ESS150-36
ESS150-36
    ETA-USA
    Module
    AC/DC CONVERTER 36V 155W
ESS150-36 数据手册
AC/DC SWITCHING POWER SUPPLY SINGLE CHANNEL OUTPUT 150 WATTS UNIVERSAL INPUT ESS150 SERIES General Description RoHS Features 1. Smaller than competitors by 15-20% 2. Operating temp shows full load at 50° C (122° F), can operate at temperatures up to 71°C 3. Five-year guarantee 4. Over-current protection 5. Over-voltage protection 6. Remote Sensing (sense line) available 7. Can meet medical and appliance standards Application Broad needs 8. Low leakage < 500µA Input Input Voltage: Input Voltage Range: AC100~240V AC85~264V (DC110~350V) Input Frequency: Frequency Range: Phase: Inrush Current: 50/60Hz 47~440Hz Single 14A at 100V; 28A at 200V *1 ETA USA 16170 Vineyard Blvd. Suite 180, Morgan Hill, CA 95037 Phone: 1-800-ETA-POWR, (408) 778-2793 Fax: (408) 779-2753 Visit us at: www.e ta-usa.com email at: sales@eta-usa.com Output Characteristic Output Voltage Output Current Voltage Adjust Range Ripple &Noise(max) Rise time Hold up time Regulation a. Line Regulation [max] b. Load Regulation c. Temperature Coefficient d. Drift(maximum) Efficiency *1 Models Unit Vdc A V mVpp mS mS ESS150-3.3 3.3 30 ESS150-05 5.0 30 ESS150-12 12 13 ESS150-15 15 10 ESS150-24 24 6.5 ESS150-36 36 4.3 ESS150-48 48 3.3 2.97~3.63 4.50~5.50 10.8~13.2 13.5~16.5 21.6~26.4 32.4~39.6 43.2~52.8 mV 20 20 48 60 96 144 192 mV 0 to 50°C -10 to 0°C mV 40 50 40 50 100 120 120 150 150 240 240 360 240 480 60 60 150 180 290 450 600 20 20 48 60 96 144 192 120 120 % Power Factor *1 ETA USA 16170 Vineyard Blvd. Suite 180, Morgan Hill, CA 95037 Phone: 1-800-ETA-POWR, (408) 778-2793 Fax: (408) 779-2753 150 150 30 typ. 30 max. 150 250 At AC100V 81%-86.5% At AC 200V 83%-89% 0.89-0.99 Visit us at: www.e ta-usa.com email at: sales@eta-usa.com 250 Environmental Specification Operating Temperature*3 Operating Humidity Storage Temperature Storage Humidity Withstanding Voltage Isolation Resistance Vibration Shock Cooling Leakage current MTBF -10 to +71 °C 20~90% RH -30 to +85 °C 10~95% RH [non-condensing] Primary-Secondary AC3,000V for 1minute Primary-Frame Ground AC2,500V for 1minute Secondary-Frame Ground AC1,000V for 1minute *Sensory Current: Secondary Frame Ground (20[mA])/Others (10[mA]) Primary-Secondary-Frame Ground 100MΩ(minimum) by DC500V insulation tester 5~10Hz:10mm double amplitude,10-55Hz:19.6m/s2,30 minute cycle each along X,Y,Z axes(non-operating) 196 m/s2 on x,y,z axis Convection 500µA >150,000 hours Environmental Agencies Line Conducted Noise [EMI] Line Harmonic Distortion/Current Safety Built to meet FCC-B, VCCI-B, CISPR22-B, EN55022-B IEC61000-3-2 Compliant UL60950-1 1st ed., CAN/CSA C22.2 No.60950-1-03 Approved UL508 17th ed., CAN/CSA C22.2 No.107.1-01 Approved EN60950-1:2001+A11:2004 Approved CE Marking:EN60950-1:2001+A11:2004(LVD) Declared Function/Protection Over current Protection Over voltage Protection Remote Sense Remote Control Series Operation Parallel Operation Driving Indicator Operate at 105% min of rated current, automatic return Input reentry at shutdown Available Applicable by Option(External signal input is required) Available Not Available (N+1 Operation is Applicable by Diode-OR) Power Source on LED indication; Green Mechanical Dimension [mm] Weight [g](typical) 37.5W × 164.5L × 81.5H 600 Conditions: *1 Rated input and Rated output *2 at Output current quick change 25% to 75% *3 At 100% load (convection cooling) ETA USA 16170 Vineyard Blvd. Suite 180, Morgan Hill, CA 95037 Phone: 1-800-ETA-POWR, (408) 778-2793 Fax: (408) 779-2753 Visit us at: www.eta-usa.com email at: sales@eta-usa.com Derating Curves ETA USA 16170 Vineyard Blvd. Suite 180, Morgan Hill, CA 95037 Phone: 1-800-ETA-POWR, (408) 778-2793 Fax: (408) 779-2753 Visit us at: www.eta-usa.com email at: sales@eta-usa.com Efficiency Curves ETA USA 16170 Vineyard Blvd. Suite 180, Morgan Hill, CA 95037 Phone: 1-800-ETA-POWR, (408) 778-2793 Fax: (408) 779-2753 Visit us at: www.e ta-usa.com email at: sales@eta-usa.com Mechanical Drawings ETA USA 16170 Vineyard Blvd. Suite 180, Morgan Hill, CA 95037 Phone: 1-800-ETA-POWR, (408) 778-2793 Fax: (408) 779-2753 Visit us at: www.e ta-usa.com email at: sales@eta-usa.com
ESS150-36 价格&库存
很抱歉,暂时无法提供与“ESS150-36”相匹配的价格&库存,您可以联系我们找货
