DATASHEET
Common-mode Chokes ED100 / ED101
Current-compensated choke series for lighting applications
Approvals & Compliances
Common and differential mode inductance
Very high differential-mode inductance
Rated currents up to 2 A
Broadband attenuation characteristics
Performance indicators
Performance
standard
very high
high
Common-mode Inductance [mH]
3
40
Differential-mode Inductance [mH]
2
1.1
0.1
0.2
6
8
10
Combination of common- and differential-mode
inductances
Rated current [A]
0.2
Features and benefits
Increases power factor
ED100
ED101
3.1
Lighting LED drivers need to be high in efficiency, low
in cost and compliant to EMC regulations. The ED100
/ ED101 series increases the efficiency of a LED driver
circuit by reducing the need for X-capacitors. Thus,
the power factor rises, and less unwanted reactive
power is generated. The inductor is a combination of
a strong common-mode inductance with a
significant differential-mode inductance. It offers two
filtering elements in one component. This helps the
circuit designer to reduce the number of elements on
the PCB, to reduce space requirement as well as
lowering costs. Combined with the high MTBF value
of the ED100 / ED101 series, a circuit design with
reduced number of components profits for its overall
reliability and lifetime.
12
16
Compact and light-weight
Small PCB footprint
Typical applications
Mains operated LED drivers
Technical specifications
Electronic ballasts
Maximum continuous operating voltage
Rated currents
Rated inductance
Stray inductance
Operating frequency
Temperature range (operation and storage)
Climatic class
High potential test voltage winding-towinding @ 25°C
300 VAC, 50/60 Hz
Creepage and clearance distances
Creepage > 3 mm / Clearance > 2.5 mm between
windings
Overvoltage category
Design corresponding to
Inductance reduction (DC bias with IN)
Cooling
Flammability corresponding to
Altitude
Protection category
Pollution degree
MTBF
Vibration and shock
II acc. IEC 60664-1
Input filters for switch mode power supplies
0.2 to 2 A @ 65°C
3 to 40 mH common-mode
0.1 - 3.1 mH
DC to 60 Hz
-40°C to 125°C
40/125/56 acc. IEC 60068-1
1500 VAC, 2 sec
IEC 60938-1/-2
Less than 10% at rated current
AN - natural convection
UL 94 V-0
Derating above 2,000 m
IP 00
PD2 acc. IEC 60664-1
> 13,000,000 hours acc. MIL-HDBK-217
3M4 acc. IEC 60721-3-3
Typical electrical schematic
L(CM)
Schaffner Group
EMC/EMI Products
Datasheets
22 Mar 2022
Choke selection table - ED100 - High Differential-Mode Inductance
Rated current
CommonMode Inductance
DifferentialMode Inductance
DC resistance
I
L (CM)
L (DM)
R
(@65°C)
(@10kHz)
(@10kHz)
(@25°C)
[A]
[mH]
[mH]
[Ω]
ED100-0.2-40M
0.2
40
1.1
10.0
10
ED100-0.3-27M
0.3
27
0.8
5.5
10
ED100-0.4-20M
0.4
3.7
10
ED100-0.5-15M
0.5
15
0.4
2.0
10
ED100-0.75-12M
0.75
12
0.3
1.2
11
1
9
0.3
0.6
12
ED100 choke
Buy
ED100-1-9M0
Weight
[g]
ED100-1.25-7M0
1.25
7
0.2
0.4
13
ED100-1.5-5M0
1.5
5
0.1
0.3
13
2
3
0.1
0.2
13
Weight
ED100-2-3M0
Choke selection table - ED101 - Very High Differential-Mode Inductance
Rated current
DC resistance
I
L (CM)
L (DM)
R
(@65°C)
(@10kHz)
(@10kHz)
(@25°C)
[A]
[mH]
[mH]
[Ω]
ED101-0.2-40M
0.2
40
3.1
10.0
11
ED101-0.3-27M
0.3
27
2.1
5.5
11
ED101-0.4-20M
0.4
3.7
11
ED101-0.5-15M
0.5
15
1.2
2.0
12
ED101-0.75-12M
0.75
12
0.9
1.2
12
1
9
0.7
0.6
13
ED101 choke
Buy
ED101-1-9M0
[g]
ED101-1.25-7M0
1.25
7
0.5
0.4
14
ED101-1.5-5M0
1.5
5
0.4
0.3
14
2
3
0.2
0.2
14
ED101-2-3M0
Test conditions: Measuring frequency: 10 kHz; 50 mV; Inductance tolerance: +50%, -30%; Resistance tolerance: ±15% @ 25°C; Electrical characteristics @ 25°C: ±2°C;
Differential-mode inductance measurement between pin 1 and 2 (pin 3 and 4 shorted)
For mechanical tolerances refer to mechanical data section.
