NV6136A-RA
NV6136A-RA
    NAVITAS(纳微)
    VQFN30
    电源开关/驱动器 1:1 N 通道 8A 30-QFN(6x8)
NV6136A-RA 数据手册
NV6136A GaNFast™ Power IC with GaNSense™ Technology 1. Features GaNFast™ Power IC • • • • • • • • • Monolithically-integrated gate drive Wide VCC range (10 to 30 V) Programmable turn-on dV/dt 200 V/ns dV/dt immunity 800 V Transient Voltage Rating 700 V Continuous Voltage Rating Low 170 mΩ resistance Zero reverse recovery charge 2 MHz operation GaNSense™ Technology • • • • • QFN 6 x 8 mm Integrated loss-less current sensing Short-circuit protection Over-temperature protection Autonomous low-current standby mode Auto-standby mode input Simplified schematic 3. Description This GaNFast™ power IC integrates a high performance eMode GaN FET with integrated gate drive to achieve unprecedented high-frequency and high efficiency operation. GaNSense™ technology is also integrated which enables real-time, accurate sensing of voltage, current and temperature to further improve performance and robustness not achieved by any discrete GaN or discrete silicon device. GaNSense™ enables integrated loss-less current sensing which eliminates external current sensing resistors and increases system efficiency. GaNSense™ also enables short circuit and over-temperature protection to increase system robustness, while auto-standby mode increases light, tiny & no-load efficiency. These GaN ICs combine the highest dV/dt immunity, high-speed integrated drive and industrystandard low-profile, low-inductance, SMT QFN packaging to enable designers to achieve simple, quick and reliable solutions. Navitas’ GaN IC technology extends the capabilities of traditional topologies such as flyback, half-bridge, buck/boost, LLC and other resonant converters to reach MHz+ frequencies with very high efficiencies and low EMI to achieve unprecedented power densities at a very attractive cost structure. Small, low-profile SMT QFN • 6 x 8 mm footprint, 0.85 mm profile • Minimized package inductance • Large cooling pad Sustainability • RoHS, Pb-free, REACH-compliant • Up to 40% energy savings vs Si solutions • System level 4kg CO2 Carbon Footprint reduction Product Reliability • 20-year limited product warranty (see Section 14 for details) 2. Topologies / Applications • AC-DC, DC-DC, DC-AC • QR flyback, ACF, Buck, Boost, Half bridge, Full bridge, LLC resonant, Class D, PFC • Wireless power, Solar Micro-inverters • LED lighting, TV SMPS, Server, Telecom VIN 4. Typical Application Circuits VCC 30 RDD NC 9 to 24V VDD Loss-less Current Sensing VOUT+ S S S D VOUT- 23 1 S CS CSOUT SGND D D D NC SGND S D D 5V D D STBY S D 15 8 PWM S S S S S S D PGND HF QR Flyback Final Datasheet 1 Rev Oct. 11, 2022 NV6136A 5. Table of Contents 8.1. GaN Power IC Connections and Component Values ..................................................................... 13 1. Features ...................................................................1 2. Topologies / Applications ......................................1 8.2. UVLO Mode ..................................................... 15 3. Description ..............................................................1 8.3. Normal Operating Mode ................................... 16 4. Typical Application Circuits ..................................1 8.4. Low Power Standby Mode ............................... 17 5. Table of Contents ...................................................2 8.5. Programmable Turn-on dV/dt Control .............. 17 6. Specifications .........................................................3 8.6. GaNSenseTM Technology Loss-Less Current Sensing ................................................................... 18 6.1. Absolute Maximum Ratings(1) .............................3 6.2. Recommended Operating Conditions(3) ..............4 8.7. Over Current Protection (OCP) ........................ 19 6.3. ESD Ratings........................................................4 8.8. Over Temperature Protection (OTP)................ 20 6.4. Thermal Resistance ............................................4 8.9. Drain-to-Source Voltage Considerations ......... 21 6.5. Electrical Characteristics.....................................5 9. PCB Layout Guidelines ....................................... 22 6.6. Electrical Characteristics (2, cont.) .....................6 10. Recommended PCB Land Pattern ................... 23 6.7. Electrical Characteristics (3, cont.) .....................7 11. Package Outline (Power QFN) .......................... 24 6.8. Switching Waveforms .........................................8 12. Tape and Reel Dimensions ............................... 25 6.9. Characteristic Graphs .........................................9 13. Ordering Information ......................................... 27 7. Pin Configurations and Functions ......................12 14. 20-Year Limited Warranty ................................. 27 8. Functional Description .........................................13 Final Datasheet 15. Revision History ................................................ 27 2 Rev Oct. 11, 2022 NV6136A 6. Specifications 6.1. Absolute Maximum Ratings(1) (with respect to Source (pad) unless noted) SYMBOL V DS (CONT) V DS (TRAN) V V PARAMETER Drain-to-Source Voltage Transient Drain-to-Source Voltage (2) MAX UNITS -7 to +700 V 800 V CC Supply Voltage 30 V DD Drive Supply Voltage 7 V R Input Voltage 7 V VSTBY Auto-Standby Mode Pin Voltage -0.6 to +20 or VCC V 6 V -0.6 to +20 or VCC V 5.3 V DD V5V V PWM V CS I 5 V Pin Voltage PWM Input Pin Voltage CS Pin Voltage D Continuous Drain Current (@ TC = 100ºC) 8 A I PULSE Pulsed Drain Current (10 µs @ TJ = 25ºC) 16 A D dV/dt 200 V/ns T J Junction Temperature -55 to 150 ºC STOR Storage Temperature -55 to 150 ºC T Slew Rate (1) Absolute maximum ratings are stress ratings; devices subjected to stresses beyond these ratings may cause permanent damage. (2) VDS (TRAN) allows for surge ratings during non-repetitive events that are
NV6136A-RA
物料型号:Navitas GaNFast NV6136A
器件简介: - 这是一款集成了GaNSense™技术的GaNFast™功率IC,具备高频率和高效率运行的能力。 - 集成了eMode GaN FET和集成门驱动,实现了高频和高效率操作。 - GaNSense™技术允许实时、准确地感测电压、电流和温度,提高了性能和鲁棒性。
引脚分配: - 该IC采用6x8毫米的QFN封装,具有多种引脚功能,包括电源引脚、门驱动供应引脚、PWM输入引脚、待机模式输入引脚等。
参数特性: - 工作电压范围宽(10V至30V)。 - 可编程的开启dV/dt。 - 200V/ns的dV/dt抗扰度和800V瞬态电压等级。 - 700V连续电压等级。 - 低至170mΩ的电阻和零反向恢复电荷。 - 操作频率高达2MHz。
功能详解: - 包括集成无损电流感测、短路保护、过温保护和自动待机模式。 - GaNSense™技术实现了无损电流感测,无需外部电流感测电阻,提高了系统效率。 - 自动待机模式提高了轻载、微型和无负载效率。
应用信息: - 适用于AC-DC、DC-DC、DC-AC转换器。 - 可用于QR flyback、ACF、Buck、Boost、半桥、全桥、LLC谐振、Class D、PFC等拓扑结构。 - 适用于无线电源、太阳能微型逆变器、LED照明、电视SMPS、服务器、电信等领域。
封装信息: - 小型、低轮廓的SMT QFN封装,6x8毫米占位,0.85毫米高度。 - 封装电感最小化,带有大冷却垫。
NV6136A-RA 价格&库存
很抱歉,暂时无法提供与“NV6136A-RA”相匹配的价格&库存,您可以联系我们找货
