SKELCAP SCA1200
SKELCAP SCA1200
    SKELETON
    插件
    1200 F (EDLC) 超级电容器 2.85 V 轴向,CAN 0.3 毫欧 65°C 时为 1500 小时
SKELCAP SCA1200 数据手册
DATA SHEET ULTRACAPACITOR SCA0500 to SCA3200 weldable cells & SCA0300 PCB-mountable cell DATA SHEET ULTRACAPACITOR + Capacitance 300 - 3200 F + Extreme power density + Durable and safe aluminum casings + Weldable terminals* + High cycle life >1,000,000 cycles + High temperature tolerance (operating and storage) + German quality + RoHS compliant + UL certified * PCB-mountable for 300F cell GENERAL SPECIFICATIONS* Rated voltage VR Surge voltage Vs Specific energy Nominal specific power Practical specific power * See values for SCA0300 on page 3. TEMPERATURE AND LIFE Operating temperature range Minimum Maximum Storage temperature range (uncharged) Minimum Maximum Life Lifetime @ VR and +65 °C Capacitance decrease 20% against rated value; 1s ESR increase 100% against rated value Storage life @ RT, uncharged Cyclelife @ RT, between VR and VR/2 GENERAL Rated voltage Rated capacitance DC 10ms ESR rated DC 1s ESR rated Maximum peak current, for 1 second1 Leakage current (At 2.85 V, 25 C and 72 hours, max) O VALUE UNIT 2.85 3.0 5.1 - 6.8 27 - 48 21 - 27 V V Wh/kg kW/kg kW/kg VALUE UNIT -40 +65 °C °C -40 +50 °C °C 1500 Hours 10 1,000,000 Years Cycles SCA0500 SCA0750 SCA1200 SCA1800 SCA3200 UNIT 2.85 500 0.38 0.70 0.6 1.6 2.85 750 0.32 0.52 0.9 2.5 2.85 1200 0.18 0.30 1.4 4.5 2.85 1800 0.16 0.27 2.0 6.3 2.85 3200 0.14 0.18 3.1 11.0 V F mΩ mΩ kA mA Copyright © 2020 Skeleton Technologies GmbH. All rights reserved. 02-DS-200129-SKELCAP-1A Page 2/6 SAFETY Short circuit current ENERGY Energy2 Specific energy3 Energy density4 POWER* SCA0500 SCA0750 SCA1200 SCA1800 SCA3200 UNIT 7.5 8.9 15.8 17.8 20.4 kA SCA0500 SCA0750 SCA1200 SCA1800 SCA3200 UNIT 0.6 5.1 7.1 0.8 5.8 7.9 1.4 5.4 7.6 2.0 6.0 8.5 3.6 6.8 9.3 Wh Wh/kg Wh/L SCA0500 SCA0750 SCA1200 SCA1800 SCA3200 UNIT 48 68 43 59 45 63 38 53 27 37 kW/kg kW/L 2.9 26 37 3.9 27 36 6.8 27 38 7.5 22 31 11.3 21 29 kW kW/kg kW/L Nominal power, calculated from 10ms ESR (for comparison) Specific power, matched impedance6 Power density, matched impedance7 Nominal power, calculated from 1s ESR (for engineering) Power, matched impedance5 Specific power, matched impedance6 Power density, matched impedance7 STANDARDS AND CERTIFICATIONS Vibration Specification Certifications THERMAL* Thermal resistance, Rca, typical Thermal capacitance, Cth, typical Max continuous current, ΔT = 15°C8 Max continuous current, ΔT = 40°C8 PHYSICAL Mass, typical (± 3-6 g, from small to large size) Volume Diameter (± 0.2 mm, including label), D1 Length (± 0.3 mm), L1 Terminal diameter, D2 Terminal length, L2 PACKAGE DETAILS* Package quantity Package weight Package height Package width Package depth I SO 16750-3, Table 12 RoHS, UL 810A SCA0500 SCA0750 SCA1200 SCA1800 SCA3200 UNIT 7.1 109.6 75 122 6.6 158.7 84 138 5.7 252.7 121 197 4.3 334.7 148 242 3.0 633.7 190 310 °C/W J/°C A A SCA0500 SCA0750 SCA1200 SCA1800 SCA3200 UNIT 0.11 0.08 40.2 63 8 3.2 0.15 0.11 40.2 85 8 3.2 0.25 0.18 60.2 63 12 3.2 0.34 0.24 60.2 85 12 3.2 0.53 0.39 60.2 138 12 3.2 kg L mm mm mm mm SCA0500 SCA0750 SCA1200 SCA1800 SCA3200 UNIT 49 6.2 120 395 395 49 8.0 120 395 395 25 7.1 170 395 395 25 9.2 170 395 395 25 14.1 170 395 395 pcs kg mm mm mm * SCA0300 only sold as a product platform, not as individual cells. Copyright © 2020 Skeleton Technologies GmbH. All rights reserved. 