SM662GAE BDSS
SM662GAE BDSS
    SILICONMOTION(慧荣)
    LBGA100
    IC FLASH 640GBIT EMMC 100BGA
SM662GAE BDSS 数据手册
Ferri-eMMC® Industrial / Automotive eMMC Memory Ferri-eMMC ® Industrial / Automotive eMMC Memory Applications Ferri-eMMC® is optimally designed for a wide range of embedded applications and is fully compliant to the JEDEC standards for eMMC* 5.1 protocols. Available in 100/153-ball BGA packages, Ferri-eMMC® eases PCB design and enables low-cost manufacturing. Built with industry proven controllers and high quality NAND components, Ferri-eMMC® offers advanced NAND management features including error correction, bad block management and health monitoring – enabling the most highly reliable, non-volatile eMMC storage solution for today’s cutting edge industrial, embedded and automotive applications. For automotive IVI applications, Ferri-eMMC® features industry leading low dppm, AEC-Q100 qualification, and product longevity support. Embedded applications using HDD or raw NAND today can migrate to Ferri-eMMC® for higher performance and capacity options. Additionally, Ferri-eMMC® can be customized via firmware for specific features and applications. As the world’s leading NAND controller vendor, Silicon Motion builds its products to the highest quality and reliability standards – backed by uncompromise sales and technical support from design through post production. Silicon Motion’s commitment to automotive and industrial quality is fully incorporated throughout the design, manufacturing and qualification phases of its Ferri-eMMC® products. In-Vehicle Infotainment Server Factory Automation / HMI Video Arcade Gaming Why Ferri-eMMC ® Thin Client Medical Device Surveillance (DVR) POS Industrial Handheld Device Multifunction printer Kiosk Test Instruments Easy to adopt .Easy PCB traces routing and layout with high PCB/SMT yield .Excellent long-term reliability and good heat dissipation Lower total cost of ownership .Eliminate requalification cost from NAND generation change .Cost saving with low density Ferri-eMMC®, HDD are typically > 160GB capacity .Long product life cycle Eliminate down time .Supports self-monitoring, analysis and reporting health status .Field programmable firmware update available Customization available .Configurable enhanced partition with content preload / protect .Technical customization available *eMMC: embedded MultiMediaCard Ferri-eMMC® Features High-Efficiency Error Correction .Advanced Hardware BCH Error Correcting Code (ECC) Engine .StaticDataRefresh ™ and EarlyRetirement ™ technologies ensure the data reliability Advanced Global Wear Leveling to Enhance Reliability .Even distribution of program / erase cycles across all NAND flash chips .Maximizes the lifespan with low Write Amplification Index (WAI) Robust Data Protection .Advanced system level protection against unstable power .Software / hardware write protect option .Multiple user data security zones .Software / hardware secure erase function .PowerShield and DataPhoenix technologies prevent data corruption in case of sudden power lost Automotive IVI compliance to the AEC-Q100 requirements Specifications SM662 Host Interface eMMC 5.1 NAND TLC / SLCmode™ Density 16~512GB TLC Dimensions 14 x 18 x 1.4(mm) 11.5 x 13 x 1.2(mm) Package 100 / 153-ball BGA Temperature Support Commercial Temp (-25℃ to +85℃) Industrial Temp (-40℃ to +85℃) Automotive Grade (-40℃ to +85 / +105℃ ) Green Product RoHs compliant / Halogen free For more information about Ferri-eMMC®, please go to www.siliconmotion.com or send e-mail to ferri@siliconmotion.com www.siliconmotion.com © Copyright 2023 Silicon Motion, Inc. FERRIEMMC-PB-202303
SM662GAE BDSS 价格&库存
很抱歉,暂时无法提供与“SM662GAE BDSS”相匹配的价格&库存,您可以联系我们找货
