CTH9F-102M
CTH9F-102M
    CENTRALTECHNOLOGIES
    插件
    1000UH AXIAL PWR LINE INDUCTOR
CTH9F-102M 数据手册
Power Line Chokes - Axial CTH9F Series www.ctparts.com SPECIFICATIONS Part numbers indicate available tolerance. M = ±20% Rated Body Lead Lead Refer L Test DCR Curr. Coil Length Wire Length to Part Inductance Freq. Max. Max. Dia. Max. Size Approx. Figure Core Number (µH) (kHz) (Ω) (A) (Inch) (Inch) (AWG) (Inch) # Material From 3.35µH to 1,000µH CTH9F-3R3M CTH9F-4R9M CTH9F-8R8M CTH9F-4R0M CTH9F-400M CTH9F-680M CTH9F-101M CTH9F-125M CTH9F-251M CTH9F-501M CTH9F-102M 3.35 4.9 8.8 4.0 40 68 100 125 250 500 1000 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 .01 .01 .02 .01 .08 .05 .21 .08 .17 .26 .55 20 15 10 8.0 3.0 5.0 2.0 3.5 2.5 2.0 1.0 .60 .60 .56 .38 .31 .56 .38 .50 .44 .56 .50 1.25 1.25 1.25 1.25 1.25 1.25 1.25 1.25 1.25 1.25 1.25 12 14 16 20 20 20 20 20 20 20 20 1.1 1.1 1.1 1.1 1.1 1.1 1.1 1.1 1.1 1.1 1.1 A A A B C D E D D D D Iron Iron Iron Ferrite Ferrite Ferrite Ferrite Ferrite Ferrite Ferrite Ferrite PHYSICAL DIMENSIONS Not Shown at Actual Size A CHARACTERISTICS Description: Axial leaded power line inductor Applications: Used in switching regulators, SCR and Triac controls, RFI suppression and filters. High current applications Operating Temperature: -55°C to +125°C (no load) -55°C to +75°C (at full rated current) Inductance Tolerance: ±20% Testing: Inductance is tested on a HP4284A at 1.0kHz Packaged: Bulk pack Inductance: Measured at 1.0 volt with zero DC Current Rated Current: Based on the inductance change within 20% of initial value and temperature rise less than 30°C within coil body Miscellaneous: RoHS Compliant. Other values are available Additional Information: Additional electrical & physical information available upon request Samples available. See website for ordering information. B C D E Manufacturer of Passive Components 800-684-5322 Inside US 949-453-1811 Outside US Copyright © 2018 by CT Magnetics, DBA Central Technologies. All rights reserved. CT Magnetics reserves the right to make improvements or change specifications without notice REV 01.10.18
CTH9F-102M 价格&库存
很抱歉,暂时无法提供与“CTH9F-102M”相匹配的价格&库存,您可以联系我们找货
