PSB-C01-M5
PSB-C01-M5
    AUTONICS(奥托尼克斯)
    SMD
    PRESSURE SENSOR M5 12-24V
PSB-C01-M5 数据手册
PSA / PSB Series Compact, Digital Display Pressure Sensors Features SENSORS ● High brightness red LED (LED height : 9.5mm) ● Min. display interval-Negative pressure: 0.1kPa -Standard pressure: 0.1kPa, 1kPa -Compound pressure: 0.2kPa ● Convertible pressure unit - Negative, Compound pressure : kPa, kgf/cm2, bar, psi, mmHg, mmH2O, inHg - Standard pressure : kPa, kgf/cm2, bar, psi ● Various output modes : Hysteresis mode, Automatic sensitivity setting mode, Independent 2 output mode, Window comparative output mode ● Chattering prevention for output (selectable response time : 2.5ms, 5ms, 100ms, 500ms) ● One-touch connector type for easy wiring and maintenance ● Analog output: voltage (1-5VDC) ● Reverse power polarity and overcurrent protection circuit ● Zero-point adjustment function, peak value monitoring function, bottom hold display CONTROLLERS MOTION DEVICES PSA Series SOFTWARE PSB Series PSB Series Connector type Please read “Safety Considerations” in the instruction manual before using. (A) Photoelectric Sensors Ordering Information PS A V 01 C P Rc1/8 Pressure port Output type Cable ※1 Pressure range Pressure type Appearance Rc1/8 NPT1/8 M5 Standard (PSA Series) Option (PSA Series) Standard (PSB Series) No mark P NPN open collector output PNP open collector output No mark C Cable type Connector type 01 1 100kPa 1,000kPa No mark V C Standard pressure Negative pressure Compound pressure A Regular square (30×30mm) Rectangular (cable type: 10.4×54.2mm) (connector type: 10×52mm) B Item ※1: It is only applied to PSB Series. PS Pressure and Max. Pressure Display Range Type Negative pressure kPa kgf/cm2 bar 0.0 to -101.3 0.000 to -1.033 0.000 to -1.013 (5.0 to -101.3) (0.051 to -1.033) (0.05 to -1.013) 0.0 to 100.0 0.000 to 1.020 0.000 to 1.000 (-0.051 to 1.122) (-0.050 to 1.100) Standard (-5.0 to 110.0) pressure 0 to 1000 0.00 to 10.20 0.00 to 10.00 (-50 to 1100) (-0.51 to 11.22) (-0.50 to 11.00) Compound -100.0 to 100.0 -1.020 to 1.020 -1.000 to 1.000 pressure (-101.2 to 110.0) (-1.034 to 1.122) (-1.012 to 1.100) ※( ) is Max. pressure display range. ※For using a unit mmH₂O, multiply display value by 100. (B) Fiber Optic Sensors psi 0.00 to -14.70 (0.74 to -14.70) 0.00 to 14.50 (-0.72 to 15.96) 0.0 to 145.0 (-7.2 to 159.6) -14.50 to 14.50 (-14.70 to 15.96) (C) LiDAR (D) Door/Area Sensors (E) Vision Sensors (F) Proximity Sensors (G) Pressure Sensors (H) Rotary Encoders Pressure Sensor (I) Connectors/ Connector Cables/ Sensor Distribution Boxes/ Sockets mmHg 0 to -760 (38 to -760) inHg 0.0 to -29.9 (1.5 to -29.9) mmH2O 0.0 to -103.3 (5.2 to -103.3) - - - - - - -750 to 750 (-760 to 824) -29.5 to 29.5 (-29.8 to 32.6) -102.0 to 102.0 (-103.4 to 112.2) Pressure Conversion Chart to Pa kPa MPa kgf/cm2 mmHg mmH2O psi bar inHg from 1Pa 1 0.001 0.000001 0.000010197 0.007501 0.101972 0.000145038 0.00001 0.0002953 1kPa 1000 1 0.001 0.010197 7.500617 101.971626 0.145038 0.01 0.2953 1MPa 1000000 1000 1 10.197162 7500.61683 101971.626 145.038243 10 295.299875 1kgf/cm2 98066.5 98.0665 0.098067 1 735.55924 10000.0005 14.223393 0.980665 28.959025 1mmHg 133.322368 0.133322 0.000133 0.001359 1 13.595099 0.019337 0.001333 0.039370 1mmH2O 9.80665 0.009807 0.000099 0.073556 1 0.00142 0.000098 0.002896 1psi 6894.733 6.89473 0.006895 0.070307 51.714752 703.016716 1 0.068947 2.036014 1bar 100000 100 0.100000 1.019716 750.062 10197.1626 14.503824 1 29.529988 1inHg 3386.388 3.386388 0.003386 0.034532 25.40022 345.315507 0.491156 0.033864 1 E.g.) For calculating 760mmHg as kPa : According to above chart, 1mmHg is 0.133322kPa, therefore 760mmHg will be 760×0.133322kPa=101.32472kPa. G-35 PSA / PSB Series Specifications Pressure type Model NPN