Current derating
1
Current (A)
2
(1 A @ 65 ◦ C)
0.5
100
Temperature ( ◦ C)
Derating curve normalized to 1 A
Distribution inventory
Up-to-date inventory levels for global distributors is available at
https://products.schaffner.com/stock
3
Schaffner Group
EMC/EMI Products
Datasheets
22 Mar 2022
1M
10M
Hz
1M
10M
Hz
1M
10M
Hz
Typical choke attenuation - ED100 - High Differential-Mode Inductance
Per CISPR 17; 50 Ω/50 Ω asym
dB
dB
dB
90
90
90
80
80
80
70
70
60
60
60
50
50
50
40
40
40
30
30
CM
CM
CM
30
DM
DM
10
10
10k
100k
1M
10M
10
10k
Hz
DM
100k
1M
10M
Hz
10k
ED100-0.3-27M
ED100-0.2-40M
ED100-0.4-20M
dB
dB
dB
90
90
90
80
80
80
70
70
70
60
60
60
50
50
50
40
40
CM
30
30
CM
DM
DM
10
DM
10k
100k
1M
10M
10k
Hz
100k
1M
10M
Hz
10k
ED100-0.75-12M
ED100-0.5-15M
dB
dB
90
90
90
80
80
80
70
70
70
60
60
60
50
50
CM
CM
40
40
30
30
40
CM
30
DM
10
ED100-1.25-7M0
100k
DM
10
10k
100k
ED100-1-9M0
dB
50
CM
30
10
10
100k
1M
10M
Hz
DM
10
10k
100k
1M
10M
Hz
10k
ED100-1.5-5M0
ED100-2-3M0
100k
4
Schaffner Group
EMC/EMI Products
Datasheets
22 Mar 2022
1M
10M
1M
10M
Hz
1M
10M
Hz
Typical choke attenuation - ED101 - Very High Differential-Mode Inductance
dB
dB
dB
90
90
90
80
80
80
70
70
60
60
50
50
50
40
40
40
30
30
70
CM
60
CM
CM
DM
DM
DM
10
10
10
10k
100k
1M
10M
10k
Hz
100k
1M
10M
Hz
10k
ED101-0.3-27M
ED101-0.2-40M
100k
Hz
ED101-0.4-20M
dB
dB
dB
90
90
90
80
80
80
70
70
70
60
60
60
50
50
50
40
40
30
30
CM
40
CM
DM
10
10
10k
100k
1M
10M
DM
10
DM
10k
Hz
100k
1M
10M
Hz
10k
ED101-0.75-12M
ED101-0.5-15M
dB
dB
90
90
90
80
80
80
70
70
70
60
60
60
50
50
CM
50
CM
40
40
30
30
DM
ED101-1.25-7M0
100k
1M
10M
Hz
10k
100k
DM
10
DM
CM
30
10
10
100k
ED101-1-9M0
dB
10k
CM
30
1M
10M
Hz
10k
ED101-1.5-5M0
ED101-2-3M0
100k
Schaffner Group
EMC/EMI Products
Mechanical data - ED100 / ED101
1
24 ± 0.3
2
20 ± 0.5
3
10 ± 0.4
14.3 +0
-0.4
15.3 ± 0.2
4
0.8
3.6 +0
-0.5
5
For dimensions [mm] without tolerances: ISO2768-m/EN22768-m applies
Pin material: Steel (base), Cu (under plating), Sn (final plating 6µm
Pin 1 marked with "dot" on label
Datasheets
22 Mar 2022
6
Schaffner Group
EMC/EMI Products
Datasheets
22 Mar 2022
Headquarters, global
innovation and development
Sales and application centers
Switzerland
Schaffner Group
Industrie Nord
Nordstrasse 11e
4542 Luterbach
T +41 32 681 66 26
info@schaffner.com
China
Schaffner EMC Ltd. Shanghai
T20-3 C, No 565 Chuangye Road,
Pudong district
201201 Shanghai
T +86 21 3813 9500
cschina@schaffner.com
www.schaffner.com.cn
Spain
Schaffner EMC España
Calle Caléndula 93, Miniparc III, Edificio E
El Soto de Moraleja, Alcobendas
28109 Madrid
T +34 917 912 900
F +34 917 912 901
spainsales@schaffner.com
Finland
Schaffner Oy
Sauvonrinne 19 H
08500 Lohja
T +358 50 468 7284
finlandsales@schaffner.com
Sweden
Schaffner EMC AB
Östermalmstorg 1
114 42 Stockholm
T +46 8 5050 2425
swedensales@schaffner.com
www.schaffner.com
France
Schaffner EMC S.A.S.
