K50LDXYXPQ
K50LDXYXPQ
    BANNER(邦纳)
    Module
    堆叠灯 全套装置 黄色 LED 连接器
K50LDXYXPQ 数据手册
EZ-LIGHT™ Indicators - Daylight Visible Datasheet E• PI GT A I L • P UR E QPMA A BL EU RO YL Intense levels of light output for outdoor applications Controlled field of view for signage and narrow lane use May also be used for low-cost vision sensor illumination Rugged, cost-effective, and easy to install Compact devices are completely self-contained, no controller needed Up to three colors in one housing Immune to ambient light, EMI, and RFI interference 50 mm (2 in) diameter with flat profile and 30 mm (1.2 in) mounting base PNP or NPN input type, depending on model 15 to 30 V dc operation •C -S T • • • • • • • • • • Contact Factory for more information CA L L F A C T O RY Note: Optional sun shield model K50DS is available for enhanced visibility in desert sun brightness levels (see Sun Shield -- MASTER on page 4). Model 1 LED Function 2 K50LDGRYPQ 3 Color: Green, Red, Yellow K50LDGRYNQ K50LDGRBPQ K50LDGRBNQ 3 Color: Green, Red, Blue Inputs 3 Model* PNP K50LDXGXPQ NPN PNP NPN LED Function 2 Inputs 3 1 Color: Green PNP/NPN K50LDXRXPQ 1 Color: Red PNP/NPN K50LDXYXPQ 1 Color: Yellow PNP/NPN K50LDXWXPQ 1 Color: White PNP/NPN K50LDXBXPQ 1 Color: Blue PNP/NPN Contact factory for other colors and color combinations. WARNING: Not To Be Used for Personnel Protection Never use this device as a sensing device for personnel protection. Doing so could lead to serious injury or death. This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A sensor failure or malfunction can cause either an energized or de-energized sensor output condition. 1 Integral QD models only are listed. • To order the 150 mm PVC pigtail with QD model, replace Q with QP in model number (example, K50LDGRYPQP). • To order the 2 m (6.5 ft) cable model, omit suffix Q from model number (example, K50LDGRYP). • A model with a QD requires a mating cable (see Accessories on page 3). 2 3-color models: 6 LEDs per color; 1-color models: 18 LEDs per color 3 1-color models are PNP/NPN selectable, depending on hookup. Original Document 137330 Rev. D 1 May 2019 137330 EZ-LIGHT™ Indicators - Daylight Visible Specifications Supply Voltage and Current 15 to 30 V dc at 120 mA maximum (1-color models) 15 to 30 V dc at 40 mA maximum per LED color (3-color models) 12 V dc minimum voltage to –20 °C for both models Supply Protection Circuitry Protected against reverse polarity and transient voltages Indicators LED colors are independently selected, depending on mode Input Response Time Indicator ON/OFF: 1 ms maximum Environmental Rating Fully encapsulated, rated IEC IP67 Construction Base and covers: polycarbonate Connections Integral 4-pin M12/Euro-style quick disconnect fitting, 150 mm PVC pigtail with QD, or 2 m (6.5 ft) integral cable, depending on model Operating Conditions –40 °C to +50 °C (–40 °F to +122 °F) 90% at +55 °C maximum relative humidity (non-condensing) Certifications Dimensions Ø50 mm (1.97") 49.5 mm (1.95") 13 mm (0.51") 20 mm (0.79") 11 mm (0.43") M30 × 1.5 (mounting nut included) max. torque 4.5 Nm (40 lbs/in.) Internal Threads ½- 14 NPSM M12 × 1 Percent of Maximum Intensity vs Viewing Angle X: Viewing Angle (Deg) Y: Intensity (Percent) 2 www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 137330 Rev. D EZ-LIGHT™ Indicators - Daylight Visible Wiring – 1-Color Models Sourcing (PNP) Input Sinking (NPN) Input 1 3 15-30V dc 1 C 2 4 Key: 1 = Brown 15-30V dc 3 C X C = Indicator Color (Green, Red, Yellow, White or Blue) 4 X 3 = Blue 4 = Black 2 X 2 = White X X = Not Used NOTE: 1-color models are PNP/NPN selectable Wiring – 3-Color Models Sourcing (PNP) Input Indicator Color or Indicator Color 15-30V dc Key: 1 = Brown 1 15-30V dc 4 G 1 R Y 3 4 G Sinking (NPN) Input 2 = White 3 = Blue 4 = Black 3 R G = Green R = Red B 2 Y or B 2 Y = Yellow B = Blue Accessories 4-Pin Threaded M12/Euro-Style Cordsets—Single Ended Model Length MQDC-406 1.83 m (6 