ANF-125A
ANF-125A
    OPTIFUSE
    插件
    FUSE STRIP 125A 32VDC RECT
ANF-125A 数据手册
Type ANF Automotive / Marine Limiter Fast Acting www.optifuse.com (619) 593-5050 Specifications: · Voltage Rating: 32 VDC · Amperage Rating: 40A, 50A, 60A, 80A, 100A, 125A, 130A, 150A, 175A, 180A, 200A, 225A, 250A, 275A, 300A, 400A · Construction: Body Material: Bakelite Terminals: Gold-plated 40A ~ 80A – Brass 100A ~ 400A – Copper Alloy Time Characteristics % of Rated Clearing Time Current Min 4h 100% Max 300s 250% Recommended Mounting: Optifuse Fuse Block BLC-09 to 200A Optifuse Fuse Block BLC-209 to 800A Mechanical Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of device with chemical solvent. Prolonged contact may damage the device performance. Note: All specifications subject to change without notice. Rev C 07/2018 - Page: 1/1 Code J01-01H
ANF-125A 价格&库存
很抱歉,暂时无法提供与“ANF-125A”相匹配的价格&库存,您可以联系我们找货