16-20 Rue Louis Rameau
95875 Bezons
T +33 1 34 34 30 60
F +33 1 39 47 02 28
francesales@schaffner.com
Germany
Schaffner Deutschland GmbH
Schoemperlenstrasse 12B
76185 Karlsruhe
T +49 721 56910
germanysales@schaffner.com
India
Schaffner India Pvt. Ltd
REGUS WORLD TRADE CENTRE
WTC, 22nd Floor Unit No 2238, Brigade
Gateway Campus, 26/1, Dr. Rajkumar Road
Malleshwaram (W)
560055 Bangalore
T +91 80 67935355
indiasales@schaffner.com
To find your local partner within Schaffner‘s
global network: www.schaffner.com
© 2022 Schaffner Group
The content of this document has been
carefully checked and understood. However,
neither Schaffner nor its subsidiaries assume
any liability whatsoever for any errors or
inaccuracies of this document and the
consequences thereof. Published specifications are subject to change without notice.
Product suitability for any area of application
must ultimately be determined by the
customer. In all cases, products must never
be operated outside their published
specifications. Schaffner does not guarantee
the availability of all published products. This
disclaimer shall be governed by substantive
Swiss law and resulting disputes shall be
settled by the courts at the place of business
of Schaffner Holding AG. Latest publications
and a complete disclaimer can be downloaded from the Schaffner website. All
trademarks recognized.
Italy
Schaffner EMC S.r.l.
Via Ticino, 30
20900 Monza (MB)
T +39 039 21 41 070
italysales@schaffner.com
Japan
Schaffner EMC K.K.
Taiju-Seimei Sangenjaya Bldg.
1-32-12, Kamiuma, Setagaya-ku
154-0011 Tokyo
T +81 3 5712 3650
F +81 3 5712 3651
japansales@schaffner.com
www.schaffner.jp
Singapore
Schaffner EMC Pte Ltd.
#05-09, Kg Ubi Ind. Estate
408705 Singapore
T +65 6377 3283
F +65 6377 3281
singaporesales@schaffner.com
Switzerland
Schaffner EMV AG
Industrie Nord
Nordstrasse 11e
4542 Luterbach
T +41 32 681 66 88
T +41 32 681 66 26
switzerlandsales@schaffner.com
Taiwan
Schaffner EMV Ltd.
20 Floor-2, No 97, Section 1, XinTai 5th Road
22175 XiZhi District New Taipei City 22175
T +886 2 2697 5500
F +886 2 2697 5533
taiwansales@schaffner.com
www.schaffner.com.tw
Thailand
Schaffner EMC Co. Ltd.
Northern Region Industrial Estate
67 Moo 4 Tambon Ban Klang
Amphur Muangg P.O. Box 14
51000 Lamphun
T +66 53 58 11 04
F +66 53 58 10 19
thailandsales@schaffner.com
United Kingdom
Schaffner Ltd.
1, Oakmede Place
Binfield
RG42 4JF Berkshire
T +44 118 9770070
F +44 118 9792969
uksales@schaffner.com
USA
Schaffner EMC Inc.
52 Mayfield Avenue
Edison, New Jersey
T +1 732 225 9533
F +1 732 225 4789
usasales@schaffner.com
www.schaffnerusa.com
很抱歉,暂时无法提供与“ED100-1.5-5M0”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+24.57000
- 200+9.80640
- 450+9.48240
- 900+9.32040
- 国内价格 香港价格
- 1+31.017611+4.01491
- 10+25.5181110+3.30306
- 25+23.6084825+3.05587
- 50+22.2588550+2.88118
- 100+20.98712100+2.71657