open collector output ※1 PNP open collector output Rated pressure range Display and set pressure range Max. pressure range Applied fluid Power supply Current consumption Control output ※2 Hysteresis Repeat error Response time Protection circuit Analog output Display digit Display method Min. display interval Pressure unit Display accuracy Ambient temp. Environment Ambient humi. Vibration Material Protection structure Cable type Cable Connector type Approval Gauge pressure Negative pressure Standard pressure Compound pressure PSA-V01PSA-01PSA-1PSA-C01PSB-V01PSB-01PSB-1PSB-C01PSB-V01CPSB-01CPSB-1CPSB-C01CPSA-V01PPSA-01PPSA-1PPSA-C01PPSB-V01PPSB-01PPSB-1PPSB-C01PPSB-V01CPPSB-01CPPSB-1CPPSB-C01CP0.0 to -101.3kPa 0.0 to 100.0kPa 0.0 to 1,000kPa -100.0 to 100.0kPa 5.0 to -101.3kPa -5.0 to 110.0kPa -50 to 1,100kPa -101.2 to 110.0kPa 2 times of rated pressure 1.5 times of rated pressure 2 times of rated pressure Air, Non-corrosive gas 12-24VDCᜡ ±10% (ripple P-P : Max. 10%) Max. 50mA NPN or PNP open collector output • Load voltage: Max. 30VDCᜡ • Load current: Max. 100mA • Residual voltage - NPN: Max. 1VDCᜡ, PNP: Max. 2VDC 1-digit fixed (2-digit for psi unit) 2-digit fixed ±0.2% F.S. ±1-digit ±0.2% F.S. ±2-digit Selectable 2.5ms, 5ms, 100ms, 500ms Output short over current protection circuit • Output voltage: 1-5VDCᜡ ±2% F.S. • Zero-point: Within 1VDCᜡ ±2% F.S. • Span: Within 4VDCᜡ ±2% F.S. • Linear: Within ±2% F.S. • Resolution: Approx. 1/200 • Output impedance: 1kΩ 3½ -digit 7-segment LED 1-digit (psi unit: 2-digit are fixed) 2-digit kPa, kgf/cm2 , bar, psi, kPa, kgf/cm2, bar, psi, 2 kPa, kgf/cm , bar, psi mmHg, mmH2O, inHg mmHg, mmH2O, inHg 0 to 50℃: Max. ±1% F.S., -10 to 0℃ : Max. ±2% F.S. -10 to 50℃, storage: -20 to 60℃ 35 to 85%RH, storage: 35 to 85%RH 1.5mm amplitude at frequency of 10 to 55Hz (for 1 min) in each X, Y, Z direction for 2 hours • PSA - Front, Rear case: Polycarbonate (insert glass), Pressure port: die-cast (Zn) • PSB - Case, Pressure port, Cover: IX EF • PSB-C - Case, Pressure port, Cover: IXEF IP40 (IEC standard) Ø4mm, 5-wire, 2m (AWG24, Core diameter: 0.08mm, Number of cores: 40, Insulation out diameter: Ø1mm) 5-wire, 3m (AWG24, Insulation out diameter: Ø1mm) • PSA: Approx. 200g (approx. 120g) • PSB: Approx. 160g (approx. 70g) • PSB-C: Approx. 160g (approx. 70g) ※1: ' ' is pressure port type. Please refer to the ' Ordering Information'. ※2: In hysteresis output mode, detection difference is variable. ※3: The weight includes packaging. The weight in parenthesis in for unit only. ※F.S.: Rated pressure. ※There may be ±1-digit error in hysteresis by pressure unit calculation error. ※The specification of pressure port is marked on the upper part of the case. ※Environment resistance is rated at no freezing or condensation. Weight ※3 ● Analog output voltage-Pressure characteristic ● Analog output voltage-Linear characteristic PSA-01 Output 6 PSA-01 Output 6 4 4 3 3 2 2 1 1 voltage (V) 5 0 G-36 voltage (V) 5 20 40 60 80 100 Pressure (kPa) 0 Full scale ±2% F.S. 20 40 60 80 100 Pressure (kPa) Compact, Digital Display Pressure Sensor Dimensions (unit: mm) 34 30 35.5 20 23 2-M3 20 13 CONTROLLERS MOTION DEVICES 10.5 A A Ø4, 2m Sold separately (front cover (PSO-P01)) 5.7 40 1 9.7 Sold separately (panel bracket (PSO-01)) ※A: Rc1/8 (standard), NPT1/8 (option) Panel cut-out 36 +0.5 0 (A) Photoelectric Sensors 42 35 26 40 28.2 SOFTWARE 40 42 SENSORS 9 8.5 30 38.5 18.4 13.4 PSA Series 30 40 20 25.8 (panel thickness: 0.8 to 3.5mm) Ø4.2 Bracket B (C) LiDAR 11 Bracket A 3 (B) Fiber Optic Sensors 13 3-Ø3.2 25 14 3-Ø3.2 (E) Vision Sensors 22 (F) Proximity Sensors 1.6 26 20 40 Ø4.2 PSB Series 1.6 20 30 35 2-Ø3.4 4 Ø4, 2m Connector type 25 12 Cable type 2-M2 4.5 Connector cable 3m 2-Ø3.2 (Accessory) 2-M2 19 19 54.2 