GNB4D2A
GNB4D2A
    CROUZET(高诺斯)
    SIP-4
    固态 SPST-NO(1 Form A) 4-SIP
GNB4D2A 数据手册
|   06/2022 › GN Board Series SIP Solid State Relays PCB Mount – AC Output Single Phase › Output Current of 4 Amps › Output Voltage of 12-275 Va, 12-460 Va, 24-600 Va › Control Voltage of 4-10 Vc, 4-30 Vc › Classic SIP package for Printed Circuit Boards › Zero Cross and Special Zero Cross Switching › cRUus, CE and UKCA Compliance › Built-in Output Overvoltage Protection GNB4D1C Product Selection - Zero Cross (Resistive Loads) Rated Load Current 4A Output Voltage 24-600 Va Control Voltage GNB4D1C 4-10 Vc Product Selection - Special Zero Cross (Resistive, Inductive and Capacitive Loads) Rated Load Current 4A Output Voltage Control Voltage 4-30 Vc 12-275 Va GNB4D2A PART NUMBERING SYSTEM 12-460 Va GNB4D2B Part Number System GN Board Series GNB: GNB Series GNB Control Voltage D1: 4-10 Vc D2: 4-30 Vc 4 D2 Output Current 4: 4 A A Output Voltage A: 12-275 Va | Special Zero Cross B: 12-460 Va | Special Zero Cross C: 24-600 Va | Zero Cross RÉFÉRENCEMENT Série Do you need an adapted or customized solution? Tension Contactdeuscommande on www.crouzet.com GNB: Série GNB D1: 4-10 Vc D2: 4-30 Vc Description: Crouzet Solid State Relays are designed to be used in almost any application, offering very long life expectancy and are easy to install, easy to use, GNB robust and multipurpose. 4 D2 A For more information about Crouzet’s Solid State relays, please visit www.crouzet.com. Courant de sortie 4: 4 A Tension de sortie A: 12-275 Va | Spécial Synchrone B: 12-460 Va | Spécial Synchrone C: 24-600 Va | Synchrone |   WWW.CROUZET.COM |  2 |   GN Board Series |   06/2022 Output Characteristics (1) Rated Load Current 4A Part Numbers GNB4D2A Maximum Load Current @ Ta=30 ° C [Arms] 4A GNB4D2B GNB4D1C Minimum Load Current [mArms] 1 1 Second surge current @ Ta=25 °C, 50/60 Hz [Apeak] 18 Maximum 1 Cycle Surge Current (50/60 Hz) [Apeak] 105 Maximum On-State Voltage Drop @ Rated Current [Vpeak] 1.01 Thermal Resistance Junction to Case (Rjc) [°C/W] 1.5 Maximum 1/2 Cycle I² t for Fusing (50/60Hz) [A² sec] min/typ 55 Minimum Heat Sink for Rated Current @ 40 °C [°C/W] No heatsink but nominal load current = 3, 5A @40 °C Operating Voltage (47-63 Hz) [Vrms] 12-275 Va 12-460 Va 24-600 Va Transient Voltage (Clamping Voltage) [Vpeak] (2) 600 (430) 800 (720) 1200 Maximum Off-State Leakage Current @ Rated Voltage [mArms] 0.1 Minimum Off-State dv/dt @ Maximum Rated Voltage [V/µsec] 500 Minimum Power Factor 0.45 0.45 with external protection (Varistor) Input Characteristics (1) Control Voltage Range 4-30 Vc 4-10 Vc Part Numbers GNB4D2A GNB4D2B GNB4D1C Maximum Reverse Voltage -6 Vc -5 Vc -10 Vc Minimum Turn-On Voltage 4 Vc Must Turn-Off Voltage 0.8 Vc Minimum Input Current (for on-state) [mA] 3 3.7 Vc 5 Maximum Input Current [mA] 30 29 Nominal Input Impedance [Ohms] 1000 270 Maximum Turn-On Time [msec] 10 Maximum Turn-Off Time [msec] 10 General Characteristics Rated Load Current 4A Part Numbers GNB4D2A Dielectric Strength, Input to Output (50/60 Hz) [V] 4000 GNB4D2B GNB4D1C Dielectric Strength, Input/Output to Ground (50/60 Hz) [V] N/A Minimum