BS211DC12
BS211DC12
    HASCO
    DIP
    BS SERIES, SPDT, 2A, DC12V SENSI
BS211DC12 数据手册
BAS/BS/SC SERIES SPDT 1,2,5 Amp FEATURES File No.:E75887 ·FCC Pt 68 ·Small Package Pending ·Sealed Type ·PC Pin ·Sensitive type and standard type are available ORDERING INFORMATION CONTACT RATINGS BAS 111 DC12 GF - 1 - XXXX Contact Arrangement 1C Contact Resistance 100mΩ (1A 24VDC) Contact Material SiIver AIIoy BAS111, BS211, SC211 Contact Rating(Resistive) BAS511 NO:2A/125VAC, 2A/30VDC NO/NC: 5A/120VAC 1A/240VAC 5A/30VDC NC:1A/240VAC 2A/30VDC Max. Switching Voltage 240VAC/60VDC 120VAC/60VDC Max. Switching Current 2A 5A Max. Switching Power 250VA/60W 600VA/150W Mechanical Life 5×106 operations Electrical Life 1×105 operations 100MΩ (at 500VDC) Dielectric Strength Between coil & contacts 1000VAC 1min Between open contacts 500VAC 1min Operate time (at nomi. volt.) ≤10ms Release time (at nomi. volt.) ≤5ms Humidity 35% ~ 85% RH Ambient temperature -25°C ~ +70°C BS/SC 211 DC12 GF - 1 - XXXX Model Coil Power:211=Sensitive type Coil Voltage GF:Gold Flash Contacts NIL:No Gold Flash 1:Dust Cover Type 2:Flux Free Type Nil:Sealed Type Customer code COIL DATA Standard Type at 23°C Max. Allowable Voltage VDC 3.3 3 Pick-up Voltage (Max.) VDC 2.1 Drop-out Voltage (Min.) VDC 0.3 5 3.5 0.5 5.5 56 6 4.2 0.6 6.6 80 Nominal Voltage VDC CHARACTERISTICS Insulation Resistance Model Coil Power:111=Standard type 511=Standard type heavy load Coil Voltage GF:Gold Flash Contacts NIL:No Gold Flash 1:Dust Cover Type 2:Flux Free Type Nil:Sealed Type Customer code Coil Resistance Ω±10% 20 9 6.3 0.9 9.9 180 12 8.4 1.2 13.2 320 24 16.8 2.4 26.4 1280 48 33.6 4.8 52.8 5120 Drop-out Voltage (Min.) VDC 0.3 Max. Allowable Voltage VDC 4.8 Coil Resistance Ω±10% Sensitive Type 3 Pick-up Voltage (Max.) VDC 2.1 Vibration resistance 10Hz ~ 55Hz 1.5mm DA 5 3.5 0.5 8.0 120 Unit weight Approx. 4g 6 4.2 0.6 9.6 180 Construction Sealed Type, Dust Cover Type, Flux Free Type Shock Resistance Functional 98m/s2 Destructive 980m/s2 Notes:1) The data shown above are initial values. 2) Please find coil temperature curve in the characteristic curved below. Nominal Voltage VDC 45 9 6.3 0.9 14.4 400 12 8.4 1.2 19.2 700 24 16.8 2.4 38.4 2800 This datasheet is for customers' reference. All the specifications are subject to change without notice. RELAYS & ELECTRONICS INT'L. CORP. TEL:(516) 328-9292 FAX:(516)326-9125 www.hascorelays.com email:info@hascorelays.com BAS/BS/SC SERIES SPDT COIL 1,2,5 Amp SAFETY APPROVAL RATINGS Coil Power UL&CUL Standard Type: 450mW Sensitive Type: 200mW BAS111, BS211, SC211 NO 2A 240VAC/60VDC NC 2A/60VDC, 1A/240VAC BAS511 NO/NC 5A 120VAC/60VDC OUTLINE DIMENSIONS, WIRING DIAGRAM AND PC BOARD LAYOUT. Wiring Diagram (Bottom view) Outline Dimensions BAS/BS Series .44 MAX .43 MAX (10.9) (11.2) BAS/BS Series 6-Φ.039(1) .3(7.62) .3 (7.62) .4(10.16) .125 (3.2) .1(2.54) SC Series .62 MAX (15.7) BAS/BS Series .047(1.2) PCB Layout (Bottom view) SC Series .047(1.2) .44 MAX .43 MAX (10.9) (11.2) .1(2.54) .4(10.16) SC Series 6-Φ.039(1) .3 (7.62) .3(7.62) .62 MAX (15.7) Unit: inch(mm) .4(10.16) .125 (3.2) .1(2.54) .1(2.54) .4(10.16) Remark:1) In case of no tolerance shown in outline dimension: outline dimension ≤1mm,tolerance should be ±0.2mm; outline dimension >1mm and ≤5mm,tolerance should be ±0.3mm;outline dimension >5mm, tolerance should be ±0.4mm.      2) The tolerance without indicating for PCB layout is always ±0.1mm. CHARACTERISTIC CURVES ENDURANCE CURVE OPERATE TIME Time (ms) Operations (×100000 OPS) Temperature Rise (K) COIL TEMPERATURE RISE Operate time Release time Switching Current (A) Coil Power (W) Coil Power (W) This datasheet is for customers' reference. All the specifications are subject to change without notice. RELAYS & ELECTRONICS INT'L. CORP. TEL:(516) 328-9292 FAX:(516)326-9125 www.hascorelays.com email:info@hascorelays.com
BS211DC12 价格&库存
很抱歉,暂时无法提供与“BS211DC12”相匹配的价格&库存,您可以联系我们找货