4 10.3 4 (H) Rotary Encoders 25.5 12 20 30 (G) Pressure Sensors Pressure port M5 Tap depth: 5 52 10 4.2 6 15 14 6 45 20 5 20 14 4.2 6 11 (D) Door/Area Sensors Pressure port M5 Tap depth: 5 Sold separately (connector cable (PSO-C01)) ※Ø4mm, 5-wire, 2m (AWG24, core diameter: 0.08mm, number of cores: 40, insulator diameter: Ø1mm) G-37 (I) Connectors/ Connector Cables/ Sensor Distribution Boxes/ Sockets PSA / PSB Series Control Output Diagram (PSA/PSB) ● NPN open collector output type ● PNP open collector output type (Brown)+V (Orange)Analog voltage output Load 1kΩ (Black)OUT1 Overcurrent protection Load + Overcurrent protection (White)OUT2 Overcurrent protection Main circuit Main circuit (Brown)+V - 12-24VDC (Black)OUT1 + Overcurrent protection (White)OUT2 1kΩ (Blue)0V (Orange)Analog voltage output Load - 12-24VDC Load (Blue)0V ※There is no short-circuit protection in analog voltage output. Do not connect this output to power supply or capacitive load directly. ※Please observe input impedance of connected equipment when use analog voltage output. And be sure to check voltage drop caused by resistance of extended wire. ※If short-circuit the control output terminal or supply current over the rated specification, control signal is abnormal due to the current protection circuit. Unit Description (PSA Series) (PSB Series) 7 7 2 3 1 2 5 3 4 1 6 6 4 5 1. 3½digit LED display (red) : Display sensing pressure, every setting value and display error. 2. 1 output indicator (red) : Output 1 is ON, LED will be ON. 3. 2 output indicator (PSA: red, PSB: green) : Output 2 is ON,LED will be ON. 4. Mode key : Parameter setting mode or preset setting mode, save setting value. 5. Up key : Set the setting value to lower step in preset setting or pressure unit, output mode, response time, analog output scale, key lock, peak hold value, bottom hold value display in parameter setting. 6. Down key : Set setting value to upper step in preset setting or pressure unit, output mode, response time, analog output scale, key lock, peak hold, bottom hold display in parameter setting. 7. Range of rated pressure : It is possible to change the pressure unit in PSA Series. Please use different unit as label for your application. Setting (PSA/PSB) RUN mode Press key over 3sec. Parameter setting Preset value setting Press key over 3sec. Press + over 1sec. Peak hold key Zero-point adjustment Display unit setting Output operation mode setting Sensing level 1 setting [ST1, LO] Peak hold Response time setting Analog output scale setting (1VDC) Analog output scale setting (5VDC) Key lock setting Sensing level 2 setting [ST2, LO] Bottom hold Zero-point adjustment Zero Point Adjustment (PSA/PSB) 1 2 1. In state of atmospheric pressure during RUN mode, press key and key at the same time for over 1sec. 2. When the zero point adjustment is completed, it will display )0 and return to RUN mode automatically. ※Please execute zero point adjustment regularly. G-38 ※If executing zero point adjustment when external pressure has been applied, ER1 will be flashing. Please execute zero point again in state of atmospheric pressure. Compact, Digital Display Pressure Sensor Parameter Setting (PSA/PSB) SENSORS RUN mode Press Key over 3sec. UNT Display unit setting CONTROLLERS UNT and previously set unit will flash in turn every 0.5 sec. Press or key to select the unit. (Press key momentarily, the unit will be saved, then move to the next mode.) MOTION DEVICES SOFTWARE ● Negative pressure, compound pressure: PA (kPa) 9F (kgf/cm2) BAR PSI MMH INH H2O (bar) (psi) (mmHg) (inHg) (mmH2O) ※For using mmH₂O unit, multiply display value by 100. ● Standard pressure: PA (kPa) OUT (kgf/cm2) BAR PSI (bar) (psi) Response time setting F-2 F-3 F-4 F-5 (C) LiDAR (D) Door/Area Sensors F-6 