MOD54415-200IR
MOD54415-200IR
    NETBURNER
    Module
MOD54415-200IR 数据手册
MOD5441X Single & Dual Port Ethernet Core Module MOD54415 (100 Version with RJ-45 | 200 Version with 10-pin header ) MOD54417 (100 Version with 2 X RJ-45 | 200 Version with 20-pin header) DATASHEET Key Points • Use as a high-performance single board computer or add Ethernet connectivity to a new or existing design • MOD54417 can function as a switch or as two independent ports, each with its own MAC address • Customize with development kit • Industrial temperature range (-40°C to 85°C) Features • ColdFire 5441x microprocessor at 250MHz • 42 digital I/Os and 2 additional digital inputs • 32MB Flash Memory • 16-bit address and data bus with 3 chip selects • 64MB DDR2 RAM • Eight 12-bit analog-to-digital converters (ADC) • Up to two 10/100Mbps Ethernet • Two 12-bit digital-to-analog converters (DAC) • 8 UARTs, 4 I C, 2 CAN, 3 SPI, and 1-Wire® support • Five pulse width modulators (PWM) 2 • SD/MMC and MicroSD flash card ready Companion development kit The following is available with the development kit: • Customize any aspect of operation including web pages, data filtering, or custom network applications • Development software: NB Eclipse IDE, Graphical debugger, deployment tools, and examples • Communication software: TCP/IP stack, SSL/TLS 1.3, HTTP web server, FTP, E-mail, and flash file system • System software: NBRTOS, ANSI C/C++ compiler and linker MOD54415-200IR MOD54415-100IR 100 Version with RJ-45 MOD54417-100IR MOD54417-200IR 100 Version with 2 X RJ-45 Updated: November 7, 2023 | Page 1 of 8 200 Version with 10-Pin Header 200 Version with 20-pin Header © 2023 NetBurner Inc. All Rights Reserved. MOD5441X Specifications Processor and Memory 32-bit NXP ColdFire 54415 or 54417 running at 250MHz with 32MByte (256Mbit) Flash and 64MByte (512Mbit) DDR2 RAM(1) Network Interface 10/100 BaseT with RJ-45 connector (MOD54415-100IR Version) 10-pin header (MOD54415-200IR Version) Two 10/100 BaseT with RJ-45 connectors (MOD54417-100IR Version) Two 10-pin headers (MOD54417-200IR Version) Data I/O Interface (J1) • Up to 8 UARTs • Up to two 12-bit digital-to-analog converters (DAC) • Up to 4 I C • Up to 5 pulse width modulators (PWM) • Up to 2 CAN 2.0b controllers • Up to 4 external timer in or outputs • Up to 3 SPI • MicroSD flash card ready • Up to 42 digital I/O + 2 digital inputs • 1-Wire® interface 2 • Up to eight 12-bit analog-to-digital converters (ADC) Flash Card Support FAT32 support for SD Cards up to 32GB (requires exclusive use of one SPI port). Serial Configurations The UARTs can be configured in the following way: • 8 TTL ports • Add external level shifter for RS-232 • Add external level shifter for RS-422/485 (up to two ports) Note: UART 0/1 also provides RTS/CTS hardware handshaking signals. LEDs Link and Speed (100 Version only, on RJ-45) Physical Characteristics Dimensions (inches): 2.95” x 2.00” Weight: 1 oz. Mounting Holes: 3 x 0.125” dia. Power MOD54415 module 3.3VDC @ 410 mA with Ethernet | 3.3VDC @ 360 mA without