ANE-50A
ANE-50A
    OPTIFUSE
    插件
    FUSE STRIP 50A 125VAC/32VDC RECT
ANE-50A 数据手册
Type ANE Automotive / Marine Limiter Fast Acting www.optifuse.com (619) 593-5050 Specifications: ∙ Voltage Rating: 125 VAC, 32 VDC ∙ Amperage Rating: 35A, 40A, 50A, 60A, 70A, 80A, 100A, 120A, 125A, 130A, 150A, 175A, 200A, 225A, 250A, 275A, 300A, 350A, 400A ∙ Interrupting Rating: 2000A @32V DC ∙ Construction: Body Material: FR4 Terminals: Gold-plated Brass/Copper Alloy Recommended Mounting: Optifuse Fuse Block BLC-09 to 200A Optifuse Fuse Block BLC-209 to 800A Time Characteristics % of Rated Clearing Time Current Min 4h 100% Max 300s 250% Mechanical Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of device with chemical solvent. Prolonged contact may damage the device performance. Note: All specifications subject to change without notice. Rev I 09/2023 - Page: 1/2 Type ANE Automotive / Marine Limiter Fast Acting www.optifuse.com (619) 593-5050 TIME CURRENT CURVE GRAPH Note: All specifications subject to change without notice. Rev I 09/2023 - Page: 2/2
ANE-50A 价格&库存
很抱歉,暂时无法提供与“ANE-50A”相匹配的价格&库存,您可以联系我们找货