SPD and the previous response time will flash by turning on. (0.5sec) Select the output operation mode with , Key. (Press key momentarily, the response time will be saved, then move to the next mode.) @5 %0 100 500 (E) Vision Sensors (F) Proximity Sensors (unit : ms) A-1 Analog output scale setting (1VDC) A-1 and the previous pressure will flash by turning on. (0.5sec) Set the pressure which will output 1VDC with , Key. Allowable setting range : Min. value of rated pressure ≤ [ A-1] ≤ 90% of rated pressure (Press key momentarily, the selected pressure is set as 1VDC scales, then move to the next mode.) A-5 Analog output scale setting (5VDC) A-5 and the previous pressure will flash by turning on. (0.5sec) Set the pressure which will output 5VDC by , Key. Allowable setting range : [ A-1] +10% of rated pressure ≤ [ A-5]< Max. value of rated pressure (Press key momentarily, the selected pressure is set as 5VDC scales, then move to the next mode.) EY Key Lock EY and the previous key lock will flash by turning on (0.5sec) Select key lock with , Key. (Press key momentarily, key lock is set, then move to the display unit setting mode.) LO PaL (A) Photoelectric Sensors (B) Fiber Optic Sensors Output operation OUT and previous output operation mode will flash by turning on. (0.5sec) Select the output operation mode with , Key. mode setting (Press key momentarily, the response time will be saved, then move to the next mode.) F-1 SPD 9F UNL ※Key lock functions • LOC : Disable to change preset value and parameter value (Enable to change EY mode only) • PaL: Disable to change parameter setting/preset, zero point adjustment (Enable to check peak hold and bottom hold, and to change EY mode) • UNL: Enable to change preset value and parameter value (Lock off) ※When advance to parameter setting mode and preset setting mode, it displays "Setting item" and "Previous setting value" by 0.5 sec. turn. This display will stop by pressing or key (Display setting value), if any key is untouched for over 1 sec., it will display old value by 0.5sec. turn again. ※When key is pressed for 3sec. during setting, it will return to RUN mode with memorizing on EEPROM. However, when there is any key is untouched for 60sec., it turns to RUN mode with keeping the previous setting value not current setting value. ※There is memory protection by EEPROM, but life cycle of EEPROM is 100,000 times. G-39 (G) Pressure Sensors (H) Rotary Encoders (I) Connectors/ Connector Cables/ Sensor Distribution Boxes/ Sockets PSA / PSB Series Preset Value Setting (PSA/PSB) Hysteresis mode[ F-1] and independent 2 output mode[ F-3, F-4, F-5] RUN mode RUN mode ST1 and previously set value will flash in turn every 0.5 sec. ST2 and previously set value will flash in turn every 0.5 sec. Press or Key to select ST1 setting value. Press or Key to select ST2 setting value. ※ST1 setting range : Min. display pressure < ST1 ≤ Max. display pressure ※ST2 setting range : - Hysteresis mode: Min. display pressure ≤ ST2 < ST1 - 2 independent output mode: Min. display pressure< ST2 ≤ Max. display pressure Automatic sensitivity setting mode[ F-2] RUN mode RUN mode ST1 and previously set value will flash in turn every 0.5 sec. ST2 and previously set value will flash in turn every 0.5 sec. After applying ST1 into Pressure port, then press Key. After applying ST2into Pressure port, than press Key. ※ST1 setting range : Min. display pressure <ST1 ≤ Max. display pressure - 1% of rated pressure ※ST2 setting range : ST1 + 1% of rated pressure <ST2 ≤ Max. display pressure SET and previously set value will flash in turn every 0.5 sec. Sensitivity will be automatically SET. Press or key to fineadjust the setting value between ST1 and ST2. ST1+ST2 SET= 2 Adjustable range of set value: Between