I-7024
I-7024
    ICPDAS(泓格)
    Module
    4-CH AO DCON RS-485 DAQ MODULE
I-7024 数据手册
I-7000 and M-7000 Modules  Features  I-7024 / M-7024 / M-7024L  4-channel Analog Output  I-7024R / M-7024R  4-channel Analog Output and 5-channel Digital Input 2  Software Selectable Current or Voltage Output 3  Safe Value Setting  Power-on Value Setting  3000 VDC Intra-module Isolation RS-485 Remote I/O Modules  Programmable Output Slope  Dual Watchdog I-7024/I-7024R M-7024/M-7024R/M-7024L 4-channel Analog Output Module  Introduction The I-7024 is a 14-bit 4-channel analog output module that provides current and voltage outputs. There are options for power-on values and safe values. It features 3000 VDC intra-module isolation. The I-7024R is the same as the I-7024 and provides additional 5-channel digital inputs and 4 KV ESD protection on each terminal. The M-7024/M-7024R support Modbus RTU and DCON protocols and can be configured via software. Their hardware specifications are the same as those of the I-7024/I-7024R.  System Specifications Model  Applications I-7024 M-7024 I-7024R M-7024R M-7024L Communication Interface RS-485 Bias Resistor No (Usually supplied by the RS-485 Master. Alternatively, add a tM-SG4 or SG-785.) Format (N, 8, 1) (N, 8, 2) (E, 8, 1) (O, 8, 1) Baud Rate 1200 to 115200 bps Protocol DCON Dual Watchdog Yes, Module (1.6 Seconds), Communication (Programmable) Modbus RTU, DCON DCON System LED Indicator  I/O Specifications Model I-7024 M-7024 I-7024R Yes, 1 as Power/Communication Indicator Analog Output I/O LED Indicators - Channels 7-segment LED Display - Range Isolation Intra-module Isolation, Field-to-Logic 3000 VDC EMS Protection I-7024(R)/M-7024(R)/M-7024L Building Automation, Factory Automation, Machine Automation, Remote Maintenance, Remote Diagnosis, Testing Equipment. Modbus RTU, DCON LED Indicators/Display 53  Wide Operating Temperature Range: -25 to +75°C ESD (IEC 61000-4-2) ±2 kV Contact for Each Terminal ±4 kV Contact for Each Terminal EFT (IEC 61000-4-4) - ±4 kV to Power Line RS (IEC 61000-4-3) - 5 V/m, 80 MHz ~ 1GHz ±8 kV Contact for Each Terminal ±4 kV to Power Line M-7024R M-7024L 4 Voltage Current 0 ~ 5 V, ±5 V, 0 ~ 10 V, ±10 V, 0 ~ 20 mA, 4 ~ 20 mA Resolution 14-bit Accuracy 0.1% 12-bit DA Output Response Time 10 ms Open Wire Detection (for current only) - Channel-to-Channel Isolation - Power-on Value Yes Safe Value Yes Digital Input Power Reverse Polarity Protection Yes Channels - 5 - Input Range +10 ~ +30 VDC Input Type - Dry Contact (Source) - Consumption 2.4 W ON Voltage Level - Close to GND - OFF Voltage Level - Open - Max. Count - 65535 (16-bit) - Max. Input Counters Frequency - 50 Hz - Min. Pulse Width - 10 ms - 3.2 W Mechanical Dimensions (L x W x H) 123 mm x 72 mm x 35 mm Installation DIN-Rail or Wall Mounting Environment Operating Temperature -25 to +75°C Storage Temperature -40 to +85°C Humidity 10 to 95% RH, Non-condensing ICP DAS CO., LTD 2.7 W Contact Level Professional Provider of High Quality Industrial Computer Products and Data Acquisition Systems Remote I/O Modules  Internal I/O Structure I-7024/M-7024/M-7024L I-7024R/M-7024R +5 V Vout0 Inut0 EEPROM DI0 EEPROM +5 V Photo-isolation Embedded Controller +Vs GND Embedded Controller Vout3 Inut3 DATA+ RS-485 Interface AGND Power Regulator +5 V +V DATA- +Vs -V GND Vout0 Inut0 Photo-isolation RS-485 Interface Power Regulator 4-ch DAC +5 V Vout3 Inut3 +V -V AGND  Pin Assignments + V - Voutx AGND I-7024 CR 4-channel Analog Output Module using the DCON Protocol (Blue Cover) (RoHS) I-7024-G CR 4-channel Analog Output Module using the DCON Protocol (Gray Cover) (RoHS) I-7024R-G CR 4-channel Analog Output and 5-channel DI Module using the DCON Protocol(Gray Cover) (RoHS) M-7024-G CR 4-channel Analog Output Module using the DCON and Modbus Protocol (Gray Cover) (RoHS) M-7024R-G CR 4-channel Analog Output and 5-channel DI Module using the DCON and Modbus Protocol (Gray Cover) (RoHS) M-7024L-G CR 12-bit 4-channel Analog Output Module using the DCON and Modbus Protocol (Gray Cover) (RoHS) Load - Load 11  Ordering Information Analog Output Wire Connection + 3 10 20 11 10  Wire Connections 1 20 I-7024R/M-7024R 1 I-7024/M-7024/M-7024L 2 RS-485 Remote I/O Modules DATA+ DATA- DI4 4-ch DAC Ioutx AGND Dry Contact Wire Connection for I-7024R and M-7024R DIx (B)GND tM-7520U CR RS-232 to RS-485 Converter (RoHS) I-7514U CR 4-channel RS-485 Hub (RoHS) tM-7561 CR USB to RS-485 Converter (RoHS) SG-770 CR 7-channel Differential or 14-channel Single-ended Surge Protector (RoHS) tM-SG4 CR RS-485 Bias and Termination Resistor Module (RoHS) Signal Conditioning Modules for Thermocouple, SG-3000 Series RTD, DC Voltage, DC Current and Power Input Transformers Website: http://www.icpdas.com E-mail: sales@icpdas.com I-7024(R)/M-7024(R)/M-7024L  Accessories 54
I-7024 价格&库存
很抱歉,暂时无法提供与“I-7024”相匹配的价格&库存,您可以联系我们找货
