CMT2210A-EQR
CMT2210A-EQR
    HOPERF(华普微)
    QFN-16-EP(3x3)
    低成本300-960 MHZ开关键控(OOK)独立式射频接收器
CMT2210A-EQR 数据手册
CMT2210/17A CMT2210/17A Low-Cost 300 – 960 MHz OOK Stand-Alone RF Receiver Features Applications   Low-Cost Consumer Electronics Applications  Very Easy Development with RFPDK  Home and Building Automation  All Features Programmable  Infrared Receiver Replacements  Embedded EEPROM  Industrial Monitoring and Controls  300 to 480 MHz (CMT2210A)  Remote Automated Meter Reading  300 to 960 MHz (CMT2217A)  Remote Lighting Control System Frequency Range  Symbol Rate: 0.1 to 40 ksps  Wireless Alarm and Security Systems  Sensitivity: -113 dBm at 1 ksps, 0.1% BER  Remote Keyless Entry (RKE)  Configurable Receiver Bandwidth: 50 to 500 kHz  3-wire SPI Interface for EEPROM Programming  Stand-Alone, No External MCU Control Required  Configurable Duty-Cycle Operation Mode  Supply Voltage: 1.8 to 3.6 V   Ordering Information Part Number Frequency Package MOQ Low Power Consumption: 3.8 mA CMT2210A-EQR 433.920 MHz QFN16 5,000 pcs Low Sleep Current CMT2210A-ESR 433.920 MHz SOP16 2,500 pcs CMT2217A-EQR 868.350 MHz QFN16 5,000 pcs  60 nA when Sleep Timer Off  440 nA when Sleep Timer On  RoHS Compliant  16-pin QFN 3x3 and SOP16 Package Options More Ordering Info: See Page 21 Descriptions The CMT2210/17A devices are ultra low power, high performance, low-cost OOK stand-alone RF receiver for various 300 to 960 MHz wireless applications. The CMT2210A covers the frequency range from 300 to 480 MHz while the CMT2217A covers the 300 to 960 MHz QFN16 (3X 3) frequency range. They are part of the CMOSTEK SOP16 NextGenRFTM family, which includes a complete line of transmitters, receivers and transceivers. An embedded NC 12 VCOP CMOSTEK USB Programmer and RFPDK. Alternatively, in nRSTO features to be programmed into the device using the VCON EEPROM allows the frequency, symbol rate and other 11 10 9 stock products of 433.92/868.35 MHz are available for GND 13 8 XIN immediate demands without the need of EEPROM RFIN 14 7 XOUT programming. When the CMT2210/17A is always on, it GND 15 6 CLKO 5 DOUT nRSTO 15 NC XIN 3 14 4 13 XOUT GND 5 12 CLKO DOUT VDD 6 11 1 2 3 4 CSB 7 10 NC GND RFIN SCL receiving sensitivity. It consumes even less power when 16 2 CSB VDD 16 1 SDA consumes only 3.8 mA current while achieving -113 dBm VCOP VCON SDA 8 9 NC SCL working in duty-cycle operation mode via the built-in sleep timer. The CMT2210/17A receiver together with the CMT211x transmitter enables an ultra low cost RF link. Copyright © By CMOSTEK Rev 1.3 | Page 1/28 CMT2210/17A Top View www.hoperf.com CMT2210/17A Typical Application 9 10 11 NC CMT2210/17A GND CLKO VDD 1 X1 C2 J1 VDD 7 1 2 3 4 CSB C3 6 SDA SCL 5 5 DOUT NC CSB C0 DOUT 8 4 16 XOUT U1 SCL 15 VDD RFIN XIN 3 14 L1 SDA C1 GND 2 13 nRSTO ANT VCOP VCON 12 L2 EEPROM Programming SCL SDA CSB Note: Connector J1 is for Figure 1. CMT2210/17A Typical Application Schematic Table 1. BOM of 433.92/868.35 MHz Typical Application Designator [1] Value (Match to 50Ω ANT) Value (Common Used ANT) 433.92 MHz 433.92 MHz Descriptions 868.35 MHz Unit Manufacturer 868.35 MHz CMT2210/17A, low-cost U1 300 – 960 MHz OOK - - - CMOSTEK 26 26 MHz EPSON nH Murata LQG18 nH Murata LQG18 pF Murata GRM15 stand-alone RF receiver X1 L1 ±20 ppm, SMD32*25 mm, crystal ±5%, 0603 multi-layer chip inductor ±5%, 0603 multi-layer chip [2] L2 inductor, for QFN16 ±5%, 0603 multi-layer chip inductor, for SOP16 27 6.8 33 6.8 22 3.9 22 3.9 15 -- 15 -- 3.3 2.7 2.7 2.7 C1 ±0.25 pF, 0402 NP0, 50 V C0 ±20%, 0402 X7R, 25 V 0.1 0.1 uF Murata GRM15 C2, C3 ±5%, 0402 NP0, 50 V 27 27 pF Murata GRM15 Note: [1]. The 868.35 MHz application is for CMT2217A only. [2]. CMT2210A devices in QFN16 and SOP16 packages share the same BOM except for the L2. Table 2. Product Selection Table Product CMT2210A CMT2217A Modulation/ Frequency Sensitivity Rx Current OOK/ -113 dBm 3.8 mA 300-480 MHz (433.92 MHz, 1 ksps, 0.1% BER) (433.92 MHz) OOK/ -110 dBm 5.2 mA 300-960 MHz (868.35 MHz, 1 ksps, 0.1% BER) (868.35 MHz) Rev 1.3 | Page 2/28 Embedded EEPROM √ √ Package QFN16(3x3)/ SOP16 QFN16(3x3) www.hoperf.com CMT2210/17A Abbreviations Abbreviations used in this data sheet are described below AGC Automatic Gain Control PC Personal Computer AN Application Notes PCB Printed Circuit Board BER Bit Error Rate PLL Phase Lock Loop BOM Bill of Materials PN9 Pseudorandom Noise 9 BSC Basic Spacing between Centers POR Power On Reset BW Bandwidth PUP Power Up DC Direct Current QFN Quad Flat No-lead EEPROM Electrically Erasable Programmable Read-Only RF Radio Frequency Memory RFPDK RF Products Development Kit ESD Electro-Static Discharge RoHS Restriction of Hazardous Substances ESR Equivalent Series Resistance RSSI Received Signal Strength Indicator Ext Extended Rx Receiving, Receiver IF Intermediate Frequency SAR Successive Approximation Register LNA Low Noise Amplifier SOP Small Outline Package LO Local Oscillator SPI Serial Port Interface LPOSC Low Power Oscillator TH Threshold Max Maximum Tx Transmission, Transmitter MCU Microcontroller Unit Typ Typical Min Minimum USB Universal Serial Bus MOQ Minimum Order Quantity VCO Voltage Controlled Oscillator NP0 Negative-Positive-Zero WOR Wake On Radio NC Not Connected XOSC Crystal Oscillator OOK On-Off Keying XTAL/Xtal Crystal Rev 1.3 | Page 3/28 www.hoperf.com CMT2210/17A Table of Contents 1. Electrical Characteristics ............................................................................................................................................ 5 1.1 Recommended Operation Conditions ................................................................................................................... 5 1.2 Absolute Maximum Ratings................................................................................................................................... 5 1.3 Receiver Specifications ......................................................................................................................................... 