| 06/2022
› GN Board Series
SIP Solid State Relays
PCB Mount – AC Output Single Phase
› Output Current of 4 Amps
› Output Voltage of 12-275 Va, 12-460 Va, 24-600 Va
› Control Voltage of 4-10 Vc, 4-30 Vc
› Classic SIP package for Printed Circuit Boards
› Zero Cross and Special Zero Cross Switching
› cRUus, CE and UKCA Compliance
› Built-in Output Overvoltage Protection
GNB4D1C
Product Selection - Zero Cross (Resistive Loads)
Rated Load Current
4A
Output Voltage
24-600 Va
Control Voltage
GNB4D1C
4-10 Vc
Product Selection - Special Zero Cross (Resistive, Inductive and Capacitive Loads)
Rated Load Current
4A
Output Voltage
Control Voltage
4-30 Vc
12-275 Va
GNB4D2A
PART NUMBERING SYSTEM
12-460 Va
GNB4D2B
Part Number System
GN Board
Series
GNB: GNB Series
GNB
Control Voltage
D1: 4-10 Vc
D2: 4-30 Vc
4
D2
Output Current
4: 4 A
A
Output Voltage
A: 12-275 Va | Special Zero Cross
B: 12-460 Va | Special Zero Cross
C: 24-600 Va | Zero Cross
RÉFÉRENCEMENT
Série
Do you need
an adapted or customized solution? Tension
Contactdeuscommande
on www.crouzet.com
GNB: Série GNB
D1: 4-10 Vc
D2: 4-30 Vc
Description:
Crouzet Solid State Relays are designed to be used in almost any application, offering very long life expectancy and are easy to install, easy to use,
GNB
robust and multipurpose.
4
D2
A
For more information about Crouzet’s Solid State relays, please visit www.crouzet.com.
Courant de sortie
4: 4 A
Tension de sortie
A: 12-275 Va | Spécial Synchrone
B: 12-460 Va | Spécial Synchrone
C: 24-600 Va | Synchrone
| WWW.CROUZET.COM
| 2
| GN Board Series
| 06/2022
Output Characteristics (1)
Rated Load Current
4A
Part Numbers
GNB4D2A
Maximum Load Current @ Ta=30 ° C [Arms]
4A
GNB4D2B
GNB4D1C
Minimum Load Current [mArms]
1
1 Second surge current @ Ta=25 °C, 50/60 Hz [Apeak]
18
Maximum 1 Cycle Surge Current (50/60 Hz) [Apeak]
105
Maximum On-State Voltage Drop @ Rated Current [Vpeak]
1.01
Thermal Resistance Junction to Case (Rjc) [°C/W]
1.5
Maximum 1/2 Cycle I² t for Fusing (50/60Hz) [A² sec] min/typ
55
Minimum Heat Sink for Rated Current @ 40 °C [°C/W]
No heatsink but nominal load current = 3, 5A @40 °C
Operating Voltage (47-63 Hz) [Vrms]
12-275 Va
12-460 Va
24-600 Va
Transient Voltage (Clamping Voltage) [Vpeak] (2)
600 (430)
800 (720)
1200
Maximum Off-State Leakage Current @ Rated Voltage
[mArms]
0.1
Minimum Off-State dv/dt @ Maximum Rated Voltage [V/µsec]
500
Minimum Power Factor
0.45
0.45 with external
protection (Varistor)
Input Characteristics (1)
Control Voltage Range
4-30 Vc
4-10 Vc
Part Numbers
GNB4D2A
GNB4D2B
GNB4D1C
Maximum Reverse Voltage
-6 Vc
-5 Vc
-10 Vc
Minimum Turn-On Voltage
4 Vc
Must Turn-Off Voltage
0.8 Vc
Minimum Input Current (for on-state) [mA]
3
3.7 Vc
5
Maximum Input Current [mA]
30
29
Nominal Input Impedance [Ohms]
1000
270
Maximum Turn-On Time [msec]
10
Maximum Turn-Off Time [msec]
10
General Characteristics
Rated Load Current
4A
Part Numbers
GNB4D2A
Dielectric Strength, Input to Output (50/60 Hz) [V]
4000
GNB4D2B
GNB4D1C
