SPAN-P10R-G18M-PNLK-PNVBA-L1
    FESTO(费斯托)
    SMD
    PRESSURE SENSOR
SPAN-P10R-G18M-PNLK-PNVBA-L1 数据手册
Pressure sensor SPAN-P10R-G18M-PNLK-PNVBA-L1 Part number: 8035533 Data sheet Feature Value Symbol 00995685 Certification RCM compliance mark c UL us - Listed (OL) CE marking (see declaration of conformity) As per EU EMC directive As per EU RoHS directive UKCA marking (see declaration of conformity) To UK instructions for EMC To UK RoHS instructions Certificate issuing authority UL E322346 Note on materials RoHS-compliant Measured variable Relative pressure Method of measurement Piezoresistive pressure sensor Pressure measuring range initial value 0 MPa Pressure measuring range initial value 0 bar Pressure measuring range initial value 0 psi Pressure measuring range end value 1 MPa Pressure measuring range end value 10 bar Pressure measuring range end value 145 psi Max. overload pressure 15 bar Overload pressure 1.5 MPa Overload pressure 15 bar Overload pressure 217.5 psi Operating medium Compressed air as per ISO 8573-1:2010 [7:4:4] Inert gas Information on operating and pilot media Operation with oil lubrication possible Temperature of medium 0 °C ... 50 °C Ambient temperature 0 °C ... 50 °C Accuracy in ± % FS 1.5 %FS Repetition accuracy in ± %FS 0.3 %FS Temperature co-efficient in ± %FS/K 0.05 %FS/K Switching output 2 x PNP or 2 x NPN switchable Switching function Window comparator Threshold value comparator Auto difference monitoring Switching element function N/C contact/N/O contact switchable Max. output current 100 mA Analog output 0 - 10 V 4 - 20 mA 1-5V 12/8/23 - Subject to change - Festo SE & Co. KG 1/3 Feature Value Max. load resistance of current output 500 Ohm Min. load resistance of voltage output 20 kOhm Short-circuit protection yes Protocol IO-Link® IO-Link®, protocol version Device V 1.1 IO-Link®, profile Smart sensor profile IO-Link®, function classes Binary data channel (BDC) Process data variable (PDV) Identification Diagnostics Teach channel IO-Link®, communication mode COM2 (38,4 kBd) IO-Link®, SIO mode support Yes IO-Link®, port class A IO-Link®, process data width OUT 0 Byte IO-Link®, process data width IN 2 Byte IO-Link®, process data content IN 14 bit PDV (pressure measurement) 2 bit BDC (pressure monitoring) IO-Link®, minimum cycle time 3 ms IO-Link®, data memory required 500 byte DC operating voltage range 15 V ... 30 V Reverse polarity protection for all electrical connections Electrical connection 1, connection type Plug Electrical connection 1, connection technology Connection diagram L1J Electrical connection 1, number of pins/wires 4 Electrical connection for input 1, connection pattern 00995428 Type of mounting Front panel mounting With thread With wall/surface bracket Mounting position Any Pneumatic connection External thread G1/8 Internal thread M5 Product weight 46 g Housing material PA-reinforced Materials in contact with the media FPM High-alloy stainless steel Display type Illuminated LCD Displayable unit(s) MPa bar inH2O inHg kPa kgf/cm² mbar mmHg psi Setting options IO-Link® Teach-in Via display and pushbuttons Protection against tampering IO-Link® PIN code Setting range threshold value 0 % ... 100 % Setting range hysteresis 0 % ... 90 % Degree of protection IP40 Corrosion resistance class (CRC) 2 - Moderate corrosion stress LABS (PWIS) conformity VDMA24364-B1/B2-L 12/8/23 - Subject to change - Festo SE & Co. KG 2/3 Feature Value Suitability for the production of Li-ion batteries Metals with more than 1% copper, zinc or nickel by mass are excluded from use. Exceptions are nickel in steel, chemically nickel-plated surfaces, printed circuit boards, cables, electrical plug connectors and coils Cleanroom class Class 4 according to ISO 14644-1 12/8/23 - Subject to change - Festo SE & Co. KG 3/3
SPAN-P10R-G18M-PNLK-PNVBA-L1 价格&库存
很抱歉,暂时无法提供与“SPAN-P10R-G18M-PNLK-PNVBA-L1”相匹配的价格&库存,您可以联系我们找货
