GNDB4D2D
GNDB4D2D
    CROUZET(高诺斯)
    SIP-4
    SSR 4A OUT 60VDC IN 4-30VDC NONE
GNDB4D2D 数据手册
|   06/2022 › GND Board Series SIP Solid State Relays PCB Mount – DC Output › Output Current of 4 or 10 Amps › Output Voltage of 2-60 Vc, 7-36 Vc › Control Voltage of 4-10 Vc, 4-30 Vc, 10-30 Vc › Classic SIP package for Printed Circuit Boards › DC Switching › CE and UKCA Compliance › Built-in Output Overvoltage Protection GNDB4D2D Product Selection - DC Switching (DC Loads) Rated Load Current 10A 4A (9) Output Voltage 2-60 Vc 7-36 Vc Control Voltage GNDB4D2D 4-30 Vc 4-10 Vc GNDB10D1E 10-30 Vc GNDB10B1E PART NUMBERING SYSTEM Part Number System GND Board Series GNDB: GNDB Series GNDB Control Voltage D1: 4-10 Vc D2: 4-30 Vc B1: 10-30 Vc 4 D2 Output Current 4: 4 A 10: 10 A D Output Voltage D: 2-60 Vc | DC Switching E: 7-36 Vc | DC Switching RÉFÉRENCEMENT Série GNDB: Série GNDB GNDB Tension de commande D1: 4-10 Vc D2: 4-30 Vc B1: 10-30 Vc 4 D2 D Do you need an adapted or customized solution? Contact us on www.crouzet.com Description: Courant de sortie 4: 4 A Tension de sortie D: 2-60 Vc | Commutation CC Crouzet Solid State Relays are designed to be used in almost anyE:application, offering very long life expectancy and are easy to install, easy to use, 10: 10 A 7-36 Vc | Commutation CC robust and multipurpose. For more information about Crouzet’s Solid State relays, please visit www.crouzet.com. NOMENCLATURA |   WWW.CROUZET.COM |  2 |   GND Board Series |   06/2022 Output Characteristics (1) Description 10A 4A (9) Minimum Load Current [mArms] 5 0.1 1 Second surge current @ Ta=25 °C [Apeak] 10 N/A Maximum 1 Cycle Surge Current [Apeak] 10 100 @t=10ms Maximum On-State Voltage Drop @ Rated Current [Vpeak] 1.6 0.2 1.36 Thermal Resistance Junction to Case (Rjc) [°C/W] 1.66 Minimum Heat Sink for Rated Current @ 40 °C [°C/W] No heatsink Operating Voltage [Vrms] 2-60 Vc Transient Voltage [Vpeak] 7-36 Vc 60 (2) Maximum Off-State Leakage Current @ Rated Voltage [mArms] 1 0.1 Minimum Off-State dv/dt @ Maximum Rated Voltage [V/µsec] 200 N/A Minimum Power Factor GNDB4D2D: 0.45 but Overvoltage (Varistor/Diode) and free-wheel diode protection required GNDB10D1E: 0.45 but free-wheel diode protection required GNDB10B1E: 0.45 Input Characteristics (1) Control Voltage Range 4-30 Vc 4-10 Vc 10-30 Vc Part Numbers GNDB4D2D GNDB10D1E GNDB10B1E Maximum Reverse Voltage -30 Vc -10 Vc -30 Vc Minimum Turn-On Voltage 3 Vc Must Turn-Off Voltage 1 Vc Minimum Input Current (for on-state) [mA] 2 7 Vc 7 6 Maximum Input Current [mA] 30 32 30 Nominal Input Impedance [Ohms] 1000 270 1000 Maximum Turn-On Time [msec] 0.2 0.01 Maximum Turn-Off Time [msec] 0.8 0.15 General Characteristics Description Dielectric Strength, Input to Output (50/60 Hz) [V] 2500 Dielectric Strength, Input/Output to Ground (50/60 Hz) [V] N/A Minimum Insulation Resistance (@ 500 Vc) [Ohms] 109 Maximum Capacitance, Input/Output [pF] 8 Ambient Operating Temperature Range [°C] 10A 4A (9) (7) 2500 -40 to 80 Ambient Storage Temperature Range [°C] -40 to 100 Weight (typical) [g] 20.5 Housing Material UL94 V-0 Baseplate Material N/A Input Terminal Screw Torque Range [in-lb/Nm] N/A Load Terminal Screw Torque Range [in-lb/Nm] N/A SSR Mounting Screw Torque Range [in-lb/Nm] N/A Humidity per IEC60068-2-78 [%] 40-85 LED Input Status Indicator No LED MTBF (Mean Time Between Failures) at 40 °C ambient temperature [years] (8) 69 42 MTBF (Mean Time Between Failures) at 60 °C ambient temperature [years] (8) 50 28 MTTFd [years] 313 138 15 Ceramic Substrate |   WWW.CROUZET.COM |  3 |   GND Board Series |   06/2022 General Notes (1) All parameters at 25 °C unless otherwise specified (2) Output will self trigger between 450-600 Vpk not suitable for capacitive loads (7) AC models operating range is -20 to 80 °C (8) All parameters at 50 % power rating and 100 % duty cycle (contact tech support for detailed report) (9) 4 A at 20°C; 3.5 A at 40°C Diagrams Wiring GND Board Series 4(-) 3(+) 2(-) 1(+) L O A D 1 - B DC + Protection Equipment: Short circuit protection GNDB4D2D: it is recommended to add an overvoltage protection Diagrams Equivalent Circuit Block GNDB4D2D, GND Board Series 4-30 Vc control; 2-60 Vc output DC switching (DC Loads) Input Current vs Input Voltage Standard Regulated DC inputs 30 4- INPUT 3+ OUTPUT Input Current (mA) 25 1+ 2- 20 15 10 5 0 0 2 4 6 8 10 12 14 16 18 20 22 24 26 28 30 Input Voltage (V) 4- INPUT 3+ 1+ OUTPUT 2- Input Current vs Input Voltage Standard Regulated DC inputs Input Current (mA) GNDB10D1E, GN Board Series 4-10 Vc control; 7-36 Vc output DC switching (DC Loads) 36 34 32 30 28 26 24 22 20 18 16 14 12 10 8 6 4 2 0 0 1 2 3 4 5 6 Input Voltage (V) 7 8 9 10 |   WWW.CROUZET.COM |  4 |   GND Board Series GNDB10B1E, GN Board Series 10-30 Vc control; 7-36 Vc output DC switching (DC Loads) Input Current vs Input Voltage Standard Regulated DC inputs Input Current (mA) 1+ 4- OUTPUT INPUT 3+ |   06/2022 2- 30 28 26 24 22 20 18 16 14 12 10 8 6 4 2 0 0 2 4 6 8 10 12 14 16 18 20 22 24 26 28 30 Input Voltage (V) Diagrams Dimensions (mm) GNDB4D2D GNDB10D1E - GNDB10B1E 7,6 ± 1 25,4 24,5 43,6 4x Ø1 7,63 ± 1 7,62 ± 1 6,4 ± 1 10,16 ± 1 12,7 ± 1 7,83 ± 1 10,2 ± 1 5,08 ± 1 6,3 ± 1 10,16 ± 1 5,08 ± 1 43,2 4,57 ± 1 4x Ø1 12,7 ± 1 Curves Thermal Derating Curves GNDB4D2D GNDB10D1E - GNDB10B1E 12 4,5 4 10 3,5 8 Current (A) Current (A) 3 2,5 2 1,5 6 4 1 2 0,5 0 0 0 10 20 30 40 50 60 Ambient Temperature (°C) 70 80 90 100 0 10 20 30 40 50 60 Ambient Temperature (°C) 70 80 90 |   WWW.CROUZET.COM |  5 |   GND Board Series |   06/2022 Standards & Electromagnetic Compatibility Specfification EN61000-4-4 Immunity to fast transients / bursts EN61000-4-5 Immunity to surges Standards L508 Warning: The product information contained in this catalogue is given purely as information and does not constitute a representation, warranty or any form of contractual commitment. Crouzet and its subsidiaries reserve the right to modify their products without notice. It is imperative that we should be consulted over any particular use or application of our products and it is the responsibility of the buyer to establish, particularly through all the appropriate tests, that the product is suitable for the use or application. Under no circumstances will our warranty apply, nor shall we be held responsible for any application (such as any modification, addition, deletion, use in conjunction with other electrical or electronic components, circuits or assemblies, or any other unsuitable material or substance) which has not been expressly agreed by us prior to the sale of our products.
GNDB4D2D 价格&库存
很抱歉,暂时无法提供与“GNDB4D2D”相匹配的价格&库存,您可以联系我们找货
GNDB4D2D
