SC-25D
SC-25D
    OSI
    插件
    光电二极管 670nm 5µs 径向
SC-25D 数据手册
Tetra-Lateral PSD’s Position Sensing Detectors (PSD) Tetra-lateral position sensing detectors are manufactured with one single resistive layer for both one and two dimensional measurements. They feature a common anode and two cathodes for one dimensional position sensing or four cathodes for two dimensional position sensing. These detectors are best when used in applications that require measurement over a wide spacial range. They offer high response uniformity, low dark current, and good position linearity over 64% of the sensing area. A reverse bias should be applied to these detectors to achieve optimum current linearity when large light signals are present. The circuit on the opposite page represents a typical circuit set up for two dimensional tetra-lateral PSDs. For further details as well as the set up for one dimensional PSDs refer to the “Photodiode Characteristics” section of the catalog. Note that the maximum recommended incident power density is 10 mW / cm2. Furthermore, typical uniformity of response for a 1 mm  spot size is ± 5% for SC-25D and SC-50D and ± 2% for all other tetra-lateral devices. FEATURES APPLICATIONS • Tool Alignment and Control • Leveling Measurements • Angular Measurements • 3 Dimensional Vision • Position Measuring • Single Resistivity Layer • High Speed Response • High Dynamic Range • Very High Resolution • Spot Size & Shape Independence Typical Position Dectectability Typical Spectral Response 0.7 0.7 0.70.7 0.6 0.6 0.60.6 0.5 0.5 0.50.5 0.4 0.4 0.40.4 0.3 0.3 0.30.3 0.2 0.2 0.20.2 0.1 0.1 0.10.1 0.0 0.0 0.00.0 Typical Capacitance vs. Reverse Bias Voltage 52 Typical Dark Current vs. Reverse Bias Tetra-Lateral Position Sensors Typical Electro-Optical Specifications at TA=23ºC -15 V -15 V -15 V 670 nm 50Ω typ. typ. Over 80% of Length 64% of Area typ. typ. typ. max. Interelectrode Resistance (kΩ) min. max. Temp Range (˚C) Package Style ¶ Storage Rise Time † (µs) -20 ~ +70 Capacitance (pF) -20 ~ +80 min. Dark Current (µA) Operating 670 nm Absolute Position Detection Error (mm) -10 ~ +60 Responsivity (A/W) 0 ~ + 70 Dimensions (mm) Area (mm2) Model Number Position Sensing Area One-Dimensional Series, Plastic Package LSC-5D « 11.5 5.3 x 2.2 LSC-30D « 122 30 x 4.1 0.35 0.42 0.040 0.01 0.10 50 0.25 2 50 0.240 0.025 0.250 300 3.00 4 100 47 / Plastic 46 / Plastic Two-Dimensional Series, Metal Package SC-4D 6.45 2.54 sq 0.080 0.005 0.050 20 0.66 SC-10D 103 10.16 sq 1.30 0.025 0.250 300 1.00 SC-25D 350 18.80 sq 2.5 0.10 1.0 1625 5.00 SC-50D 957 30.94 2q 5.0 0.25 2.5 3900 5.00 0.35 0.42 3 30 41 / TO-5 44 / Special 45 / Special 21 / Special † Rise time specifications are with a 1 mm φ spot size at the center of the device. ¶ For mechanical drawings please refer to pages 61 thru 73. * Non-Condensing temperature and Storage Range, Non-Condensing Environment. Chip centering within ± 0.010". « Minimum order quantities apply For further details, refer to the “Photodiode Characteristics” section of the catalog. World Class Products - Light Sensing Solutions 53 Photodiode Care and Handling Instructions AVOID DIRECT LIGHT Since the spectral response of silicon photodiode includes the visible light region, care must be taken to avoid photodiode exposure to high ambient light levels, particularly from tungsten sources or sunlight. During shipment from OSI Optoelectronics, your photodiodes are packaged in opaque, padded containers to avoid ambient light exposure and damage due to shock from dropping or jarring. AVOID SHARP PHYSICAL SHOCK Photodiodes can be rendered inoperable if dropped or sharply jarred. The wire bonds are delicate and can become separated from the photodiode’s bonding pads when the detector is dropped or otherwise receives a sharp physical blow. CLEAN WINDOWS WITH OPTICAL GRADE CLOTH / TISSUE Most windows on OSI