HCG 150-10-480
HCG 150-10-480
    ASCCAPACITOR
    插件
    HC GEL FILLED 150UF 480 VRMS
HCG 150-10-480 数据手册
ASC™ HC (High Current) single phase capacitors are manufactured with very high quality metallized polypropylene film, designed for long life, low dielectric losses, higher RMS current ratings, and low ESR. The capacitors are filled with ASC™ soft gel or biodegradable vegetable based oil designed to offer excellent thermal conductivity to help reduce internal heating and extend the life of the capacitor. The capacitor is incorporated with internal UL recognized fusing mechanisms that interrupt when pressure reaches a tested level. *Capacitance and KVAR ratings are dependent upon voltage levels, frequency and total current ** UL recognized product is limited to 620Vrms Parameter Value Capacitance Tolerance KVAR Ratings Rated Voltage Temperature Range (operational) Temperature Range (Storage) RMS Current Standards Can/ Cover Terminals Suggested Mounting Position AFC Rating (UL810) Tan δ Terminal to Terminal Test Terminal to Case Test Reliability 17.5µF – 760µF* ±3%, ±5%, ±10%, +10-5% – Special Tolerance on Request Available on Request* 250 – 690 Vrms* -40/70C (custom ratings available) -40/85C Up to 80 Arms IEC61071, IEC60831, UL810** Aluminum Male (M6 or M8), Female (M5-M8) tin plated brass Oil – Upright, Gel – Any Position 10,000 A 2 x 10-4 Polypropylene 2.15 x Urms 10 seconds UT-CASE = 2 UI +1000V or 2000V whichever is highest value 100 FIT AC input and output filtering Cap (µF) IRMS [ARMS] 250 Vrms 150 325 600 760 15.0 31.0 56.0 72.0 400 Vrms 65 135 260 450 10.0 21.0 40.0 70.0 480 Vrms 50 105 200 340 9.0 19.0 37.0 62.0 525 Vrms 38 80 155 265 340 7.6 16.0 31.0 52.0 68.0 600 Vrms 25 60 120 210 300 6.0 14.0 28.0 48.0 68.0 **690 Vrms 17.5 40 85 145 260 4.6 11.0 22.0 38.0 68.0 IMAX (10°ΔT) [ARMS] IPEAK [KA] 354 Vac Peak 25.0 60.0 80.0 80.0 Pieces / Box 3.2 5.0 5.0 5.0 3.9 3.6 2.5 2.2 4.0 2.9 2.1 2.1 75 85 100 116 108 152 178 203 10 9 9 5 2.0 4.0 5.0 5.0 3.9 3.8 2.6 1.8 7.6 6.0 3.8 2.7 75 85 100 116 108 152 178 203 10 9 9 5 1.8 3.8 5.0 5.0 3.9 3.7 2.5 1.8 9.3 7.4 4.7 3.3 75 85 100 116 108 152 178 203 10 9 9 5 1.6 2.2 3.3 4.5 4.5 4.0 3.7 2.6 1.9 1.6 12.0 9.3 5.7 4.0 4.1 75 85 100 116 136 108 152 178 203 245 10 9 9 5 4 6.0 3.9 2.6 1.8 1.5 6.6 3.8 2.4 1.8 1.8 75 85 100 116 136 112 152 178 203 245 10 9 9 5 4 5.9 4.0 2.5 1.8 1.3 9.1 5.3 3.1 2.2 1.8 1290 Vsurge 0.1 0.3 0.6 1.0 1.4 976 Vac Peak 14.0 21.0 35.0 50.0 