JHC 8402104 N59F
JHC 8402104 N59F
    MATSUO(松尾电机)
    SMD2
    100 A AC 直流保险丝 板安装(不包括管筒式) 表面贴装型 2-SMD,J 形引线
JHC 8402104 N59F 数据手册
(P-JHC-E010/1) Type JHC TYPE JHC High Current Micro Fuse is designed for the purpose of external short circuit protection of the lithium ion battery of medium sizes, such as a power tool and an electric assistant bicycle. Though it was a surface mount type, it was small and realized high current rating, because a fuse element and a terminal adopt the structure of one. Furthermore perfectly compliant to Lead-free makes environment friendly design. FEATURES 1. High current rating was realized because a fuse element and a terminal adopt the structure of one. 2. Surface mount type and small size of 7358 (7.3mm × 5.8mm × 4.2mm) and 1173 (11.0mm × 7.3mm × 5.9mm). 3. Surface temperature rise is 75°C or less when applying rated current. This gives little influence to the peripheral units. 4. Alumina ceramics are adopted as a case, original structure is adopted as the inside of a case, and the safety at the time of fusing is improved. 5. Suitable for automatic mounting 6. Complete lead-free APPLICATION CLASSIFICATION BY USE The application classification by use which divided the market and use into four is set up supposing our products being used for a broad use. Please confirm the application classification by use of each product that you intend to use. Moreover, please be sure to inform to our Sales Department in advance in examination of the use of those other than the indicated use. Market Use Application classification by use High reliability apparatus Typical example of application Circuit Protection Components 1 - Apparatus in which advanced safety and reliability are demanded. - Whether failure of the apparatus which cannot maintenance exchange products, and a product is direct for a human life, apparatus which changes or may cause a fatal system failure. - Space development apparatus relation (Satellite, Rocket, Artificial Satellite) - Aviation and a defensive system - Atomic power, fire power, and a water-power generation system With no relevance 2 - Apparatus in which reliability is important. - The apparatus in which maintenance exchange of a product is very difficult, and failure of a product influence a human life, or the range of failure is wide range. - Vehicles control of transport machines, such as a car, and a railroad, a vessel (Engine control, drive control, brake control) - The operation control system of the Shinkansen and a main artery Type KAB N series Type JAG N series Type KVA N series 3 -Apparatus which can maintenance exchange products, and apparatus in which the loss of the system failure is large although failure of a product does not influence a human life, and maintenance engineering is demanded - Vehicle indoor loading parts, such as an air-conditioner and car navigation, and in-vehicle communication facility - Security management system for home/buildings etc. - Control apparatus, such as Industrial use robots and   a machine tool etc. Type KAB M series Type JHC H series 4 - The small size and the thin article which applies leading-edge technology positively - The product supposing being used widely in the market for the apparatus which can maintenance exchange products, and apparatus with a partial system failure by failure of product -Smart phone, Mobile phone, Mobile PC (tablet), Electronic dictionary - Desktop PC, Notebook PC, Home network - Amusement apparatus (Pachinko,Game machine) Type KAB Type KAB T series Type KAH Type JAE, Type JAG Type JAH, Type JAH L series Type JHB Type JHC Type KVA In-vehicle Industrial apparatus Apparatus in general Outline Recommendation Type RATING Category Temperature Range   30A、40A、50A、60A、80A、100A Rated Current Rated Voltage Voltage Drop Insulation Resistance (between terminals and case) Fusing Characteristics Clearing Characteristics -40 ~+125℃   35VDC, 60VDC, 110VDC   Refer to CATALOG NUMBERS AND RATING   1000MΩ or more   Fusing within 1 minute if the current is 250% of rated current.   