CTS4F-182K
CTS4F-182K
    CENTRALTECHNOLOGIES
    插件
    1800UH XIALSHIELDED INDUCTOR
CTS4F-182K 数据手册
Shielded Inductors- Axial CTS4F Series SPECIFICATIONS Please specify tolerance code when ordering. CTS4F-R10_ J = ±5%, K = ±10% Part Inductance Number (µH) From .10µH to 150,000µH Not Shown at Actual Size CHARACTERISTICS Description: Axial leaded (shielded) inductor Applications: Used for high reliability applications. Vital for telecommunication applications. Ideal for various RF appications. Higher DC current than CTS3 series Operating Temperature: -55°C to +125°C Inductance Tolerance: ±5% & ±10% Testing: Inductance and Q are tested on an HP4284A or HP4285A at specified frequency Packaging: Tape & Reel, 2,500 parts per reel Marking: EIA color banded with inductance code or marked with part value Material: Molded epoxy resin over the magnetic core for superior shielding and reliability Incremental Current: DC current required to cause a maximum reduction of 5% in inductance for nominal value of inductance measured with zero DC current Shielding: Less than 3% coupling units side by side @ 1kHz Miscellaneous: RoHS Compliant. Other values available Additional Information: Additional electrical & physical information available upon request Samples available. See website for ordering information PHYSICAL DIMENSIONS Size A Max. mm 11.4 inches 0.45 www.ctparts.com B C 24 AWG Max. Typ. Nom. 4.06 29.2 0.511 0.16 1.15 0.02 L Test Freq. (_Hz) Q Factor Min. Q Test Freq. (MHz) CTS4F-R10_ .10 25M 50 25 CTS4F-R12_ .12 25M 50 25 CTS4F-R15_ .15 25M 50 25 CTS4F-R18_ .18 25M 50 25 CTS4F-R22_ .22 25M 50 25 CTS4F-R27_ .27 25M 50 25 CTS4F-R33_ .33 25M 47 25 CTS4F-R39_ .39 25M 47 25 CTS4F-R47_ .47 25M 47 25 CTS4F-R56_ .56 25M 45 25 CTS4F-R68_ .68 25M 43 25 CTS4F-R82_ .82 25M 41 25 CTS4F-1R0_ 1.0 25M 42 25 CTS4F-1R2_ 1.2 7.9M 43 7.9 CTS4F-1R5_ 1.5 7.9M 41 7.9 CTS4F-1R8_ 1.8 7.9M 42 7.9 CTS4F-2R2_ 2.2 7.9M 42 7.9 CTS4F-2R7_ 2.7 7.9M 41 7.9 CTS4F-3R3_ 3.3 7.9M 41 7.9 CTS4F-3R9_ 3.9 7.9M 41 7.9 CTS4F-4R7_ 4.7 7.9M 42 7.9 CTS4F-5R6_ 5.6 7.9M 42 7.9 CTS4F-6R8_ 6.8 7.9M 42 7.9 CTS4F-8R2_ 8.2 7.9M 46 7.9 CTS4F-100_ 10 7.9M 46 7.9 CTS4F-120_ 12 2.5M 50 2.5 CTS4F-150_ 15 2.5M 50 2.5 CTS4F-180_ 18 2.5M 50 2.5 CTS4F-220_ 22 2.5M 50 2.5 CTS4F-270_ 27 1.0k 50 2.5 CTS4F-330_ 33 1.0k 50 2.5 CTS4F-390_ 39 1.0k 50 2.5 CTS4F-470_ 47 1.0k 55 2.5 CTS4F-560_ 56 1.0k 55 2.5 CTS4F-680_ 68 1.0k 55 2.5 CTS4F-820_ 82 1.0k 55 2.5 CTS4F-101_ 100 1.0k 65 2.5 CTS4F-121_ 120 1.0k 65 .79 CTS4F-151_ 150 1.0k 65 .79 