Tetra-Lateral PSD’s
Position Sensing Detectors (PSD)
Tetra-lateral position sensing detectors are manufactured with one single resistive layer
for both one and two dimensional measurements. They feature a common anode and
two cathodes for one dimensional position sensing or four cathodes for two dimensional
position sensing.
These detectors are best when used in applications that require measurement over a
wide spacial range. They offer high response uniformity, low dark current, and good
position linearity over 64% of the sensing area.
A reverse bias should be applied to these detectors to achieve optimum current linearity
when large light signals are present. The circuit on the opposite page represents a typical
circuit set up for two dimensional tetra-lateral PSDs. For further details as well as the set up
for one dimensional PSDs refer to the “Photodiode Characteristics” section of the catalog.
Note that the maximum recommended incident power density is 10 mW / cm2. Furthermore,
typical uniformity of response for a 1 mm spot size is ± 5% for SC-25D and SC-50D and
± 2% for all other tetra-lateral devices.
FEATURES
APPLICATIONS
• Tool Alignment and Control
• Leveling Measurements
• Angular Measurements
• 3 Dimensional Vision
• Position Measuring
• Single Resistivity Layer
• High Speed Response
• High Dynamic Range
• Very High Resolution
• Spot Size & Shape Independence
Typical Position Dectectability
Typical Spectral Response
0.7
0.7
0.70.7
0.6
0.6
0.60.6
0.5
0.5
0.50.5
0.4
0.4
0.40.4
0.3
0.3
0.30.3
0.2
0.2
0.20.2
0.1
0.1
0.10.1
0.0
0.0
0.00.0
Typical Capacitance vs. Reverse Bias Voltage
52
Typical Dark Current vs. Reverse Bias
Tetra-Lateral Position Sensors
Typical Electro-Optical Specifications at TA=23ºC
-15 V
-15 V
-15 V
670 nm
50Ω
typ.
typ.
Over
80% of Length
64% of Area
typ.
typ.
typ.
max.
Interelectrode
Resistance
(kΩ)
min.
max.
Temp
Range
(˚C)
Package
Style ¶
Storage
Rise
Time †
(µs)
-20 ~
+70
Capacitance
(pF)
-20 ~ +80
min.
Dark Current
(µA)
Operating
670 nm
Absolute
Position Detection
Error
(mm)
-10 ~
+60
Responsivity
(A/W)
0 ~ + 70
Dimensions (mm)
Area (mm2)
Model Number
Position Sensing
Area
One-Dimensional Series, Plastic Package
LSC-5D «
11.5
5.3 x 2.2
LSC-30D «
122
30 x 4.1
0.35
0.42
0.040
0.01
0.10
50
0.25
2
50
0.240
0.025
0.250
300
3.00
4
100
47 / Plastic
46 / Plastic
Two-Dimensional Series, Metal Package
SC-4D
6.45
2.54 sq
0.080
0.005
0.050
SC-10D
103
10.16 sq
1.30
0.025
0.250
300
1.00
SC-25D
350
18.80 sq
2.5
0.10
1.0
1625
5.00
SC-50D
957
30.94 2q
5.0
0.25
2.5
3900
5.00
0.35
0.42
3
30
41 / TO-5
44 / Special
45 / Special
21 / Special
† Rise time specifications are with a 1 mm φ spot size at the center of the device.
¶ For mechanical drawings please refer to pages 61 thru 73.
* Non-Condensing temperature and Storage Range, Non-Condensing Environment.
Chip centering within ± 0.010".
« Minimum order quantities apply
For further details, refer to the “Photodiode
World Class Products - Light Sensing Solutions
53
Photodiode Care and Handling Instructions
AVOID DIRECT LIGHT
Since the spectral response of silicon photodiode includes the visible light region, care must be taken to avoid photodiode exposure to
high ambient light levels, particularly from tungsten sources or sunlight. During shipment from OSI Optoelectronics, your photodiodes are
packaged in opaque, padded containers to avoid ambient light exposure and damage due to shock from dropping or jarring.
AVOID SHARP PHYSICAL SHOCK
Photodiodes can be rendered inoperable if dropped or sharply jarred. The wire bonds are delicate and can become separated from the
photodiode’s bonding pads when the detector is dropped or otherwise receives a sharp physical blow.