Breaking voltage:Rated Voltage   Breaking Current:Under 60V: 300A,600A 110V: 1000A,1500A 1 ORDERING INFORMATION JHC Type JHC 3502 Code 3502 6002 1103 CATALOG Voltage 35V 60V 110V 503 R 44E Code Rated current Code Rated current Code Package type Code Case size 303 403 503 30 A 40 A 50 A 603 803 104 60 A 80 A 100 A R N φ180 Reel φ330 Reel 44E 59F 7.3×5.8 11.0×7.3 NUMBERS AND RATING Apr. Rated current A Internal resistance mΩ (Typical) 30 1.38 40 1.08 50 0.85 60 0.74 JHC 3502 803 □ 44E 80 0.56 JHC 3502 104 □ 44E 100 0.47 JHC 1103 303 □ 59F 30 1.46 JHC 1103 403 □ 59F 40 1.09 50 0.88 60 0.74 Catalog number Case size JHC 3502 303 □ 44E JHC 6002 303 □ 44E JHC 3502 403 □ 44E JHC 6002 403 □ 44E JHC 3502 503 □ 44E 7.3×5.8 JHC 6002 503 □ 44E JHC 3502 603 □ 44E JHC 6002 603 □ 44E JHC 1103 503 □ 59F 11.0×7.3 JHC 1103 603 □ 59F JHC 6002 803 □ 59F 80 0.55 JHC 6002104 □ 59F 100 0.45 2020 Voltage drop mV (Max.) Rated voltage Breaking current VDC A 35 60 80 35 60 35 60 35 90 60 35 100 80 1000 110 1500 90 100 DIMENSIONS 50 JHC T P W L Main body:Ceramic case Terminal:Tin plating (mm) Case size Case code L W T P 7358 44E 7.3±0.3 5.8±0.2 4.2±0.2 1.2±0.3 1173 59F 11.0±0.3 7.3±0.3 5.9±0.2 1.8±0.3 2 600 35 60 ・For the taping type, the packing code ”R or N" will be entered in □. For 59F, only ”N" will be entered in □. ・Catalog numbers are approved by UL. cUL.(File No.E170721,E480488) P 300 600 MARKING Code : Rated current Code : Rated current 30 : 30A 40 : 40A 50 : 50A 60 : 60A 80 : 80A 100 : 100A CONSTRUCTION 50 JHC Marking All-in-one fuse element with terminal Ceramic case Empty space Ceramic plate Seal resin Name All-in-one fuse element with terminal Ceramic case Ceramic plate Seal resin Marking Empty space Material, standard, and treatment Copper Alloy(Tin plating terminal) Alumina ceramics Alumina ceramics Silicone resin UV curable resin ― RECOMMENDED PAD DIMENSION (mm) Size 7358 Size 1173 a 2.7 3.3 b 5.8 7.3 c 4.4 6.9 b a C (Reflow) STANDARD TEST BOARD 60mm 4.4mm Glass epoxy body on one side 10mm 33mm Board thickness : 1.6mm Thickness of Copper layer : 400μm Rated Current : 30~50A 60mm 4.4mm Glass epoxy body on one side 20mm 33mm Board thickness : 1.6mm Thickness of Copper layer : 500μm Rated Current : 60~100A 3 PERFORMANCE No Performance Item Test method Temperature rise shall not exceed 75℃ 1 Temperature rise 2 Current-carrying capacity Shall not open within 1 hour. Apply rated current Apply 100% of rated current 3 Clearing characteristics Arc shall not be continued. No ignition. Marking shall be legible No bursting of the fuse 4 Voltage drop Voltage drop is below the value specified in CATALOG NUMBERS AND RATING. Apply rated current 5 Fusing characteristics Fusing within I min. Apply 250% of rated current (Ambient temperature: 10~30℃) 6 Insulation resistance 1000MΩ or more Insulation resistance between terminals and case(ceramics) 7 Electrode strength (Bending) No mechanical damage. Resistance change after the test shall be within ± 20%. 8 Shear test No mechanical damage. Resistance change after the test shall be within ± 20%. 9 Core body strength No mechanical damage. Resistance change after the test shall be within ± 20%. 10 Solderability (Solder Wetting time) Solder Wetting time : within 3s Solderability 11 (new uniform coating of solder) 12 Resistance to soldering heat The dipping surface of the terminals shall be covered more than 95% with new solder. Marking shall be legible. No mechanical damage. Resistance change after the test shall be within ± 20%. 13 Solvent resistance Marking shall be legible. No mechanical damage. No significant irregularity in the appearance. 14 Vibration No mechanical damage. Resistance change after the test shall be within ± 20%. 15 Shock No mechanical damage. Resistance change after the test shall be within ± 20%. 16 Thermal shock No mechanical damage. Resistance change after the test shall be within ± 20%. Breaking voltage : Rated voltage Breaking current : Under 60V:300A(30~50A)、600A(60~100A) 110V:1000A(30~40A)、1500A(50~60A) Board supporting width : 90mm Bending speed : Approx. 