ST1 and ST2. Window comparison output mode[ F-6] RUN mode RUN mode LO and previously set value will flash in turn every 0.5 sec. Press or Key to select LOsetting value. HIand previously set value will flash in turn every 0.5 sec. Press or Key to select HIsetting value. ※Low value setting range : Min. display pressure ≤ LO ≤ Max. display pressure ※High value setting range : LO ≤ HI< Max. display pressure ● If no key is touched for 60sec., it will return to RUN mode. [Automatic sensitivity setting mode[F-2] is exception] ● When changing the display unit, preset value will be calculated according to the display unit. ●Whenever key touched one time, it is increased (decreased) as 1 digit (2 digits for psi unit and compound pressure) but it will be continuously increasing (decreasing) by pressing , key constantly. Peak Hold and Bottom Hold Check 1. Press key for over 3sec. in RUN mode. 2. PeH and memorized max. pressure (Negative pressure type is for max. negative pressure) will flash by turning on (0.5sec.) then display peak hold value. 3. BoH and memorized min. pressure (Negative pressure type is for min. negative pressure) will flash by turning on (0.5sec.) then display bottom hold value. 4. If pressing key one time shortly, memorized peak hold and bottom hold value will be removed then return to RUN mode. ※When the peak hold and bottom hold value is over the max. display pressure value, it displays HHH, On the opposite, it displays LLL. Please remove peak hold and bottom hold value by using key. G-40 Compact, Digital Display Pressure Sensor Output Operation Mode (PSA/PSB) 1. Hysteresis mode [ F-1] Input ※It can be set for pressure sensing level[ST1] and sensing difference[ST2]. ※ST1 setting range : Min. display pressure<ST1 ≤ Max. display pressure ST2 setting range : Min. display pressure ≤ ST2 < ST1 • OUT 1: When applying pressure is larger than ST1, it wil be ON. • OUT 2: When applying pressure is lower than ST2, it will be ON. SENSORS ST1 ST2 OUT1 ON OFF OUT2 ON OFF CONTROLLERS Time MOTION DEVICES SOFTWARE 2. Automatic sensitivity setting mode [ F-2] ※This function is to set pressure sensing level to the proper Input position automatically, it is set by received pressure from two ST2 positions [ST1, ST2]. ※The sensing hysteresis fixed to 1 digit (2 digits for psi unit and SET compound type) ST1 ※The pressure sensing level [SET] is shown in the following calculation. (ST1 + ST2) SET = 2 ON • OUT 1 : When applying pressure is larger than SET value, it will OUT1 OFF be ON. OUT2 ON • OUT 2 : When applying pressure is between ST1 and ST2, it OFF will be ON. Note1) If it is not enough for difference of sensing level between ST1 and ST2, ER3 will be displayed. Please set again after applying enough pressure. Note2) ST1 setting range: Min. display pressure ≤ ST1 ≤ Max. display pressure -1% of rated pressure ST2 setting range: ST1 +1% of rated pressure ≤ ST2 ≤ Max. display pressure Note3) If fine adjustment for sensing level is required, adjust sensing level by , key. (Adjustment range : Between ST1 and ST2) 3. Independent 2 output mode [ F-3, F-4, F-5] ※ST1 and ST2 can be set independently within display pressure range. One is for control, the other is for alarm or optional control. ※The sensing hysteresis fixed to 1 digit (2 digits for psi unit and compound type) ※ST1 setting range : Min. display pressure ≤ ST1 ≤ Max. display pressure ST2 setting range : Min. display pressure ≤ ST2 ≤ Max. display pressure ● Independent 2 output mode [F-3] • OUT 1 : It will be ON, when it is over ST1. • OUT 2 : It will be ON, when it is over ST2. ● Independent 2 opposite mode [F-4] • OUT 1 : It will be OFF when it is over ST1. • OUT 2 : It will be OFF, when it is over ST2. ● Independent 2 cross mode [F-5] • OUT 1 : It will be