ft) MQDC-415 4.57 m (15 ft) MQDC-430 9.14 m (30 ft) MQDC-450 15.2 m (50 ft) MQDC-406RA 1.83 m (6 ft) MQDC-415RA 4.57 m (15 ft) MQDC-430RA 9.14 m (30 ft) Style Dimensions 44 Typ. Straight M12 x 1 ø 14.5 P/N 137330 Rev. D 15.2 m (50 ft) 1 4 32 Typ. [1.26"] 30 Typ. [1.18"] Right-Angle MQDC-450RA Pinout (Female) 2 3 1 = Brown 2 = White 3 = Blue 4 = Black M12 x 1 ø 14.5 [0.57"] www.bannerengineering.com - Tel: + 1 888 373 6767 3 EZ-LIGHT™ Indicators - Daylight Visible Mounting Brackets SMB30A • Right-angle bracket with curved slot for versatile orientation • Clearance for M6 (¼ in) hardware • Mounting hole for 30 mm sensor • 12-ga. stainless steel SMBAMS30RA • Right-angle SMBAMS series bracket • 30 mm hole for mounting sensors • Articulation slots for 90°+ rotation • 12-ga. (2.6 mm) cold-rolled steel 45 C 61 B A 69 Hole center spacing: A to B=40 Hole size: A=ø 6.3, B= 27.1 x 6.3, C=ø 30.5 C 53 A B 48 Hole center spacing: A=26.0, A to B=13.0 Hole size: A=26.8 x 7.0, B=ø 6.5, C=ø 31.0 SMBAMS30P • Flat SMBAMS series bracket • 30 mm hole for mounting sensors • Articulation slots for 90°+ rotation • 12-ga. 300 series stainless steel SMB30SC • Swivel bracket with 30 mm mounting hole for sensor • Black reinforced thermoplastic polyester • Stainless steel mounting and swivel locking hardware included 45 C A 93 B Hole center spacing: A=26.0, A to B=13.0 Hole size: A=26.8 x 7.0, B=ø 6.5, C=ø 31.0 SMB30MM • 12-ga. stainless steel bracket with curved mounting slots for versatile orientation • Clearance for M6 (¼ in) hardware • Mounting hole for 30 mm sensor 45 67 B 58 29 A Hole center spacing: A=ø 50.8 Hole size: A=ø 7.0, B=ø 30.0 SMB3018SC • 18 mm swivel side or barrelmount bracket • Black reinforced thermoplastic polyester • Stainless steel swivel locking hardware included 57 70 C 57 B 67 B 59 A 29 Hole center spacing: A = 51, A to B = 25.4 Hole size: A = 42.6 x 7, B = ø 6.4, C = ø 30.1 LMBE12RA35 Hole center spacing: A = 50.8 Hole size: A = ø 7.0, B = ø 18.0 55 35 • Direct mounting of stand-off pipe, with common bracket type • Zinc-plated steel • 1/2-14 NPSM nut • Mounting distance from the wall to the NPSM NUT center of the 1/2-14 NPSM nut is 35 mm Hole center spacing: 20.0 A 1/2 - 14 2X Ø9 LMBE12RA45 38.25 57 • Direct mounting of stand-off pipe, with common bracket type • Zinc-plated steel • 1/2-14 NPSM nut • Mounting distance from the wall to the center of the 1/2-14 NPSM nut is 45 mm Hole center spacing: 35.0 65 45 1/2 - 14 NPSM NUT 38.25 81 2X Ø11 Sun Shield -- MASTER K50DS • Use for enhanced visibility in desert sun brightness levels • Thermoplastic polyester K90DS 4 • Use for enhanced visibility in direct sunlight conditions • Polycarbonate www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 137330 Rev. D EZ-LIGHT™ Indicators - Daylight Visible Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to: www.bannerengineering.com. For patent information, see www.bannerengineering.com/patents. © Banner Engineering Corp. All rights reserved
K50LDXYXPQ
物料型号: - K50LDGRYPQ:3色型号,PNP输入,颜色包括绿色、红色和黄色。 - K50LDGRYNQ:3色型号,NPN输入。 - K50LDGRBPQ:3色型号,PNP输入,颜色包括绿色、红色和蓝色。 - K50LDGRBNQ:3色型号,NPN输入。
器件简介: EZ-LIGHT™ Indicators是一种高亮度的指示器,适用于户外应用,具有控制视野,适合用于标识和狭窄通道。它们是坚固、成本效益高且易于安装的紧凑型设备,无需控制器,具有高达三种颜色的型号。
引脚分配: - 1色型号:棕色(1)连接15-30V直流电源,白色(2)为输入,蓝色(3)为公共端,黑色(4)为指示器颜色。 - 3色型号:输入电源和公共端相同,但每种颜色的LED都有各自的输入端。
参数特性: - 供电电压和电流:1色型号为15至30V直流,最大120mA;3色型号为每LED颜色15至30V直流,最大40mA。 - 工作温度范围:-40°C至+50°C。 - 湿度:最高90%相对湿度(不凝结)。 - 响应时间:指示器开/关最大1毫秒。
功能详解: LED颜色可以独立选择,取决于模式。1色型号可以选择PNP或NPN输入类型。3色型号有6个LED每种颜色,1色型号有18个LED。
应用信息: EZ-LIGHT™ Indicators可用于低成本的视觉传感器照明,但不适用于人员保护。使用该设备作为人员保护的感应设备可能导致严重伤害或死亡。
封装信息: - 直径:50mm (2英寸),安装基座直径30mm (1.2英寸)。 - 高度:13mm (0.51英寸)。 - 安装螺母:M30 × 1.5,最大扭矩4.5 Nm (40 lbs/in.)。
警告: 不要将此设备用作人员保护的感应设备。该设备不包括自我检查的冗余电路,不适用于人员安全应用。
配件: 提供了不同长度和样式的4针M12/Euro-style插头电缆套装,以及多种安装支架选项。
保修信息: Banner Engineering Corp.提供一年有限保修,涵盖材料和工艺缺陷。保修不包括由于误用、滥用或不当应用或安装Banner产品造成的损坏或责任。
K50LDXYXPQ 价格&库存
很抱歉,暂时无法提供与“K50LDXYXPQ”相匹配的价格&库存,您可以联系我们找货