6 1.4 Crystal Oscillator ................................................................................................................................................... 7 1.5 LPOSC .................................................................................................................................................................. 7 2. Pin Descriptions .......................................................................................................................................................... 8 3. Typical Performance Characteristics ....................................................................................................................... 10 4. Typical Application Schematic ................................................................................................................................. 11 5. Functional Descriptions ............................................................................................................................................ 11 5.1 Overview ............................................................................................................................................................. 12 5.2 Modulation, Frequency and Symbol Rate ........................................................................................................... 12 5.3 Embedded EEPROM and RFPDK ...................................................................................................................... 13 5.4 All Configurable Options ..................................................................................................................................... 13 5.5 Internal Blocks Description .................................................................................................................................. 15 5.5.1 5.5.2 RF Front-end and AGC ............................................................................................................................ 15 IF Filter..................................................................................................................................................... 15 5.5.3 5.5.4 RSSI ........................................................................................................................................................ 15 SAR ADC ................................................................................................................................................. 15 5.5.5 5.5.6 Crystal Oscillator ...................................................................................................................................... 16 Frequency Synthesizer ............................................................................................................................ 16 5.5.7 LPOSC..................................................................................................................................................... 16 5.6 Operation Mode .................................................................................................................................................. 16 5.7 Always Receive Mode ......................................................................................................................................... 17 5.8 Duty-Cycle Receive Mode ................................................................................................................................... 18 5.9 Easy Duty-Cycle Configurations.......................................................................................................................... 19 5.10 The nRSTO ......................................................................................................................................................... 19 5.11 The CLKO ........................................................................................................................................................... 20 6. Ordering Information ................................................................................................................................................. 21 7. Package Outline......................................................................................................................................................... 22 8. Top Marking ............................................................................................................................................................... 24 8.1 CMT2210/17A Top Marking ................................................................................................................................ 24 9. Other Documentations .............................................................................................................................................. 26 10. Document Change List.............................................................................................................................................. 27 11. Contact Information .................................................................................................................................................. 28 Rev 1.3 | Page 4/28 www.hoperf.com CMT2210/17A 1. Electrical Characteristics VDD = 3.3 V, TOP = 25 ℃, FRF = 433.92 MHz, sensitivities are measured in receiving a PN9 sequence and matching to 50 Ω impedance, with the BER of 0.1%. All measurements are performed using the board CMT2210/17A-EM V1.0, unless otherwise noted. 