RP1D060D8M1
RP1D060D8M1
    CARLOGAVAZZI
    SIP-4
    固态 SPST-NO(1 Form A) 4-SIP
RP1D060D8M1 数据手册
RP1D RP1D 1-phase PCB mount DC switching solid state relays Main features • • • • • • • DC Solid State Relay for PCB mounting Rated operational current: up to 8 ADC Rated operational voltage: up to 350 VDC Surface mount technology Flexible encapsulation for extended life Control voltage: 4.25 to 32 VDC Isolation (Input to Output): 4000 VACrms Description The DC switching relay for PCB mounting is used in applications where there is a need for fast switching of small DC loads with a high input/output insulation of more than 4000 VACrms. The DC switching relay always switches on and off in accordance with the applied control voltage. Specifications are at a surrounding temperature of 25°C unless otherwise specified. Applications These relays can be used to switch heaters, motors, valves or solenoids Main functions • DC switching • Ratings up to 8 ADC / 60 VDC, 1 ADC / 350 VDC • DC control voltage 31/10/2023 RP1D DS ENG Carlo Gavazzi Ltd. 1 RP1D Order code RP1D D Enter the code option instead of Code R P 1 D D Option 060 350 1 4 8 Mx . Refer to the Selection guide section for valid part numbers. Description Comments Solid State Relay (PCB) with DC switching Number of poles Switching mode: DC switching Rated voltage: 60 VDC Rated voltage: 350 VDC Control voltage: 4.25-32 VDC Rated current: 1 ADC Rated current: 4 ADC Rated current: 8 ADC M1 = Mounting on DIN EN adaptor RPM1 M2 = Mounting on DIN EN adaptor RPM2 Up to 250 V Up to 600 V Selection guide Max. rated voltage 60 VDC 350 VDC Rated operational current @ 40oC Control voltage 4.25 - 32 VDC 1 ADC 4 ADC 8 ADC - RP1D060D4 RP1D060D8 RP1D350D1 - - Selection guide: mounted on DIN EN adaptor Max. rated voltage 60 VDC 350 VDC Rated operational current @ 40oC Control voltage 6.25 - 34 VDC 1 ADC 4 ADC 8 ADC - RP1D060D4M1 RP1D060D8M1 RP1D350D1M2 - - Carlo Gavazzi compatible components Description Component code Notes DIN rail adaptors RPM1 DIN adaptor 250 V with LED RPM1P DIN adaptor 250 V with pins for removal of RP RPM1PD DIN adaptor 250 V with pins for removal of RP and LED RPM2 DIN adaptor 600 V 31/10/2023 RP1D DS ENG Carlo Gavazzi Ltd. 2 RP1D Features General data Material PBT, RAL7035 Potting compound Flame-retardant flexible silicone rubber Weight Approx. 20 g Isolation Input to output: 4000 VACrms Dimensions Dimensions in mm unless otherwise noted. Tolerances +/- 0.5 mm. 31/10/2023 RP1D DS ENG Carlo Gavazzi Ltd. 3 RP1D Performance Mains supply Operational voltage range Blocking voltage RP1D060.. RP1D350.. 1 - 60 VDC 1 - 350 VDC 60 VDC 350 VDC Outputs RP1D350D1 RP1D060D4 RP1D060D8 DC1 DC5 DC13 Min. operational load current 1 ADC 1 ADC 1 ADC 4 ADC 4 ADC 4 ADC 1 mADC 8 ADC 8 ADC 8 ADC Rep. overload current t=1 s 20 ADC 15 ADC 60 ADC Rated operational current @ Ta=40°C Off-state leakage current @ rated voltage On-state voltage drop @ rated current < 0.01 mADC < 0.5 VDC < 0.5 VDC < 1.0 VDC Inputs Control voltage range (Uc) Pick-up voltage 4.25 - 32 VDC 3.3 VDC Drop-out voltage 1 VDC