ED100-2-3M0
ED100-2-3M0
    SCHAFFNER(夏弗纳)
    DIP4
    3 mH @ 10 kHz 2 线路共模扼流圈 通孔 2A DCR 200 毫欧(标准)
ED100-2-3M0 数据手册
DATASHEET Common-mode Chokes ED100 / ED101 Current-compensated choke series for lighting applications Approvals & Compliances Common and differential mode inductance Very high differential-mode inductance Rated currents up to 2 A Broadband attenuation characteristics Performance indicators Performance standard very high high Common-mode Inductance [mH] 3 40 Differential-mode Inductance [mH] 0 4 2 1.1 0.1 0.2 6 8 10 Combination of common- and differential-mode inductances Rated current [A] 0 8 0.2 Features and benefits Increases power factor ED100 ED101 3.1 Lighting LED drivers need to be high in efficiency, low in cost and compliant to EMC regulations. The ED100 / ED101 series increases the efficiency of a LED driver circuit by reducing the need for X-capacitors. Thus, the power factor rises, and less unwanted reactive power is generated. The inductor is a combination of a strong common-mode inductance with a significant differential-mode inductance. It offers two filtering elements in one component. This helps the circuit designer to reduce the number of elements on the PCB, to reduce space requirement as well as lowering costs. Combined with the high MTBF value of the ED100 / ED101 series, a circuit design with reduced number of components profits for its overall reliability and lifetime. Rated currents up to 2 A 12 16 20 2 Compact and light-weight Small PCB footprint Typical applications Mains operated LED drivers Technical specifications Electronic ballasts Maximum continuous operating voltage Rated currents Rated inductance Stray inductance Operating frequency Temperature range (operation and storage) Climatic class High potential test voltage winding-towinding @ 25°C 300 VAC, 50/60 Hz Creepage and clearance distances Creepage > 3 mm / Clearance > 2.5 mm between windings Overvoltage category Design corresponding to Inductance reduction (DC bias with IN) Cooling Flammability corresponding to Altitude Protection category Pollution degree MTBF Vibration and shock II acc. IEC 60664-1 Input filters for switch mode power supplies 0.2 to 2 A @ 65°C 3 to 40 mH common-mode 0.1 - 3.1 mH DC to 60 Hz -40°C to 125°C 40/125/56 acc. IEC 60068-1 1500 VAC, 2 sec IEC 60938-1/-2 Less than 10% at rated current AN - natural convection UL 94 V-0 Derating above 2,000 m IP 00 PD2 acc. IEC 60664-1 > 13,000,000 hours acc. MIL-HDBK-217 3M4 acc. IEC 60721-3-3 Typical electrical schematic L(CM) Schaffner Group EMC/EMI Products Datasheets 22 Mar 2022 Choke selection table - ED100 - High Differential-Mode Inductance Rated current CommonMode Inductance DifferentialMode Inductance DC resistance I L (CM) L (DM) R (@65°C) (@10kHz) (@10kHz) (@25°C) [A] [mH] [mH] [Ω] ED100-0.2-40M 0.2 40 1.1 10.0 10 ED100-0.3-27M 0.3 27 0.8 5.5 10 ED100-0.4-20M 0.4 20 0.6 3.7 10 ED100-0.5-15M 0.5 15 0.4 2.0 10 ED100-0.75-12M 0.75 12 0.3 1.2 11 1 9 0.3 0.6 12 ED100 choke Buy ED100-1-9M0 Weight [g] ED100-1.25-7M0 1.25 7 0.2 0.4 13 ED100-1.5-5M0 1.5 5 0.1 0.3 13 2 3 0.1 0.2 13 Weight ED100-2-3M0 Choke selection table - ED101 - Very High Differential-Mode Inductance Rated current CommonMode Inductance DifferentialMode Inductance