AC/DC SWITCHING POWER SUPPLY
SINGLE CHANNEL OUTPUT
50 WATTS
UNIVERSAL INPUT
ESS50 SERIES
General Description
RoHS
Features
1. Smaller than competitors by 15-20%
2. Operating temp shows full load at 50° C
(122° F), can operate at temperatures up to
71°C
3. Five-year guarantee
4. Over-current protection
5. Over-voltage protection
6. Remote Sensing (sense line) available
7. Can meet medical and appliance
standards
Application
Broad needs
Input
Input Voltage:
Input Voltage Range:
AC100~240V
AC85~264V (DC110~350V)
Frequency:
Frequency Range:
Phase:
Inrush Current:
50/60Hz
47~440Hz
Single
14A at 100V; 28A at 200V
*1
ETA USA
16170 Vineyard Blvd. Suite 180, Morgan Hill, CA 95037
Phone: 1-800-ETA-POWR, (408) 778-2793 Fax: (408) 779-2753
8. Low leakage < 500µA
Visit us at: www.e
ta-usa.com
email at: sales@eta-usa.com
Output
Characteristic
Output Voltage
Output Current
Ripple &Noise(max)
Voltage Adjust Range
Rise time
Hold up time
Regulation
a. Line Regulation
[max]
b. Load Regulation
c. Temperature
Coefficient
d. Drift(maximum)
Efficiency
*1
Models
Unit
Vdc
A
mVpp
V
mS
mS
ESS50-3.3
ESS50-05
ESS50-12
ESS50-15
ESS50-24
ESS50-36
3.3
10
120
5.0
10.0
120
12
4.3
150
15
3.5
150
24
2.2
150
36
1.4
250
2.97~3.63
4.50~5.50
10.8~13.2
13.5~16.5
30 Typ.
30 max
21.6~26.4
32.4~39.6
ESS5048
48
1.1
250
43.2~52.8
mV
60
96
144
192
mV
0 to
50°C
-10
to
0°C
mV
40
50
40
50
100
120
120
150
150
240
240
360
240
480
60
60
150
180
290
450
600
60
96
144
192
Power Factor *1
ETA USA
At AC100V 77%-87%
At AC 200V 79%-89%
0.87~0.99
Visit us at: www.e
ta-usa.com
Environmental Specification
Operating Temperature*3
Operating Humidity
Storage Temperature
Storage Humidity
Withstanding Voltage
Isolation Resistance
Vibration
Shock
Cooling
Leakage current
MTBF
-10 to +71 °C
20~90% RH
-30 to +85 °C
10~95% RH [non-condensing]
Primary-Secondary
AC3,000V for 1minute
Primary-Frame Ground
AC2,500V for 1minute
Secondary-Frame Ground AC1,000V for 1minute
*Sensory Current: Secondary Frame Ground
(20[mA])/Others (10[mA])
Primary-Secondary-Frame Ground
100MΩ(minimum) by
DC500V insulation tester
5~10Hz:10mm double amplitude,10-55Hz:19.6m/s2,30 minute
cycle each along X,Y,Z axes(non-operating)
196 m/s2 on x,y,z axis
Convection
500µA
>210,000 hours
Environmental Agencies
Line Conducted Noise [EMI]
Line Harmonic
Distortion/Current
Safety
FCC part 15 class B, VCCI-B, CISPR22-B, EN55022-B Compliant
IEC61000-3-2 Compliant
UL60950-1 1st ed., CAN/CSA C22.2 No.60950-1-03 Approved
UL508 17th ed. , CAN/CSA C22.2 No.107.1-01 Approved
EN60950-1:2001+A11:2004 Approved
CE Marking:EN60950-1:2001+A11:2004(LVD) Declared
Function/Protection
Over current Protection
Operate at 105% min of rated current, automatic return
Over voltage Protection
Remote Sense
Remote Control
Series Operation
Parallel Operation
Driving Indicator
Input reentry at shutdown
Not Available
Applicable by Option(External signal input is required)
Available
Not Available (N+1 Operation is Applicable by Diode-OR)
Power Source on LED indication; Green
Mechanical
Dimension [mm]
Weight [g](typical)
33W × 110L × 79H
280
Conditions:
*1 Rated input and Rated output
*2 at Output current quick change 25% to 75%
*3 At 100% load (convection cooling)
ETA USA
Visit us at: www.eta-usa.com
Derating Curves
ETA USA
Efficiency Curves
Mechanical drawings
ETA USA
Block Diagram
ETA USA
Visit us at: www.e
ta-usa.com
很抱歉,暂时无法提供与“ESS50-36”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2019.48120
- 200+1896.70680
- 500+1833.32160
- 1000+1802.00160
