SC3000-270-ASC
SC3000-270-ASC
    LICAP
    插件,D61xL165mm
    3000 F (EDLC) 超级电容器 2.7 V 轴向,CAN - 螺丝端子 0.28 毫欧 65°C 时为 1500 小时
SC3000-270-ASC 数据手册
2.7V, 3000F Ultracapacitor Cell Specifications SC3000-270-ASC Capacitance Voltage ESR Rated1 3000F Tolerance -0/+20% Rated 2.7V DC Surge 2.85V DC ESR (DC) - typical 0.22mΩ 2 ESR (DC) - maximum initial 0.28mΩ Maximum leakage 5.2mA 3 Current Maximum peak 2100A Maximum continuous current (ΔT = 15℃) 131 RMS Maximum continuous current (ΔT = 40℃) 211A RMS Maximum energy5 3.04Wh Usable energy 2.3Wh 4 4 Energy Storage 6 Volumetric energy density7 7.3Wh/L Gravametric energy density 5.8Wh/kg Power density 6008W/kg 8 Power Density 9 Temperature APPLICATIONS • Wind Turbine Pitch Control • Industrial Backup Power • Rail Transit • Renewable Energy Systems • Engine Starting • Hybrid Power Systems Temperature Characteristics Storage Temperature Range -50℃ to +70℃ Short Circuit Current Safety 4600A • This product may vent or rupture if overcharged, reverse charged incinerated or heated above 100°C • Do not crush, mutilate, or disassemble • Do not dispose of unit in trash Service Lifetime Product held at rated voltage in 65℃ environment for 1500 hours Change in capacitance (% drop from rated) ≤20% Change in ESR (% increase from maximum initial) ≤100% Product held at rated voltage in 25℃ environment DC Life • One Million Cycles Lifetime • Exceptional Low Temperature Performance • Ultra High Power Density -40℃ to +65℃ Standards, Safety & Environmental Endurance FEATURES & ADVANTAGES Operating Temperature Range10 Projected Life 10+ years Change in capacitance (% drop from rated) ≤20% Change in ESR (% increase from maximum initial) ≤100% Cycling from rated voltage to 50% voltage under constant current in 25℃ environment Cycle Life • Ultra Low Internal Resistance Storage Life Projected Life 1,000,000 cycles Change in capacitance (% drop from rated) ≤20% Change in ESR (% increase from maximum initial) ≤100% Stored uncharged in original packaging in 25℃ environment Life 4 years Physical Characteristics Mechanical Operation Vibration IEC60068-2-6, SAEJ380 Impact IEC60068-2-27, SAE J2464 2.7V, 3000F Ultracapacitor Cell Outline Drawings: Weight and Size: Weight: 520g | Size: L (Max.) 165mm +/- 0.2mm, D (Max.) 61.0mm Naming Rules: Type SC Supercapacitor Cell Capacitance Dash Rated Voltage Dash Termination 3000 = 3000F - 270 = 2.7V - ASC = Axial Screw Notes: 1. Measure capacitance and DC internal resistance at 25℃ under specified test current per Figure 1 +1 V4 0 0 Time t1 V1 = Vrated t2 - t1 = 15 seconds V3 = 0.5 x Vrated t4 - t3 = 5 seconds t2 t3 t4 Capacitor Current Capacitor Voltage V2 V3 Voltage Current -1 Capacitance = I x (t3-t2)/(V2-V3) ESR = (V4 - V3)/I Figure 1 3. Corresponding current value after 72 hours of rated voltage at 25℃ 4. T=I x ESR x Rca 0.12V2 ESRDC x weight(kg) 10. Test after the sample has been maintained at -50℃ for 16 hours and the temperature raised 10℃ each time and maintained for 1 hour, then test the sample Figure 2 200% 190% 180% ESR Capacitance 170% 160% 150% 140% 130% 120% 110% 100% 90% 80% Temperature 5. 0.5CV /3600 6. 0.5C(V 6 -60 -50 -40 -30 -20 -10 0 10 20 30 40 50 60 70 2 2 nom 2 9. Per IEC62391-2 Pd = 2. Surge voltage is non-repeatable and duration cannot exceed 1s 2 rms ( πr (mm)1x10x L(mm) ) 8. Whusable/weight(kg) CAP/ESR Measurement Waveform V1 7. Whusable/ Figure 2 -V 2 min )/3600 Axial weldable version available, please contact LICAP for details Specifications are subject to change without notice. LICAP Technologies, Inc. 9795 Business Park Drive - Sacramento, CA 95827 USA https://licaptech.com/ • info@licaptech.com MAY 27, 2020
SC3000-270-ASC 价格&库存
很抱歉,暂时无法提供与“SC3000-270-ASC”相匹配的价格&库存,您可以联系我们找货