Ethernet MOD54415 module mounted on MOD-DEV-70 3.3VDC @ 450 mA with Ethernet | 3.3VDC @ 400 mA without Ethernet MOD54417 module 3.3VDC @ 520mA with Ethernet | 3.3VDC @ 450 mA without Ethernet MOD54417 module mounted on MOD-DEV-70 3.3VDC @ 530 mA with Ethernet | 3.3VDC @ 520 mA without Ethernet Updated: November 7, 2023 | Page 2 of 8 © 2023 NetBurner Inc. All Rights Reserved. MOD5441X Environmental Operating Temperature -40° to 85° C RoHS Compliance The Restriction of Hazardous Substances guidelines ensure that electronics are manufactured with fewer environment harming materials. Part Numbers MOD54415 Ethernet Core Module (100 Version, with RJ-45) Part Number: MOD54415-100IR MOD54415 Ethernet Core Module (200 Version, with 10-pin header) Part Number: MOD54415-200IR MOD54415 LC Development Kit Part Number: NNDK-MOD54415LC-KIT Kit includes all the hardware and software you need to customize the included platform hardware. See NetBurner Store product page for package contents. MOD54417 Ethernet Core Module (100 Version, with 2 X RJ-45) Part Number: MOD54417-100IR MOD54417 Ethernet Core Module (200 Version, with 20-pin header) Part Number: MOD54417-200IR MOD54417 LC Development Kit Part Number: NNDK-MOD54417LC-KIT Kit includes all the hardware and software you need to customize the included platform hardware. See NetBurner Store product page for package contents. Ordering Information E-mail: sales@netburner.com Online Store: www.NetBurner.com Telephone: 1-800-695-6828 Notes: (1) Both Spansion and Macronix Flash memory chips have been fully qualified and are interchangeable. Updated: November 7, 2023 | Page 3 of 8 © 2023 NetBurner Inc. All Rights Reserved. TXTX+ TXCT RX+ RXRXCT GND N/C LED LED 1 2 3 4 5 6 7 8 9 10 Updated: November 7, 2023 | Page 4 of 8 Signal Pin Transmit Transmit + Transmit Data Center Tap Receive + Receive Receive Data Center Tap Ground Not Connected LED control sink, speed LED control sink, link/activity Description Table 1: MOD54415-200IR Signal Descriptions for JP1 Header RXRX+ NC TX+ TXNC GND TXCT LED LED Signal Transmit Transmit + No Connect Transmit + Transmit No Connectr Ground Transmit Centertap LED control sink, link/activity LEC control sink, speed Description © 2023 NetBurner Inc. All Rights Reserved. Transmit and Receive Data Center Taps on the magnetics must be connected to 1.0uF capacitors to ground. 1 2 3 4 5 6 7 8 9 10 Pin Table 2: MOD54417-200IR Signal Descriptions for JP1 & JP2 Headers Please refer to the appliction note, “Adding an External Ethernet RJ-45 Connector and CPB Layout Guidelines for NetBurner -200 Version Modules”, for details and examples. The 200 version board has a 10-pin header instead of an RJ-45 jack. This header enables you to relocate the jack to another location or to add a different jack with power over ethernet (PoE) capabilities to your module. Pinout and Signal Description MOD5441X F1 D1 F4 A5 H3 D5 C6 A6 B6 A7 D6 B7 8 9 10 11 12 13 14 15 16 17 18 19 20 D18 D17 D20 D19 D22 D21 D24 TA BE1 BE0 TIP Generated D16 OE/RE GND GND VSTBY R/W CS1 CS4 CS5 