1.1 Recommended Operation Conditions Table 3. Recommended Operation Conditions Parameter Symbol Conditions Min Typ Max Unit Operation Voltage Supply VDD 1.8 3.6 V Operation Temperature TOP -40 85 ℃ Supply Voltage Slew Rate 1 mV/us 1.2 Absolute Maximum Ratings Table 4. Absolute Maximum Ratings Parameter Symbol Conditions [1] Min Max Unit Supply Voltage VDD -0.3 3.6 V Interface Voltage VIN -0.3 VDD + 0.3 V Junction Temperature TJ -40 125 ℃ Storage Temperature TSTG -50 150 ℃ Soldering Temperature TSDR 255 ℃ -2 2 kV -100 100 mA [2] Lasts at least 30 seconds ESD Rating Human Body Model (HBM) Latch-up Current @ 85 ℃ Notes: [1]. Stresses above those listed as “absolute maximum ratings” may cause permanent damage to the device. This is a stress rating only and functional operation of the device under these conditions is not implied. Exposure to maximum rating conditions for extended periods may affect device reliability. [2]. The CMT2210/17A is high-performance RF integrated circuits with VCON/P pins having an ESD rating < 2 kV HBM. Handling and assembly of this device should only be done at ESD-protected workstations. Caution! ESD sensitive device. Precaution should be used when handling the device in order to prevent permanent damage. Rev 1.3 | Page 5/28 www.hoperf.com CMT2210/17A 1.3 Receiver Specifications Table 5. Receiver Specifications Parameter Symbol Frequency Range FRF Symbol Rate SR S433.92 Sensitivity S868.35 Saturation Input Signal Level Working Current IDD ISLEEP Frequency Resolution FRES Settle Time Min TLOCK 480 MHz 300 960 MHz 0.1 40 ksps FRF = 433.92 MHz, SR = 1 ksps, BER = -113 dBm -110 dBm 10 dBm 3.8 mA FRF = 868.35 MHz 5.2 mA When sleep timer is on 440 nA When sleep timer is off 60 nA 24.8 Hz 150 us 52 dB 74 dB 75 dB 35 dB -25 dBm 0.1% FRF = 868.35 MHz, SR = 1 ksps, BER = 0.1% FRF = 433.92 MHz From XOSC settled SR = 1 ksps, ±2 MHz offset, CW interference SR = 1 ksps, ±10 MHz offset, CW interference Image Rejection Ratio IMR rd Input 3 Order Intercept Point Receiver Bandwidth IIP3 IF = 280 kHz Two tone test at 1 MHz and 2 MHz offset frequency. Maximum system gain settings BW Receiver Start-up Time TSTART-UP Receiver Wake-up Time TWAKE-UP Unit 300 interference BI Max CMT2217A SR = 1 ksps, ±1 MHz offset, CW Blocking Immunity Typ CMT2210A PLVL Sleep Current Frequency Synthesizer Conditions 50 From power up to receive, in Always Receive Mode From sleep to receive, in Duty-Cycle Receive Mode Rev 1.3 | Page 6/28 500 kHz 7.3 ms 0.61 ms www.hoperf.com CMT2210/17A 1.4 Crystal Oscillator Table 6. Crystal Oscillator Specifications Parameter Symbol [1] Crystal Frequency Conditions FXTAL Min Typ Max Unit 26 26 26 MHz [2] Crystal Tolerance ±20 Load Capacitance CLOAD Crystal ESR 10 15 Rm [3] XTAL Startup Time tXTAL ppm 20 pF 60 Ω 400 us Notes: [1]. The CMT2210/17A can directly work with external 26 MHz reference clock input to XIN pin (a coupling capacitor is required) with peak-to-peak amplitude of 0.3 to 0.7 V. [2]. This is the total tolerance including (1) initial tolerance, (2) crystal loading, (3) aging, and (4) temperature dependence. The acceptable crystal tolerance depends on RF frequency and channel spacing/bandwidth. [3]. This parameter is to a large degree crystal dependent. 1.5 LPOSC Table 7. LPOSC Specifications Parameter Symbol Calibrated Frequency[1] FLPOSC Frequency Accuracy Temperature Coefficient After calibration [2] Supply Voltage Coefficient Initial Calibration Time Conditions [3] tLPOSC-CAL Min Typ Max Unit 1 kHz 1 % -0.02 %/°C +0.5 %/V 4 ms Notes: [1]. The LPOSC is automatically calibrated to the crystal oscillator during the PUP state, and is periodically calibrated since then. [2]. Frequency drifts when temperature changes after calibration. [3]. Frequency drifts when supply voltage changes after calibration. Rev 1.3 | Page 7/28 www.hoperf.com CMT2210/17A VCON VCOP nRSTO NC 2. Pin Descriptions 12 11 10 9 7 XOUT GND 15 6 CLKO VDD 16 5 DOUT 1 2 3 4 NC RFIN 14 SCL XIN SDA 8 CSB GND 13 Figure 2. CMT2210/17A Pin Assignments in QFN16 (3x3) Package Table 8. CMT2210/17A Pin Descriptions in QFN16 (3x3) Package Pin Number Name I/O Descriptions 1 CSB I 2 SDA IO 3 SCL I 4,9 NC NA Not connected, leave floating 5 DOUT O Received data output 6 CLKO O Programmable clock output to drive an external MCU 7 XOUT O Crystal oscillator output 3-wire SPI chip select input for EEPROM programming, internally pulled high 3-wire SPI data input and output for EEPROM programming 3-wire SPI clock input for EEPROM programming, internally pulled low 8 XIN I Crystal oscillator input or external reference clock input 10 nRSTO O Active-low power-on-reset output to reset an external MCU 11 VCOP 12 VCON IO VCO tank, connected to an external inductor 13, 15 GND I Ground 14 RFIN I RF signal input to the LNA 16 VDD I Power supply input Rev 1.3 | Page 8/28 www.hoperf.com CMT2210/17A VCOP 1 16 nRSTO VCON 2 15 NC GND 3 14 XIN RFIN 4 13 XOUT GND 5 12 CLKO VDD 6 11 DOUT CSB 7 10 NC SDA 8 9 SCL Figure 3. CMT2210A Pin Assignments in SOP16 Package Table 9. CMT2210A Pin Assignments in SOP16 Package Pin Number Name 1 VCOP 2 VCON I/O IO Descriptions VCO tank, connected to an external inductor 3, 5 GND I Ground 4 RFIN I RF signal input to the LNA 6 VDD I Power supply input 7 CSB I 3-wire SPI chip select input for EEPROM programming 8 SDA IO 9 SCL I 3-wire SPI clock input for EEPROM programming 3-wire SPI data input and output for EEPROM programming 10,15 NC - Not connected, leave floating 11 DOUT O Received data output 12 CLKO O Programmable clock output to drive an external MCU 13 XOUT O Crystal oscillator output 14 XIN I Crystal oscillator input or external reference clock input 16 nRSTO O Active-low power-on-reset output to reset an external MCU Rev 1.3 | Page 9/28 www.hoperf.com CMT2210/17A 3. Typical Performance Characteristics Current vs. Supply Voltage Current vs. Temperature 6.60 5.50 6.20 Current Consumption (mA) 6.00 Current Consumption (mA) 5.00 4.50 4.00 3.50 868.35 MHz 3.00 433.92 MHz 2.50 5.80 868.35MHz/3.6V 5.40 868.35MHz/3.3V 5.00 868.35MHz/1.8V 433.92MHz/3.6V 4.60 433.92MHz/3.3V 4.20 433.92MHz/1.8V 3.80 3.40 2.00 3.00 1.60 1.85 2.10 2.35 2.60 2.85 3.10 3.35 3.60 3.85 -50 -30 -10 Supply Voltage (V) 10 30 50 70 90 Temperature (℃) Figure 5. Current vs. Voltage, FRF = 433.92 / Figure 4. Current vs. Temperature, FRF = 868.35 MHz, SR = 1 ksps 433.92/868.35 MHz, SR = 1 ksps Sensitivity vs. Temperature Sensitivity vs. Supply Voltage -108 -107.0 -109 -108.0 -110 Sensitivity (dBm) Sensitivity (dBm) -109.0 -110.0 868.35 MHz -111.0 433.92 MHz -112.0 -111 -112 -113 868.35 MHz -113.0 -114 -114.0 -115 -115.0 433.92 MHz -116 1.6 1.9 2.2 2.5 2.8 3.1 3.4 3.7 4 -60 -40 -20 0 20 40 60 