WP48007025
30W, 48V GaN HEMT Die
Product Features
Applications
Up to 7 GHz Operation
U/VHF Amplifiers
14.0 dB Typical Small Signal Gain at 3.5 GHz
Broadband Amplifiers
30 W Typical Psat at 5.8GHz
Base Station Communications
48V Operation
Drone, UAV
High Breakdown Voltage
WiMAX, LTE, WCDMA, GSM
High Efficiency
WPT, V2X
Reliability Monitoring Supporting
Radar Application
WP48007025
Absolute Maximum Rating (not simultaneous) at 25℃
Symbol
Typical
Value
Units
Conditions
Threshold voltage @ Id=1mA/mm, Vd=10V
Vto
-3.4
V
25°C
Breakdown voltage @ Id=1mA/mm
VDG
160
V
25°C
Drain-source current, Id @ Vd=10V, Vg=0
Idss
800
mA/mm
25°C
Operating Junction Temperature
TJ
225
°C
Storage Temperature
TSTG
-65, +150
°C
Thermal Resistance, Junction to Case (packaged)
RθJC
°C/W
Thermal Resistance, Junction to Case (die only)
RθJC
°C/W
Parameter
Mounting Temperature (30 seconds)
TS
320
°C
30 seconds
DC Characteristics (Frequency= 3.5GHz unless otherwise stated; TA=25℃)
Parameter
Ohmic contact resistance
Maximum Drain-source current, Id @ Vd=10V, Vg=1V (1X125μm device)
Max. trans-conductance, @ Vd=10V, Vg=-4V ~ -1V (1X125μm device)
Symbol
Typical
Value
Units
Conditions
RC
0.3
Ohm-mm
25°C
Idmax
1000
mA/mm
25°C
GM_PEAK
290
mS/mm
25°C
RF Characteristics (Frequency= 3.5GHz unless otherwise stated; TA=25℃)
Symbol
Typical
Value
Units
Conditions
Small Signal Gain
GSS
>12
dB
VDD=48V, IDQ=250mA
Saturated Power Output
PSAT
30
W
VDD=48V, IDQ=250mA
η
>60
VDD=48V, IDQ=250mA
Intermodulation Distortion
IM3
很抱歉,暂时无法提供与“WP48007025”相匹配的价格&库存,您可以联系我们找货