OFF when it is under ST1. • OUT 2 : It will be ON, when it is under ST2. (A) Photoelectric Sensors Time (B) Fiber Optic Sensors (C) LiDAR (D) Door/Area Sensors (E) Vision Sensors (F) Proximity Sensors Input ST2 (G) Pressure Sensors ST1 F-3 F-4 OUT1 ON OFF Time (I) Connectors/ Connector Cables/ Sensor Distribution Boxes/ Sockets OUT2 ON OFF OUT1 ON OFF OUT2 ON OFF OUT1 ON OFF OUT2 ON OFF F-5 4. Window comparison output mode [ F-6] ※It is able to set High limit value [HI], Low limit value [LO] of pressure sensing level in this mode. ※The sensing hysteresis fixed to 1 digit (psi unit and compound type 2 digits) ※LO setting range : Min. display pressure ≤ LO< Max. display pressure HIsetting range : LO≤ HI< Max. display pressure • OUT 1 : It will be ON between high limit value[ HI] and low limit value[LO] • OUT 2 :It will be ON when it is over high limit value[ HI] and low limit value[ LO]. Input HI LO ON OFF OUT2 ON OFF (H) Rotary Encoders Time OUT1 G-41 PSA / PSB Series Functions (PSA/PSB) Pressure unit change PS -V01 (C) (P)/PS -C01 (C) (P) has 7 kinds of pressure unit and PS -01 (C) (P)/PS -1 (C) (P) has 4 kinds of pressure unit. Please select the proper unit for application. • PS -V01 (C) (P), PS -C01 (C) (P) : kPa, kgf/cm², bar, psi, mmHg, inHg, mmH₂O • PS -01 (C) (P), PS -1 (C) (P) : kPa, kgf/cm², bar, psi ※When using mmH₂O multiply the display value by 100. Output mode change There are 6 kinds of control output modes in order to provide the various detection. Select a mode for your proper application. • Hysteresis mode [ F-1] When variable hysteresis is required for pressure detection. • Automatic sensitivity setting mode [ F-2] When it is required to set detecting sensitivity automatically at proper position. • Independent 2 output mode [ F-3, F-4, F-5] When it is required to detect pressure from two position with one product. • Window comparison output mode [ F-6] When is required to detect pressure in a certain range. Error display Error display Description When external pressure is input while adjusting zero ER1 point When overload is applied ER2 on control output When the setting value is not matched with setting ER3 condition When applied pressure exceeds High-limit of HHH display pressure range When applied pressure exceeds Low-limit of LLL display pressure range Troubleshooting Try again after removing external pressure Remove overload Check setting conditions and set proper setting values Apply pressure within display pressure range Installation (PSA Series) 1. When installing pressure port, it is able to bring pressure from 3 directions by changing the mounting direction of the pressure port. 2. Basic spec of pressure port is Rc1/8 and option pressure port is NPT1/8. Use general one-touch fitting. Response time change (chattering prevention) It can prevent chattering of control output by changing response time. It is able to set 4 kinds of response time (2.5, 5, 100, 500ms) and if the response is getting longer, the sensing will be more stable by increasing the number of digital filter. Analog output scale setting It is not fixed the analog output (1-5VDC) scale as the rated pressure range but this is a function to change properly for user's application. When the position[A-1] for 1VDC output and the position [A-5] for 5VDC output are set, the pressure range of A-1 to A-5 is to 1-5VDC analog output. 3. Please use seal tape at port plug in order to prevent pressure leak. 4. Please block another two pressure ports not used with port plug. Spring washer Key lock This unit has 2 kinds of key lock function in order to prevent wrong operation. • LOC: All keys are locked, it is impossible to change any parameter setting/preset, zero point adjustment, peak hold and bottom hold. (Enable to change EY mode only). • PaL: It is impossible to change parameter setting/preset, zero point adjustment. (Enable to check peak hold and bottom hold, and to change EY mode). • UNL: All keys are unlocked. Port plug Hexagon wrench bolt 5. Please connect it by using spanner (13mm) at the metal part in order not to overload on the body when connecting one touch fitting. 