Function 1 FB_TSIZE0 FB_TSIZE1 DREQ1 DACK1 Function 2 NFC_R/B NFC_CE Function 3 PA4 PA0 PA1 PB4 PB5 PB6 General Purpose I/O J1 Connector Ground Ground Input power 3.3 VDC Data Bus - Read / NOT Write Data Bus - Chip Select 1 or NAND Flash Controller Chip Enable Data Bus - Chip Select 4 or External DMA Request 1 Data Bus - Chip Select 5 or External DMA Acknowledge 1 Data Bus - Output Enable / Read Enable or Burst Transfer Indicator / Read Enable Byte Enable 1 for D16 to D23 (8 bits) or FlexBus Transfer Size 0 Byte Enable 0 for D24 to D31 (8 bits) or FlexBus Transfer Size 1 Data Bus - Transfer in Progress2 Data Bus - Data 16 Data Bus - Transfer Acknowledge or NAND Flash Controller Flash Ready / NOT Busy Data Bus - Data 18 Data Bus - Data 17 Data Bus - Data 20 Data Bus - Data 19 Data Bus - Data 22 Data Bus - Data 21 Data Bus - Data 24 Description 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC Max Voltage Updated: November 7, 2023 | Page 5 of 8 © 2023 NetBurner Inc. All Rights Reserved. Note: 1. Active low signals, such as RESET, are indicated with an overbar. 2. The TIP signal is the logical AND of *CS1, *CS4 and *CS5. TIP can used to control an external data bus buffer for the data bus signals. An example circuit design can be found on the Module Development Board schematic. An external data bus buffer is recommended for any designs that use data bus signals D16-D31. E16 G2 E1 B1 F2 CPU Pin 1 2 3 4 5 6 7 Pin Table 2: Pinout and Signal Descriptions for J1 Connector (1) The module has two dual in-line 50 pin headers which enable you to connect to one of our standard NetBurner Carrier Boards, or a board you create on your own. Table 2 provides descriptions of pin function of the module header. The primary functionality of a pin is not necessarily its default functionality. Most pins that are muxed with GPIO default to their GPIO functionality. See Table 2-1 in section 2.2 of the MCF5441x Reference Manual for a list of the exceptions. MOD5441X C7 A8 D7 B8 D8 C8 A9 K15 B9 L16 G1 F3 C2 B2 A2 E3 D3 E4 C3 B3 C4 C5 B4 D4 A3 A4 B5 CPU Pin D23 D26 D25 D28 D27 D30 D29 RESET D31 RSTOUT CLK A0 A1 A2 A3 A4 A5 A6 A7 A8 A9 A10 A11 A12 A13 A14 A15 VCC3V GND GND Function 1 Function 2 Function 3 Updated: November 7, 2023 | Page 6 of 8 Note: 1. Active low signals, such as RESET, are indicated with an overbar. 2. Internal bus clock is one-half the core/system clock fsys/2 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 Pin MOD5441X PB7 General Purpose I/O Data Bus - Data 23 Data Bus - Data 26 Data Bus - Data 25 Data Bus - Data 28 Data Bus - Data 27 Data Bus - Data 30 Data Bus - Data 29 Processor Reset Input Data Bus - Data 31 Processor Reset Output Internal Bus Clock2 Data Bus - Address 0 Data Bus - Address 1 Data Bus - Address 2 Data Bus - Address 3 Data Bus - Address 4 Data Bus - Address 5 Data Bus - Address 6 Data Bus - Address 7 Data Bus - Address 8 Data Bus - Address 9 Data Bus - Address 10 Data Bus - Address 11 Data Bus - Address 12 Data Bus - Address 13 Data Bus - Address 14 Data Bus - Address 15 Input power 3.3 VDC Ground Ground Description J1 Connector (continued) © 2023 NetBurner Inc. All Rights Reserved. 