0.5mm/s Duration :5s Bending : 3mm Applied force : 20N Duration : 10s Tool : R0.5 Direction of the press : side face Supporting dimension : 3.65mm Applied force : 20N Duration : 10s Tool : R0.5 Direction of the press : thickness direction of product Solder : Sn-3Ag-0.5Cu Temperature : 245±5℃ meniscograph method Solder : Sn-3Ag-0.5Cu Temperature : 245±5℃ Dippinng : 3s Dipping(1 cycle) Preconditioning : 100~150℃/60s Temperature : 265±3℃/6~7s Reflow(2 cycle) Preconditioning : Lower than 180℃  1~2min Peak : 250±5℃   5s Holding : 230~250℃ 30~40s Cooling : More than 2min Manual soldering(2 cycle) Temperature : 350±10℃ Duration : 3~4s Measure after 1hour left under room temperature and humidity. Dipping rinse Solvent : Isopropyl alcohol Duration : 90s Frequency rage : 10~55~10Hz/min Vibration amplitude : 1.5mm Duration : 2 hours in each of XYZ directions (total : 6 hours) Peak value Duration : 490m/s2 : 11ms 6 aspects × 3 times (total: 18 times) -55±3℃ Room temperature 125±2℃ Room temperature : 30min : 2~3min or less : 30min : 2~3min or less Repeat above step for 10 cycles 17 Moisture resistance No mechanical damage. Resistance change after the test shall be within ± 20%. Temperature Humidity Duration 18 Load life No mechanical damage. Resistance change after the test shall be within ± 20%. Temperature Applied current Duration : 85±2℃ : Rated current×70% : 1000h 19 Moisture resistance load No mechanical damage. Resistance change after the test shall be within ± 20%. Temperature Humidity Applied current Duration : 85±3℃ : 85±5%RH : Rated current×70% : 1000h 20 Stability No mechanical damage. Resistance change after the test shall be within ± 20%. Temperature Duration : 125±2℃ : 1000h 4 : 85±3℃ : 85±5%RH : 1000h I2T - T CHARACTERISTICS FUSING CHARACTERISTICS Case code: 44E Case code: 44E Reference 10000000 40A 60A 100A 30A 50A 80A 100 Reference 100A 80A 60A 50A 40A 30A 1000000 Joule integral (A2s) Fusing time (s) 10 1 100000 10000 0.1 1000 0.01 100 0.001 10 10 100 Applied current (A) Case code: 59F 0.001 1000 0.1 1 Fusing time (s) 10 Case code: 59F Reference 40A 60A 100A 30A 50A 80A 100 0.01 Reference 10000000 100A 80A 60A 50A 40A 30A 1000000 Joule integral (A2s) 10 Fusing time (s) 100 1 0.1 100000 10000 1000 0.01 100 0.001 10 100 Applied current (A) 10 1000 0.001 5 0.01 0.1 1 Fusing time (s) 10 100 DISTRIBUTION OF FUSING CHARACTERISTICS Case code: 44E 100 Fusing time (s) 10 1 0.1 0.01 0.001 10 100 Applied current (A) 1000 DISTRIBUTION OF FUSING TIME Case code: 44E 100 Fusing time (s) 10 250% rated current is applied 1 0.1 0.01 400% rated current is applied 0.001 0 20 40 60 Numbers of pcs 6 80 100 DETERMINATION OF RATED VALUE AND SELECTION OF MICRO FUSE ( TYPE JHC) Determine the rated value of the micro fuse, and select the micro fuse for your circuit. If you select the micro fuse , safety of your circuit can be ensured. How to determine the rated value of the micro fuse is described below: ■Flow for fuse selection 1. Measurement of circuit values using actual device Measure the circuit values, such as operating current of the circuit. 2. Calculation from operating current From the obtained operating current and the category temperature, calculate minimum rated value to determine the applicable fuse. 3. Calculation from overload current From the obtained overload current, calculate the maximum rated value to determine the applicable fuse. 4. Calculation from inrush current From the inrush current, calculate the minimum rated value to determine the applicable fuse. 5. Final determination of rated value From the calculation results of steps 2 through 4, determine the rated value. 6. Operation check using actual device After selecting the rating, confirm if the device works properly under the pre-determined conditions. ■Fuse selection 1. Measurement of circuit values using actual device Before determining the rated value of the fuse, preliminarily measure the following condition by using the actual device. 