SKELCAP SCA0300
SKELCAP SCA0300
    SKELETON
    插件
    300 F (EDLC) 超级电容器 2.85 V 径向,罐形 - 焊接耳片 1.6 毫欧 65°C 时为 1500 小时
SKELCAP SCA0300 数据手册
DATA SHEET ULTRACAPACITOR + Capacitance 300 F + Extreme power density + Durable and safe aluminum casings + PCB solderable terminals + High cycle life >1,000,000 cycles + RoHS & UL810A compliant + In accordance with AEC-Q200 Note: Polarity of the cell is stated as following: center terminal for "-", can and 3-pillar PCB frame for "+". GENERAL SPECIFICATIONS Rated voltage VR Surge voltage Vs Specific energy Nominal specific power Practical specific power TEMPERATURE AND LIFE Operating temperature range Minimum Maximum Storage temperature range (uncharged) Minimum Maximum Life Lifetime at VR and +65 °C Capacitance decrease 20% against rated value; 1s ESR increase 100% against rated value Storage life @ RT, uncharged Cyclelife @ RT, between VR and VR/2 GENERAL VRated Rated capacitance DC 10ms ESR, rated DC 1s ESR, rated Maximum peak current, for 1 second1 Leakage current (at 2.85 V, 25 °C and 72 h, max) VALUE UNIT 2.85 3.0 5.3 32 20 V V Wh/kg kW/kg kW/kg VALUE UNIT -40 +65 °C °C -40 +50 °C °C 1500 Hours 10 1,000,000 Years Cycles VALUE UNIT 2.85 300 1.00 1.60 0.3 1.5 V F mΩ mΩ kA mA Copyright © 2019 Skeleton Technologies GmbH. All rights reserved. 01-DS-20190827-SCA0300-1A Page 1/3 SAFETY VALUE UNIT Short circuit current 3 kA ENERGY VALUE UNIT Energy2 Specific energy3 Energy density4 0.34 5.3 6.4 Wh Wh/kg Wh/L POWER* VALUE UNIT 32 39 kW/kg kW/L 1.3 20 24 kW kW/kg kW/L Nominal power*, calculated from 10 ms ESR (for comparison) Specific power, matched Impedance6 Power density, matched Impedance7 Practical power*, calculated from 1 s ESR (for engineering) Power, matched impedance5 Specific power, matched Impedance6 Power density, matched impedance7 STANDARDS AND CERTIFICATIONS Vibration Specification Shock Resistance Certifications Standards ISO 16750-3 Table 12 IEC60068-2-27 Shock Test RoHS REACH, UL810A, AEC-Q200 THERMAL* VALUE UNIT Thermal resistance, Rca, typical Thermal capacitance, Cth, typical Max continuous current, ΔT = 15°C8 Max continuous current, ΔT = 40°C8 10.8 60 37 61 °C/W J/°C A A PHYSICAL PARAMETERS VALUE UNIT Mass. Typical Volume Diameter Length 0.064 0.053 33 61.5 kg L mm mm Copyright © 2019 Skeleton Technologies GmbH. All rights reserved. 01-DS-20190827-SCA0300-1A Page 2/3 *Power values calculated using DC 10ms ESR ≈ AC 100Hz. Standard markings + Name of Manufacturer, Part number, Serial number, Rated voltage + Rated capacitance, Negative and positive terminals, Warning marking + Total energy in watt-hours Notes + Testing instructions available on www.skeletontech.com + All information provided on this data sheet and all subsequent ultracapacitors sales and testing are subject to Standard Terms of Service (ToS) available on www.skeletontech.com, document General Terms of Sale for Skeleton Technologies OÜ. Skeleton Technologies GmbH Sales and Headquarters Schücostraße 8, 01900 Großröhrsdorf, Germany info@skeletontech.com www.skeletontech.com Copyright © 2019 Skeleton Technologies GmbH. All rights reserved. 01-DS-20190827-SCA0300-1A Page 3/3
SKELCAP SCA0300 价格&库存
很抱歉,暂时无法提供与“SKELCAP SCA0300”相匹配的价格&库存,您可以联系我们找货