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC - Max Voltage SSI0_RX USBO_DP USBH_DP SSI0_TX 1.6 C12 B14 1.7+ B15 C13 E15 C9 D9 D10 C10 A10 20 21 22 23 24 25 UART1_CTS SDHC_CLK UART1_RTS SSI0_FS UART1_RX UART1_TX Updated: November 7, 2023 | Page 7 of 8 N2 19 18 UART2_TX USBO_DM USBH_DM A14 1.7+ A15 17 1.6 SSI0_BCLK A13 16 15 14 ADC_IN0 ADC_IN1 ADC_IN2 ADC_IN3 ADC_IN4 ADC_IN5 ADC_IN6 ADC_IN7 VSSA_ADC VSSA_DAC_ADC SSI0_MCLK VDDA_DAC_ADC GND VCC3V UART0_RX UART0_TX Function 1 H1 J1 J2 K4 G4 J3 H2 K3 H5 J5 A12 J4 H4 B10 D11 CPU Rev Pin 6 7 8 9 10 11 12 13 5 1 2 3 4 Pin UART5_TX PWM_A0 UART5_RX UART7_TX I2C5_SDA I2C5_SCL PWM_B3 I2C2_SCL I2C2_SDA UART7_RX SSI_CLKIN DAC1_OUT DAC0_OUT I2C4_SDA I2C4_SCL Function 2 Fuction 3 SPI3_SCK SPI1_SCK SPI3_PCS0 SIM1_RST SPI3_SIN SPI3_SOUT SSI1_TX SIM1_DATA SIM1_VEN SIM1_PD SIM1_CLK SPI2_SIN SPI2_SOUT Table 3: Pinout and Signal Descriptions for J2 Connector (1) MOD5441X PE2/RGPIO PG5 PE1/RGPIO PH5 PE0 PF7 PE3 PH6 Input only PH7 Input only PH3 PH4 PF4 PF3 General Purpose I/O J2 Connector 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC - 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC Max Voltage © 2023 NetBurner Inc. All Rights Reserved. SSI 0 Serial Master Clock or SSI Clock Input or SIM 1 Clock SSI 0 Serial Bit Clock or UART 7 Receive or SIM 1 Card Insertion Detect Signal2 USB- On-the-Go (default configuration) USB- Host (see appnote for host mode configuration) SSI 0 Serial Receive or I2C 2 Serial Data or SIM 1 Power Supply Enable Signal3 USB+ On-the-Go (default configuration) USB+ Host (see appnote for host mode configuration) SSI 0 Serial Transmit or I2C 2 Serial Clock or SIM 1 Bidirectional Transmit/ Receive Data Signal3 UART 2 Transmit or PWM B3 Output Signal/Input Capture or SSI 1 Serial Transmit2 SSI 0 Serial Frame Sync or UART 7 Transmit or SIM 1 Reset Signal2 UART 1 Receive or I2C 5 Serial Data or SPI 3 Serial Data In2,3 UART 1 Transmit or I2C 5 Serial Clock or SPI 3 Serial Data Out2,3 UART 1 Request To Send or UART 5 Receive or SPI 2 Peripheral Select 0 Chip2 UART 1 Clear To Send or UART 5 Transmit or SPI 3 Serial Clock2 SDHC Clock or PWM A0 Output Signal/Input or SPI 1 Serial Clock ADC and DAC Reference Ground (required when using ADC or DAC) Ground Input power 3.3 VDC UART 0 Receive or I2C 4 Serial Data or SPI 2 Serial Data In2,3 UART 0 Transmit or I2C 4 Serial Clock or SPI 2 Serial Data Out2,3 ADC and DAC Supply Voltage 3.3V@24mA, By default VDDA_DAC_ADC is used as the analog reference. If you wish to use a different reference voltage value, the lternate References inputs are: ADC_IN0 for ADC_IN1-3, ADC_IN4 for ADC_IN5-7 Analog to Digital Converter 0 Input Analog to Digital Converter 1 Input Analog to Digital Converter 2 Input Analog to Digital Converter 3 Input or Digital to Analog Coverter 0 Output Analog to Digital Converter 4 Input Analog to Digital Converter 5 Input Analog to Digital Converter 6 Input Analog to Digital