Insulation Resistance (@ 500 Vc) [Ohms] 109 Maximum Capacitance, Input/Output [pF] 8 Ambient Operating Temperature Range [°C] (7) -40 --> 80 °C Ambient Storage Temperature Range [°C] -40 --> 100 °C Weight (typical) [g] 20g Housing Material UL94 V-0 Humidity per IEC60068-2-78 [%] 40-85 % LED Input Status Indicator No LED MTBF (Mean Time Between Failures) at 40 °C ambient temperature [years] (8) 140 131 MTBF (Mean Time Between Failures) at 60 °C ambient temperature [years] (8) 119 108 MTTFd [years] 219 172 |   WWW.CROUZET.COM |  3 |   GN Board Series |   06/2022 General Notes All parameters at 25 °C unless otherwise specified (1) (2) Output will self trigger between 450-600 Vpk not suitable for capacitive loads (7) AC models operating range is -20 to 80 °C (8) All parameters at 50 % power rating and 100 % duty cycle (contact tech support for detailed report) Diagrams Wiring GN Board Series 4(-) 3(+) 2 L O A D 1 1 AC B Protection Equipment: Short circuit protection GNB4D1C: it is recommended to add an overvoltage protection Diagrams Equivalent Circuit Block GNB4D1C, GN Board Series 4-10 Vc control; 24-600 Va output - Input Current vs Input Voltage Zero Cross Standard Regulated DC inputs 30 28 26 INPUT 3+ 24 L1 OUTPUT T1 22 Input Current (mA) 4- 20 18 16 14 12 10 8 6 4 2 0 0 2 4 6 8 Input Voltage (V) GNB4D2A / GNB4D2B, GN Board Series 4-30 Vc control; Input Current vs Input Voltage 12-275 Va/12-460 Va output - Special Zero Cross Standard Regulated DC inputs 10 30 28 26 INPUT 3+ 1 AC OUTPUT 2 AC 24 22 Input Current (mA) 4- 20 18 16 14 12 10 8 6 4 2 0 0 2 4 6 8 10 12 14 16 18 Input Voltage (V) 20 22 24 26 28 30 |   WWW.CROUZET.COM |  4 |   GN Board Series |   06/2022 Diagrams Dimensions (mm) 25,4 GN Board Series 4x Ø1 7,63 ± 1 12,7 ± 1 7,62 ± 1 6,4 ± 1 10,16 ± 1 10,2 ± 1 5,08 ± 1 43,2 Curves Thermal Derating Curves GN Board Series 5 4,5 4 Current (Amps) 3,5 3 2,5 2 1,5 1 0,5 0 0 10 20 30 40 50 60 70 80 90 Ambient Temperature (°C) Standards & Electromagnetic Compatibility Specfification EN61000-4-4 Immunity to fast transients / bursts EN61000-4-5 Immunity to surges Standards Warning: The product information contained in this catalogue is given purely as information and does not constitute a representation, warranty or any form of contractual commitment. Crouzet and its subsidiaries reserve the right to modify their products without notice. It is imperative that we should be consulted over any particular use or application of our products and it is the responsibility of the buyer to establish, particularly through all the appropriate tests, that the product is suitable for the use or application. Under no circumstances will our warranty apply, nor shall we be held responsible for any application (such as any modification, addition, deletion, use in conjunction with other electrical or electronic components, circuits or assemblies, or any other unsuitable material or substance) which has not been expressly agreed by us prior to the sale of our products.
GNB4D2A 价格&库存
很抱歉,暂时无法提供与“GNB4D2A”相匹配的价格&库存,您可以联系我们找货
GNB4D2A
    • 1+501.19560
    • 200+199.98360
    • 500+193.29840
    • 1000+190.00440