80 100 Temperature (℃) Supply Voltage (V) Figure 7. Sensitivity vs. Supply Voltage, SR Figure 6. Sensitivity vs. Temperature, FRF = 433.92 = 1 ksps, BER = 0.1% / 868.35 MHz, SR = 1 ksps, BER = 0.1% Sensitivity vs. BER Sensitivity vs. Symbol Rate -108 -90 -109 -110 Sensitivity (dBm) Sensitivity (dBm) -95 -100 -105 868.35 MHz -110 433.92 MHz -111 -112 -113 -114 -115 -115 -116 -120 0 5 10 15 20 25 30 35 40 -117 0.01% Symbol Rate (ksps) 868.35 MHz 433.92 MHz 0.10% 1.00% 10.00% Bit Error Rate Figure 8. Sensitivity vs. SR, FRF = 433.92 / Figure 9. Sensitivity vs. BER, FRF = 433.92 868.35 MHz, VDD = 3.3 V, BER = 0.1% / 868.35MHz, VDD = 3.3 V, SR = 1 ksps Rev 1.3 | Page 10/28 www.hoperf.com CMT2210/17A 4. Typical Application Schematic 9 NC 11 10 XOUT U1 CMT2210/17A GND CLKO VDD CSB X1 C2 J1 VDD 7 1 2 3 4 CSB C3 6 SDA SCL 5 5 DOUT NC SCL 8 4 1 CSB C0 DOUT 3 16 XIN SCL 15 VDD RFIN SDA 14 L1 2 C1 GND SDA 13 nRSTO ANT VCOP VCON 12 L2 Figure 10. Typical Application Schematic Notes: 1. Connector J1 is a must for the CMT2210/17A EEPROM access during development or manufacture. 2. The general layout guidelines are listed below. For more design details, please refer to “AN107 CMT221x Schematic and PCB Layout Design Guideline”.  Use as much continuous ground plane metallization as possible.  Use as many grounding vias (especially near to the GND pins) as possible to minimize series parasitic inductance between the ground pour and the GND pins. 3.  Avoid using long and/or thin transmission lines to connect the components.  Place C0 as close to the CMT2210/17A as possible for better filtering. The table below shows the BOM of typical application. Table 10. BOM of 433.92/868.35 MHz Typical Application Designator [1] Value (Match to 50Ω ANT) Value (Common Used ANT) 433.92 MHz 433.92 MHz Descriptions 868.35 MHz Unit Manufacturer 868.35 MHz CMT2210/17A, low-cost U1 300 – 960 MHz OOK - - - CMOSTEK 26 26 MHz EPSON nH Murata LQG18 nH Murata LQG18 pF Murata GRM15 stand-alone RF receiver X1 L1 ±20 ppm, SMD32*25 mm, crystal ±5%, 0603 multi-layer chip inductor ±5%, 0603 multi-layer chip L2[2] inductor, for QFN16 ±5%, 0603 multi-layer chip inductor, for SOP16 27 6.8 33 6.8 22 3.9 22 3.9 15 -- 15 -- 3.3 2.7 2.7 2.7 C1 ±0.25 pF, 0402 NP0, 50 V C0 ±20%, 0402 X7R, 25 V 0.1 0.1 uF Murata GRM15 C2, C3 ±5%, 0402 NP0, 50 V 27 27 pF Murata GRM15 Note: [1]. The 868.35 MHz application is for CMT2217A only. [2]. CMT2210A devices in QFN16 and SOP16 packages share the same BOM except for the L2. Rev 1.3 | Page 11/28 www.hoperf.com CMT2210/17A 5. Functional Descriptions AGC I-LMT I-MXR RFI Image Rejection Band-pass Filter LNA GND Q-MXR OOK DEMOD RSSI CSB Radio Controller SAR 3-wire SPI AFC & AGC SCL SDA Q-LMT VCO Loop Filter LO GEN PFD/CP 26 MHz EEPROM LDOs DIVIDER LPOSC VDD GND Bandgap AFC & Σ-Δ Modulator XOSC CLKO DOUT POR VCON VCOP nRSTO XIN XOUT Figure 11. Functional Block Diagram 5.1 Overview The CMT2210/17A devices are ultra low power, high performance, low-cost OOK stand-alone RF receiver for various 300 to 960 MHz wireless applications. The CMT2210A covers the frequency range from 300 to 480 MHz while the CMT2217A covers the 300 to 960 MHz frequency range. They are part of the CMOSTEK NextGenRFTM family, which includes a complete line of transmitters, receivers and transceivers. The chip is based on a fully integrated, low-IF receiver architecture. The low-IF architecture facilitates a very low external component count and does not suffer from powerline - induced interference problems. The synthesizer contains a VCO and a low noise fractional-N PLL with an output frequency resolution of 24.8 Hz. The VCO operates at 2x the Local Oscillator (LO) frequency to reduce spurious emissions. Every analog block is calibrated on each Power-on Reset (POR) to the internal reference voltage. The calibration helps the device to finely work under different temperatures and supply voltages. The baseband filtering and demodulation is done by the digital demodulator. The demodulated signal is output to the external MCU via the DOUT pin. No external MCU control is needed in the applications. The 3-wire SPI interface is only used for configuring the device. The configuration can be done with the RFPDK and the USB Programmer. The RF Frequency, symbol rate and other product features are all configurable. This saves the cost and simplifies the design, development and manufacture. Alternatively, in stock products of 433.92/868.35 MHz are available for immediate demands with no need of EEPROM programming. The CMT2210/17A operates from 1.8 to 3.6 V so that it can finely work with most batteries to their useful power limits. The receive current is only 3.8 mA at 433.92 MHz and 5.2 mA at 868.35 MHz. The CMT2210/17A receiver together with the CMT211x transmitter enables an ultra low cost RF link. 5.2 Modulation, Frequency and Symbol Rate The CMT2210/17A supports OOK demodulation with the symbol rate from 0.1 to 40 ksps. The CMT2210A continuously covers the frequency range from 300 to 480 MHz, including the license free ISM frequency band around 315 MHz and 433.92 MHz. And the CMT2217A covers the frequency range from 300 MHz to 960 MHz, including the license free ISM frequency band around 315 MHz, 433.92 MHz, 868.35 MHz and 915 MHz. The internal frequency synthesizer contains a high-purity VCO and a low noise fractional-N PLL with an output frequency resolution of 24.8 Hz. See the table below for the demodulation, frequency and symbol rate information. Rev 1.3 | Page 12/28 www.hoperf.com CMT2210/17A Table 11. Modulation, Frequency and Symbol Rate Parameter Value Demodulation Unit OOK - Frequency (CMT2210A) 300 to 480 MHz Frequency (CMT2217A) 300 to 960 MHz Frequency Resolution Symbol Rate 24.8 Hz 0.1 to 40 ksps 5.3 Embedded EEPROM and RFPDK The RFPDK is a PC application developed to help the user to configure the CMOSTEK NextGenRFTM products in the most intuitional way. The user only needs to connect the USB Programmer between the PC and the device, fill in/select the proper value of each parameter on the RFPDK, and