CLEAN WINDOWS WITH OPTICAL GRADE CLOTH / TISSUE
Most windows on OSI Optoelectronics photodiodes are either silicon or quartz. They should be cleaned with isopropyl alcohol and a soft
(optical grade) pad.
OBSERVE STORAGE TEMPERATURES AND HUMIDITY LEVELS
Photodiode exposure to extreme high or low storage temperatures can affect the subsequent performance of a silicon photodiode. Storage
temperature guidelines are presented in the photodiode performance specifications of this catalog. Please maintain a non-condensing
environment for optimum performance and lifetime.
OBSERVE ELECTROSTATIC DISCHARGE (ESD) PRECAUTIONS
OSI Optoelectronics photodiodes, especially with IC devices (e.g. Photops) are considered ESD sensitive. The photodiodes are shipped in
ESD protective packaging. When unpacking and using these products, anti-ESD precautions should be observed.
DO NOT EXPOSE PHOTODIODES TO HARSH CHEMICALS
Photodiode packages and/or operation may be impaired if exposed to CHLOROTHENE, THINNER, ACETONE, or TRICHLOROETHYLENE.
INSTALL WITH CARE
Most photodiodes in this catalog are provided with wire or pin leads for installation in circuit boards or sockets. Observe the soldering
temperatures and conditions specified below:
Soldering Iron:
Soldering 30 W or less
Temperature at tip of iron 300°C or lower.
Dip Soldering:
Bath Temperature:
Immersion Time:
Soldering Time:
Vapor Phase Soldering:
DO NOT USE
Reflow Soldering:
DO NOT USE
260±5°C.
within 5 Sec.
within 3 Sec.
Photodiodes in plastic packages should be given special care. Clear plastic packages are more sensitive to environmental stress than those
of black plastic. Storing devices in high humidity can present problems when soldering. Since the rapid heating during soldering stresses
the wire bonds and can cause wire to bonding pad separation, it is recommended that devices in plastic packages to be baked for 24 hours
at 85°C.
The leads on the photodiode SHOULD NOT BE FORMED. If your application requires lead spacing modification, please contact OSI
Optoelectronics Applications group at (310)978-0516 before forming a product’s leads. Product warranties could be voided.
*Most of our standard catalog products are RoHS Compliant. Please contact us for details
59
A
a
B
c
Distance from top of chip to top of glass.
Photodiode Anode.
Distance from top of glass to bottom of case.
Photodiode Cathode
(Note: cathode is common to case in metal package products unless otherwise noted).
W = Window Diameter.
F.O.V. = Filed of View (see definition below).
2. Dimensions are in inches (1 inch = 25.4 mm).
3. Pin diameters are 0.018 ± 0.002" unless otherwise specified.
4. Tolerances (unless otherwise noted)
General: 0.XX ±0.01"
0.XXX ±0.005"
Chip Centering: ±0.010"
Dimension ‘A’: ±0.015"
5. Windows
All ‘UV’ Enhanced products are provided with QUARTZ glass windows,
0.027 ± 0.002" thick.
All ‘XUV’ products are provided with removable windows.
All ‘DLS’ PSD products are provided with A/R coated glass windows.
All ‘FIL’ photoconductive and photovoltaic products are epoxy filled
instead of glass windows.
Mechanical Drawings
Mechanical Specifications and Die Topography
1. Parameter Definitions:
For Further Assistance
Please Call One of Our Experienced
Sales and Applications Engineers
310-978-0516
- Or visit our website at
www.osioptoelectronics.com
61
All units in inches. Pinouts are bottom view.
BPW34
BPW34B
BPW34S
typ
15°
0.177
0.169
0.067
0.059
0.035
0.028
0.157
0.150
0.032
0.004
MIN
64
BPW34S
CATHODE
0.047
MAX
0-5˚
0.264
0.240
SC-4D
SL3-1
SPOT-2D
SPOT-3D
SPOT-4D
SPOT-4DMI
QD7-0
SPOT-2DMI
QD7-0
0.050
0.130
SL5-1
0.230
QD7-0
SPOT-9D
SPOT-9DMI
68
SC-10D
SC-25D
69
很抱歉,暂时无法提供与“SC-10D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+1680.99784100+218.52428