Dielectric Strength, Input/Output to Ground (50/60 Hz) [V]
N/A
Minimum Insulation Resistance (@ 500 Vc) [Ohms]
109
Maximum Capacitance, Input/Output [pF]
8
Ambient Operating Temperature Range [°C] (7)
-40 --> 80 °C
Ambient Storage Temperature Range [°C]
-40 --> 100 °C
Weight (typical) [g]
20g
Housing Material
UL94 V-0
Humidity per IEC60068-2-78 [%]
40-85 %
LED Input Status Indicator
No LED
MTBF (Mean Time Between Failures) at 40 °C ambient
temperature [years] (8)
140
131
MTBF (Mean Time Between Failures) at 60 °C ambient
119
108
MTTFd [years]
219
172
| WWW.CROUZET.COM
| 3
| GN Board Series
| 06/2022
General Notes
All parameters at 25 °C unless otherwise specified
(1)
(2)
Output will self trigger between 450-600 Vpk not suitable for capacitive loads
(7)
AC models operating range is -20 to 80 °C
(8)
All parameters at 50 % power rating and 100 % duty cycle (contact tech support for detailed report)
Diagrams
Wiring
GN Board Series
4(-)
3(+)
2
L
O
A
D
1
1
AC
B
Protection Equipment: Short circuit protection
GNB4D1C: it is recommended to add an overvoltage protection
Diagrams
Equivalent Circuit Block
GNB4D1C, GN Board Series 4-10 Vc control; 24-600 Va output -
Input Current vs Input Voltage
Zero Cross
Standard Regulated DC inputs
30
28
26
INPUT
3+
24
L1
OUTPUT
T1
22
Input Current (mA)
4-
16
14
12
10
8
6
4
2
4
6
8
Input Voltage (V)
GNB4D2A / GNB4D2B, GN Board Series 4-30 Vc control;
12-275 Va/12-460 Va output - Special Zero Cross
10
30
28
26
INPUT
3+
1 AC
OUTPUT
2 AC
24
22
Input Current (mA)
4-
16
14
12
10
8
6
4
2
4
6
8
10
12
14
16
18
Input Voltage (V)
24
26
28
30
| WWW.CROUZET.COM
| 4
| GN Board Series
| 06/2022
Diagrams
Dimensions (mm)
25,4
GN Board Series
4x Ø1
7,63 ± 1
12,7 ± 1
7,62 ± 1
6,4 ± 1
10,16 ± 1
10,2 ± 1
5,08 ± 1
43,2
Curves
Thermal Derating Curves
GN Board Series
5
4,5
4
Current (Amps)
3,5
3
2,5
2
1,5
1
0,5
40
50
60
70
80
90
Ambient Temperature (°C)
Standards & Electromagnetic Compatibility Specfification
EN61000-4-4 Immunity to fast transients / bursts
EN61000-4-5 Immunity to surges
Standards
Warning:
The product information contained in this catalogue is given purely as information and does not constitute a representation, warranty or any form of contractual commitment. Crouzet and its subsidiaries reserve the right to
modify their products without notice. It is imperative that we should be consulted over any particular use or application of our products and it is the responsibility of the buyer to establish, particularly through all the appropriate
tests, that the product is suitable for the use or application. Under no circumstances will our warranty apply, nor shall we be held responsible for any application (such as any modification, addition, deletion, use in conjunction
with other electrical or electronic components, circuits or assemblies, or any other unsuitable material or substance) which has not been expressly agreed by us prior to the sale of our products.
很抱歉,暂时无法提供与“GNB4D2B”相匹配的价格&库存,您可以联系我们找货