click the “Burn” button to program the configurations into the device. The configurations of the device will then remain unchanged until the next programming. No external MCU control is required in the application program. The RFPDK also allows the user to save the active configuration into a list by clicking on the “List” button, so that the saved configuration can be directly reloaded from the list in the future. Furthermore, it supports exporting the configuration into a hexadecimal file by clicking on the “Export” button. This file can be used to burn the same configuration into a large amount of devices during the mass production. See the figure below for the accessing of the EEPROM. CMT2210/17A RFPDK EEPROM CSB Interface SCL SDA CMOSTEK USB Programmer Figure 12. Accessing Embedded EEPROM For more details of the CMOSTEK USB Programmer and the RFPDK, please refer to “AN103 CMT211xA-221xA One-Way RF Link Development Kits Users Guide”. 5.4 All Configurable Options Beside the demodulation, frequency and symbol rate, more options can be used to customize the device. The following is a table of all the configurable options. On the RFPDK, the Basic Mode only contains a few options allowing the user to perform easy and fast configurations. The Advanced Mode shows all the options that allow the user to customize the device in a deeper level. The options in “Basic Mode” are a subset of that in the “Advanced Mode”. Rev 1.3 | Page 13/28 www.hoperf.com CMT2210/17A Table 12. Configurable Parameters in RFPDK Category Parameters Frequency (CMT2210A) Frequency (CMT2217A) Demodulation Symbol Rate RF Settings Descriptions The receive radio frequency, the range is from 300 to 480 MHz, with resolution of 0.001 MHz. The receive radio frequency, the range is from 300 to 960 MHz, with resolution of 0.001 MHz. The demodulation type, only OOK demodulation is supported in this product. The receiver symbol rate, the range is from 0.1 to 40 ksps, with resolution of 0.1 ksps. Squelch TH The threshold of the squelch circuit to suppress (CMT2210A/CMT2217A) the noise, the range is from 0 to 255. Default Mode Basic 433.920 MHz Advanced Basic 868.350 MHz Advanced Basic OOK Advanced Basic 2.4 ksps Advanced Basic 54 / 40 Advanced The sum of the crystal frequency tolerance of Xtal Tol. | Rx BW (CMT2210A/CMT2217A) the Tx and the Rx, the range is from 0 to ±300 ±150 ppm | 200 kHz Basic ppm. And the calculated BW is configured and / ±40 ppm | 100 kHz Advanced displayed. Time for the device to wait for the crystal to get Xtal Stabilizing Time settled after power up. The options are: 78, 155, 310 us 310, 620, 1240 or 2480 us. Duty-Cycle Mode Sleep Time Rx Time Turn on/off the duty-cycle receive mode, the options are: on or off. The sleep time in duty-cycle receive mode, the range is from 3 to 134,152,192 ms. The receive time in duty-cycle receive mode, the range is from 0.04 to 2,683,043.00 ms. On 3 ms 2,000 ms Basic Advanced Basic Advanced Basic Advanced Basic Advanced The extended receive time in duty-cycle receive Rx Time Ext mode, the range is from 0.04 to 2,683,043.00 200.00 ms Advanced Off Advanced ms. It is only available when WOR is on. Wake-On Radio Operation Settings Turn on/off the wake-on radio function, the options are: on or off. The condition to wake on the radio. The options Wake-On Condition are: Extended by Preamble, or Extended by RSSI. It is only available when WOR is on. System Clock Output Turn on/off the system clock output on CLKO, the options are: on or off. Extended by Preamble Advanced Off Advanced 6.5 MHz Advanced Peak TH Advanced 60 / 50 Advanced The system clock output frequency, the options are: 13.000, 6.500, 4.333, 3.250, 2.600, 2.167, System Clock Frequency 1.857, 1.625, 1.444, 1.300, 1.182, 1.083, 1.000, 0.929, 0.867, 0.813, 0.765, 0.722, 0.684, 0.650, 0.619, 0.591, 0.565, 0.542, 0.520, 0.500, 0.481, 0.464, 0.448, 0.433, 0.419 or 0.406 MHz. It is only available when System Clock Output is on. Demod Method are: Peak TH, or Fixed TH The threshold value when the Demod Method is OOK Settings The OOK demodulation methods, the options Fixed Demod TH (CMT2210A/CMT2217A) “Fixed TH”, the minimum input value is the value of Squelch Threshold set on the RFPDK, the maximum value is 255. Rev 1.3 | Page 14/28 www.hoperf.com CMT2210/17A Category Parameters Peak Drop Peak Drop Step Descriptions Turn on/off the RSSI peak drop function, the options are on, or off. The RSSI peak drop step, the options are: 1, 2, 3, 5, 6, 9, 12 or 15. The RSSI peak drop rate, the options are: 1 Peak Drop Rate step/4 symbols, 1 step/2 symbols, 1 step /1 symbol, or 1 step/0.5 symbol. AGC Decode Settings Automatic Gain Control, the options are: on or off. Default Mode On Advanced 1 Advanced 1 step / 4 symbols Advanced On Advanced 2-byte Advanced The size of the valid preamble, the options are: Preamble 1-byte, 2-byte, 3-byte, or 4-byte. It is only available when WOR is on. 5.5 Internal Blocks Description 5.5.1 RF Front-end and AGC The CMT2210/17A features a low-IF receiver. The RF front-end of the receiver consists of a Low Noise Amplifier (LNA), I/Q mixer and a wide-band power detector. Only a low-cost inductor and a capacitor are required for matching the LNA to any common used antennas. The input RF signal induced on the antenna is amplified and down-converted to the IF frequency for further processing. By means of the wide-band power detector and the attenuation networks built around the LNA, the Automatic Gain Control (AGC) loop regulates the RF front-end’s gain to get the best system linearity, selectivity and sensitivity performance, even though the receiver suffers from strong out-of-band interference. 