TP44200SG
TP44200SG
    TAGORE
    VFQFN22
    电源开关/驱动器 22-QFN(5x7)
TP44200SG 数据手册
TP44200SG SUPERIOR GaN TP44200SG – 180mΩ, 650V GaN HEMT 1.0 Features • • • • • • • • • 650V, 180mΩenhancement mode power HEMT Adapt to various PWM controllers Zero reverse recovery Adjustable turn-on slew rate High switching frequency (>2MHz) Reverse conduction capable Enhanced thermal performance with NC center pad Simple and low cost interface circuit Direct PWM drive, no external VCC needed (Top view) (Bottom View) Figure 1 Device Image (22pin 5×7×0.85 mm QFN Package) 2.0 Topologies and Applications • • • • • • • As switching FETs in singles, or in pairs as half-bridges AC-DC, DC-DC, DC-AC converters PFC applications (standard and totem-pole) High frequency LLC converters Mobile chargers and laptop adapters LED and motor drives Server power supplies RoHS/REACH/Halogen Free Compliance 3.0 Description The SUPERIOR GaN TP44200SG is a 180mΩ, 650V GaN power HEMT device. It can be directly driven from a standard 12V PWM controller, or the new generations of 6V PWM controllers dedicated to GaN HEMT. No external VCC is needed in either case. This device has low input/output capacitances which allows switching at high frequency with minimum loss. Due to its high breakdown voltage and high reliability, it can be safely used to improve efficiency and power density while bringing down overall system cost at the same time. Its low inductance QFN package greatly helps to minimize various ground bounce related issues. Provision for controlled switching transition time helps reduce EMI very effectively. Figure 2 Functional Block Diagram 4.0 Ordering Information Table 1 Ordering Information Part Number Package Type TP44200SG 22 Pin 5×7×0.8mm QFN Revision 1.1 - 2022-01-17 Form Qty Tape and 3000 Reel Evaluation Board Reel Diameter Reel Width Orderable Part Number 13” (330mm) 18mm TP44200SG http://www.tagoretech.com TP44200SG-EVB Page 1 of 18
TP44200SG 价格&库存
很抱歉,暂时无法提供与“TP44200SG”相匹配的价格&库存,您可以联系我们找货
