditions Min. Typ. Max. Units Source @ 0.8VDD 260 μA Sink @ 0.2 VDD 600 μA CL = 15pF, pin DO, 10-90% 2 μsec 2 μsec Power Supply Symbol Parameter Conditions Min. Typ. Max. Units ICC Supply Current @ VDD = 5V fRX = 315MHz 4.5 mA fRX = 433.92MHz 7.0 mA IOFF Shut Down Current SHDN = High 0.5 μA Note 1: Device is ESD sensitive. Use appropriate ESD precautions. Exceeding the absolute maximum rating may damage the device. Note 2: Sensitivity is defined as the average signal level measured at the input necessary to achieve 10-2 BER (bit error rate). The input signal is defined as a return-to-zero (RZ) waveform with 50% average duty cycle (Manchester encoded) at a data rate of 1kbps. Note 3: When data burst does not contain preamble, duty cycle is defined as total duty cycle, including any “quiet” time between data bursts. When data bursts contain preamble sufficient to charge the slice level on capacitor CTH, then duty cycle is the effective duty cycle of the burst alone. [For example, 100msec burst with 50% duty cycle, and 100msec “quiet” time between bursts. If burst includes preamble, duty cycle is TON/(TON + TOFF) = 50%; without preamble, duty cycle is TON/(TON + TOFF + TQUIET) = 50msec/(200msec) = 25%. TON is the (Average number of 1’s/burst) × bit time, and TOFF = TBURST–TON.] *This preliminary datasheet is subject to change without notification. -4- TYPICAL CHARACTERISTICS Unless otherwise noted, VDD = 5V, CAGC = 1μF, CTH = 0.1μF, 1Kbps data rate (Manchester encoded, BER =10E-2), all test at TA = 25° C. *This preliminary datasheet is subject to change without notification. -5- BLOCK DIAGRAM AGC VDD ANT Σ LNA Analog Filter GND RO CAGC REF OSC PLL&LO Silicer DO CTH Figure 1 Simplified Block Diagram FUNCTIONAL DESCRIPTION Figure 1 Simplified Block Diagram that illustrates the basic structure of the SYN531R. It is composed of five modules; Low Noise Amplifier, Weaver architecture receiver, the Slicer, Auto Gain Control and Reference and Control Logics. LNA The RF input signal is AC-coupled into the gate circuit of the grounded source LNA input stage. The LNA uses a Cascoded NMOS structure circuit, and the output is converted to differential signals for next stage mixers. Weaver Receiver The LNA output signals are first mixed with quadrature phases of the local oscillator signal. After filtering both mixer output with a low-pass filter, the output signals are mixed again by another set of mixing operation in both signal paths, the sum of the two final signals cancels the image band to yield the desired signal, while the subtraction removes the desired signal and selects the image band. Slicer The signal prior to slicer is still linear demodulated AM. Data slicer converts this signal into digital “1” and “0” by comparing with the threshold voltage built up on the CTH capacitor. This *This preliminary datasheet is subject to change without notification. -6- threshold is determined by detecting the positive and negative peaks of the data signal and storing the mean value. Slicing threshold is at 50%. After the slicer, the signal is now digital OOK data. During long periods of “0” or no data period, threshold voltage on the CTH capacitor may be very low. Large random noise spikes during this time may cause erroneous “1” at DO pin. AGC The AGC comparator monitors the signal amplitude from the output of the Weaver receiver. When the output signal is less than 750mV, the threshold 1.5μA current is sourced into the external CAGC capacitor. When the output signal is greater than 750mV, a 15µ A current sink discharges the CAGC capacitor. The voltage developed on the CAGC capacitor acts to adjust the gain of the mixers of Weaver receiver to compensate for RF input signal level variation. Reference Oscillator The reference oscillator in the SYN531R uses a basic Colpitts crystal oscillator configuration with MOS transconductor to provide negative resistance. The RO pin external capacitor is integrated inside SYN531R. User only needs to connect reference oscillation crystal. Reference oscillator crystal frequency can be calculated: FOSC = FRF/(32 + 1.198/12) For 433.92 MHz, FOSC = 13.51783 MHz. *This preliminary datasheet is subject to change without notification. -7- EVALUATION BOARD Figure 2, 3 and 4 show the top, bottom and top solder layers of the SYN531R @433.92MHz application board. Keep traces as short as possible. Long traces will alter the matching network, and the values suggested will not be valid. Ground plane must be solid and possibly without interruptions. Avoid ground plane on top next to the matching elements. It normally adds additional stray capacitance which changes the matching. RF path should be as straight as possible avoiding loops and unnecessary turns. Figure 2 Top Layer Figure 3 Bottom Layer *This preliminary datasheet is subject to change without notification. -8- Figure 4 Top Solder Layer with Dimensions BOARD BILL OF MATERIALS Footprint Comment Designator Description 0603-STD 5pF C1 Capacitor 1 0603-STD 3.7pF C2 Capacitor 1 0603-STD 0.1μF C3, C4 Capacitor 2 0603-STD 1μF C5 Capacitor 1 0603-STD 27nH L1 Inductor 1 0603-STD 33nH L2 Inductor 1 SMA-KHD RF SMA P1 SMA Connector 1 HDR1X4 Header 4 P2 Header, 4-Pin 1 SOP-8 SYN531R U1 SYNOXO 1 XTAL-HC49S 13.51783MHz Y1 Crystal Oscillator 1 *This preliminary datasheet is subject to change without notification. Quantity -9- PACKAGE DESCRIPTION SOP-8 Package Outline Dimensions shown in millimeters and (inches) *This preliminary datasheet is subject to change without notification. - 10 -
SYN531R 价格&库存
很抱歉,暂时无法提供与“SYN531R”相匹配的价格&库存,您可以联系我们找货