1-1. Operating current Using an oscilloscope or equivalents, measure operating current of the circuit. 1-2. Overload current Using an oscilloscope or equivalents, measure the overload current that needs to break the circuit. 1-3. Inrush current Using an oscilloscope or equivalents, measure the inrush current of circuit at power-on or power-off. In addition, determine the number of inrush current applied. 1-4.Category temperature Measure the ambient temperature of the fuse circuit. In a 25℃ environment under normal circumstances, please design substrate wiring so that the surface temperature of a fuse does not exceed 80℃. EXAMPLE TO SELECT RATINGS OF TYPE JHC Effective operating current : 30 A 300A Effective overload current : 140 A Inrush current waveform : Fig. A (Pulse width : 2 ms, Wave height : 300 A) Numbers to withstand inrush current : 100,000 times 2ms Category temperature : 85°C Fig. A:Inrush current waveform Operating time:4,000h 2. Calculation from operating current 2–1. Measurement of operating current Using an oscilloscope or equivalents, measure operating current (effective current) of the actual circuit. Example : Effective operating current = 30 A Fig. B 2–2 Derating 140 Using Fig. B, find the temperature derating factor correspond to the Temperature. However, in order to be allowed to check an operating condition in use to the apparatus used for a long time that the operating time exceeds 4,000 h, please ask our Sales Department. ②Rated derating factor Rated derating factor = 0.94 (Constant irrespective of temperature) Derating factor (%) ①Temperature derating factor 120 100 80 60 40 20 0 -50 JHC temperature derating -25 0 25 50 75 Temperature(℃) Use Formula 1 to calculate the rated current of the fuse to be used for the circuit. Rated current of fuse ≥ Operating current/(①×②) ... Formula 1 7 100 125 Example : Category temperature = 85°C, Operating current =30 A ①Temperature derating factor = 0.90 (Refer to Fig. B.) ②Rated derating factor = 0.94 (Constant irrespective of temperature) Calculation using Formula 1 : Rated current ≥ 30/(0.90×0.94) = 35.5A The above calculation result shows that the fuse with rated current of 35.5A or more should be selected for this circuit. Type JHC, with rated current of 50 A and 40A can be selected. 3. Calculation from overload current 3–1 Measurement of overload current Using oscilloscope or equivalents, measure overload current that needs to break circuit. Example : Effective overload current = 140 A 3–2 Calculation from overload current Determine rated current so that overload current can be 2.5 times larger than rated current. Use Formula 2 to calculate rated current of fuse. Rated current of fuse ≤ Overload current/2.5 ... Formula 2 Example : Overload current = 140 A Use Formula 2 to calculate the rated current. Rated current ≤ 140/2.5 = 56 A The above calculation result shows that the fuse with rated current of 56 A or less should be selected for this circuit. Type JHC, with rated current of 50 A and 40A can be selected. 4. Calculation from inrush current 4–1 Measurement of inrush current waveform Using an oscilloscope or equivalent, measure waveform of inrush current of actual circuit. 4–2 Creation of approximate waveform Generally, waveform of inrush current is complicated. For this reason, 300A create the approximate waveform of inrush current as shown on Fig. C to simplify calculation. 2ms 4–3 Calculation of I2t of inrush current 2 Calculate I t (Joule integral) of approximate waveform. The formula for this calculation depends on the approximate waveform. Refer to Table A. Fig. C:Inrush current waveform Red line : Actual measurement waveform Black line:Approximate waveform Example : Pulse applied = 2 ms, Peak value = 300 A Approximate waveform = Triangular wave Since the approximate waveform is a triangular wave, use the following formula for calculation. I2t of rush current = 1/3 × Im2 × t ... Formula 3 (Im : Peak value, t : Pulse applying time) Use Formula 3 to calculate I2t of the inrush current: I2t = 1/3 × 300 × 300 × 0.002 = 60 (A2s) JOULE-INTEGRAL VALUES FOR EACH WAVEFORM Name Waveform Sine wave (1cycle) 0 t m 1 m2 t 2 Sine wave (half cycle) 0 m 0 t2 Trapezoidal wave m 0 2 Waveform I t m 0 t1 t2 t3 Various wave 1  0 1 2 wave 2 2 0 m2 t discharge waveform t 2 * Following formula is generally used for calculation of I t as i(t) equal to current. 