Reverse voltage 32 VDC Switching frequency < 100 Hz Response time pick-up @ Vin ≥ 5 VDC < 100 μs Response time drop-out @ Vin ≤ 24 VDC max. < 250 μs Input current 31/10/2023 RP1D DS ENG 15 mA Carlo Gavazzi Ltd. 4 RP1D Current derating curve 9 8 Load Loadcurrent current(ADC) (ADC) 7 6 5 RP1D060D8 RP1D060D4 4 RP1D350D1 3 2 1 0 20 25 30 35 40 45 50 55 60 65 70 75 80 Surrounding ambient temperature (°C) Surrounding ambient temperature (°C) 31/10/2023 RP1D DS ENG Carlo Gavazzi Ltd. 5 RP1D Compatibility and conformance Approvals Standards compliance LVD: EMCD: EE: EMC: cURus: EN 60947-1 EN 60947-1 EN 60947-1 EN 60947-1 UL508 Recognized, C22.2 No. 14 (E80573), NRNT2, NRNT8 Electromagnetic compatibility (EMC) - Immunity Electrostatic discharge (ESD) EN/IEC 61000-4-2 8 kV air discharge, 4 kV contact (PC1) Radiated radio frequency EN/IEC 61000-4-3 10 V/m, from 80 MHz to 2700 MHz (PC1)2 Electrical fast transient (burst) EN/IEC 61000-4-4 Output: 2 kV, 5 kHz (PC2) Input: 1 kV, 5 kHz (PC2) Conducted radio frequency EN/IEC 61000-4-6 10 V/m, from 0.15 to 80 MHz (PC1)2 Electrical surge EN/IEC 61000-4-5 Line to earth: 500 V (PC2) Line to line: 500 V (PC2) Voltage dips, interrupts and variations EN 61000-4-29 0, 30, 40, 60, 70, 80, 120% 1, 3, 10, 30, 100, 300, 1000 ms (PC2) Voltage interruptions EN/IEC 61000-4-11 0% for 10 ms (PC2) 0% for 20 ms (PC2) 0% for 40 ms (PC2) 0% for 100 ms (PC2) 0% for 200 ms (PC2) 0% for 5000 ms (PC2) Electromagnetic compatibility (EMC) - Emissions Radio interference field emission (radiated) EN 55011 Class A1: from 30 to 1000 MHz Radio interference voltage emissions (conducted) EN 55011 Class A1: from 0.15 to 30 MHz 31/10/2023 RP1D DS ENG Carlo Gavazzi Ltd. 6 RP1D Filter connection diagram +60 / 350 VDC +24 VDC Cinput L output Rinput +1 +3 Chassis GND 0 VDC Coutput Chassis GND RP1D -4 Cinput = 1 nF 2 kV (Y2 class, ceramic disc) Rinput = 10 Ω (0.25 W) -2 LOAD 0 VDC Loutput = ferrite core + 4 turns Coutput = 1 nF 2 kV (Y2 class, ceramic disc) Output: the combinational use of Loutput and/or Coutput depends on the level on EM noise reduction required in the end use. Input: the combinational use of Linput and/or Cinput depends on the level on EM noise reduction required in the end use. Note: 1. A filter is required to meet the Class A limits of EN55011: A filter (capacitor or snubber) could be necessary from 60 / 350 VDC supply to chassis Ground. A filter (capacitor or snubber) could be necessary from 24 VDC input to chassis Ground. Refer to the section 'Filter connection diagram' for further details. Attention: This product has been designed for class A equipment. Use of the product in domestic environments may cause radio interference, in which case the user may be required to employ additional mitigation methods. 2. It is recommended that the control input lines are installed together (i.e. a 2 core cable) to ensure acceptable susceptability to RF (Radio Frequency) is maintained. The manufacturer has set a maximum allowable deviation when under RF exposure of
RP1D060D8M1 价格&库存
很抱歉,暂时无法提供与“RP1D060D8M1”相匹配的价格&库存,您可以联系我们找货
