D150D48Z501ZR/LS500
D150D48Z501ZR/LS500
    CALRAMIC
    插件
    500 pF -20%,+80% 15000V(15kV) 陶瓷电容器 Z5U 径向,圆片式
D150D48Z501ZR/LS500 数据手册
1. Lead Size: D30, D40 @ 0.025" Dia (#22 AWG) [0.64mm] D50 & Larger @ 0.032" Ø (#20 AWG) [0.81mm] 2. Standard / RoHS - 100% Tin Plate 3. Order of marking may vary depending on size of capacitor PerfoUPDQFH &hDUDFWHULVWLFV General Information 1. Custom voltages, package sizes and capacitance values available. Contact factory. 2. Higher voltage parts may require further encapsulation to prevent surface arc-over and breakdown. When required, parts should first be cleaned, and oven dried at +85°C. Silicone rubbers or a suitable epoxy may be used and de-airing of encapsulates is recommended. 3. Testing of higher voltage parts before installation and / or supplemental encapsulation, may be done in a suitable, non-contaminating dielectric fluid like FC-40. 4. Large ceramic capacitors, even leaded devices are susceptible to damage when exposed to thermal and / or mechanical shock. Refer to Technical Bulletin AN103 for handling and installation recommendations. 4 &57 5ev 1211-DKA (OHFWULFDO0HFKDQLFDO&KDUDFWHULVWLFV 5 &57 5ev 1211-DKA 3DUW1XPEHU2UGHULQJ,QIRUPDWLRQ PeUfRUPDQFe &KDUWV 7\SLFDO &ODVV,,7HPSHUDWXUH&RHIÀFLHQW VROWDJe Coefficient 6 1327HPSHUDWXUH&RHIÀFLHQW &DSDFLWDQFH9V)UHTXHQF\ &57 5ev 1211-DKA
D150D48Z501ZR/LS500 价格&库存
很抱歉,暂时无法提供与“D150D48Z501ZR/LS500”相匹配的价格&库存,您可以联系我们找货