13mm spanner Zero-point adjustment This function is to set the display value of pressure at zero when port is opened to atmospheric pressure. Peak hold and bottom hold This function is diagnosis malfunction of the system caused by parasitic pressure or to check through memorizing the max./min. pressure that occurred in the system. G-42 Caution The tightening torque of one touch fitting should be max. 10N.m. If not, it may cause mechanical problem. Compact, Digital Display Pressure Sensor 6. PSA Series has 2 kinds of brackets so it is able to install it in two different ways. 7. At first, please unscrew hexagon wrench bolt and assemble the bracket on this unit by fixing the hexagon wrench bolt. Spring washer Proper Usage Caution Hexagon wrench bolt Caution In this case, tightening torque of hexagon wrench should be max. 3N.m. If not, it may cause mechanical problem. 8. Bracket (PSO-01) and front protection cover (PSO-P01) are sold separately. Please see the pictures for installation. SENSORS PSA, PSB Series is for sensing of non corrosive gas. Do not use this product at corrosive gas or flammable gas, etc. • Please using this unit within the range of specification, if applying pressure is larger than specification, it may not be working properly due to damage. • After supplying power, it takes 3 sec. to work. • When using switching mode power supply, frame ground (F.G.) terminal of power supply should be grounded. CONTROLLERS MOTION DEVICES SOFTWARE Panel bracket (PSO-01) Switching mode power supply Body (PSA) + - (A) Photoelectric Sensors F.G. Protection cover (s) (B) Fiber Optic Sensors Bracket panel Installation (PSB Series) 1. Pressure port is M5. Use general one touch fitting. Body O-Ring Pressure port • It may cause malfunction by noise, when wiring with power line or high voltage line. • Do not insert any sharp or pointed object into pressure port. It may cause mechanical problem due to sensor damage. • Do not use this unit with flammable gas, because this is not an explosion proof structure. • Be sure that this unit should not be contacted directly with water, oil, thinner, etc. Hexagon wrench bolt (M2×10) One touch fitting 2. It is able to use it without the pressure port according to environment. In this case O-Ring between pressure port and its body should not be taken out in order to prevent pressure leak. 10mm Spanner (F) Proximity Sensors (I) Connectors/ Connector Cables/ Sensor Distribution Boxes/ Sockets ● PSA/PSB • Pressure unit label ±100kPa ±101.3kPa 100kPa ±1.020㎏f/㎠ -1.034㎏f/㎠ 1.020㎏f/㎠ 1MPa 10.20㎏f/㎠ ±14.50㎰i -14.70㎰i 14.50㎰i 145.0㎰i ±1.000bar -1.013bar 1.000bar 10.00bar ±750㎜hg -760㎜hg ×10 ×10 ±29.5inHg -29.9inHg ×100 ×100 ±102.0㎜H2O -103.4㎜H2O ×1000 ×1000 DISPLAY UNIT LABEL ● Only for PSA Series Caution (E) Vision Sensors (H) Rotary Encoders Accessory 3. Please connect it by using spanner (10mm) at pressure port in order not to overload on the body when connecting one touch fitting. (D) Door/Area Sensors (G) Pressure Sensors • Wiring must be done with power off. ※Do not pull the cable with a tensile strength of 30N or over. (C) LiDAR • Port plug • Bracket A • Bracket B The tightening torque of one touch fitting and hexagon wrench should be Max. 5N.m and 2N.m. It may cause mechanical trouble. Please do not use spanner to install as it may cause mechanical trouble. G-43
PSB-C01-M5 价格&库存
很抱歉,暂时无法提供与“PSB-C01-M5”相匹配的价格&库存,您可以联系我们找货
