Data Sheet No:E08007
Version:V1
Date:2023/09/17
HVLR
High Voltage Non-Inductive Resistor
Resistance
1KΩ~1GΩ
Tolerance
±0.1%
TCR
±100ppm/℃
Operating Voltage
48000V m a x
Applications
Medical Equipment
Electrical Equipment
Instrumentation
Automotive Electronics
Testing & Measurement Equipment
Better Solution for Sustainable
High End Manufacturing
HVLR
Tight Tolerance, High Voltage, Low VCR and High Reliability
Introduction
HVLR series resistor applies self-developed electronic paste on Al 2 O 3 ceramic rod by
precise thick-film technology. The TCR of HVLR can reach within ±100ppm/℃ in the
temperature range of -25℃~+125℃, with ±0.1% tightest tolerance and 0.01ppm/V VCR.
Voltage coefficient of resistance (VCR) is one of the most critical electrical parameters of
high voltage resistor. As electronic paste is made by mixing conductive and nonconductive materials, the non-conductive materials are activated to form a parallel
resistance in a high-voltage operation, resulting in the change in the resistance value.
The low VCR is mainly determined by the quality of manufacturing and processing of
electronic paste. HVLR undergoes 100% high-voltage testing after manufactured to
ensure the performance of each resistor under high-voltage conditions.
The core materials and processes of HVLR have been independently controllable. with
stable quality and timely deliver y. If the standard specifications cannot meet your needs,
please contact our sales.
Electrical Parameters
Series Size
Rated
Power
(+125℃)
Max.
Operating
Voltage*
Operating
Temperature
HVLR
1505
0.7W
2500V
-55℃~+175℃
HVLR
1905
1.0W
3500V
-55℃~+175℃
HVLR
2505
1.2W
5500V
-55℃~+175℃
HVLR
2408
2.0W
5500V
-55℃~+175℃
HVLR
3908
3.0W
10000V
-55℃~+175℃
HVLR
5208
5.0W
15000V
-55℃~+175℃
HVLR
7609
7.5W
22500V
-55℃~+175℃
HVLR
1029
10.0W
32000V
-55℃~+175℃
HVLR
1179
11.0W
35000V
-55℃~+175℃
HVLR
1279
12.0W
40000V
-55℃~+175℃
HVLR
1379
13.0W
45000V
-55℃~+175℃
HVLR
1529
15.0W
48000V
-55℃~+175℃
TCR
ppm/℃
±100
(-25℃~+125℃,+25℃ ref)
±100
±100
±100
±100
±100
±100
±100
±100
±100
±100
±100
Resistance
Unit Weight
g
Tolerance
1KΩ~1GΩ
1.70±1
±0.1~±10.0
1KΩ~1GΩ
1.93±1
±0.1~±10.0
1KΩ~1GΩ
2.45±1
±0.1~±10.0
1KΩ~1GΩ
5.16±2
±0.1~±10.0
1KΩ~1GΩ
7.57±2
±0.1~±10.0
1KΩ~1GΩ
9.58±2
±0.1~±10.0
1KΩ~1GΩ
18.60±2
±0.1~±10.0
1KΩ~1GΩ
23.63±2
±0.1~±10.0
1KΩ~1GΩ
26.24±2
±0.1~±10.0
1KΩ~1GΩ
28.56±2
±0.1~±10.0
1KΩ~1GΩ
31.64±2
±0.1~±10.0
1KΩ~1GΩ
34.34±2
±0.1~±10.0
*The maximum operating voltage should be the smaller one between U=√(P * R) and Umax.
1/17
C&B Electronics Shenzhen CO., LTD. | www.resistor.today | resi@cbeureka.com | Tel:0755-83981080/83981010
HVLR
Unit :mm
Dimensions
36±3
A
B
C
D
Series
Size
Resistance
A
B
C
D
HVLR
1505
1KΩ~1GΩ
15±1.5
5±1.0
0.8±0.1
6.5±1.0
HVLR
1905
1KΩ~1GΩ
19±1.5
5±1.0
0.8±0.1
6.5±1.0
HVLR
2505
1KΩ~1GΩ
25.4±1.5
5±1.0
0.8±0.1
6.5±1.0
HVLR
2408
1KΩ~1GΩ
24±1.5
8±1.0
1.0±0.1
9.5±1.0
HVLR
3908
1KΩ~1GΩ
39±1.5
8±1.0
1.0±0.1
9.5±1.0
HVLR
5208
1KΩ~1GΩ
52±1.5
8±1.0
1.0±0.1
9.5±1.0
HVLR
7609
1KΩ~1GΩ
76±1.5
9±1.0
1.0±0.1
10.5±1.0
HVLR
1029
1KΩ~1GΩ
102±1.5
9±1.0
1.0±0.1
10.5±1.0
HVLR
1179
1KΩ~1GΩ
117±1.5
9±1.0
1.0±0.1
10.5±1.0
HVLR
1279
1KΩ~1GΩ
127±1.5
9±1.0
1.0±0.1
10.5±1.0
HVLR
1379
1KΩ~1GΩ
137±1.5
9±1.0
1.0±0.1
10.5±1.0
HVLR
1529
1KΩ~1GΩ
152±1.5
9±1.0
1.0±0.1
10.5±1.0
2/17
HVLR
Performance
Test
Test Method
Standards
Test Results
Voltage Coefficient
of Resistance
25 ± 5 ℃, apply 10% rated voltage and 100% rated voltage,
load time ≤ 0.5s, interval 5s
MIL-STD-202 Method 309
Typical 0.01ppm/V,
Max. 2ppm/V
Voltage Proof
Apply 4500VDC between the lead and the epoxy coating for 60s
IEC 60115-1 4.7
No breakdown or flashover,
△R≤±0.5%
Thermal Shock
-55°C, 15min~ambient temperature
很抱歉,暂时无法提供与“HVLR3908F1G00K9”相匹配的价格&库存,您可以联系我们找货