Converter 7 Input or Digital to Analog Converter 1 Output Description D12 H15 N11 B11 G14 E14 35 36 37 38 39 40 GND VCC3V IRQ7 IRQ2 CAN1_TX IRQ1 GND IRQ6 I2C0_SCL CAN1_RX SDHC_DAT2 UART2_RX T3IN/PWM_ EXTA3 T2IN/PWM_ EXTA2 T1IN/PWM_ EXTA1 SDHC_DAT1 T0IN/PWM_ EXTA0 OW-DAT UART0_RTS I2C0_SDA SDHC_DAT3 SDHC_DAT0 UART0_CTS SDHC_CMD IRQ3 Function 1 SPI0_PCS2 UART9_TX UART8_TX UART9_RX PWM_B1 DACK0 UART4_RX UART8_RX T0OUT PWM_A2 T1OUT T2OUT T3OUT PWM_A3 PWM_A1 PWM_B2 UART4_TX PWM_B0 SPI0_PCS3 Function 2 USB_CLKIN USBH_VBUS_OC I2C1_SCL CAN0_TX I2C1_SDA SPI1_PCS2 SPI2_PCS0 CAN0_RX USBO_VBUS_OC SPI1_PCS1 SDHC_DAT1 SDHC_DAT2 USBO_VBUS_EN SSI1_RX SPI1_PCS0 SPI1_SOUT SPI2_SCK SPI1_SIN USBH_VBUS_EN Function 3 PC6 PC5 PC2 PB0 PC1 PB2 PC7 PF1 PD3/RGPIO PF5/RGPIO PB1 PE7/RGPIO PF0 PD0/RGPIO PD1/RGPIO PD2/RGPIO PE4 PF2 G7 PF6/RGPIO PG6 PC3 Ground Input power 3.3 VDC External Interrupt 7 External Interrupt 2 or SPI 0 Chip Select 2 or USB Host VBUS Over-Current CAN 1 Transmit or UART 9 Transmit or I2C 1 Serial Clock2,3 External Interrupt 1 Ground External Interrupt 6 or USB Clock In I2C 0 Serial Clock or UART 8 Transmit or CAN 0 Transmit2,3 External Interrupt 3 or SPI 0 Chip Select 3 or USB Host VBUS Enable SDHC Command Line or PWM B0 Output Signal/Input Capture or SPI 1 Serial Data In SDHC DAT0 Line or PWM B2 Output Signal/Input or Serial Data Out UART 0 Clear To Send or UART 4 Transmit or SPI 2 Serial Clock2 SDHC DAT3 Line / Card Detection or PWM A1 Output Signal/Input Capture or SPI 1 Chip Select 0 UART 2 Receive or PWM A3 Output Signal/Input Capture or SSI 1 Serial Receive2 Timer Input 3 / Alternate PWM control signal 3 or Timer Output 3 or USB On-TheGo VBUS Enable Timer Input 2 / Alternate PWM control signal 2 or Timer Output 2 or SDHC DAT2 Line / Read Wait Timer Input 1 / Alternate PWM control signal 1 or Timer Output 1 or SDHC DAT1 Line / Interrupt Detect SDHC DAT1 Line or PWM A2 Output Signal/Input Capture or SPI Chip Select 1 Timer Input 0 / Alternate PWM control signal 0 or Timer Output 0 or USB On-TheGo VBUS Over-Current 1-Wire Data Signal or DMA Acknowledge 0 UART 0 Request To Send or UART 4 Receive or SPI 2 Chip Select 01 I2C 0 Serial Data or UART 8 Receive or CAN 0 Receive2,3 SDHC DAT2 Line / Read Wait or PWM B1 Output Signal/Input Capture or SPI 1 Chip Select 2 CAN 1 Receive or UART 9 Receive or I2C 1 Serial Data2,3 General Purpose Description I/O J2 Connector (continued) Updated: November 7, 2023 | Page 8 of 8 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC Max Voltage © 2023 NetBurner Inc. All Rights Reserved. Note: 1. Active low signals, such as RESET, are indicated with an overbar. 2. Each UART can be clocked from an internal or external source. For external clocks, each UARTn can be clocked by the corresponding DTn_IN vnput pin. 3. If using I2C, the module must add pull-up resistors to SDA/SCL. 49 50 F12 H13 34 48 H14 33 N1 G13 32 M2 D14 F13 P1 31 43 44 45 46 47 B13 30 D15 B12 E13 28 29 G15 C11 27 41 M1 26 42 CPU Pin Pin MOD5441X
MOD54415-200IR 价格&库存
很抱歉,暂时无法提供与“MOD54415-200IR”相匹配的价格&库存,您可以联系我们找货