DC resistance I L (CM) L (DM) R (@65°C) (@10kHz) (@10kHz) (@25°C) [A] [mH] [mH] [Ω] ED101-0.2-40M 0.2 40 3.1 10.0 11 ED101-0.3-27M 0.3 27 2.1 5.5 11 ED101-0.4-20M 0.4 20 1.5 3.7 11 ED101-0.5-15M 0.5 15 1.2 2.0 12 ED101-0.75-12M 0.75 12 0.9 1.2 12 1 9 0.7 0.6 13 ED101 choke Buy ED101-1-9M0 [g] ED101-1.25-7M0 1.25 7 0.5 0.4 14 ED101-1.5-5M0 1.5 5 0.4 0.3 14 2 3 0.2 0.2 14 ED101-2-3M0 Test conditions: Measuring frequency: 10 kHz; 50 mV; Inductance tolerance: +50%, -30%; Resistance tolerance: ±15% @ 25°C; Electrical characteristics @ 25°C: ±2°C; Differential-mode inductance measurement between pin 1 and 2 (pin 3 and 4 shorted) For mechanical tolerances refer to mechanical data section. Current derating 1 Current (A) 2 (1 A @ 65 ◦ C) • 0.5 0 0 50 100 Temperature ( ◦ C) Derating curve normalized to 1 A Distribution inventory Up-to-date inventory levels for global distributors is available at https://products.schaffner.com/stock 3 Schaffner Group EMC/EMI Products Datasheets 22 Mar 2022 1M 10M Hz 1M 10M Hz 1M 10M Hz Typical choke attenuation - ED100 - High Differential-Mode Inductance Per CISPR 17; 50 Ω/50 Ω asym dB dB dB 90 90 90 80 80 80 70 70 60 60 60 50 50 50 40 40 40 30 30 20 20 70 CM CM CM 30 DM DM 10 10 0 0 10k 100k 1M 10M 10 10k Hz 20 DM 100k 1M 10M Hz 10k ED100-0.3-27M ED100-0.2-40M 0 ED100-0.4-20M dB dB dB 90 90 90 80 80 80 70 70 70 60 60 60 50 50 50 40 40 CM 30 30 20 20 40 CM 20 DM DM 10 DM 0 0 10k 100k 1M 10M 10k Hz 100k 1M 10M Hz 0 10k ED100-0.75-12M ED100-0.5-15M dB dB 90 90 90 80 80 80 70 70 70 60 60 60 50 50 CM CM 40 40 30 30 40 CM 30 20 20 DM 10 0 0 ED100-1.25-7M0 100k 20 DM 10 10k 100k ED100-1-9M0 dB 50 CM 30 10 10 100k 1M 10M Hz DM 10 10k 100k 1M 10M Hz 0 10k ED100-1.5-5M0 ED100-2-3M0 100k 4 Schaffner Group EMC/EMI Products Datasheets 22 Mar 2022 1M 10M 1M 10M Hz 1M 10M Hz Typical choke attenuation - ED101 - Very High Differential-Mode Inductance Per CISPR 17; 50 Ω/50 Ω asym dB dB dB 90 90 90 80 80 80 70 70 60 60 50 50 50 40 40 40 30 30 70 CM 60 CM CM DM 20 30 20 20 DM DM 10 10 10 0 0 10k 100k 1M 10M 10k Hz 100k 1M 10M Hz 10k ED101-0.3-27M ED101-0.2-40M 0 100k Hz ED101-0.4-20M dB dB dB 90 90 90 80 80 80 70 70 70 60 60 60 50 50 50 40 40 30 30 20 20 CM 40 CM 20 DM 10 10 0 0 10k 100k 1M 10M DM 10 DM 10k Hz 100k 1M 10M Hz 0 10k ED101-0.75-12M ED101-0.5-15M dB dB 90 90 90 80 80 80 70 70 70 60 60 60 50 50 CM 50 CM 40 40 30 30 20 20 40 20 DM 0 ED101-1.25-7M0 100k 1M 10M Hz 10k 100k DM 10 DM 0 CM 30 10 10 100k ED101-1-9M0 dB 10k CM 30 1M 10M Hz 0 10k ED101-1.5-5M0 ED101-2-3M0 100k Schaffner Group EMC/EMI Products Mechanical data - ED100 / ED101 1 24 ± 0.3 2 20 ± 0.5 3 10 ± 0.4 14.3 +0 -0.4 15.3 ± 0.2 4 0.8 3.6 +0 -0.5 5 For dimensions [mm] without tolerances: ISO2768-m/EN22768-m applies Pin material: Steel (base), Cu (under plating), Sn (final plating 6µm Pin 1 marked with "dot" on label Datasheets 22 Mar 2022 6 Schaffner Group EMC/EMI Products Datasheets 22 Mar 2022 Headquarters, global innovation and development Sales and application centers Switzerland Schaffner Group Industrie Nord Nordstrasse 11e 4542 Luterbach T +41 32 681 66 26 info@schaffner.com China Schaffner EMC Ltd. Shanghai T20-3 C, No 565 Chuangye Road, Pudong district 201201 Shanghai T +86 21 3813 9500 cschina@schaffner.com