5.5.2 IF Filter The signals coming from the RF front-end are filtered by the fully integrated 3rd-order band-pass image rejection IF filter which achieves over 35 dB image rejection ratio typically. The IF center frequency is dynamically adjusted to enable the IF filter to locate to the right frequency band, thus the receiver sensitivity and out-of-band interference attenuation performance are kept optimal despite the manufacturing process tolerances. The IF bandwidth is automatically computed according to the three basic system parameters input from the RFPDK: RF frequency, Xtal tolerance, and symbol rate. 5.5.3 RSSI The subsequent multistage I/Q Log amplifiers enhance the output signal from IF filter before it is fed for demodulation. Receive Signal Strength Indicator (RSSI) generators are included in both Log amplifiers which produce DC voltages that are directly proportional to the input signal level in both of I and Q path. The resulting RSSI is a sum of both these two paths. Extending from the nominal sensitivity level, the RSSI achieves over 66 dB dynamic range. The CMT2210/17A integrates a patented DC-offset cancellation engine. The receiver sensitivity performance benefits a lot from the novel, fast and accurate DC-offset removal implementation. 5.5.4 SAR ADC The on-chip 8-bit SAR ADC digitalizes the RSSI for OOK demodulation. Rev 1.3 | Page 15/28 www.hoperf.com CMT2210/17A 5.5.5 Crystal Oscillator The crystal oscillator is used as the reference clock for the PLL frequency synthesizer and system clock for the digital blocks. A 26 MHz crystal should be used with appropriate loading capacitors (C2 and C3 in Figure 10 of Page 11). The values of the loading capacitors depend on the total load capacitance CL specified for the crystal. The total load capacitance seen between the XIN and XOUT pin should equal CL for the crystal to oscillate at 26 MHz. CL = 1 + Cparasitic 1 1 + C3 C2 The parasitic capacitance is constituted by the input capacitance and PCB tray capacitance. The ESR of the crystal should be within the specification in order to ensure a reliable start-up. An external signal source can easily be used in place of a conventional XTAL and should be connected to the XIN pin. The incoming clock signal is recommended to have a peak-to-peak swing in the range of 300 mV to 700 mV and AC-coupled to the XIN pin. 5.5.6 Frequency Synthesizer A fractional-N frequency synthesizer is used to generate the LO frequency for the down conversion I/Q mixer. The frequency synthesizer is fully integrated except the VCO tank inductor which enables the ultra low-power receiver system design. Using the 26 MHz reference clock provided by the crystal oscillator or the external clock source, it can generate any receive frequency between 300 to 480 MHz with a frequency resolution of 24.8 Hz. The VCO always operates at 2x of LO frequency. A high Q (at VCO frequency) tank inductor should be chosen to ensure the VCO oscillates at any conditions meanwhile burns less power and gets better phase noise performance. In addition, properly layout the inductor matters a lot of achieving a good phase noise performance and less spurious emission. The recommended VCO inductors for different LO frequency bands are shown as bellow. Table 13. VCO Inductor for 315/433.92/868.35/915 MHz Frequency Band LO Frequency Band (MHz) 315 433.92 868.35 915 VCO Inductor for QFN16 package (nH) 33 22 3.9 3.9 VCO Inductor for SOP16 package (nH) 27 15 -- -- Multiple subsystem calibrations are performed dynamically to ensure the frequency synthesizer operates reliably in any working conditions. 5.5.7 LPOSC An internal 1 kHz low power oscillator is integrated in the CMT2210/17A. It generates a clock to drive the sleep timer to periodically wake the device from sleep state. The Sleep Time can be configured from 3 to 134,152,192 ms (more than 37 hours) when the device works in duty-cycle receive mode. Since the frequency of the LPOSC drifts when the temperature and supply voltage change, it is automatically calibrated during the PUP state, and is periodically calibrated since then. The calibration scheme allows the LPOSC to maintain its frequency tolerance to less than ±1%. 5.6 Operation Mode An option “Duty-Cycle On-Off” on the RFPDK allows the user to determine how the device behaves. The device is able to work in two operation modes, as shown in the figure below. Rev 1.3 | Page 16/28 www.hoperf.com CMT2210/17A PUP PUP SLEEP SLEEP RX XTAL TUNE TUNE RX Always Receive Mode (“Duty-Cycle Mode” is set to Off ) Duty-Cycle Receive Mode (“Duty-Cycle Mode” is set to On ) Figure 13. Two different operation modes Power Up (PUP) State Once the device is powered up, the device will go through the Power Up (PUP) sequence which includes the task of releasing the Power-On Reset (POR), turning on the crystal and calibrating the internal blocks. The PUP takes about 4 ms to finish in the always receive mode, and about 9.5 ms to finish in the duty-cycle receive mode. This is because that the LPOSC and sleep timer is turned off in the always receive mode, while it must be turned on and calibrated during the PUP in the duty-cycle receive mode. The average current of the PUP sequence is about 0.9 mA. SLEEP State In this state, all the internal blocks are powered down except the sleep timer. In Always Receive Mode, the sleep time is fixed at about 3 ms. In Duty-Cycle Receive Mode, the sleep time is defined by the option “Sleep Time” on the RFPDK. The sleep current is about 60 nA in the always receive mode, and about 440 nA (with LPOSC and sleep timer turned on) in the duty-cycle receive mode. XTAL State The XTAL state only exists in the duty-cycle receive mode. Once the device wakes up from the SLEEP State, the crystal oscillator restarts to work. The option “XTAL Stabilizing Time” on the RFPDK defines the time for the device to wait for the crystal oscillator to settle. The current consumption in this state is about 520 uA. TUNE State The device is tuned to the desired frequency defined by the option “Frequency” on the RFPDK and ready to receive. It usually takes approximately 300 us to complete the tuning sequence. The current consumption in this state is about 2 mA. RX State The device receives the incoming signals and outputs the demodulated data from the DOUT pin. In duty-cycle receive mode, the device only stays in the RX State for a certain amount of time, which is defined by the option “Rx Time” on