02-DS-200129-SKELCAP-1A Page 3/6 Typical value represents the mean production sample value Rated value represents the absolute minimum capacitance or maximum ESR value of production sample. *Power values calculated using DC 10ms ESR ≈ AC 100Hz. Standard markings + Name of manufacturer, part number, serial number, rated voltage + Rated capacitance, negative and positive terminals, warning marking + Total energy in watt-hours + Electrolyte material used Notes + Testing instructions available on www.skeletontech.com + All information provided on this data sheet and all subsequent ultracapacitors sales and testing are subject to Standard Terms of Service (ToS) available on www.skeletontech.com, document General Terms of Sale for Skeleton Technologies OÜ. SCA0300 PCB-Mountable Cell Note: Polarity of the cell is stated as following: center terminal for “-”, can and 3-pillar PCB frame for “+”. GENERAL SPECIFICATIONS Rated voltage VR Surge voltage Vs Specific energy Nominal specific power Practical specific power TEMPERATURE AND LIFE Operating temperature range Minimum Maximum Storage temperature range (uncharged) Minimum Maximum Life Lifetime at VR and +65 °C Capacitance decrease 20% against rated value; 1s ESR increase 100% against rated value Storage life @ RT, uncharged Cyclelife @ RT, between VR and VR/2 VALUE UNIT 2.85 3.0 5.3 32 20 V V Wh/kg kW/kg kW/kg VALUE UNIT -40 +65 °C °C -40 +50 °C °C 1500 Hours 10 1,000,000 Years Cycles Copyright © 2020 Skeleton Technologies GmbH. All rights reserved. 02-DS-200129-SKELCAP-1A Page 4/6 GENERAL VALUE UNIT VRated Rated capacitance DC 10ms ESR, rated DC 1s ESR, rated Maximum peak current, for 1 second1 Leakage current (at 2.85 V, 25 °C and 72 h, max) 2.85 300 1.00 1.60 0.3 1.5 V F mΩ mΩ kA mA SAFETY VALUE UNIT Short circuit current 3 kA ENERGY VALUE UNIT Energy2 Specific energy3 Energy density4 0.34 5.3 6.4 Wh Wh/kg Wh/L POWER* VALUE UNIT 32 38 kW/kg kW/L 1.3 20 24 kW kW/kg kW/L Nominal power*, calculated from 10 ms ESR (for comparison) Specific power, matched Impedance6 7 Power density, matched Impedance Practical power*, calculated from 1 s ESR (for engineering) Power, matched impedance5 Specific power, matched Impedance6 7 Power density, matched impedance STANDARDS AND CERTIFICATIONS Vibration Specification Shock Resistance Certifications Standards ISO 16750-3 Table 12 IEC60068-2-27 Shock Test RoHS REACH, UL 810A, AEC-Q200* *Tested according AEC-Q200 requirements, modified to match ultracapacitor properties THERMAL* VALUE UNIT Thermal resistance, Rca, typical Thermal capacitance, Cth, typical Max continuous current, ΔT = 15°C8 Max continuous current, ΔT = 40°C8 10.8 60 37 61 °C/W J/°C A A PHYSICAL PARAMETERS VALUE UNIT Mass. Typical Volume Diameter Length 0.064 0.053 33 61.5 kg L mm mm Copyright © 2020 Skeleton Technologies GmbH. All rights reserved. 02-DS-200129-SKELCAP-1A Page 5/6 *Power values calculated using DC 10ms ESR ≈ AC 100Hz. Standard markings + Name of manufacturer, part number, serial number, rated voltage + Rated capacitance, negative and positive terminals, warning marking + Total energy in watt-hours Notes + Testing instructions available on www.skeletontech.com + All information provided on this data sheet and all subsequent ultracapacitors sales and testing are subject to Standard Terms of Service (ToS) available on www.skeletontech.com, document General Terms of Sale for Skeleton Technologies OÜ. Skeleton Technologies GmbH Sales and Headquarters Schücostraße 8, 01900 Großröhrsdorf, Germany info@skeletontech.com www.skeletontech.com Copyright © 2020 Skeleton Technologies GmbH. All rights reserved. 02-DS-200129-SKELCAP-1A Page 6/6
SKELCAP SCA1200 价格&库存
很抱歉,暂时无法提供与“SKELCAP SCA1200”相匹配的价格&库存,您可以联系我们找货