www.schaffner.com.cn Spain Schaffner EMC España Calle Caléndula 93, Miniparc III, Edificio E El Soto de Moraleja, Alcobendas 28109 Madrid T +34 917 912 900 F +34 917 912 901 spainsales@schaffner.com Finland Schaffner Oy Sauvonrinne 19 H 08500 Lohja T +358 50 468 7284 finlandsales@schaffner.com Sweden Schaffner EMC AB Östermalmstorg 1 114 42 Stockholm T +46 8 5050 2425 swedensales@schaffner.com www.schaffner.com France Schaffner EMC S.A.S. 16-20 Rue Louis Rameau 95875 Bezons T +33 1 34 34 30 60 F +33 1 39 47 02 28 francesales@schaffner.com Germany Schaffner Deutschland GmbH Schoemperlenstrasse 12B 76185 Karlsruhe T +49 721 56910 germanysales@schaffner.com India Schaffner India Pvt. Ltd REGUS WORLD TRADE CENTRE WTC, 22nd Floor Unit No 2238, Brigade Gateway Campus, 26/1, Dr. Rajkumar Road Malleshwaram (W) 560055 Bangalore T +91 80 67935355 indiasales@schaffner.com To find your local partner within Schaffner‘s global network: www.schaffner.com © 2022 Schaffner Group The content of this document has been carefully checked and understood. However, neither Schaffner nor its subsidiaries assume any liability whatsoever for any errors or inaccuracies of this document and the consequences thereof. Published specifications are subject to change without notice. Product suitability for any area of application must ultimately be determined by the customer. In all cases, products must never be operated outside their published specifications. Schaffner does not guarantee the availability of all published products. This disclaimer shall be governed by substantive Swiss law and resulting disputes shall be settled by the courts at the place of business of Schaffner Holding AG. Latest publications and a complete disclaimer can be downloaded from the Schaffner website. All trademarks recognized. Italy Schaffner EMC S.r.l. Via Ticino, 30 20900 Monza (MB) T +39 039 21 41 070 italysales@schaffner.com Japan Schaffner EMC K.K. Taiju-Seimei Sangenjaya Bldg. 1-32-12, Kamiuma, Setagaya-ku 154-0011 Tokyo T +81 3 5712 3650 F +81 3 5712 3651 japansales@schaffner.com www.schaffner.jp Singapore Schaffner EMC Pte Ltd. #05-09, Kg Ubi Ind. Estate 408705 Singapore T +65 6377 3283 F +65 6377 3281 singaporesales@schaffner.com Switzerland Schaffner EMV AG Industrie Nord Nordstrasse 11e 4542 Luterbach T +41 32 681 66 88 T +41 32 681 66 26 switzerlandsales@schaffner.com Taiwan Schaffner EMV Ltd. 20 Floor-2, No 97, Section 1, XinTai 5th Road 22175 XiZhi District New Taipei City 22175 T +886 2 2697 5500 F +886 2 2697 5533 taiwansales@schaffner.com www.schaffner.com.tw Thailand Schaffner EMC Co. Ltd. Northern Region Industrial Estate 67 Moo 4 Tambon Ban Klang Amphur Muangg P.O. Box 14 51000 Lamphun T +66 53 58 11 04 F +66 53 58 10 19 thailandsales@schaffner.com United Kingdom Schaffner Ltd. 1, Oakmede Place Binfield RG42 4JF Berkshire T +44 118 9770070 F +44 118 9792969 uksales@schaffner.com USA Schaffner EMC Inc. 52 Mayfield Avenue Edison, New Jersey T +1 732 225 9533 F +1 732 225 4789 usasales@schaffner.com www.schaffnerusa.com
ED100-2-3M0 价格&库存
很抱歉,暂时无法提供与“ED100-2-3M0”相匹配的价格&库存,您可以联系我们找货
ED100-2-3M0
  • 1+35.339581+4.59403
  • 10+29.0322210+3.77410
  • 25+26.8572325+3.49136
  • 50+25.3233250+3.29195
  • 100+23.87699100+3.10394
库存:419