70.0 Height “H” [mm] 1129 Vsurge 0.2 0.3 0.6 1.0 1.4 849 Vac Peak 15.0 26.0 40.0 56.0 70.0 Diameter “D” [mm] 1023 Vsurge 0.2 0.4 0.8 1.2 742 Vac Peak 14.0 33.0 52.0 70.0 80.0 ESR (60Hz) [mΩ] 860 Vsurge 0.2 0.4 0.8 1.4 679 Vac Peak 16.0 37.0 58.0 80.0 Rth C-E [°C/W] 538 Vsurge 0.3 0.6 1.1 1.4 566 Vac Peak 18.0 42.0 65.0 80.0 ISURGE [KA] 1.1 3.1 5.0 5.0 5.0 1484 Vsurge 0.1 0.2 0.5 0.8 1.4 1.2 1.4 2.5 5.0 5.0 (** Max UL Rating is 620 Vrms) 75 85 100 116 136 112 152 178 203 245 10 9 9 5 4 Cap (µF) IRMS [ARMS] 250 Vrms 150 325 600 760 15.0 32.0 55.0 80.0 80.0 4.6 11.0 22.0 38.0 68.0 15.0 26.0 40.0 56.0 70.0 3.2 5.0 5.0 5.0 2.0 4.0 5.0 5.0 1.4 3.2 5.0 5.0 5.0 1.3 2.6 5.0 5.0 5.0 O = Oil G = Gel Height “H” [mm] Pieces / Box 3.9 3.6 2.5 2.2 4.0 2.9 2.1 2.1 75 85 100 116 108 152 178 203 10 9 9 5 3.9 3.8 2.6 1.8 7.6 6.0 3.8 2.7 75 85 100 116 108 152 178 203 10 9 9 5 4.0 3.8 2.6 1.9 1.7 6.8 6.5 3.5 2.0 1.6 75 85 100 116 136 108 152 178 203 245 10 9 9 5 4 4.1 3.9 2.6 1.8 1.5 10.6 9.5 5.2 2.4 1.7 75 85 100 116 136 108 152 178 203 245 10 9 9 5 4 6.0 3.9 2.6 1.8 1.5 6.6 3.8 2.4 1.8 1.8 75 85 100 116 136 112 152 178 203 245 10 9 9 5 4 5.9 4.0 2.5 1.8 1.3 9.1 5.3 3.1 2.2 1.8 1290 Vsurge 0.1 0.3 0.6 1.0 1.4 1.1 3.1 5.0 5.0 5.0 1484 Vsurge 0.1 0.2 0.5 0.8 1.4 1.2 1.4 2.5 5.0 5.0 Type Fill Material Capacitance HC Diameter “D” [mm] 1129 Vsurge 0.1 0.3 0.5 0.9 1.4 976 Vac Peak 14.0 21.0 35.0 50.0 80.0 ESR (60Hz) [mΩ] 1023 Vsurge 0.2 0.3 0.6 1.1 1.4 849 Vac Peak 6.0 14.0 28.0 48.0 68.0 **690 Vrms 17.5 40 85 145 260 19.0 40.0 65.0 80.0 80.0 Rth C-E [°C/W] 860 Vsurge 0.2 0.4 0.8 1.4 742 Vac Peak 7.0 13.0 26.0 47.0 68.0 600 Vrms 25 60 120 210 300 18.0 42.0 65.0 80.0 ISURGE [KA] 538 Vsurge 0.3 0.6 1.1 1.4 679 Vac Peak 8.0 16.0 30.0 53.0 68.0 525 Vrms 32 65 130 235 340 25.0 60.0 80.0 80.0 566 Vac Peak 10.0 21.0 40.0 70.0 480 Vrms 41 85 165 290 375 IPEAK [KA] 354 Vac Peak 15.0 31.0 56.0 72.0 400 Vrms 65 135 260 450 IMAX (10°ΔT) [ARMS] 20 ↕ 620 (** Max UL Rating is 620 Vrms) Tolerance 3 = ±3% 5 = ±5% 5-10 = +5/-10% 10-5 = +10/-5% 10 = ±10% 75 85 100 116 136 112 152 178 203 245 Voltage Terminals “T” 250 ↕ 690 Examples: Type HC, Oil Filled, 50uF ±5%, 480 Vrms, Male M8 Terminals Type HC, Gel Filled, 120uF +10/-5%, 600 Vrms, Female M6 Terminals F5 = Female M5 F6 = Female M6 F8 = Female M8 M6 = Male M6 M8 = Male M8 Order Code HCO 50-5-480 M8 HCG 120-10-5-600 F6 10 9 9 5 4
HCG 150-10-480 价格&库存
很抱歉,暂时无法提供与“HCG 150-10-480”相匹配的价格&库存,您可以联系我们找货
