WCB15JB3K00
WCB15JB3K00
    SEI
    插件,47.6x12.7mm
    RES 3K OHM 15W 5% AXIAL
WCB15JB3K00 数据手册
Stackpole Electronics, Inc. WCB / WCBF / NWCB Series Resistive Product Solutions Welded Ceramic Housed Axial Leaded Wirewound Resistor Features: • • • • • • • • • Welded element on ceramic core Low noise, high reliability compared to fiberglass core wirewounds Fireproof power wirewound High thermal conductivity NWCB – Non-inductively Ayrton Perry winding Body standoffs available; add “F” after WCB 100% RoHS compliant and lead free without exemption Halogen free REACH compliant Electrical Specifications Ohmic Range (Ω) and Tolerance Type/Code Power Rating (W) @ 70ºC WCB5, WCBF5 5 1 - 10K 0.1 - 10K 1 - 15K 0.1 - 15K 1 - 20K 0.1 - 20K WCB7, WCBF7 7 WCB10, WCBF10 10 WCB15, WCBF15 15 WCB20, WCBF20 20 WCB25, WCBF25 25 NWCB5 5 NWCB7 7 NWCB10 10 NWCB15 15 NWCB20 20 NWCB25 25 TCR (ppm/ºC) 0.5% 1% 0.1Ω to 10Ω = ± 50 ppm/ºC > 10Ω = ± 20 ppm/ºC 5% 0.1 - 4.7K 0.1 - 7.5K 0.1 - 10K Max Voltage Rating = √ P*R Mechanical Specifications Type/Code A Body Length B Height C Width D Lead Diameter E (WCBF only) WCB5, WCBF5, NWCB5 0.875 ± 0.039 22.23 ± 0.99 0.375 ± 0.039 9.53 ± 0.99 0.375 ± 0.039 9.53 ± 0.99 0.036 ± 0.002 0.91 ± 0.05 0.410 ± 0.039 10.41 ± 0.99 1.500 ± 0.250 inches 38.10 ± 6.35 mm WCB7, WCBF7, NWCB7 1.400 ± 0.039 35.56 ± 0.99 0.375 ± 0.039 9.53 ± 0.99 0.375 ± 0.039 9.53 ± 0.99 0.036 ± 0.002 0.91 ± 0.05 0.450 ± 0.039 11.43 ± 0.99 1.500 ± 0.250 inches 38.10 ± 6.35 mm WCB10, WCBF10, NWCB10 1.875 ± 0.039 47.63 ± 0.99 0.375 ± 0.039 9.53 ± 0.99 0.375 ± 0.039 9.53 ± 0.99 0.036 ± 0.002 0.91 ± 0.05 0.470 ± 0.039 11.94 ± 0.99 1.500 ± 0.250 inches 38.10 ± 6.35 mm WCB15, WCBF15, NWCB15 1.875 ± 0.039 47.63 ± 0.99 0.500 ± 0.039 12.70 ± 0.99 0.500 ± 0.039 12.70 ± 0.99 0.036 ± 0.002 0.91 ± 0.05 0.610 ± 0.039 15.49 ± 0.99 1.500 ± 0.250 inches 38.10 ± 6.35 mm WCB20, NWCB20 2.500 ± 0.039 63.50 ± 0.99 0.500 ± 0.039 12.70 ± 0.99 0.500 ± 0.039 12.70 ± 0.99 0.036 ± 0.002 0.91 ± 0.05 - 1.500 ± 0.250 inches 38.10 ± 6.35 mm WCBF20 2.355 ± 0.039 59.82 ± 0.99 - 0.570 ± 0.039 14.48 ± 0.99 0.036 ± 0.002 0.91 ± 0.05 0.660 ± 0.039 16.76 ± 0.99 1.500 ± 0.250 inches 38.10 ± 6.35 mm WCB25, NWCB25 2.500 ± 0.039 63.50 ± 0.99 0.500 ± 0.039 12.70 ± 0.99 0.500 ± 0.039 12.70 ± 0.99 0.036 ± 0.002 0.91 ± 0.05 - 1.500 ± 0.250 inches 38.10 ± 6.35 mm WCBF25 2.355 ± 0.039 59.82 ± 0.99 - 0.570 ± 0.039 14.48 ± 0.99 0.036 ± 0.002 0.91 ± 0.05 0.660 ± 0.039 16.76 ± 0.99 1.500 ± 0.250 inches 38.10 ± 6.35 mm Rev Date: 5/17/2023 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 1 F Lead Length Unit www.seielect.com marketing@seielect.com