the RFPDK. The current in this state is about 3.8 mA. 5.7 Always Receive Mode If the duty-cycle receive mode is turned off, the device will go through the Power Up (PUP) sequence, stay in the SLEEP state for about 3 ms, tune the receive frequency, and finally stay in the RX state until the device is powered down. The power up sequence, which takes about 4 ms to finish, includes the task of turning on the crystal and calibrating the internal blocks. The device will continuously receive the incoming RF signals during the RX state and send out the demodulated data on the DOUT pin. The configurable system clock is also output from the CLKO pin if it is enabled in the Advanced Mode on the RFPDK. The figure below shows the timing characteristics and current consumption of the device from the PUP to RX. Rev 1.3 | Page 17/28 www.hoperf.com CMT2210/17A Data (DOUT pin) System Clock (CLKO pin) 3.8 mA Current 2.0 mA 900 uA 440 nA SLEEP PUP about 4 ms about 3 ms State RX TUNE about 300 us Figure 14. Timing and Current Consumption for Always Receive Mode 5.8 Duty-Cycle Receive Mode If the duty-cycle mode is turned on, after the PUP the device will automatically repeat the sequence of SLEEP, XTAL, TUNE and RX until the device is powered down. This allows the device to re-tune the synthesizer regularly to adept to the changeable environment and therefore remain its highest performance. The device will continuously receive any incoming signals during the RX state and send out the demodulated data on the DOUT pin. The configurable system clock output is output from the CLKO pin during the TUNE and RX state. The PUP sequence consumes about 9.5 ms which is longer than the 4 ms in the Always Receive Mode. This is because the LPOSC, which drives the sleep timer, must be calibrated during the PUP. Data (DOUT pin) System Clock (CLKO pin) 3.8 mA 3.8 mA Current 2.0 mA 900 uA 440 nA 2.0 mA 520 uA PUP SLEEP XTAL about 9.5 ms Sleep Time Xtal Stabilizing Time 440 nA TUNE about 300 us 520 uA RX SLEEP XTAL TUNE Rx Time Sleep Time Xtal Stabilizing Time about 300 us RX State Rx Time Figure 15. Timing and Current Consumption for Duty-Cycle Receive Mode It is strongly recommended for the user to turn on the duty-cycle receive mode option. The advantages are:  Maintaining the highest performance of the device by regular frequency re-tune.  Increasing the system stability by regular sleep (resetting most of the blocks).  Saving power consumptions of both of the Tx and Rx device. As long as the Sleep Time and Rx Time are properly configured, the transmitted data can always be captured by the device. Rev 1.3 | Page 18/28 www.hoperf.com CMT2210/17A 5.9 Easy Duty-Cycle Configurations When the user wants to take the advantage of maintaining the highest system stability and performance, and the power consumption is not the first concern in the system, the Easy Configuration can be used to let the device to work in the duty-cycle mode without complex calculations, the following is a good example: TX Data T = Packet Length (72 ms) A missed packet Two missed packets RX State SLEEP, XTAL and TUNE T = Sleep Time (3 ms) + XTAL Stabilizing Time (310 us) + Tuning Time (300 us) = 3.61 ms time RX T = Rx Time (1000 ms) output data corrupted output data corrupted Data (DOUT pin) Figure 16. Tx and Rx relationship of Easy Configuration In this example, the Tx device transmits the data at 1.2 ksps and there are 60 symbols in one data packet. Thus, the packet length is 50 ms. The user can do the following:  Set the Sleep Time to the minimum value of 3 ms.  Set the Rx Time to 1 second which is much longer than the packet length.  Let the Tx device to send out 3 continuous data packets in each transmission. Because the Sleep Time is very short, the non-receive time is only about 3.61 ms (the sum of the Sleep Time, XTAL stabilizing time and the tuning time), which is much shorter than the packet length of 50 ms. Therefore, this non-receive time period will only have a change to corrupt no more than 2 packets receiving. During the non-receive time period, the DOUT pin will output logic 0. Because the Rx Time is very long, and 3 continuous data packets are sent in each transmission, there is at least 1 packet that can be completely received by the device and sent out via the DOUT pin with no corruption. The external MCU will only need to observe the DOUT pin status to perform data capturing and further data processing. If the system power consumption is a sensitive and important factor in the application, the Precise Configuration can be used. Also, based on the duty-cycle receive mode, the “Wake-On Radio” technique allows the device to even save more power. For the precise duty-cycle configurations and the use of wake-on radio, please refer to the “AN108 CMT2210/17A Configuration Guideline”. 5.10 The nRSTO By default, an active low reset signal is generated by the internal POR and output via the nRSTO pin. It can be used to reset the external MCU if it is required. Rev 1.3 | Page 19/28 www.hoperf.com CMT2210/17A Trise VDD Vth TPOR (POR) nRSTO Figure 17. nRSTO Timing Characteristics On the above figure, Trise is the time taken for the VDD to rise from 0 V to its ultimate stabilized level. After the internal Power-On Reset circuit detects that the VDD has risen over the threshold voltage (Vth), it takes the time TPOR for the POR to change its state from logical 0 to 1. The Vth is about 1.2 V. The value of TPOR varies according to the time taken for the VDD to rise from 0 to 3 V, as listed in the table below. When the VDD falls, the nRSTO follows with the VDD simultaneously. Table 14. TPOR Timing Characteristics TRISE (us) TPOR (us) 3,000 500 1,000 300 300 160 100 100 30 70 10 60 5.11 The CLKO A clock divided down from the crystal oscillator clock is output via the CLKO pin if the “System Clock Output” is set to “On” on the RFPDK. This clock can be used to drive the external MCU, and is available when the device is in the XTAL, TUNE and RX states. The clock frequency is selected by the option “System Clock