CTS4F-181_ 180 1.0k 65 .79 CTS4F-221_ 220 1.0k 65 .79 CTS4F-271_ 270 1.0k 65 .79 CTS4F-331_ 330 1.0k 65 .79 CTS4F-391_ 390 1.0k 65 .79 CTS4F-471_ 470 1.0k 70 .79 CTS4F-561_ 560 1.0k 70 .79 CTS4F-681_ 680 1.0k 75 .79 CTS4F-821_ 820 1.0k 70 .79 CTS4F-102_ 1000 1.0k 65 .79 CTS4F-122_ 1200 1.0k 70 .25 CTS4F-152_ 1500 1.0k 70 .25 CTS4F-182_ 1800 1.0k 70 .25 CTS4F-222_ 2200 1.0k 70 .25 CTS4F-272_ 2700 1.0k 70 .25 CTS4F-332_ 3300 1.0k 70 .25 CTS4F-392_ 3900 1.0k 70 .25 CTS4F-472_ 4700 1.0k 70 .25 CTS4F-562_ 5600 1.0k 70 .25 CTS4F-682_ 6800 1.0k 70 .25 CTS4F-822_ 8200 1.0k 70 .25 CTS4F-103_ 10000 1.0k 70 .25 CTS4F-123_ 12000 1.0k 50 .25 CTS4F-153_ 15000 1.0k 50 .079 CTS4F-183_ 18000 1.0k 50 .079 CTS4F-223_ 22000 1.0k 50 .079 CTS4F-273_ 27000 1.0k 50 .079 CTS4F-333_ 33000 1.0k 50 .079 CTS4F-393_ 39000 1.0k 50 .079 CTS4F-473_ 47000 1.0k 50 .079 CTS4F-563_ 56000 1.0k 50 .079 CTS4F-683_ 68000 1.0k 50 .079 CTS4F-823_ 82000 1.0k 50 .079 CTS4F-104_ 100000 1.0k 50 .079 CTS4F-154_ 150000 25k 30 .025 Manufacturer of Passive Components 800-684-5322 Inside US 949-453-1811 Outside US Copyright © 2017 by CT Magnetics, DBA Central Technologies. All rights reserved. CT Magnetics reserves the right to make improvements or change specifications without notice SRF Min. (MHz) DCR Max. (Ω) 400 400 400 400 400 400 325 390 264 249 221 200 156 144 128 121 108 96 88 84 72 69 62 58 53 47 41 43 38 36 33 29 27 25 23 14 12 11 11 10 9.4 8.0 7.3 6.9 6.5 6.0 5.6 4.8 4.5 2.6 2.5 2.3 2.2 2.1 2.0 1.8 1.7 1.6 1.5 1.4 1.3 .88 .78 .72 .57 .46 .42 .42 .37 .36 .34 .33 .32 .18 .02 .03 .03 .04 .05 .09 .12 .16 .22 .29 .38 .45 .05 .07 .09 .11 .14 .18 .26 .35 .47 .51 .75 .83 1.3 1.7 2.3 .67 .74 .85 .93 1.3 1.5 1.6 2.2 1.9 2.3 2.4 2.8 3.1 3.5 4.5 5.1 5.6 6.4 8.0 8.8 10 12 15 17 19 22 25 33 37 51 54 62 86 93 84 97 104 145 195 222 242 217 362 410 440 484 560 Rated DC (mA) Incr (mA) 3000 2860 2600 2300 2050 1625 1400 1220 1060 900 790 725 2080 1840 1560 1480 1290 1130 950 815 710 680 560 535 432 368 325 596 565 526 505 429 400 380 328 349 322 311 294 277 251 231 215 205 192 174 163 151 139 125 119 111 103 97 85 80 68 66 62 52 50 53 49 48 40 34 32 31 27 25 24 23 22 15 3000 2860 2600 2300 2050 1625 1400 1200 1060 900 790 725 2080 1840 1560 1480 1290 1130 950 815 710 680 560 535 432 368 325 235 220 200 190 180 175 160 150 140 120 95 90 85 80 70 65 60 58 55 50 45 40 35 33 30 27 25 22 20 19 17 16 15 14 13 12 10 9.0 8.0 7.0 6.0 5.0 5.0 4.0 3.0 3.0 3.0 REV 08.29.17
CTS4F-182K 价格&库存
很抱歉,暂时无法提供与“CTS4F-182K”相匹配的价格&库存,您可以联系我们找货