Stackpole Electronics, Inc. WCB / WCBF / NWCB Series Welded Ceramic Housed Axial Leaded Wirewound Resistor Resistive Product Solutions Performance Characteristics Test Test Results Moisture Resistance Thermal Shock Load Life @ 70C - 1000 hours Resistance to Soldering Heat Short Time Overload - 5 X Pn for 5 seconds Dielectric Withstanding Voltage Operating Temperature Range: -55C to +275C ± 5% ± 2% ± 5% ± 2% ± 2% ± 2% Power Derating Curve: Recommended Soldering Condition Flow Soldering: - Pre-heating: 110°C MAX - Peak temperature/duration: 260°C within 10 seconds (1st, 2nd wave total) - Temperature profile (see chart on the right) Iron Soldering: - 380°C, 5 seconds, once/terminal Rev Date: 5/17/2023 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 2 www.seielect.com marketing@seielect.com Stackpole Electronics, Inc. WCB / WCBF / NWCB Series Resistive Product Solutions Welded Ceramic Housed Axial Leaded Wirewound Resistor RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series WCB WCBF Description Ceramic Housed with Axial Leads Wirewound Resistor Ceramic Housed with Axial Leads Wirewound Resistor Package / Termination Type Standard Series RoHS Compliant Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) Lead-Free Effective Date Code (YY/WW) Axial Yes 100% Matte Sn Jan-06 06/01 Axial Yes 100% Matte Sn Always Always “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the Eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. How to Order W Product Series WCB Standard WCBF With standoff NWCB Non-inductive C B Power Rating Code (W) 5 5 7 7 10 10 15 15 20 20 25 25 5 J B Tolerance Code Tol D 0.5% F 1% J 5% Rev Date: 5/17/2023 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. Code B 3 1 0 Packaging Description Size 5 7, 10 Bulk 15 20 25 0 R Resistance Value Quantity 500 250 200 200 200 Four characters with the multiplier used as the decimal holder. 0.1 ohm = R100 33 ohm = 33R0 3.32 Kohm = 3K32 www.seielect.com marketing@seielect.com
WCB15JB3K00
1. 物料型号:文档列出了不同型号的电阻器,包括WCB5, WCBF5, NWCB5, WCB7, WCBF7, NWCB7等,每个型号都有其特定的功率额定值。
2. 器件简介:这些电阻器具有焊接在陶瓷芯上的元件,与玻璃纤维芯绕线电阻器相比,具有更低的噪音和更高的可靠性。它们还具有防火、高热导率的特点,并且NWCB型号采用了非感性Ayrton Perry绕组。
3. 引脚分配:文档提供了详细的机械规格,包括身体长度、高度、宽度、引脚直径和引脚长度。
4. 参数特性:电阻器的电气规格包括功率额定值、温度系数(TCR)、欧姆范围和公差。
5. 功能详解:文档描述了电阻器的性能特性,如耐湿性、热冲击、负载寿命、耐焊热、短时过载和耐电压。
6. 应用信息:电阻器的工作温度范围是-55°C至+275°C,并提供了功率降额曲线和推荐的焊接条件。
7. 封装信息:文档提供了详细的封装规格,包括尺寸和引脚信息。
8. 环保合规性:Stackpole Electronics遵守RoHS指令,提供无铅产品,并符合REACH指令,确保所有被动元件不含高关注物质(SVHC)。
9. 订购指南:文档提供了如何根据产品系列、电阻值、公差、包装和数量来订购电阻器的指南。
WCB15JB3K00 价格&库存
很抱歉,暂时无法提供与“WCB15JB3K00”相匹配的价格&库存,您可以联系我们找货
WCB15JB3K00
  • 200+8.05237200+1.04139