Frequency”. More details of using the CLKO can be referred to the “AN108 CMT2210/17A Configuration Guideline”. Rev 1.3 | Page 20/28 www.hoperf.com CMT2210/17A 6. Ordering Information Table 15. CMT2210/17A Ordering Information Part Number CMT2210A-EQR[1] CMT2210A-ESR[1] CMT2210A-ESB[1] CMT2217A-EQR[1] Descriptions Low-Cost 300 – 480 MHz OOK Stand-Alone RF Receiver Low-Cost 300 – 480 MHz OOK Stand-Alone RF Receiver Low-Cost 300 – 480 MHz OOK Stand-Alone RF Receiver Low-Cost 300 – 960 MHz OOK Stand-Alone RF Receiver Package Package Type Option QFN16 (3x3) Tape & Reel SOP16 Tape & Reel SOP16 Tube QFN16 (3x3) Tape & Reel Operating MOQ / Condition Multiple 1.8 to 3.6 V, -40 to 85 ℃ 1.8 to 3.6 V, -40 to 85 ℃ 1.8 to 3.6 V, -40 to 85 ℃ 1.8 to 3.6 V, -40 to 85 ℃ 5,000 2,500 1,000 5,000 Note: [1]. “E” stands for extended industrial product grade, which supports the temperature range from -40 to +85 ℃. “Q” stands for the package type of QFN16 (3x3). “S” stands for the package type of SOP16. “R” stands for the tape and reel package option, the minimum order quantity (MOQ) is 5,000 pieces for QFN package type and 1,000 pieces for SOP package type. “B” stands for the tube package option, the MOQ is 1,000 pieces for SOP16 package type. The default frequency for CMT2210A is 433.920 MHz, and for CMT2217A is 868.350 MHz. Please refer to the Table 12 in Page 14 for details of other settings. Visit www.cmostek.com/products to know more about the product and product line. Contact sales@cmostek.com or your local sales representatives for more information. Rev 1.3 | Page 21/28 www.hoperf.com CMT2210/17A 7. Package Outline The 16-pin QFN 3x3 illustrates the package details for the CMT2210/17A. The table below lists the values for the dimensions shown in the illustration. D e L b E2 E D2 16 16 1 1 Bottom View c A1 A Top View Side View Figure 18. 16-Pin QFN 3x3 Package Table 16. 16-Pin QFN 3x3 Package Dimensions Symbol Size (millimeters) Min Max A 0.7 0.8 A1 — 0.05 b 0.18 0.30 c 0.18 0.25 D 2.90 3.10 D2 1.55 1.75 e 0.50 BSC E 2.90 3.10 E2 1.55 1.75 L 0.35 0.45 Rev 1.3 | Page 22/28 www.hoperf.com CMT2210/17A The CMT2210A is also available in the SOP16 package, see below figures and tables for the dimension details. D A3 h A2 A 0.25 c A1 θ L L1 E1 b E e Figure 19. SOP16 Package Table 17. SOP16 Package Dimensions Size (millimeters) Symbol Min Typ Max A - - 1.75 A1 0.05 - 0.225 A2 1.30 1.40 1.50 A3 0.60 0.65 0.70 b 0.39 - 0.48 c 0.21 - 0.26 D 9.70 9.90 10.10 E 5.80 6.00 6.20 E1 3.70 3.90 4.10 e 1.27 BSC h 0.25 - 0.50 L 0.50 - 0.80 L1 θ 1.05 BSC 0 - Rev 1.3 | Page 23/28 8° www.hoperf.com CMT2210/17A 8. Top Marking 8.1 CMT2210/17A Top Marking 2 1 0 A 2 1 7 A ①②③④ ①②③④ Y WW Y WW Figure 20. CMT2210 (Left) and CMT2217A (Right) Top Marking in QFN16 Package Table 18. CMT2210/17A QFN16 Top Marking Explanation Mark Method Laser Pin 1 Mark Circle’s diameter = 0.3 mm Font Size 0.5 mm, right-justified Line 1 Marking Line 2 Marking Line 3 Marking 210A, represents part number CMT2210A 217A, represents part number CMT2217A ①②③④ Internal tracking number Date code assigned by the assembly house. Y represents the last digit of the mold year and WW represents the workweek Rev 1.3 | Page 24/28 www.hoperf.com CMT2210/17A CMT 2 2 1 0 A Y Y W W ①②③④⑤⑥ Figure 21. CMT2210A Top Marking in SOP16 Package Table 19. CMT2210A SOP16 Top Marking Explanation Mark Method Laser Pin 1 Mark Circle’s diameter = 1 mm Font Size 0.35 mm, right-justified Line 1 Marking CMT2210A, represents part number CMT2210A YYWW is the Date code assigned by the assembly house. YY represents the last two digits of the Line 2 Marking mold year and WW represents the workweek ①②③④⑤⑥ is the internal tracking number Rev 1.3 | Page 25/28 www.hoperf.com CMT2210/17A 9. Other Documentations Table 20. Other Documentations for CMT2210/17A Brief AN103 AN107 AN108 Name Descriptions CMT211xA-221xA One-Way RF Link Development Kits Users Guide User’s Guides for CMT211xA and CMT221xA Development Kits, including Evaluation Board and Evaluation Module, CMOSTEK USB Programmer and RFPDK. CMT221x Schematic and PCB Layout Design Guideline Details of CMT2210/13/17/19A and CMT2210L PCB schematic and layout design rules, RF matching network and other application layout design related issues. CMT2210/17A Configuration Guideline Details of configuring CMT2210/17A features on the RFPDK. Rev 1.3 | Page 26/28 www.hoperf.com CMT2210/17A 10. Document Change List Table 21. Document Change List Rev. No. Chapter Description of Changes 0.9 All Initial released version 2014-06-14 1.0 5 Update Section 5.7 and Figure 14 2014-06-30 1.1 All Add Product CMT2217A to the datasheet 2015-01-23 1.2 All Add SOP16 to product CMT2210A 2015-05-04 1.3 All Update the VCO inductor for CMT2210A in SOP16 package 2015-06-17 Rev 1.3 | Page 27/28 Date www.hoperf.com CMT2210/17A 11. Contact Information Hope Microelectronics Co., Ltd Address: 2/F,Building3,Pingshan Private Enterprise science and Technology Park,Xili Town,Nanshan District,Shenzhen,China Tel: +86-755-82973805 Fax: +86-755-82973550 Email: sales@hoperf.com hoperf@gmail.com Website: http://www.hoperf.com http://www.hoperf.cn Copyright. CMOSTEK Microelectronics Co., Ltd. All rights are reserved. The information furnished by CMOSTEK is believed to be accurate and reliable. However, no responsibility is assumed for inaccuracies and specifications within this document are subject to change without notice. The material contained herein is the exclusive property of CMOSTEK and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of CMOSTEK. CMOSTEK products are not authorized for use as critical components in life support devices or systems without express written approval of CMOSTEK. The CMOSTEK logo is a registered trademark of CMOSTEK Microelectronics Co., Ltd. All other names are the property of their respective owners. Rev 1.3 | Page 28/28 www.hoperf.com
CMT2210A-EQR 价格&库存
很抱歉,暂时无法提供与“CMT2210A-EQR”相匹配的价格&库存,您可以联系我们找货
CMT2210A-EQR
    • 1+3.99600
    • 10+3.21840
    • 30+2.82960
    • 100+2.44080
    • 500+2.21400
    • 1000+2.09520
    库存:4601