2 t=∫0ti2(t)dt 8 t1 t2 1 t3 -t/τ  m i (t) =  m e 0.368 1 m2 t1 + m2 (t2-t1) + 3 1 m2 (t -t ) 3 2 3  1 2 t + 1 (1-2) 2 t 3 t Various 1 m2 t 3 Charge/ Rectangular wave Table A Name t Triangular wave I t 1 m2 t 2 m 1 2 2 m 0 τ -t 1 2 1  1 t1+{12+ (1-2) 2} 3 1 32 (t2-t1)+  2 (t3-t2) 3 1 m2 τ 2 4-4 Search of load ratio PULSE RESISTANCE CHARACTERISTICS ①Set up number of cycles to withstand. (generally 100,000 times) Fig. D ②Obtain load ratio from Pulse resistance characteristics. (Fig. D) Example : 100,000 times is required against inrush current 1000000 applied. The load ratio is 35% or less from Fig. D. Number of resistance (cycle) 100000 10000 1000 100 10 0 10 20 30 40 50 60 70 80 90 100 Load ratio (%) 4–5 Calculation from Joule integral and load ratio Use Formula 4 to calculate the standard I2t for the fuse to be JOULE INTEGRAL VS. FUSING TIME used. Fig. E Standard I2t of fuse > (I2t of inrush current/load ratio) .......... 1000000 ..........Formula 4 2 Example : I t of pulse = 60 A2s, Pulse applied = 2 ms, Required load ratio = 35% From Formula 4, 100000 Standard I2t of fuse > 60/0.35 = 171.4 (A2s) The standard I2t of the fuse should be 171.4 (A2s) or more. Joule Integral (A2s) Since the rush pulse applied is 2 ms, obtain the intersection of 2 ms (horizontal axis) and 171.4 A2s (vertical axis) from Fig. E (refer to the arrow shown in Fig. E). Select a fuse whose curve is above the intersection. Type JHC with rated current of 50 A and 40A should be selected. 5. Final determination of rated value 10000 1000 100 Determine the rated current of micro fuse. Rated current should meet all the calculation results. Example : Rated current of 50 A and 40A meets the all requirement. 10 0.001 0.01 0.1 1 Fusing time (s) 6. Operation check using actual device After selecting rating, confirm if the device works properly under pre-determined conditions. 9 10 100 Application Notes for Micro Fuse 1. Circuit Design 5. Caution During Usage HIGH CURRENT MICRO FUSE should be designated only after (1) HIGH CURRENT MICRO FUSE with electricity should never be touched. confirming operating conditions and Micro Fuse characteristics. HIGH CURRENT MICRO FUSE with electricity may cause burning due to When determining the rated current, be sure to observe the following HIGH CURRENT MICRO FUSE high temperature. items : Also, in case of touching HIGH CURRENT MICRO FUSE without (1) HIGH CURRENT MICRO FUSE should always be operated below the electricity, please check the safety temperature of HIGH CURRENT value considered in the rated derating rate and temperature derating MICRO FUSE. rate for rated current. (2) Protective eye glasses should always be worn when performing fusing (2) HIGH CURRENT MICRO FUSE should always be operated below tests. the rated voltage. However, there is a fear that HIGH CURRENT MICRO FUSE will explode (3) HIGH CURRENT MICRO FUSE should be selected with correct rated during test. During fusing tests, please cover particles not to fly outward value to be fused at overload current. from the board or testing fixture. Caution is necessary during usage at all (4) When HIGH CURRENT MICRO FUSE are used in inrush current times. applications, please confirm sufficiently inrush resistance of Micro Fuse. 6. Environmental Conditions (5) Please do not apply the current exceeding the breaking current to HIGH CURRENT MICRO FUSE. In addition, I would like confirmation (1) HIGH CURRENT MICRO FUSE should not be stored or operated in the beforehand not to have possibilities to cut if off normally when you presence of acids, or alkalis, or corrosive atomosphere. uses it by a high inductance circuit. (2) HIGH CURRENT MICRO FUSE should not be vibrated, shocked, or (6) Use HIGH CURRENT MICRO FUSE under the condition of category pressed excessively. temperature. (3) HIGH CURRENT MICRO FUSE should not be operated in a flammable or (7) HIGH CURRENT MICRO FUSE should not be used in the AC power explosive atmosphere. source and primary power source. (4) HIGH CURRENT MICRO FUSE should not be used under dew (8) HIGH CURRENT MICRO FUSE should be selected by determining the condensation environment. 