SC1200-270-ASC
SC1200-270-ASC
    LICAP
    插件
    1200 F (EDLC) 超级电容器 2.7 V 轴向,CAN - 螺丝端子 0.58 毫欧 65°C 时为 1500 小时
SC1200-270-ASC 数据手册
2.7V, 1200F Ultracapacitor Cell SC1200-270-ASC Specifications Capacitance Voltage ESR Rated1 1200F Tolerance -0/+20% Rated 2.7V DC Surge 2.85V DC ESR (DC) - typical 0.40mΩ 2 ESR (DC) - maximum initial 0.58mΩ Maximum leakage 2.7mA Maximum peak 950A 3 Current Maximum continuous current (ΔT = 15℃)4 70A RMS Maximum continuous current (ΔT = 40℃) 110A RMS Maximum energy5 1.22Wh 4 Energy Storage Power Density Usable energy 0.91Wh 6 Volumetric energy density 5.06Wh/L Gravametric energy density8 3.65Wh/kg Power density 6033W/kg 7 9 Temperature APPLICATIONS • Engine Starting • Industrial Backup Power • Renewable Energy Systems • Hybrid Power Systems • Energy Harvesting Temperature Characteristics Operating Temperature Range10 -40℃ to +65℃ Storage Temperature Range -50℃ to +70℃ Standards, Safety & Environmental Short Circuit Current Safety 4600A • This product may vent or rupture if overcharged, reverse charged incinerated or heated above 100°C • Do not crush, mutilate, or disassemble • Do not dispose of unit in trash Service Lifetime Endurance FEATURES & ADVANTAGES • One Million Cycles Lifetime • Esceptional Low Temperature Performance • 10-15 year calendar life Change in capacitance (% drop from rated) ≤20% Change in ESR (% increase from maximum initial) ≤100% Product held at rated voltage in 25℃ environment DC Life Projected Life 10+ years Change in capacitance (% drop from rated) ≤20% Change in ESR (% increase from maximum initial) ≤100% Cycling from rated voltage to 50% voltage under constant current in 25℃ environment • Ultra High Power Density • Ultra Low Internal Resistance Product held at rated voltage in 65℃ environment for 1500 hours Cycle Life Storage Life Projected Life 1,000,000 cycles Change in capacitance (% drop from rated) ≤20% Change in ESR (% increase from maximum initial) ≤100% Stored uncharged in original packaging in 25℃ environment Life Physical Characteristics Mechanical 4 years Operation Vibration IEC60068-2-6, SAE J380 Impact IEC60068-2-27, SAE J2464 2.7V, 1200F Ultracapacitor Cell Outline Drawings: Weight and Size: Weight: 250g | Size: 63.2 L/mm, 60.2 D/mm Naming Rules: Type Supercapacitor Cell SC Capacitance Dash Rated Voltage Dash Termination 1200 = 1200F - 270 = 2.7V - ASC = Axial Screw Notes: 1. Measure capacitance and DC internal resistance at 25℃ under specified test current per Figure 1 +1 V4 0 0 Time t1 V1 = Vrated t2 - t1 = 15 seconds V3 = 0.5 x Vrated t4 - t3 = 5 seconds t2 t3 t4 Capacitor Current Capacitor Voltage V2 V3 Voltage Current -1 Capacitance = I x (t3-t2)/(V2-V3) ESR = (V4 - V3)/I Figure 1 3. Corresponding current value after 72 hours of rated voltage at 25℃ 4. T=I x ESR x Rca 0.12V2 ESRDC x weight(kg) 10. Test after the sample has been maintained at -50℃ for 16 hours and the temperature raised 10℃ each time and maintained for 1 hour, then test the sample Figure 2 200% 190% 180% ESR Capacitance 170% 160% 150% 140% 130% 120% 110% 100% 90% 80% Temperature 5. 0.5CV /3600 6. 0.5C(V 6 -60 -50 -40 -30 -20 -10 0 10 20 30 40 50 60 70 2 2 nom 2 9. Per IEC62391-2 Pd = 2. Surge voltage is non-repeatable and duration cannot exceed 1s 2 rms ( πr (mm)1x10x L(mm) ) 8. Whusable/weight(kg) CAP/ESR Measurement Waveform V1 7. Whusable/ Figure 2 -V 2 min )/3600 Axial weldable version available, please contact LICAP for details Specifications are subject to change without notice. LICAP Technologies, Inc. 9795 Business Park Drive - Sacramento, CA 95827 USA https://licaptech.com/ • info@licaptech.com MAY 27, 2020
SC1200-270-ASC 价格&库存
很抱歉,暂时无法提供与“SC1200-270-ASC”相匹配的价格&库存,您可以联系我们找货
