I-7017
I-7017
    ICPDAS(泓格)
    Module
    8-CH AI DCON RS-485 DAQ MODULE
I-7017 数据手册
I-7000 and M-7000 Modules  Features  M-7017  8-channel Differential Analog Input  I-7017 and I-7017F  8-channel Differential or 6-channel Differential and 2-channel Single-ended Analog Input 2  Voltage and Current Input  ±35 VDC Overvoltage Protection  High Resolution: 16-bit RS-485 Remote I/O Modules 3  Open Wire Detection for 4 ~ 20 mA  3000 VDC Intra-module Isolation  Dual Watchdog  RoHS Compliant I-7017 I-7017F M-7017 8-channel Analog Input Module  Introduction The I-7017 and I-7017F are analog input modules that provide either 8 differential input channels, or 6 differential input channels and 2 single-ended input channels, selectable via a jumper. The input type includes both voltage and current, and all channels are available for the same input range. An optional external 125 Ω resistor is required for current input. The modules also feature 3000 VDC intra-module isolation, as well as ±35 VDC overvoltage protection. The sampling rate for the I-7017F is adjustable, meaning that either fast mode or normal mode can be selected. The M-7017 supports both the Modbus RTU and DCON protocols, which can be configured via software, and provides 8 differential analog input channels. Other hardware specifications are the same as the I-7017.  System Specifications Model I-7017  Applications I-7017F M-7017 Communication Interface RS-485 Bias Resistor No (Usually supplied by the RS-485 Master. Alternatively, add a tM-SG4 or SG-785.) Format (N, 8, 1) Baud Rate 1200 to 115200 bps Protocol DCON Dual Watchdog Yes, Module (1.6 Seconds), Communication (Programmable) Modbus RTU, DCON • Remote Maintenance • Remote Diagnosis • Testing Equipment  I/O Specifications I-7017 I-7017F Yes, 1 as Power/Communication Indicator Analog Input I/O LED Indicators - Channels 8 7-segment LED Display - Wiring 6-channel Differential and 2-channel Single-ended, or 8-channel Differential. System LED Indicator Isolation Intra-module Isolation, Field-to-Logic 3000 VDC Input Range EMS Protection ESD (IEC 61000-4-2) ±2 kV Contact for each Terminal EFT (IEC 61000-4-4) ±4 kV for Power Line Surge (IEC 61000-4-5) ±0.5 kV for Power Line Power I-7017/I-7017F/M-7017 • Building Automation • Factory Automation • Machine Automation Model LED Indicators/Display 23  Wide Operating Temperature Range: -25 to +75°C Reverse Polarity Protection Yes Input Range +10 ~ +30 VDC Consumption 1.3 W Mechanical Dimensions (L x W x H) 123 mm x 72 mm x 35 mm Installation DIN-Rail or Wall Mounting ±4 kV Contact for each Terminal Sampling Rate 8-channel Differential. Voltage ±150 mV, ±500 mV, ±1 V, ±5 V, ±10 V Current ±20 mA, 0 ~ 20 mA, 4 ~ 20 mA (Require an optional external 125 Ω resistor) Normal Mode 0.1% Fast Mode - Normal Mode 10 Hz Fast Mode - Resolution Accuracy M-7017 16-bit Input Impedance 20 MΩ Common Voltage Protection ±15 VDC Individual Channel Configuration - Overvoltage Protection ±35 VDC 0.5 % - 60 Hz - Environment Operating Temperature -25 to +75°C Storage Temperature -40 to +85°C Humidity 10 to 95% RH, Non-condensing ICP DAS CO., LTD Professional Provider of High Quality Industrial Computer Products and Data Acquisition Systems Remote I/O Modules  Internal I/O Structure I-7017/I-7017F M-7017 INIT EEPROM Vin7+ Vin7+ Vin7Vin6+ Vin6- Photo-isolation Embedded Controller ADC Vin7Vin6+ Vin6- EEPROM Photo-isolation Embedded Controller MUX ADC MUX Vin1+ Vin1+ DATA+ DATA- +Vs GND +5 V Power Regulator +V DATA+ DATA- +Vs GND -V Vin1Vin0+ Vin0- RS-485 Interface Power Regulator +5 V +V -V Frame Ground  Pin Assignments I-7017/I-7017F M-7017  Wire Connections  Ordering Information I-7017/I-7017F Analog Input for Wire Connection Channels 0 to 5 Vinx+ Vinx- + mV/V V - 3 RS-485 Remote I/O Modules Vin1Vin0+ Vin0- RS-485 Interface 2 mA + - ƻ Vinx+ Vinx- Require an2SWLRQDO([WHUQDOƻ5HVLVWRU 2-wire Transmitter Wire Connection 2-wire 7UDQVPLWWHU + V - Vinx+ Vinx- ƻ I-7017 CR 8-channel Analog Input Module using the DCON Protocol (Blue Cover) (RoHS) I-7017-G CR 8-channel Analog Input Module using the DCON Protocol (Gray Cover) (RoHS) M-7017-G CR 8-channel Analog Input Module using the DCON and Modbus RTU Protocols (Gray Cover) (RoHS) I-7017F CR 8-channel Analog Input Module using the DCON Protocol (Fast Sampling Version) (Blue Cover) (RoHS) I-7017F-G CR 8-channel Analog Input Module using the DCON Protocol (Fast Sampling Version) (Gray Cover) (RoHS) Require an2SWLRQDO([WHUQDOƻ5HVLVWRU Analog Input for Digital Wire Connection Channels 6 and 7 8-channel Mode JP1 mV/V + - V Vin6+ + V - Vin7+ mV/V + - Vin6+ mA + - ƻ + - V mV/V V + mV/V Vin6INIT/Vin7- Vin6+ Vin6- + mA + ƻ Vin6Vin7+ INIT/Vin7- tM-7561 CR USB to RS-485 Converter (RoHS) Vin6+ Vin6- ƻ tM-SG4 CR Vin7+ I-7514U CR 4-channel RS-485 Hub (RoHS) M-7017 Analog Input Wire Connection Vinx+ Vinx- mA RS-485 Bias and Termination Resistor Module (RoHS) INIT/Vin7- 5HTXLUHDQ2SWLRQDO([WHUQDOƻ5HVLVWRU + mV/V V - RS-232 to RS-485 Converter (RoHS) Vin7+ INIT/Vin7- mA tM-7520U CR + - ƻ Vinx+ Vinx- 5HTXLUHDQ2SWLRQDO([WHUQDOƻ5HVLVWRU Website: http://www.icpdas.com SG-770 CR 7-channel Differential or 14-channel Single-ended Surge Protector (RoHS) 125 Ω, 0.1% DIP Resistor 125 Ω External Resistor for use with Current input on I-7011/I-7012/I-7017/I-7018 series modules E-mail: sales@icpdas.com I-7017/I-7017F/M-7017 mA ƻ  Accessories INIT* Mode JP1 24
I-7017 价格&库存
很抱歉,暂时无法提供与“I-7017”相匹配的价格&库存,您可以联系我们找货