Optoelectronics photodiodes are either silicon or quartz. They should be cleaned with isopropyl alcohol and a soft (optical grade) pad. OBSERVE STORAGE TEMPERATURES AND HUMIDITY LEVELS Photodiode exposure to extreme high or low storage temperatures can affect the subsequent performance of a silicon photodiode. Storage temperature guidelines are presented in the photodiode performance specifications of this catalog. Please maintain a non-condensing environment for optimum performance and lifetime. OBSERVE ELECTROSTATIC DISCHARGE (ESD) PRECAUTIONS OSI Optoelectronics photodiodes, especially with IC devices (e.g. Photops) are considered ESD sensitive. The photodiodes are shipped in ESD protective packaging. When unpacking and using these products, anti-ESD precautions should be observed. DO NOT EXPOSE PHOTODIODES TO HARSH CHEMICALS Photodiode packages and/or operation may be impaired if exposed to CHLOROTHENE, THINNER, ACETONE, or TRICHLOROETHYLENE. INSTALL WITH CARE Most photodiodes in this catalog are provided with wire or pin leads for installation in circuit boards or sockets. Observe the soldering temperatures and conditions specified below: Soldering Iron: Soldering 30 W or less Temperature at tip of iron 300°C or lower. Dip Soldering: Bath Temperature: Immersion Time: Soldering Time: Vapor Phase Soldering: DO NOT USE Reflow Soldering: DO NOT USE 260±5°C. within 5 Sec. within 3 Sec. Photodiodes in plastic packages should be given special care. Clear plastic packages are more sensitive to environmental stress than those of black plastic. Storing devices in high humidity can present problems when soldering. Since the rapid heating during soldering stresses the wire bonds and can cause wire to bonding pad separation, it is recommended that devices in plastic packages to be baked for 24 hours at 85°C. The leads on the photodiode SHOULD NOT BE FORMED. If your application requires lead spacing modification, please contact OSI Optoelectronics Applications group at (310)978-0516 before forming a product’s leads. Product warranties could be voided. *Most of our standard catalog products are RoHS Compliant. Please contact us for details World Class Products - Light Sensing Solutions 59 A a B c = = = = Distance from top of chip to top of glass. Photodiode Anode. Distance from top of glass to bottom of case. Photodiode Cathode (Note: cathode is common to case in metal package products unless otherwise noted). W = Window Diameter. F.O.V. = Filed of View (see definition below). 2. Dimensions are in inches (1 inch = 25.4 mm). 3. Pin diameters are 0.018 ± 0.002" unless otherwise specified. 4. Tolerances (unless otherwise noted) General: 0.XX ±0.01" 0.XXX ±0.005" Chip Centering: ±0.010" Dimension ‘A’: ±0.015" 5. Windows All ‘UV’ Enhanced products are provided with QUARTZ glass windows, 0.027 ± 0.002" thick. All ‘XUV’ products are provided with removable windows. All ‘DLS’ PSD products are provided with A/R coated glass windows. All ‘FIL’ photoconductive and photovoltaic products are epoxy filled instead of glass windows. Mechanical Drawings Mechanical Specifications and Die Topography 1. Parameter Definitions: For Further Assistance Please Call One of Our Experienced Sales and Applications Engineers 310-978-0516 - Or visit our website at www.osioptoelectronics.com 61 Mechanical Specifications All units in inches. Pinouts are bottom view. BPW34 BPW34B BPW34S typ 15° 0.177 0.169 0.067 0.059 0.035 0.028 0.157 0.150 0.032 0.004 MIN 64 BPW34S CATHODE 0.047 MAX 0-5˚ 0.264 0.240 Mechanical Specifications All units in inches. Pinouts are bottom view. SC-4D SL3-1 SPOT-2D SPOT-3D SPOT-4D SPOT-4DMI QD7-0 SPOT-2DMI QD7-0 0.050 0.130 SL5-1 0.230 QD7-0 SPOT-9D SPOT-9DMI 68 SC-10D SC-25D Mechanical Specifications All units in inches. World Class Products - Light Sensing Solutions 69
SC-25D 价格&库存
很抱歉,暂时无法提供与“SC-25D”相匹配的价格&库存,您可以联系我们找货
