PS115-1N
PS115-1N
    BANNER(邦纳)
    Module
    PS115-1N SENSOR INTERFACE MODULE
PS115-1N 数据手册
PS24-1 and PS115-1 Sensor Interface Power Supplies Datasheet • • • • • • • • • Optional mounts, plastic housing and brackets included. Low-cost interface between ac power supply and dc-operated sensors Power supply can source up to 100 milliamps Integral TEACH push button and remote TEACH function available on all models Integral SPDT relay isolates dc sensor output for ac applications LED indicators for Power ON and Output Active Easy-to-adjust 45° screw terminals for all electrical wiring Multiple mounting configurations using supplied hardware BENC-L enclosure available for NEMA 4X / IP55 applications Use a sinking (NPN) interface module model with an NPN-output sensor, and a sourcing (PNP) interface module model with a PNPoutput sensor. Input Models PS24-1N Output Sinking (NPN) 21 to 27V ac, 50/60 Hz PS24-1P 100 mA PS115-1N 105 to 130V ac, 50/60 Hz PS115-1P Relay Input Sourcing (PNP) Sinking (NPN) Sourcing (PNP) A sinking (NPN) interface module model must be used with an NPN-output sensor, and a sourcing (PNP) interface module model must be used with a PNP-output sensor. Overview This interface module combines the functions of a power supply, a TEACH button, and an SPDT relay to economically interface dc-operated sensors for ac applications. The interface accepts either a 24V ac or 115V ac power supply, depending on the model. It uses a transformer to isolate the input power supply from the dc sensor. The transformer output voltage is rectified and filtered to supply up to 100 milliamps to run dc sensors. 25 20 V Output (dc) An integral TEACH button can be used to activate the TEACH functions of a Banner Expert™ sensor. Remote TEACH capability also is available on all models (refer to hookup diagrams and sensor literature). Maximum AC Input Voltage 27V ac (PS24-1..) 130V ac (PS115-1..) The SPDT relay is controlled via the relay coil input. A dc sensor output (either sinking or sourcing, depending on interface module model) can be tied to the relay coil input. The module's amber LED is ON when the sensor output is active. The module's green LED is used as a power indicator. 15 Minimum AC Input Voltage 21V ac (PS24-1..) 105V ac (PS115-1..) 10 For sensor supply voltage and current requirements, refer to the chart. 5 0 20 0 40 60 80 100 Load Current dc (milliamps) NOTE: Ripple voltage is less than 1.2V at 100 mA load P/N 123566 Rev. C 9 Oct 2013 0 123566 1 PS24-1 and PS115-1 Sensor Interface Power Supplies 1. Output Indicator LED (amber) 2. TEACH button 3. Power Indicator LED (green) 1 2 3 Installing the PS24-1 or PS115-1 Power Supply The module must be isolated from conductive surfaces. It may be installed in a user-supplied housing using the four slots in the board’s corners, or it may be inserted into the supplied plastic housing. When you use the supplied housing, either insert the two DIN clips into the grooves on the housing’s underside and add the two end caps (shown), or install only the end caps and use the screw-holes in the end caps for mounting to a flat surface. Screws are provided for attaching the end caps to the housing. 2 www.bannerengineering.com - tel: 763-544-3164 P/N 123566 Rev. C PS24-1 and PS115-1 Sensor Interface Power Supplies Specifications Input Supply Voltage PS24-1: 21–27V ac, 47/63 Hz PS115-1: 105–130V ac, 47/63 Hz Voltage and Current Output Rating 100 mA, exclusive of relay coil input; see load curves Relay Input Voltage Range 12–30V dc Relay Output Rating SPDT Relay Maximum Switched Power: 150W, 1200VA Maximum Switched Current: 5A (resistive load) Maximum Switched Voltage: 30V dc, 250V ac Minimum Current and Voltage: 10 mA at 5V dc Mechanical Life: 10,000,000 operations Electrical Life: 100,000 operations at full load Relay Response Time 10 milliseconds Relay Input Resistance 470 ohms ±10% Indicators Green LED: Power applied Amber LED: Relay coil energized (output active) Construction Circuit board is shipped separate from housing. Plastic housing, end caps and DIN rail mounting hardware are supplied for user assembly. Connections Screw-clamp terminal block accepts 12–24 gauge wire Adjustments TEACH button Environmental Rating IP00; use BENC-L enclosure for NEMA 4X / IP55 rating. Operating Conditions Temperature: –40 to 70 °C (–40 to 158 °F) Max. Relative Humidity: 90% at 50 °C (122 °F) (non-condensing) Certifications CSA and UL approvals pending Dimensions Module With Plastic Housing Assembly 2X 11.8 mm (0.46") 2X 57.2 mm 2X 2.7 mm (0.11") [2.25"] 2X 3.3 mm [0.13"] 111.7 mm (4.40") 102.5 mm (4.04") 78.7 mm (3.10") 82.5 mm [3.25"] 4X R1.8 mm 43.2 mm (1.70") [R 0.07"] 2X R 2.7 mm (R 0.11") 31.7 mm [1.25"] 44.4 mm (1.75") 61.5 mm (2.42") 72.4 mm [2.85"] 86.4 mm (3.40") P/N 123566 Rev. C www.bannerengineering.com - tel: 763-544-3164 3 PS24-1 and PS115-1 Sensor Interface Power Supplies Hookup Diagrams NPN Input PS24-1P PS115-1P AC Relay Coil + IN N.O. – C T N.C. AUX* Teach V+ Sourcing Output V– Teach AC DC Sensor AC AC + IN N.O. – C T T N.C. – AUX* Remote Teach PS24-1N PS115-1N Relay Coil Teach V+ DC Sensor PNP Input Sinking Output V– Teach T – Remote Teach * AUX is an electrically isolated terminal. Accessories BENC-L • Corrosion-resistant plastic enclosure with clear polycarbonate cover to protect module • Rated NEMA 4X, IP55 • Includes o-ring and 4 each: 1/4"-20x30 and #8 self-tapping screws • Temperature rating –40 to 70 °C (–40 to 158 °F) 4x 1/4"-20 x 30 Screws 2xS Ø 8.3 mm [0.33"] 127.8 mm [5.03"] 55.9 mm [2.20"] 2x 1/2" NPSM thread 4X #8 Self-tapping Screw 87.6 mm [3.45"] 148.1 mm [5.83"] 167.4 mm [6.59"] 59.3 mm (2.34") PS24-1.. or PS115-1.. Module (Order separately) O-Ring Banner Engineering Corp Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. www.bannerengineering.com - tel: 763-544-3164
PS115-1N 价格&库存
很抱歉,暂时无法提供与“PS115-1N”相匹配的价格&库存,您可以联系我们找货