7. Emergency operating conditions that will occur after final assembly, or estimating potential abnormalities through cycle testing. In case of fire, smoking, or offensive odor during operation, please cut off (9) In a 25 ℃ environment under normal circumstances, please design the power in the circuit or pull the plug out. substrate wiring so that the surface temperature of a fuse does not exceed 80 ℃. 8. Storage And, please use after checking that turn on operating current and overload (1) HIGH CURRENT MICRO FUSE should be stored at room temperature (-10°C ~+40°C) without direct sunlight. current by an actual substrate in advance, and it is satisfactory. HIGH CURRENT MICRO FUSE should not be stored in corrosive 2. Assembly and Mounting atmosphere such as H2S (hydrogen sulfide) or SO2(sulfur dioxide) . During the entire assembly process, observe Micro Fuse body Direct sunlight may cause decolorization and deformation of the exterior temperature and the heating time specified in the performance table. and taping. In addition, observe the following items : Also, there is a fear that solderability will be remarkably lower in high (1) Mounting and adjusting with soldering irons are not recommendable humidity. since temperature and time control is difficult. (2) If the products are stored for an extended period of time, please contact (2) Once Micro Fuse mounted on the board, they should never be Matsuo Sales Department for recommendation. remounted on boards or substrates. The longer storage term causes packages and tapings to worsen. If the (3) During mounting, be careful not to apply any excessive mechanical products are stored for longer term, please contact Matsuo Sales stresses to HIGH CURRENT MICRO FUSE. Department for advice. (3) The products in taping, package, or box should not be given any kind of 3. Solvents physical pressure. Deformation of taping or package may affect For cleaning of Micro Fuse, immersion in isopropyl alcohol for 90 automatic mounting. seconds (at 20 ~ 30°C liquid temp.) will not be damaged. TM TM TM 9. Disposal If organic solvents (Pine Alpha , Techno Care , Clean Through , etc.) will be applied to HIGH CURRENT MICRO FUSE, be sure to When HIGH CURRENT MICRO FUSE are disposed of as waste or preliminarily check that the solvent will not damage HIGH CURRENT “scrap”, they should be treated as “industrial waste”. MICRO FUSE . 10.Samples 4. Ultrasonic Cleaning HIGH CURRENT MICRO FUSE received as samples should not be used Ultrasonic cleaning is not recommended for HIGH CURRENT MICRO in production applications. A sample is provided for the special use (in FUSE. This may cause damage to HIGH CURRENT MICRO FUSE such such cases as the one for the form sample, the electriccharacteristic as broken terminals which results in electrical characteristics effects, etc. confirmation) depending on the conditions. MATSUO MATSUO ELECTRIC CO., LTD. Please feel free to ask our sales department for more information on Micro Fuse. Overseas Sales 5-3,3-Chome,Sennari-cho,Toyonaka-shi,Osaka 561-8558,Japan Head office 5-3,3-Chome,Sennari-cho,Toyonaka-shi,Osaka 561-8558,Japan URL https://www.ncc-matsuo.co.jp/ Tel:06-6332-0883 Fax:06-6332-0920 Tel:06-6332-0871 Fax:06-6331-1386 The specifications on this catalog are subject to change without prior notice. Please inquire of our Sales Department to confirm the specifications prior to use. 10
JHC 8402104 N59F 价格&库存
很抱歉,暂时无法提供与“JHC 8402104 N59F”相匹配的价格&库存,您可以联系我们找货
